[PATCH v3] testsuites: Added tests for sig2str/str2sig methods
Joel Sherrill
joel at rtems.org
Fri Jul 16 21:43:08 UTC 2021
On Fri, Jul 9, 2021 at 4:01 AM Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> Fixed newline error at end of psxsignal09.yml. Added psxsignal09 in
> psxtests and compile only test in psxhdrs in order to evaluate newly
> added POSIX standard methods in Newlib.
> spec/build/testsuites/psxtests/grp.yml | 2 +
> spec/build/testsuites/psxtests/libpsxhdrs.yml | 1 +
> .../build/testsuites/psxtests/psxsignal09.yml | 21 ++
> testsuites/psxtests/Makefile.am | 11 +
> testsuites/psxtests/configure.ac | 1 +
> testsuites/psxtests/psxhdrs/signal/sig2str.c | 57 ++++
> testsuites/psxtests/psxsignal09/init.c | 249 ++++++++++++++++++
> .../psxtests/psxsignal09/psxsignal09.doc | 35 +++
> .../psxtests/psxsignal09/psxsignal09.scn | 32 +++
> 9 files changed, 409 insertions(+)
> create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
> create mode 100644 testsuites/psxtests/psxhdrs/signal/sig2str.c
> create mode 100644 testsuites/psxtests/psxsignal09/init.c
> create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
> create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
> diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
> index fb7ce465ae..f61f45dbe9 100644
> --- a/spec/build/testsuites/psxtests/grp.yml
> +++ b/spec/build/testsuites/psxtests/grp.yml
> @@ -205,6 +205,8 @@ links:
> uid: psxsignal07
> - role: build-dependency
> uid: psxsignal08
> +- role: build-dependency
> + uid: psxsignal09
> uid: psxspin01
> diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
> index 6a0ab6d4f7..5767bcdacd 100644
> --- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
> +++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
> @@ -513,6 +513,7 @@ source:
> - testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
> - testsuites/psxtests/psxhdrs/signal/sigwait.c
> - testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
> +- testsuites/psxtests/psxhdrs/signal/sig2str.c
> - testsuites/psxtests/psxhdrs/stddef/offsetof.c
> - testsuites/psxtests/psxhdrs/stdio/clearerr.c
> - testsuites/psxtests/psxhdrs/stdio/ctermid.c
> diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
> new file mode 100644
> index 0000000000..08a29c7c5b
> --- /dev/null
> +++ b/spec/build/testsuites/psxtests/psxsignal09.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> +- RTEMS_POSIX_API
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/psxtests/psxsignal09/init.c
> +stlib: []
> +target: testsuites/psxtests/psxsignal09.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index a35f00b665..b62d5cab59 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -924,6 +924,17 @@ psxsignal08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal08) \
> endif
> endif
> +if HAS_POSIX
> +if TEST_psxsignal09
> +psx_tests += psxsignal09
> +psx_screens += psxsignal09/psxsignal09.scn
> +psx_docs += psxsignal09/psxsignal09.doc
> +psxsignal09_SOURCES = psxsignal09/init.c
> +psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
> + $(support_includes) -I$(top_srcdir)/include
> +endif
> +endif
> if TEST_psxspin01
> psx_tests += psxspin01
> psx_screens += psxspin01/psxspin01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 3f95010cd3..7b9a1027ca 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -138,6 +138,7 @@ RTEMS_TEST_CHECK([psxsignal05])
> RTEMS_TEST_CHECK([psxsignal06])
> RTEMS_TEST_CHECK([psxsignal07])
> RTEMS_TEST_CHECK([psxsignal08])
> +RTEMS_TEST_CHECK([psxsignal09])
> RTEMS_TEST_CHECK([psxspin01])
> RTEMS_TEST_CHECK([psxstack01])
> RTEMS_TEST_CHECK([psxstack02])
> diff --git a/testsuites/psxtests/psxhdrs/signal/sig2str.c b/testsuites/psxtests/psxhdrs/signal/sig2str.c
> index 0000000000..520a0db740
> --- /dev/null
> +++ b/testsuites/psxtests/psxhdrs/signal/sig2str.c
> @@ -0,0 +1,57 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief Header File Conformance Test
> + * This test file is used to verify that the header files associated with
> + * invoking this function are correct.
