[PATCH v3] bsps: Move optfdt* files to shared parent directory
Thu Jul 15 15:13:27 UTC 2021
This patch looks fine to me if someone can pick it up. It does touch a
lot of build BSPs though.
On Fri, Jul 9, 2021 at 12:16 AM Pranav Dangi <dangipranav at gmail.com> wrote:
> ping. (Apart from moving the files in a shared directory, a part of this patch also gets the RTEMS master branch to work on all the Pi's except 4.)
> On Fri, 2 Jul 2021, 09:35 Pranav Dangi, <dangipranav at gmail.com> wrote:
>> yes, I've built all of them
>> On Thu, Jul 1, 2021 at 10:01 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> Did you build all affected BSPs?
>>> On Thu, Jul 1, 2021 at 4:05 AM pranav <dangipranav at gmail.com> wrote:
>>> >  .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
>>> >  spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
>>> >  spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
>>> >  spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
>>> >  spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
>>> >  spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
>>> >  spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
>>> >  spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
>>> >  spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
>>> >  spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
>>> >  spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
>>> >  spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
>>> >  .../{arm/altera-cyclone-v => }/optfdtcpyro.yml   |  0
>>> >  .../{arm/altera-cyclone-v => }/optfdtmxsz.yml    |  0
>>> >  .../bsps/{arm/altera-cyclone-v => }/optfdtro.yml |  0
>>> >  .../{arm/altera-cyclone-v => }/optfdtuboot.yml   |  0
>>> >  spec/build/bsps/powerpc/qoriq/grp.yml            |  4 ++--
>>> >  spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml     | 16 ----------------
>>> >  spec/build/bsps/powerpc/qoriq/optfdtro.yml       | 15 ---------------
>>> >  spec/build/bsps/riscv/riscv/grp.yml              |  8 ++++----
>>> >  spec/build/bsps/riscv/riscv/optfdtcpyro.yml      | 15 ---------------
>>> >  spec/build/bsps/riscv/riscv/optfdtmxsz.yml       | 16 ----------------
>>> >  spec/build/bsps/riscv/riscv/optfdtro.yml         | 15 ---------------
>>> >  spec/build/bsps/riscv/riscv/optfdtuboot.yml      | 15 ---------------
>>> >  24 files changed, 26 insertions(+), 232 deletions(-)
>>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>>> >  delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>>> >  delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
>>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
>>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
>>> >  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
>>> >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>> >  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
>>> >  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> > index da567ddd79..a9f3f7dabf 100644
>>> > --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> > +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>> > @@ -73,15 +73,15 @@ links:
>>> >  - role: build-dependency
>>> >    uid: optconuart1
>>> > -  uid: optfdtcpyro
>>> > +  uid: ../../optfdtcpyro
>>> >    uid: optfdten
>>> > -  uid: optfdtmxsz
>>> > +  uid: ../../optfdtmxsz
>>> > -  uid: optfdtro
>>> > +  uid: ../../optfdtro
>>> > -  uid: optfdtuboot
>>> > +  uid: ../../optfdtuboot
>>> >    uid: opti2cspeed
>>> > diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
>>> > index 1375913fd0..3452c3e5c8 100644
>>> > --- a/spec/build/bsps/arm/beagle/grp.yml
>>> > +++ b/spec/build/bsps/arm/beagle/grp.yml
>>> > @@ -22,13 +22,13 @@ links:
>>> >    uid: optdm3730
>>> > -  uid: optfdtcpyro
>>> > -  uid: optfdtmxsz
>>> > -  uid: optfdtro
>>> > -  uid: optfdtuboot
>>> >    uid: ../grp
>>> > diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> > deleted file mode 100644
>>> > index c26b1ae051..0000000000
>>> > --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> > -actions:
>>> > -- get-boolean: null
>>> > -- define-condition: null
>>> > -build-type: option
>>> > -copyrights:
>>> > -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>> > -default: true
>>> > -default-by-variant: []
>>> > -description: |
>>> > -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
>>> > -enabled-by: true
>>> > -links: []
>>> > -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> > index 14af766230..0000000000
>>> > --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>> > +++ /dev/null
>>> > @@ -1,16 +0,0 @@
>>> > -actions:
>>> > -- get-integer: null
>>> > -- define: null
