GSoC - Code Formatting and Style Checking for RTEMS score
Ida Delphine idadelm at gmail.com
Fri Jul 9 23:08:21 UTC 2021
Hello everyone,
I added the functionality for my script to ignore certain directories like
/bsps/, /testsuites/, '/cpukit/zlib', '/cpukit/mghttpd'.
https://github.com/Idadelveloper/rtems/blob/master/hooks/pre-commit
Are there any extra directories I should exclude?
Also open to more suggestions and feedback to make my code better :)
Cheers,
Ida.
On Sun, Jul 4, 2021 at 12:40 AM Ida Delphine <idadelm at gmail.com> wrote:
> Hello mentors,
> I got some feedback and I have improved my code based on it -
> Will love to get some more feedback and ways to make it look better.
> And is it okay I start working on its documentation though it hasn't been
> approved yet?
> Cheers,
> Ida
> On Thu, Jul 1, 2021 at 6:42 PM Ida Delphine <idadelm at gmail.com> wrote:
>> Thank you. I will make changes accordingly.
>> On Thu, 1 Jul 2021, 5:31 pm Gedare Bloom, <gedare at rtems.org> wrote:
>>> Hi Ida,
>>> On Tue, Jun 29, 2021 at 1:11 PM Ida Delphine <idadelm at gmail.com> wrote:
>>> > Hello mentors,
>>> > Here is the code for my pre-commit hook script. How it works is by
>>> default, upon commiting it outputs a warning stating the number of style
>>> issues in case there are mismatches.
>>> > The user can trigger the strict mode which gives a more detailed
>>> output of the style issues by running adding the mode to the config file (
>>> git config mode "strict") - will document this.
>>> I made comments on your commit that added this:
>>> https://github.com/Idadelveloper/rtems/commit/6bfc4802d17b3aab260190d53467b750848f0002
>>> > I had already sent some screenshots here on how the outcome looks
>>> like. Will love to improve my code based on your feedback and get more
>>> suggestions.
>>> > On Mon, Jun 21, 2021 at 7:05 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> >> On Sun, Jun 20, 2021 at 1:13 AM Ida Delphine <idadelm at gmail.com>
>>> wrote:
>>> >>> Hello everyone,
>>> >>> I updated the hooks script. About the modes, we have the default,
>>> "strict" and "nonstrict" (couldn't think of better names). With the default
>>> mode, it prints a warning specifying the number of style issues if any and
>>> aborts the commit. With the strict mode, it goes into more detail showing
>>> both the formatted and unformatted patch, the number of style issues, and
>>> aborts the commit. In the non-strict mode, it simply displays the warning
>>> with the style issues and the commit happens.
>>> >>> The default mode basically happens when you run
>>> >>>> git commit -m "Commit message"
>>> >>> The best method I could find to pass arguments to a script was via
>>> environment variables. So the nonstrict mode applies when you run
>>> >>>> STYLEMODE=nonstrict git commit -m "Commit message"
>>> >>> The strict mode applies when you run
>>> >>>> STYLEMODE=strict git commit -m "Commit message"
>>> >> What are the possible options to pass arguments? (Maybe, a blog post
>>> :)) Reading from a git-config file would be better than environment
>>> variables.
>>> >> It might be better to share screenshots by a link (e.g., a blog post
>>> :)) to avoid hitting the mailing list attachment limits.
>>> >> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210710/a93d2ac9/attachment.html>
