[PATCH 06/41] rtems: Add rtems_interrupt_get_attributes()
Sebastian Huber
Mon Jul 12 12:49:28 UTC 2021
Add a directive to query the attributes of an interrupt vector. This
be used for generic tests and system diagnostics.
Update #3269.
cpukit/include/rtems/irq-extension.h | 198 +++++++++++++++++++++++++++
1 file changed, 198 insertions(+)
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index 5f24fb502e..d6b5cd5e45 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -419,6 +419,204 @@ rtems_status_code rtems_interrupt_set_affinity(
const cpu_set_t *affinity
+/* Generated from spec:/rtems/intr/if/signal-variant */
+ * @ingroup RTEMSAPIClassicIntr
+ * @brief This enumeration provides interrupt trigger signal variants.
+typedef enum {
+ * @brief This interrupt signal variant indicates that the interrupt trigger
+ * signal is unspecified.
+ RTEMS_INTERRUPT_SIGNAL_UNSPECIFIED,
+ * @brief This interrupt signal variant indicates that the interrupt is
+ * triggered by a low level signal.
+ RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW,
+ * triggered by a high level signal.
+ RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH,
+ * triggered by a falling edge signal.
+ RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING,
+ * triggered by a raising edge signal.
+ RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING
+} rtems_interrupt_signal_variant;
+/* Generated from spec:/rtems/intr/if/attributes */
+ * @brief This structure provides the attributes of an interrupt vector.
+ * The rtems_interrupt_get_attributes() directive may be used to obtain the
+ * attributes of an interrupt vector.
+typedef struct {
+ * @brief This member is true, if the interrupt vector is maskable by
+ * rtems_interrupt_local_disable(), otherwise it is false.
+ * Interrupt vectors which are not maskable by rtems_interrupt_local_disable()
+ * should be used with care since they cannot use most operating system
+ * services.
+ bool is_maskable;
+ * @brief This member is true, if the interrupt vector is always enabled,
+ * otherwise it is false.
+ * For an always enabled interrupt vector it follows that it can be enabled and
+ * that it cannot be disabled.
+ bool always_enabled;
+ * @brief This member is true, if the interrupt vector can be enabled by
+ * rtems_interrupt_vector_enable(), otherwise it is false.
+ * When an interrupt vector can be enabled, this means that the enabled state
+ * can always be changed from disabled to enabled and from enabled to enabled.
+ * For an interrupt vector which can be enabled it follows that it may be
+ * enabled.
+ bool can_enable;
+ * @brief This member is true, if the interrupt vector may be enabled by
+ * When an interrupt vector may be enabled, this means that the enabled state
+ * may be changed from disabled to enabled and from enabled to enabled. The
+ * requested enabled state change should be checked by
+ * rtems_interrupt_vector_is_enabled(). Some interrupt vectors may be
+ * optionally avaialable and cannot be enabled on a particular target.
+ bool maybe_enable;
+ * @brief This member is true, if the interrupt vector can be disabled by
+ * rtems_interrupt_vector_disable(), otherwise it is false.
+ * When an interrupt vector can be disabled, this means that the enabled state
+ * can be changed from disabled to disabled and from enabled to disabled.
+ bool can_disable;
+ * @brief This member is true, if the interrupt vector can be caused by
+ * rtems_interrupt_cause(), otherwise it is false.
+ bool can_cause;
+ * @brief This member is true, if the interrupt vector can be caused on a
+ * processor by rtems_interrupt_cause_on(), otherwise it is false.
+ bool can_cause_on;
+ * @brief This member is true, if the interrupt vector can be cleared by
+ * rtems_interrupt_clear(), otherwise it is false.
+ bool can_clear;
+ * @brief This member is true, if the pending status of the interrupt
+ * associated with the interrupt vector is cleared by an interrupt
+ * acknowledge from the processor, otherwise it is false.
+ bool cleared_by_acknowledge;
+ * @brief This member is true, if the affinity set of the interrupt vector can
+ * be obtained by rtems_interrupt_get_affinity(), otherwise it is false.
+ bool can_get_affinity;
+ * be set by rtems_interrupt_set_affinity(), otherwise it is false.
+ bool can_set_affinity;
+ * @brief This member is true, if the interrupt associated with the interrupt
+ * vector can be triggered by a message.
+ * Interrupts may be also triggered by signals, rtems_interrupt_cause() or
+ * rtems_interrupt_cause_on(). Examples for message triggered interrupts are
+ * the PCIe MSI/MSI-X and the ARM GICv3 Locality-specific Peripheral Interrupts
+ * (LPI).
+ bool may_be_triggered_by_message;
+ * @brief This member describes the trigger signal of the interrupt associated
+ * with the interrupt vector.
+ * Interrupts may be also triggered by messages, rtems_interrupt_cause() or
+ rtems_interrupt_signal_variant trigger_signal;
+} rtems_interrupt_attributes;
+/* Generated from spec:/rtems/intr/if/get-attributes */
+ * @brief Gets the attributes of the interrupt vector.
+ * @param vector is the interrupt vector number.
+ * @param[out] attributes is the pointer to an rtems_interrupt_attributes
+ * object. When the directive call is successful, the attributes of the
+ * interrupt vector will be stored in this object.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``attributes`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ * number specified by ``vector``.
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within interrupt context.
+ * * The directive may be called from within device driver initialization
+ * context.
+ * * The directive may be called from within task context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+rtems_status_code rtems_interrupt_get_attributes(
+ rtems_vector_number vector,
+ rtems_interrupt_attributes *attributes
/* Generated from spec:/rtems/intr/if/handler-iterate */
2.26.2