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: 262144
>>> > -description: |
>>> > -  maximum size of the FDT blob in bytes
>>> > -enabled-by: true
>>> > -format: '{}'
>>> > -links: []
>>> > -name: BSP_FDT_BLOB_SIZE_MAX
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
>>> > index a61bb2924b..0000000000
>>> > --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -  place the FDT blob into the read-only data area
>>> > -enabled-by: true
>>> > -links: []
>>> > -name: BSP_FDT_BLOB_READ_ONLY
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> > index 5805e912ff..0000000000
>>> > --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -  copy the U-Boot provided FDT to an internal storage
>>> > -enabled-by: true
>>> > -links: []
>>> > -name: BSP_START_COPY_FDT_FROM_U_BOOT
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
>>> > index c65e02db2b..14719745f0 100644
>>> > --- a/spec/build/bsps/arm/imx/bspimx.yml
>>> > +++ b/spec/build/bsps/arm/imx/bspimx.yml
>>> > @@ -61,13 +61,13 @@ links:
>>> >    uid: optconirq
>>> > -  uid: optfdtcpyro
>>> > -  uid: optfdtmxsz
>>> > -  uid: optfdtro
>>> > -  uid: optfdtuboot
>>> >    uid: optresetvec
>>> > diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> > --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> > --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>> > +++ /dev/null
>>> > @@ -1,16 +0,0 @@
>>> > -actions:
>>> > -- define: null
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: 262144
>>> > -description: |
>>> > -enabled-by: true
>>> > -format: '{}'
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
>>> > --- a/spec/build/bsps/arm/imx/optfdtro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
>>> > --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
>>> > index 7291e8b178..3c59ad77c1 100644
>>> > --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>>> > +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>>> > @@ -31,6 +31,14 @@ links:
>>> >    uid: optrpi2
>>> >    uid: optspiiomode
>>> > +- role: build-dependency
>>> >    uid: ../start
>>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
>>> > similarity index 100%
>>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>>> > rename to spec/build/bsps/optfdtcpyro.yml
>>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
>>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>>> > rename to spec/build/bsps/optfdtmxsz.yml
>>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
>>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>>> > rename to spec/build/bsps/optfdtro.yml
>>> > diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
>>> > rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>>> > rename to spec/build/bsps/optfdtuboot.yml
>>> > diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
>>> > index 3e295cb599..08533ded6f 100644
>>> > --- a/spec/build/bsps/powerpc/qoriq/grp.yml
>>> > +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
>>> > @@ -68,9 +68,9 @@ links:
>>> >    uid: optexcfixdhdlr
>>> > -  uid: optfdtmxsz
>>> > -  uid: optfdtro
>>> >    uid: opthid0
>>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>> > +++ /dev/null
>>> > @@ -1,16 +0,0 @@
>>> > -actions:
>>> > -- define: null
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: 262144
>>> > -description: |
>>> > -enabled-by: true
>>> > -format: '{}'
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>> > --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
>>> > index 396f8986ec..77583d351e 100644
>>> > --- a/spec/build/bsps/riscv/riscv/grp.yml
>>> > +++ b/spec/build/bsps/riscv/riscv/grp.yml
>>> > @@ -32,13 +32,13 @@ links:
>>> >    uid: optextirqmax
>>> > -  uid: optfdtcpyro
>>> > -  uid: optfdtmxsz
>>> > -  uid: optfdtro
>>> > -  uid: optfdtuboot
>>> >    uid: optfrdme310arty
>>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>> > --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>> > index 63a42f5a29..0000000000
>>> > --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>> > +++ /dev/null
>>> > @@ -1,16 +0,0 @@
>>> > -actions:
>>> > -- define: null
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: 65536
>>> > -description: |
>>> > -enabled-by: true
>>> > -format: '{}'
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
>>> > --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>> > --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>> > +++ /dev/null
>>> > @@ -1,15 +0,0 @@
>>> > -actions:
>>> > -build-type: option
>>> > -copyrights:
>>> > -default: true
>>> > -description: |
>>> > -enabled-by: true
>>> > -links: []
>>> > -type: build
>>> > 2.27.0
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
