[PATCH v3] testsuites: Added tests for sig2str/str2sig methods
Matt Joyce
mfjoyce2004 at gmail.com
Fri Jul 9 09:00:59 UTC 2021
Fixed newline error at end of psxsignal09.yml. Added psxsignal09 in
psxtests and compile only test in psxhdrs in order to evaluate newly
added POSIX standard methods in Newlib.
spec/build/testsuites/psxtests/grp.yml | 2 +
spec/build/testsuites/psxtests/libpsxhdrs.yml | 1 +
.../build/testsuites/psxtests/psxsignal09.yml | 21 ++
testsuites/psxtests/Makefile.am | 11 +
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxhdrs/signal/sig2str.c | 57 ++++
testsuites/psxtests/psxsignal09/init.c | 249 ++++++++++++++++++
.../psxtests/psxsignal09/psxsignal09.doc | 35 +++
.../psxtests/psxsignal09/psxsignal09.scn | 32 +++
9 files changed, 409 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
create mode 100644 testsuites/psxtests/psxhdrs/signal/sig2str.c
create mode 100644 testsuites/psxtests/psxsignal09/init.c
create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..f61f45dbe9 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -205,6 +205,8 @@ links:
uid: psxsignal07
- role: build-dependency
uid: psxsignal08
+- role: build-dependency
+ uid: psxsignal09
uid: psxspin01
diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
index 6a0ab6d4f7..5767bcdacd 100644
--- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
+++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
@@ -513,6 +513,7 @@ source:
- testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
- testsuites/psxtests/psxhdrs/signal/sigwait.c
- testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
+- testsuites/psxtests/psxhdrs/signal/sig2str.c
- testsuites/psxtests/psxhdrs/stddef/offsetof.c
- testsuites/psxtests/psxhdrs/stdio/clearerr.c
- testsuites/psxtests/psxhdrs/stdio/ctermid.c
diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
new file mode 100644
index 0000000000..08a29c7c5b
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxsignal09.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxsignal09/init.c
+stlib: []
+target: testsuites/psxtests/psxsignal09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a35f00b665..b62d5cab59 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -924,6 +924,17 @@ psxsignal08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal08) \
endif
endif
+if HAS_POSIX
+if TEST_psxsignal09
+psx_tests += psxsignal09
+psx_screens += psxsignal09/psxsignal09.scn
+psx_docs += psxsignal09/psxsignal09.doc
+psxsignal09_SOURCES = psxsignal09/init.c
+psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
+ $(support_includes) -I$(top_srcdir)/include
+endif
+endif
if TEST_psxspin01
psx_tests += psxspin01
psx_screens += psxspin01/psxspin01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 3f95010cd3..7b9a1027ca 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -138,6 +138,7 @@ RTEMS_TEST_CHECK([psxsignal05])
RTEMS_TEST_CHECK([psxsignal06])
RTEMS_TEST_CHECK([psxsignal07])
RTEMS_TEST_CHECK([psxsignal08])
+RTEMS_TEST_CHECK([psxsignal09])
RTEMS_TEST_CHECK([psxspin01])
RTEMS_TEST_CHECK([psxstack01])
RTEMS_TEST_CHECK([psxstack02])
diff --git a/testsuites/psxtests/psxhdrs/signal/sig2str.c b/testsuites/psxtests/psxhdrs/signal/sig2str.c
index 0000000000..520a0db740
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/signal/sig2str.c
@@ -0,0 +1,57 @@
+ * @file
+ * @brief Header File Conformance Test
+ * This test file is used to verify that the header files associated with
+ * invoking this function are correct.