> + * Copyright (C) 2021 Matthew Joyce
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <signal.h>
> +#define BUFLEN 10
> +int test( void );
> +int test( void )
> + int result;
> + int signal_number;
> + char signal_name[BUFLEN];
Use SIG2STR_MAX to ensure it is defined properly
> + signal_number = SIGALRM;
> + result = sig2str(signal_number, signal_name);
> + return result;
> diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
> index 0000000000..3684484723
> --- /dev/null
> +++ b/testsuites/psxtests/psxsignal09/init.c
> @@ -0,0 +1,249 @@
> + * @file
> + * @brief Test of sig2str and str2sig methods
> + * This test file is used to verify that the methods sig2str and str2sig
> + * are functioning as expected
> + * are met:
> +/* Defined to have access to SIG2STR_MAX and function prototypes in signal.h*/
> +#define _GNU_SOURCE
> +#endif
> +#include <rtems.h>
> +#include <tmacros.h>
> +#include <rtems/test.h>
> +#include "test_support.h"
> +//#include <sys/signal.h>
> +const char rtems_test_name[] = "SIG2STR AND STR2SIG";
> +static rtems_task Init(
> + rtems_task_argument ignored
> + rtems_print_printer_fprintf_putc(&rtems_test_printer);
> + TEST_BEGIN();
> + char test1[SIG2STR_MAX];
> + char test2[SIG2STR_MAX];
> + char test3[SIG2STR_MAX];
> + char test4[SIG2STR_MAX];
> + char test5[SIG2STR_MAX];
> + char test6[SIG2STR_MAX];
> + char test7[SIG2STR_MAX];
> + char test8[SIG2STR_MAX];
> + char test9[SIG2STR_MAX];
> + int res1;
> + int res2;
> + int res3;
> + int res4;
> + int res5;
> + int res6;
> + int res7;
> + int res8;
> + int res9;
> + int retval1;
> + int retval2;
> + int retval3;
> + int retval4;
> + int retval5;
> + int retval6;
> + int retval7;
> + int retval8;
> + int retval9;
You can reuse variables. Minimize how many there are.
> + int min = SIGRTMIN;
> + int max = SIGRTMAX;
> + printf( "\n" );
> + printf( "SIGRTMIN is %d and SIGRTMAX is %d\n", min, max );
> + printf( "\n" );
> + printf( "Calling sig2str: \n" );
> + /* Expected pass */
Add something like:
rtems_test_assert( SIGHUP == 1 );
to each block to ensure your assumption holds for the signal number.
> + retval1 = sig2str( 1, test1 );
> + rtems_test_assert( retval1 == 0 );
> + rtems_test_assert( strcmp( test1, "HUP" )==0 );
> + printf( "The string test1 is: %s\n", test1 );
> + retval2 = sig2str( 3, test2 );
> + rtems_test_assert( retval2 == 0 );
> + rtems_test_assert( strcmp( test2, "QUIT" )==0);
> + printf( "The string test2 is: %s\n", test2 );
> + retval3 = sig2str( 27, test3 );
> + rtems_test_assert( retval3 == 0 );
> + rtems_test_assert( strcmp( test3, "RTMIN" )==0 );
> + printf( "The string test3 is: %s\n", test3 );
> + retval4 = sig2str( 29, test4 );
> + rtems_test_assert( retval4 == 0 );
> + rtems_test_assert( strcmp( test4, "RTMIN+2" )==0 );
> + printf( "The string test4 is: %s\n", test4 );
> + retval5 = sig2str( 31, test5 );
> + rtems_test_assert( retval5 == 0 );
> + rtems_test_assert( strcmp( test5, "RTMAX" )==0);
> + printf( "The string test5 is: %s\n", test5 );
> + retval6 = sig2str( 30, test6 );
> + rtems_test_assert( retval6 == 0 );
> + rtems_test_assert( strcmp( test6, "RTMIN+3" )==0);
> + printf( "The string test6 is: %s\n", test6 );
> + retval7 = sig2str( 9, test7 );
> + rtems_test_assert( retval7 == 0 );
> + rtems_test_assert(strcmp( test7, "KILL" )==0);
> + printf( "The string test7 is: %s\n", test7 );
> + /* Expected fail, invalid signal number */
> + retval8 = sig2str( 201, test8 );
> + rtems_test_assert( retval8 == -1);
