[PATCH 17/41] bsps/irq: bsp_interrupt_get_affinity()
Sebastian Huber
Mon Jul 12 12:49:39 UTC 2021
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
bsps/include/dev/irq/arm-gic-irq.h | 2 +-
bsps/powerpc/qoriq/include/bsp/irq.h | 2 +-
bsps/powerpc/qoriq/irq/irq.c | 5 +++--
bsps/powerpc/t32mppc/include/bsp/irq.h | 3 ++-
bsps/riscv/griscv/include/bsp/irq.h | 2 +-
bsps/riscv/griscv/irq/irq.c | 4 +++-
bsps/riscv/riscv/include/bsp/irq.h | 2 +-
bsps/riscv/riscv/irq/irq.c | 4 +++-
bsps/shared/dev/irq/arm-gicv2.c | 3 ++-
bsps/shared/dev/irq/arm-gicv3.c | 3 ++-
bsps/shared/irq/irq-affinity.c | 9 ++++++++-
bsps/sparc/erc32/include/bsp/irq.h | 3 ++-
bsps/sparc/leon3/include/bsp/irq.h | 2 +-
bsps/sparc/leon3/start/eirq.c | 3 ++-
bsps/sparc/shared/irq/irq-shared.c | 2 +-
15 files changed, 33 insertions(+), 16 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gic-irq.h b/bsps/include/dev/irq/arm-gic-irq.h
index 5ce9d54684..730d792ce4 100644
--- a/bsps/include/dev/irq/arm-gic-irq.h
+++ b/bsps/include/dev/irq/arm-gic-irq.h
@@ -74,7 +74,7 @@ void bsp_interrupt_set_affinity(
const Processor_mask *affinity
-void bsp_interrupt_get_affinity(
+rtems_status_code bsp_interrupt_get_affinity(
rtems_vector_number vector,
diff --git a/bsps/powerpc/qoriq/include/bsp/irq.h b/bsps/powerpc/qoriq/include/bsp/irq.h
index cf46832045..6618d54190 100644
--- a/bsps/powerpc/qoriq/include/bsp/irq.h
+++ b/bsps/powerpc/qoriq/include/bsp/irq.h
@@ -385,7 +385,7 @@ void bsp_interrupt_set_affinity(
diff --git a/bsps/powerpc/qoriq/irq/irq.c b/bsps/powerpc/qoriq/irq/irq.c
index f1b50a7dd8..9ca903496c 100644
--- a/bsps/powerpc/qoriq/irq/irq.c
+++ b/bsps/powerpc/qoriq/irq/irq.c
@@ -64,7 +64,7 @@ void bsp_interrupt_set_affinity(
rtems_interrupt_lock_release(&lock, &lock_context);
@@ -75,6 +75,7 @@ void bsp_interrupt_get_affinity(
ev_int_get_config(vector, &config, &priority, &destination);
_Processor_mask_From_uint32_t(affinity, destination, 0);
+ return RTEMS_SUCCESSFUL;
rtems_status_code bsp_interrupt_get_attributes(
@@ -323,7 +324,7 @@ void bsp_interrupt_set_affinity(
src_cfg->dr = _Processor_mask_To_uint32_t(affinity, 0);
diff --git a/bsps/powerpc/t32mppc/include/bsp/irq.h b/bsps/powerpc/t32mppc/include/bsp/irq.h
index 998eadf3df..c0c374edae 100644
--- a/bsps/powerpc/t32mppc/include/bsp/irq.h
+++ b/bsps/powerpc/t32mppc/include/bsp/irq.h
@@ -35,13 +35,14 @@ RTEMS_INLINE_ROUTINE void bsp_interrupt_set_affinity(
(void) affinity;
-RTEMS_INLINE_ROUTINE void bsp_interrupt_get_affinity(
+RTEMS_INLINE_ROUTINE rtems_status_code bsp_interrupt_get_affinity(
(void) vector;
_Processor_mask_From_index( affinity, 0 );
#ifdef __cplusplus
diff --git a/bsps/riscv/griscv/include/bsp/irq.h b/bsps/riscv/griscv/include/bsp/irq.h
index f9e280d5a9..1df7b4b584 100644
--- a/bsps/riscv/griscv/include/bsp/irq.h
+++ b/bsps/riscv/griscv/include/bsp/irq.h
@@ -61,7 +61,7 @@ void bsp_interrupt_set_affinity(
diff --git a/bsps/riscv/griscv/irq/irq.c b/bsps/riscv/griscv/irq/irq.c
index f5b493bd02..1128678d3b 100644
--- a/bsps/riscv/griscv/irq/irq.c
+++ b/bsps/riscv/griscv/irq/irq.c
@@ -156,7 +156,7 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
@@ -171,6 +171,8 @@ void bsp_interrupt_get_affinity(
_Processor_mask_Set(affinity, cpu_index);
