[PATCH 28/41] validation: HasInterruptVectorEntriesInstalled()
Mon Jul 12 12:49:50 UTC 2021
Update #3269.
 .../testsuites/validation/libvalidation.yml   |  1 +
 testsuites/validation/tx-interrupt.c          | 79 +++++++++++++++++++
 testsuites/validation/tx-support.h            |  2 +
 3 files changed, 82 insertions(+)
 create mode 100644 testsuites/validation/tx-interrupt.c
diff --git a/spec/build/testsuites/validation/libvalidation.yml b/spec/build/testsuites/validation/libvalidation.yml
index 54c7ae0ac0..98dd2e3623 100644
--- a/spec/build/testsuites/validation/libvalidation.yml
+++ b/spec/build/testsuites/validation/libvalidation.yml
@@ -12,6 +12,7 @@ install-path: null
 links: []
 source:
 - testsuites/validation/tx-call-within-isr.c
+- testsuites/validation/tx-interrupt.c
 - testsuites/validation/tx-support.c
 target: validation
 type: build
diff --git a/testsuites/validation/tx-interrupt.c b/testsuites/validation/tx-interrupt.c
new file mode 100644
index 0000000000..d056af5abc
--- /dev/null
+++ b/testsuites/validation/tx-interrupt.c
@@ -0,0 +1,79 @@
+ * @file
+ * @ingroup RTEMSTestSuites
+ * @brief This source file contains the implementation of
+ *   HasInterruptVectorEntriesInstalled().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "tx-support.h"
+#include <rtems/irq-extension.h>
+#include <rtems/test.h>
+static void HasInstalled(
+  void                   *arg,
+  const char             *info,
+  rtems_option            options,
+  rtems_interrupt_handler handler_routine,
+  void                   *handler_arg
+  bool *has_installed_entries;
+  (void) info;
+  (void) options;
+  (void) handler_routine;
+  (void) handler_arg;
+  has_installed_entries = arg;
+  *has_installed_entries = true;
+bool HasInterruptVectorEntriesInstalled( rtems_vector_number vector )
+  bool              has_installed_entries;
+  rtems_status_code sc;
+  has_installed_entries = false;
+  sc = rtems_interrupt_handler_iterate(
+    vector,
+    HasInstalled,
+    &has_installed_entries
+  T_quiet_rsc_success( sc );
+  return has_installed_entries;
diff --git a/testsuites/validation/tx-support.h b/testsuites/validation/tx-support.h
index 9d5a51e461..378e98ee3f 100644
--- a/testsuites/validation/tx-support.h
+++ b/testsuites/validation/tx-support.h
@@ -113,6 +113,8 @@ void CallWithinISRSubmit( CallWithinISRRequest *request );
 void CallWithinISRWait( const CallWithinISRRequest *request );
+bool HasInterruptVectorEntriesInstalled( rtems_vector_number vector );
 #ifdef __cplusplus
2.26.2