> + rtems_test_assert( strcmp( test8, "Unknown signal 201" )==0);
> + printf( "The string test8 is: %s\n", test8 );
Add a case for max signal integer value + 1
> + /* Expected fail, if signum is 0 the output is unspecified */
> + retval9 = sig2str( 0, test9 );
> + rtems_test_assert( retval9 == -1 );
> + printf( "The string test9 is: %s\n", test9 );
> + printf( "\n" );
> + printf( "Calling str2sig: \n" );
> + retval1 = str2sig( "PIPE", &res1 );
> + rtems_test_assert( retval1 == 0);
> + rtems_test_assert( res1 == 13 );
> + printf( "Result 1 is: %d\n", res1 );
> + retval2 = str2sig( "TSTP", &res2 );
> + rtems_test_assert( retval2 == 0);
> + rtems_test_assert( res2 == 18 );
> + printf( "Result 2 is: %d\n", res2 );
> + retval3 = str2sig( "KILL", &res3 );
> + rtems_test_assert( retval3 == 0);
> + rtems_test_assert( res3 == 9 );
> + printf( "Result 3 is: %d\n", res3 );
> + /* Expected pass, String representation of integer */
> + retval4 = str2sig( "10", &res4 );
> + rtems_test_assert( retval4 == 0);
> + rtems_test_assert( res4 == 10 );
> + printf( "Result 4 is: %d\n", res4 );
> + retval5 = str2sig( "RTMIN", &res5 );
> + rtems_test_assert( retval5 == 0);
> + rtems_test_assert( res5 == 27 );
> + printf( "Result 5 is: %d\n", res5 );
> + retval6 = str2sig( "RTMIN+1", &res6 );
> + rtems_test_assert( retval6 == 0);
> + rtems_test_assert( res6 == 28 );
> + printf( "Result 6 is: %d\n", res6 );
> + retval7 = str2sig( "RTMAX-2", &res7 );
> + rtems_test_assert( retval7 == 0);
> + rtems_test_assert( res7 == 29 );
> + printf( "Result 7 is: %d\n", res7 );
> + /* Expected fail, invalid signal name */
> + retval8 = str2sig( "BOSS", &res8 );
> + printf( "Result 8 is: %d\n", res8 );
> + retval9 = str2sig( "RTMIN+1000", &res9 );
> + rtems_test_assert( retval9 == -1);
> + printf( "Result 9 is: %d\n", res9 );
> + printf( "\n" );
> + printf( "Calling str2sig using the result from previous call to sig2str\n" );
> + retval1 = str2sig( test1, &res1 );
> + rtems_test_assert( res1 == 1 );
> + retval2 = str2sig( test2, &res2 );
> + rtems_test_assert( res2 == 3 );
> + retval3 = str2sig( test3, &res3 );
> + rtems_test_assert( res3 == 27 );
> + /* Expected fail, calling using string from invalid sig2str call */
> + retval4 = str2sig( test8, &res4 );
> + rtems_test_assert( retval4 == -1 );
> + TEST_END();
> + rtems_test_exit( 0 );
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
> index 0000000000..c90ee805f0
> --- /dev/null
> +++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
> @@ -0,0 +1,35 @@
> + * @file
> + * are met:
> diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
> index 0000000000..37c9b5b1fc
> --- /dev/null
> +++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
> @@ -0,0 +1,32 @@
> +*** BEGIN OF TEST SIG2STR AND STR2SIG ***
> +SIGRTMIN is 27 and SIGRTMAX is 31
> +Calling sig2str:
> +The string test1 is: HUP
> +The string test2 is: QUIT
> +The string test3 is: RTMIN
> +The string test4 is: RTMIN+2
> +The string test5 is: RTMAX
> +The string test6 is: RTMIN+3
> +The string test7 is: KILL
> +The string test8 is: Unknown signal 201
> +The string test9 is: Unknown signal 0
> +Calling str2sig:
> +Result 1 is: 13
> +Result 2 is: 18
> +Result 3 is: 9
> +Result 4 is: 10
> +Result 5 is: 27
> +Result 6 is: 28
> +Result 7 is: 29
> +Result 8 is: 0
> +Result 9 is: 0
> +Calling str2sig using the result from previous call to sig2str
> +Result 1 is: 1
> +Result 2 is: 3
> +Result 3 is: 27
> +*** END OF TEST SIG2STR AND STR2SIG ***
> 2.31.1
> devel mailing list
> devel at rtems.org