diff --git a/bsps/riscv/riscv/include/bsp/irq.h b/bsps/riscv/riscv/include/bsp/irq.h
index 306988d5e3..03fe8ced3a 100644
--- a/bsps/riscv/riscv/include/bsp/irq.h
+++ b/bsps/riscv/riscv/include/bsp/irq.h
diff --git a/bsps/riscv/riscv/irq/irq.c b/bsps/riscv/riscv/irq/irq.c
index 52b14ee9e6..555365b2aa 100644
--- a/bsps/riscv/riscv/irq/irq.c
+++ b/bsps/riscv/riscv/irq/irq.c
@@ -399,7 +399,7 @@ void bsp_interrupt_set_affinity(
@@ -433,4 +433,6 @@ void bsp_interrupt_get_affinity(
_Processor_mask_Assign(affinity, _SMP_Get_online_processors());
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index fd7ca49458..ffc65ab672 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -303,7 +303,7 @@ void bsp_interrupt_set_affinity(
gic_id_set_targets(dist, vector, targets);
@@ -312,6 +312,7 @@ void bsp_interrupt_get_affinity(
uint8_t targets = gic_id_get_targets(dist, vector);
_Processor_mask_From_uint32_t(affinity, targets, 0);
void arm_gic_trigger_sgi(rtems_vector_number vector, uint32_t targets)
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 12e0aa3534..fc76209298 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -410,7 +410,7 @@ void bsp_interrupt_set_affinity(
@@ -419,6 +419,7 @@ void bsp_interrupt_get_affinity(
diff --git a/bsps/shared/irq/irq-affinity.c b/bsps/shared/irq/irq-affinity.c
index d2214cf6ec..34ebd8c354 100644
--- a/bsps/shared/irq/irq-affinity.c
+++ b/bsps/shared/irq/irq-affinity.c
@@ -74,6 +74,9 @@ rtems_status_code rtems_interrupt_get_affinity(
Processor_mask set;
Processor_mask_Copy_status status;
+#if defined(RTEMS_SMP)
+ rtems_status_code sc;
+#endif
if ( affinity == NULL ) {
return RTEMS_INVALID_ADDRESS;
@@ -84,7 +87,11 @@ rtems_status_code rtems_interrupt_get_affinity(
- bsp_interrupt_get_affinity(vector, &set);
+ sc = bsp_interrupt_get_affinity( vector, &set );
+ if ( sc != RTEMS_SUCCESSFUL ) {
+ return sc;
#else
_Processor_mask_From_index(&set, 0);
#endif
diff --git a/bsps/sparc/erc32/include/bsp/irq.h b/bsps/sparc/erc32/include/bsp/irq.h
index 9e0f511b55..17ab3c09f0 100644
--- a/bsps/sparc/erc32/include/bsp/irq.h
+++ b/bsps/sparc/erc32/include/bsp/irq.h
(void) affinity;
(void) vector;
#endif /* LIBBSP_ERC32_IRQ_CONFIG_H */
diff --git a/bsps/sparc/leon3/include/bsp/irq.h b/bsps/sparc/leon3/include/bsp/irq.h
index 5a53246a6b..baf97815e3 100644
--- a/bsps/sparc/leon3/include/bsp/irq.h
+++ b/bsps/sparc/leon3/include/bsp/irq.h
@@ -34,7 +34,7 @@ void bsp_interrupt_set_affinity(
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index 822b49959a..dcfaf5b3db 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -226,11 +226,12 @@ void bsp_interrupt_set_affinity(
LEON3_IRQCTRL_RELEASE(&lock_context);
*affinity = leon3_interrupt_affinities[vector];
#endif
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index 976c9256cc..aa1d412be0 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -16,7 +16,7 @@ static inline int bsp_irq_cpu(int irq)
Processor_mask affinity;
- bsp_interrupt_get_affinity((rtems_vector_number) irq, &affinity);
+ (void) bsp_interrupt_get_affinity((rtems_vector_number) irq, &affinity);
return (int) _Processor_mask_Find_last_set(&affinity);
#elif defined(LEON3)
return _LEON3_Get_current_processor();
2.26.2
