[PATCH v3] bsps: Move optfdt* files to shared parent directory
Pranav Dangi dangipranav at gmail.com
Fri Jul 9 06:15:52 UTC 2021
ping. (Apart from moving the files in a shared directory, a part of this
patch also gets the RTEMS master branch to work on all the Pi's except 4.)
On Fri, 2 Jul 2021, 09:35 Pranav Dangi, <dangipranav at gmail.com> wrote:
> yes, I've built all of them
> On Thu, Jul 1, 2021 at 10:01 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Did you build all affected BSPs?
>> On Thu, Jul 1, 2021 at 4:05 AM pranav <dangipranav at gmail.com> wrote:
>> >  .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
>> >  spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
>> >  spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
>> >  spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
>> >  spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
>> >  spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
>> >  spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
>> >  spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
>> >  spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
>> >  spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
>> >  spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
>> >  spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
>> >  .../{arm/altera-cyclone-v => }/optfdtcpyro.yml   |  0
>> >  .../{arm/altera-cyclone-v => }/optfdtmxsz.yml    |  0
>> >  .../bsps/{arm/altera-cyclone-v => }/optfdtro.yml |  0
>> >  .../{arm/altera-cyclone-v => }/optfdtuboot.yml   |  0
>> >  spec/build/bsps/powerpc/qoriq/grp.yml            |  4 ++--
>> >  spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml     | 16 ----------------
>> >  spec/build/bsps/powerpc/qoriq/optfdtro.yml       | 15 ---------------
>> >  spec/build/bsps/riscv/riscv/grp.yml              |  8 ++++----
>> >  spec/build/bsps/riscv/riscv/optfdtcpyro.yml      | 15 ---------------
>> >  spec/build/bsps/riscv/riscv/optfdtmxsz.yml       | 16 ----------------
>> >  spec/build/bsps/riscv/riscv/optfdtro.yml         | 15 ---------------
>> >  spec/build/bsps/riscv/riscv/optfdtuboot.yml      | 15 ---------------
>> >  24 files changed, 26 insertions(+), 232 deletions(-)
>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml
>> (100%)
>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml
>> (100%)
>> >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > index da567ddd79..a9f3f7dabf 100644
>> > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>> > @@ -73,15 +73,15 @@ links:
>> >  - role: build-dependency
>> >    uid: optconuart1
>> > -  uid: optfdtcpyro
>> > +  uid: ../../optfdtcpyro
>> >    uid: optfdten
>> > -  uid: optfdtmxsz
>> > +  uid: ../../optfdtmxsz
>> > -  uid: optfdtro
>> > +  uid: ../../optfdtro
>> > -  uid: optfdtuboot
>> > +  uid: ../../optfdtuboot
>> >    uid: opti2cspeed
>> > diff --git a/spec/build/bsps/arm/beagle/grp.yml
>> b/spec/build/bsps/arm/beagle/grp.yml
>> > index 1375913fd0..3452c3e5c8 100644
>> > --- a/spec/build/bsps/arm/beagle/grp.yml
>> > +++ b/spec/build/bsps/arm/beagle/grp.yml
>> > @@ -22,13 +22,13 @@ links:
>> >    uid: optdm3730
>> > -  uid: optfdtcpyro
>> > -  uid: optfdtmxsz
>> > -  uid: optfdtro
>> > -  uid: optfdtuboot
>> >    uid: ../grp
>> > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> > deleted file mode 100644
>> > index c26b1ae051..0000000000
>> > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> > -actions:
>> > -- get-boolean: null
>> > -- define-condition: null
>> > -build-type: option
>> > -copyrights:
>> > -- Copyright (C) 2020 embedded brains GmbH (
>> http://www.embedded-brains.de)
>> > -default: true
>> > -default-by-variant: []
>> > -description: |
>> > -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
>> > -enabled-by: true
>> > -links: []
>> > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> > index 14af766230..0000000000
>> > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>> > +++ /dev/null
>> > @@ -1,16 +0,0 @@
>> > -actions:
>> > -- get-integer: null
>> > -- define: null
>> > -build-type: option
>> > -copyrights:
>> > -default: 262144
>> > -description: |
>> > -  maximum size of the FDT blob in bytes
>> > -enabled-by: true
>> > -format: '{}'
>> > -links: []
>> > -name: BSP_FDT_BLOB_SIZE_MAX
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml
>> b/spec/build/bsps/arm/beagle/optfdtro.yml
>> > index a61bb2924b..0000000000
>> > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -  place the FDT blob into the read-only data area
>> > -enabled-by: true
>> > -links: []
>> > -name: BSP_FDT_BLOB_READ_ONLY
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> > index 5805e912ff..0000000000
>> > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -  copy the U-Boot provided FDT to an internal storage
>> > -enabled-by: true
>> > -links: []
>> > -name: BSP_START_COPY_FDT_FROM_U_BOOT
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/imx/bspimx.yml
>> b/spec/build/bsps/arm/imx/bspimx.yml
>> > index c65e02db2b..14719745f0 100644
>> > --- a/spec/build/bsps/arm/imx/bspimx.yml
>> > +++ b/spec/build/bsps/arm/imx/bspimx.yml
>> > @@ -61,13 +61,13 @@ links:
>> >    uid: optconirq
>> > -  uid: optfdtcpyro
>> > -  uid: optfdtmxsz
>> > -  uid: optfdtro
>> > -  uid: optfdtuboot
>> >    uid: optresetvec
>> > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>> > +++ /dev/null
>> > @@ -1,16 +0,0 @@
>> > -actions:
>> > -- define: null
>> > -build-type: option
>> > -copyrights:
>> > -default: 262144
>> > -description: |
>> > -enabled-by: true
>> > -format: '{}'
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml
>> b/spec/build/bsps/arm/imx/optfdtro.yml
>> > --- a/spec/build/bsps/arm/imx/optfdtro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml
>> b/spec/build/bsps/arm/imx/optfdtuboot.yml
>> > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml
>> b/spec/build/bsps/arm/raspberrypi/grp.yml
>> > index 7291e8b178..3c59ad77c1 100644
>> > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>> > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>> > @@ -31,6 +31,14 @@ links:
>> >    uid: optrpi2
>> >    uid: optspiiomode
>> > +- role: build-dependency
>> >    uid: ../start
>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>> b/spec/build/bsps/optfdtcpyro.yml
>> > similarity index 100%
>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>> > rename to spec/build/bsps/optfdtcpyro.yml
>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>> b/spec/build/bsps/optfdtmxsz.yml
>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>> > rename to spec/build/bsps/optfdtmxsz.yml
>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>> b/spec/build/bsps/optfdtro.yml
>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>> > rename to spec/build/bsps/optfdtro.yml
>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>> b/spec/build/bsps/optfdtuboot.yml
>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>> > rename to spec/build/bsps/optfdtuboot.yml
>> > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml
>> b/spec/build/bsps/powerpc/qoriq/grp.yml
>> > index 3e295cb599..08533ded6f 100644
>> > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
>> > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
>> > @@ -68,9 +68,9 @@ links:
>> >    uid: optexcfixdhdlr
>> > -  uid: optfdtmxsz
>> > -  uid: optfdtro
>> >    uid: opthid0
>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>> > +++ /dev/null
>> > @@ -1,16 +0,0 @@
>> > -actions:
>> > -- define: null
>> > -build-type: option
>> > -copyrights:
>> > -default: 262144
>> > -description: |
>> > -enabled-by: true
>> > -format: '{}'
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/grp.yml
>> b/spec/build/bsps/riscv/riscv/grp.yml
>> > index 396f8986ec..77583d351e 100644
>> > --- a/spec/build/bsps/riscv/riscv/grp.yml
>> > +++ b/spec/build/bsps/riscv/riscv/grp.yml
>> > @@ -32,13 +32,13 @@ links:
>> >    uid: optextirqmax
>> > -  uid: optfdtcpyro
>> > -  uid: optfdtmxsz
>> > -  uid: optfdtro
>> > -  uid: optfdtuboot
>> >    uid: optfrdme310arty
>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> > index 63a42f5a29..0000000000
>> > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>> > +++ /dev/null
>> > @@ -1,16 +0,0 @@
>> > -actions:
>> > -- define: null
>> > -build-type: option
>> > -copyrights:
>> > -default: 65536
>> > -description: |
>> > -enabled-by: true
>> > -format: '{}'
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml
>> b/spec/build/bsps/riscv/riscv/optfdtro.yml
>> > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>> > +++ /dev/null
>> > @@ -1,15 +0,0 @@
>> > -actions:
>> > -build-type: option
>> > -copyrights:
>> > -default: true
>> > -description: |
>> > -enabled-by: true
>> > -links: []
>> > -type: build
>> > 2.27.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210709/7fc6d582/attachment-0001.html>