+ * Copyright (C) 2021 Matthew Joyce
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <signal.h>
+#define BUFLEN 10
+int test( void );
+int test( void )
+ int result;
+ int signal_number;
+ char signal_name[BUFLEN];
+ signal_number = SIGALRM;
+ result = sig2str(signal_number, signal_name);
+ return result;
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 0000000000..3684484723
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -0,0 +1,249 @@
+ * @file
+ * @brief Test of sig2str and str2sig methods
+ * This test file is used to verify that the methods sig2str and str2sig
+ * are functioning as expected
+ * are met:
+/* Defined to have access to SIG2STR_MAX and function prototypes in signal.h*/
+#define _GNU_SOURCE
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <rtems/test.h>
+#include "test_support.h"
+//#include <sys/signal.h>
+const char rtems_test_name[] = "SIG2STR AND STR2SIG";
+static rtems_task Init(
+ rtems_task_argument ignored
+ rtems_print_printer_fprintf_putc(&rtems_test_printer);
+ TEST_BEGIN();
+ char test1[SIG2STR_MAX];
+ char test2[SIG2STR_MAX];
+ char test3[SIG2STR_MAX];
+ char test4[SIG2STR_MAX];
+ char test5[SIG2STR_MAX];
+ char test6[SIG2STR_MAX];
+ char test7[SIG2STR_MAX];
+ char test8[SIG2STR_MAX];
+ char test9[SIG2STR_MAX];
+ int res1;
+ int res2;
+ int res3;
+ int res4;
+ int res5;
+ int res6;
+ int res7;
+ int res8;
+ int res9;
+ int retval1;
+ int retval2;
+ int retval3;
+ int retval4;
+ int retval5;
+ int retval6;
+ int retval7;
+ int retval8;
+ int retval9;
+ int min = SIGRTMIN;
+ int max = SIGRTMAX;
+ printf( "\n" );
+ printf( "SIGRTMIN is %d and SIGRTMAX is %d\n", min, max );
+ printf( "\n" );
+ printf( "Calling sig2str: \n" );
+ /* Expected pass */
+ retval1 = sig2str( 1, test1 );
+ rtems_test_assert( retval1 == 0 );
+ rtems_test_assert( strcmp( test1, "HUP" )==0 );
+ printf( "The string test1 is: %s\n", test1 );
+ retval2 = sig2str( 3, test2 );
+ rtems_test_assert( retval2 == 0 );
+ rtems_test_assert( strcmp( test2, "QUIT" )==0);
+ printf( "The string test2 is: %s\n", test2 );
+ retval3 = sig2str( 27, test3 );
+ rtems_test_assert( retval3 == 0 );
+ rtems_test_assert( strcmp( test3, "RTMIN" )==0 );
+ printf( "The string test3 is: %s\n", test3 );
+ retval4 = sig2str( 29, test4 );
+ rtems_test_assert( retval4 == 0 );
+ rtems_test_assert( strcmp( test4, "RTMIN+2" )==0 );
+ printf( "The string test4 is: %s\n", test4 );
+ retval5 = sig2str( 31, test5 );
+ rtems_test_assert( retval5 == 0 );
+ rtems_test_assert( strcmp( test5, "RTMAX" )==0);
+ printf( "The string test5 is: %s\n", test5 );
+ retval6 = sig2str( 30, test6 );
+ rtems_test_assert( retval6 == 0 );
+ rtems_test_assert( strcmp( test6, "RTMIN+3" )==0);
+ printf( "The string test6 is: %s\n", test6 );
+ retval7 = sig2str( 9, test7 );
+ rtems_test_assert( retval7 == 0 );
+ rtems_test_assert(strcmp( test7, "KILL" )==0);
+ printf( "The string test7 is: %s\n", test7 );
+ /* Expected fail, invalid signal number */
+ retval8 = sig2str( 201, test8 );
+ rtems_test_assert( retval8 == -1);
+ rtems_test_assert( strcmp( test8, "Unknown signal 201" )==0);
