[PATCH 06/41] rtems: Add rtems_interrupt_get_attributes()
Gedare Bloom
gedare at rtems.org
Wed Jul 21 18:00:14 UTC 2021
On Mon, Jul 12, 2021 at 6:50 AM Sebastian Huber
> Add a directive to query the attributes of an interrupt vector. This
nit, add "can"
> be used for generic tests and system diagnostics.
> Update #3269.
> cpukit/include/rtems/irq-extension.h | 198 +++++++++++++++++++++++++++
> 1 file changed, 198 insertions(+)
> diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
> index 5f24fb502e..d6b5cd5e45 100644
> --- a/cpukit/include/rtems/irq-extension.h
> +++ b/cpukit/include/rtems/irq-extension.h
> @@ -419,6 +419,204 @@ rtems_status_code rtems_interrupt_set_affinity(
> const cpu_set_t *affinity
> +/* Generated from spec:/rtems/intr/if/signal-variant */
> + * @ingroup RTEMSAPIClassicIntr
> + * @brief This enumeration provides interrupt trigger signal variants.
> +typedef enum {
> + * @brief This interrupt signal variant indicates that the interrupt trigger
> + * signal is unspecified.
> + RTEMS_INTERRUPT_SIGNAL_UNSPECIFIED,
> + * @brief This interrupt signal variant indicates that the interrupt is
> + * triggered by a low level signal.
> + RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW,
> + * triggered by a high level signal.
> + RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH,
> + * triggered by a falling edge signal.
> + RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING,
> + * triggered by a raising edge signal.
> + RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING
> +} rtems_interrupt_signal_variant;
> +/* Generated from spec:/rtems/intr/if/attributes */
> + * @brief This structure provides the attributes of an interrupt vector.
> + * The rtems_interrupt_get_attributes() directive may be used to obtain the
> + * attributes of an interrupt vector.
> +typedef struct {
> + * @brief This member is true, if the interrupt vector is maskable by
> + * rtems_interrupt_local_disable(), otherwise it is false.
> + * Interrupt vectors which are not maskable by rtems_interrupt_local_disable()
> + * should be used with care since they cannot use most operating system
> + * services.
> + bool is_maskable;
> + * @brief This member is true, if the interrupt vector is always enabled,
> + * otherwise it is false.
> + * For an always enabled interrupt vector it follows that it can be enabled and
> + * that it cannot be disabled.
Should this refer to the attributes explicitly? (can_enable == true
and can_disable == false)
> + bool always_enabled;
> + * @brief This member is true, if the interrupt vector can be enabled by
> + * rtems_interrupt_vector_enable(), otherwise it is false.
> + * When an interrupt vector can be enabled, this means that the enabled state
> + * can always be changed from disabled to enabled and from enabled to enabled.
> + * For an interrupt vector which can be enabled it follows that it may be
> + * enabled.
> + bool can_enable;
> + * @brief This member is true, if the interrupt vector may be enabled by
> + * When an interrupt vector may be enabled, this means that the enabled state
> + * may be changed from disabled to enabled and from enabled to enabled. The
s/may/might
It is more proper to say "might" when something "might not". "may" and
"can" are close synonyms, but "maybe" is closer to "might" in usage.
English is still terrible.
> + * requested enabled state change should be checked by
> + * rtems_interrupt_vector_is_enabled(). Some interrupt vectors may be
> + * optionally avaialable and cannot be enabled on a particular target.
available
> + bool maybe_enable;
> + * @brief This member is true, if the interrupt vector can be disabled by
> + * rtems_interrupt_vector_disable(), otherwise it is false.
> + * When an interrupt vector can be disabled, this means that the enabled state
> + * can be changed from disabled to disabled and from enabled to disabled.
> + bool can_disable;
> + * @brief This member is true, if the interrupt vector can be caused by
> + * rtems_interrupt_cause(), otherwise it is false.
> + bool can_cause;
> + * @brief This member is true, if the interrupt vector can be caused on a
> + * processor by rtems_interrupt_cause_on(), otherwise it is false.
> + bool can_cause_on;
> + * @brief This member is true, if the interrupt vector can be cleared by
> + * rtems_interrupt_clear(), otherwise it is false.
> + bool can_clear;
> + * @brief This member is true, if the pending status of the interrupt
> + * associated with the interrupt vector is cleared by an interrupt
> + * acknowledge from the processor, otherwise it is false.
> + bool cleared_by_acknowledge;
> + * @brief This member is true, if the affinity set of the interrupt vector can
> + * be obtained by rtems_interrupt_get_affinity(), otherwise it is false.
> + bool can_get_affinity;
> + * be set by rtems_interrupt_set_affinity(), otherwise it is false.
> + bool can_set_affinity;
> + * @brief This member is true, if the interrupt associated with the interrupt
> + * vector can be triggered by a message.
> + * Interrupts may be also triggered by signals, rtems_interrupt_cause() or
> + * rtems_interrupt_cause_on(). Examples for message triggered interrupts are
> + * the PCIe MSI/MSI-X and the ARM GICv3 Locality-specific Peripheral Interrupts
> + * (LPI).
> + bool may_be_triggered_by_message;
Either use "can_be" or "maybe" as mentioned above to avoid some
confusion. "can be" should be preferred if it is always possible, and
"maybe" should be preferred if it might not be triggered by messages.
Avoid using "may_be" as it will be confusing to the difference between
"can" and "may".
> + * @brief This member describes the trigger signal of the interrupt associated
> + * with the interrupt vector.
> + * Interrupts may be also triggered by messages, rtems_interrupt_cause() or
> + rtems_interrupt_signal_variant trigger_signal;
> +} rtems_interrupt_attributes;
> +/* Generated from spec:/rtems/intr/if/get-attributes */
> + * @brief Gets the attributes of the interrupt vector.
> + * @param vector is the interrupt vector number.
> + * @param[out] attributes is the pointer to an rtems_interrupt_attributes
> + * object. When the directive call is successful, the attributes of the
> + * interrupt vector will be stored in this object.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``attributes`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
> + * number specified by ``vector``.
> + * @par Constraints
> + * @parblock
> + * The following constraints apply to this directive:
> + * * The directive may be called from within interrupt context.
> + * * The directive may be called from within device driver initialization
> + * context.
> + * * The directive may be called from within task context.
> + * * The directive will not cause the calling task to be preempted.
> + * @endparblock
> +rtems_status_code rtems_interrupt_get_attributes(
> + rtems_vector_number vector,
> + rtems_interrupt_attributes *attributes
> /* Generated from spec:/rtems/intr/if/handler-iterate */
> 2.26.2
> devel mailing list
> devel at rtems.org
