[PATCH 27/41] validation: Add CallWithinISR()
Sebastian Huber
Mon Jul 12 12:49:49 UTC 2021
Update #3269.
.../testsuites/validation/libvalidation.yml | 1 +
testsuites/validation/tx-call-within-isr.c | 134 ++++++++++++++++++
testsuites/validation/tx-support.h | 14 ++
3 files changed, 149 insertions(+)
create mode 100644 testsuites/validation/tx-call-within-isr.c
diff --git a/spec/build/testsuites/validation/libvalidation.yml b/spec/build/testsuites/validation/libvalidation.yml
index d55d4b9e41..54c7ae0ac0 100644
--- a/spec/build/testsuites/validation/libvalidation.yml
+++ b/spec/build/testsuites/validation/libvalidation.yml
@@ -11,6 +11,7 @@ install: []
install-path: null
links: []
source:
+- testsuites/validation/tx-call-within-isr.c
- testsuites/validation/tx-support.c
target: validation
type: build
diff --git a/testsuites/validation/tx-call-within-isr.c b/testsuites/validation/tx-call-within-isr.c
new file mode 100644
index 0000000000..226647c0bc
--- /dev/null
+++ b/testsuites/validation/tx-call-within-isr.c
@@ -0,0 +1,134 @@
+ * @file
+ * @ingroup RTEMSTestSuites
+ * @brief This source file contains the implementation of CallWithinISR(),
+ * CallWithinISRSubmit(), and CallWithinISRWait().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tx-support.h"
+#include <rtems/sysinit.h>
+#include <rtems/score/chainimpl.h>
+#include <bsp.h>
+/* Some target architectures need this variable for <tm27.h> */
+uint32_t Interrupt_nest;
+#define _RTEMS_TMTEST27
+#include <tm27.h>
+typedef struct {
+ Chain_Control pending;
+ RTEMS_INTERRUPT_LOCK_MEMBER( lock )
+} CallWithinISRContext;
+static CallWithinISRContext CallWithinISRInstance = {
+#if defined( RTEMS_SMP )
+ .lock = RTEMS_INTERRUPT_LOCK_INITIALIZER( "CallWithinISR" ),
+#endif
+ .pending = CHAIN_INITIALIZER_EMPTY( CallWithinISRInstance.pending )
+static void CallWithinISRHandler( rtems_vector_number vector )
+ CallWithinISRContext *ctx;
+ (void) vector;
+ ctx = &CallWithinISRInstance;
+ while ( true ) {
+ rtems_interrupt_lock_context lock_context;
+ CallWithinISRRequest *request;
+ rtems_interrupt_lock_acquire( &ctx->lock, &lock_context );
+ request = (CallWithinISRRequest *)
+ _Chain_Get_unprotected( &ctx->pending );
+ rtems_interrupt_lock_release( &ctx->lock, &lock_context );
+ if ( request == NULL ) {
+ break;
+ ( *request->handler )( request->arg );
+ _Atomic_Store_uint( &request->done, 1, ATOMIC_ORDER_RELEASE );
+void CallWithinISR( void ( *handler )( void * ), void *arg )
+ CallWithinISRRequest request;
+ request.handler = handler;
+ request.arg = arg;
+ CallWithinISRSubmit( &request );
+ CallWithinISRWait( &request );
+void CallWithinISRSubmit( CallWithinISRRequest *request )
+ _Atomic_Store_uint( &request->done, 0, ATOMIC_ORDER_RELAXED );
+ _Chain_Initialize_node( &request->node );
+ _Chain_Append_unprotected( &ctx->pending, &request->node );
+ Cause_tm27_intr();
+void CallWithinISRWait( const CallWithinISRRequest *request )
+ while ( _Atomic_Load_uint( &request->done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
+ /* Wait */
+static void CallWithinISRInitialize( void )
+ Install_tm27_vector( CallWithinISRHandler );
+RTEMS_SYSINIT_ITEM(
+ CallWithinISRInitialize,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/testsuites/validation/tx-support.h b/testsuites/validation/tx-support.h
index 932584b168..9d5a51e461 100644
--- a/testsuites/validation/tx-support.h
+++ b/testsuites/validation/tx-support.h
@@ -38,6 +38,7 @@
#define _TX_SUPPORT_H
+#include <rtems/score/atomic.h>
#ifdef __cplusplus
extern "C" {
@@ -99,6 +100,19 @@ void RestoreRunnerMode( void );
void RestoreRunnerPriority( void );
+typedef struct {
+ Chain_Node node;
+ void ( *handler )( void * );
+ void *arg;
+ Atomic_Uint done;
+} CallWithinISRRequest;
+void CallWithinISR( void ( *handler )( void * ), void *arg );
+void CallWithinISRSubmit( CallWithinISRRequest *request );
+void CallWithinISRWait( const CallWithinISRRequest *request );
#ifdef __cplusplus
2.26.2