+ printf( "The string test8 is: %s\n", test8 );
+ /* Expected fail, if signum is 0 the output is unspecified */
+ retval9 = sig2str( 0, test9 );
+ rtems_test_assert( retval9 == -1 );
+ printf( "The string test9 is: %s\n", test9 );
+ printf( "\n" );
+ printf( "Calling str2sig: \n" );
+ retval1 = str2sig( "PIPE", &res1 );
+ rtems_test_assert( retval1 == 0);
+ rtems_test_assert( res1 == 13 );
+ printf( "Result 1 is: %d\n", res1 );
+ retval2 = str2sig( "TSTP", &res2 );
+ rtems_test_assert( retval2 == 0);
+ rtems_test_assert( res2 == 18 );
+ printf( "Result 2 is: %d\n", res2 );
+ retval3 = str2sig( "KILL", &res3 );
+ rtems_test_assert( retval3 == 0);
+ rtems_test_assert( res3 == 9 );
+ printf( "Result 3 is: %d\n", res3 );
+ /* Expected pass, String representation of integer */
+ retval4 = str2sig( "10", &res4 );
+ rtems_test_assert( retval4 == 0);
+ rtems_test_assert( res4 == 10 );
+ printf( "Result 4 is: %d\n", res4 );
+ retval5 = str2sig( "RTMIN", &res5 );
+ rtems_test_assert( retval5 == 0);
+ rtems_test_assert( res5 == 27 );
+ printf( "Result 5 is: %d\n", res5 );
+ retval6 = str2sig( "RTMIN+1", &res6 );
+ rtems_test_assert( retval6 == 0);
+ rtems_test_assert( res6 == 28 );
+ printf( "Result 6 is: %d\n", res6 );
+ retval7 = str2sig( "RTMAX-2", &res7 );
+ rtems_test_assert( retval7 == 0);
+ rtems_test_assert( res7 == 29 );
+ printf( "Result 7 is: %d\n", res7 );
+ /* Expected fail, invalid signal name */
+ retval8 = str2sig( "BOSS", &res8 );
+ printf( "Result 8 is: %d\n", res8 );
+ retval9 = str2sig( "RTMIN+1000", &res9 );
+ rtems_test_assert( retval9 == -1);
+ printf( "Result 9 is: %d\n", res9 );
+ printf( "\n" );
+ printf( "Calling str2sig using the result from previous call to sig2str\n" );
+ retval1 = str2sig( test1, &res1 );
+ rtems_test_assert( res1 == 1 );
+ retval2 = str2sig( test2, &res2 );
+ rtems_test_assert( res2 == 3 );
+ retval3 = str2sig( test3, &res3 );
+ rtems_test_assert( res3 == 27 );
+ /* Expected fail, calling using string from invalid sig2str call */
+ retval4 = str2sig( test8, &res4 );
+ rtems_test_assert( retval4 == -1 );
+ TEST_END();
+ rtems_test_exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
index 0000000000..c90ee805f0
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
@@ -0,0 +1,35 @@
+ * @file
+ * are met:
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
index 0000000000..37c9b5b1fc
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
@@ -0,0 +1,32 @@
+*** BEGIN OF TEST SIG2STR AND STR2SIG ***
+SIGRTMIN is 27 and SIGRTMAX is 31
+Calling sig2str:
+The string test1 is: HUP
+The string test2 is: QUIT
+The string test3 is: RTMIN
+The string test4 is: RTMIN+2
+The string test5 is: RTMAX
+The string test6 is: RTMIN+3
+The string test7 is: KILL
+The string test8 is: Unknown signal 201
+The string test9 is: Unknown signal 0
+Calling str2sig:
+Result 1 is: 13
+Result 2 is: 18
+Result 3 is: 9
+Result 4 is: 10
+Result 5 is: 27
+Result 6 is: 28
+Result 7 is: 29
+Result 8 is: 0
+Result 9 is: 0
+Calling str2sig using the result from previous call to sig2str
+Result 1 is: 1
+Result 2 is: 3
+Result 3 is: 27
+*** END OF TEST SIG2STR AND STR2SIG ***
2.31.1
