[PATCH 25/41] bsps/irq: Add rtems_interrupt_entry_install()
Mon Jul 12 12:49:47 UTC 2021
Add rtems_interrupt_entry_remove().  Split up irq-generic.c into several files.
In particular, place all functions which use dynamic memory into their own
file.
Add optional macros to let the BSP customize the vector installation after
installing the first entry and the vector removal before removing the last
entry:
* bsp_interrupt_vector_install()
* bsp_interrupt_vector_remove()
Use these new customization options in the m68k/genmcf548x BSP so re-use the
generic interrupt controller support.
Update #3269.
 bsps/i386/shared/irq/irq.c                   |   8 +-
 bsps/include/bsp/irq-generic.h               | 214 ++++++--
 bsps/m68k/genmcf548x/include/bsp/irq.h       |   8 +
 bsps/m68k/genmcf548x/irq/irq.c               | 140 +-----
 bsps/shared/irq-default-sources.am           |   3 +
 bsps/shared/irq-sources.am                   |   3 +
 bsps/shared/irq/irq-entry-remove.c           | 115 +++++
 bsps/shared/irq/irq-generic.c                | 486 ++++++-------------
 bsps/shared/irq/irq-handler-install.c        | 114 +++++
 bsps/shared/irq/irq-handler-iterate.c        |  21 +-
 bsps/shared/irq/irq-handler-remove.c         |  80 +++
 c/src/lib/libbsp/m68k/genmcf548x/Makefile.am |  10 +-
 c/src/lib/libbsp/powerpc/ss555/Makefile.am   |   3 +
 spec/build/bsps/m68k/genmcf548x/grp.yml      |   2 +
 spec/build/bsps/m68k/genmcf548x/obj.yml      |   9 -
 spec/build/bsps/objirq.yml                   |   3 +
 spec/build/bsps/powerpc/ss555/bspss555.yml   |   3 +
 17 files changed, 681 insertions(+), 541 deletions(-)
 create mode 100644 bsps/shared/irq/irq-entry-remove.c
 create mode 100644 bsps/shared/irq/irq-handler-install.c
 create mode 100644 bsps/shared/irq/irq-handler-remove.c
diff --git a/bsps/i386/shared/irq/irq.c b/bsps/i386/shared/irq/irq.c
index d0004698e7..25f8fb69b0 100644
--- a/bsps/i386/shared/irq/irq.c
+++ b/bsps/i386/shared/irq/irq.c
@@ -353,13 +353,7 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
 static bool bsp_interrupt_handler_is_empty(rtems_vector_number vector)
-  rtems_vector_number index;
-  rtems_interrupt_entry *head;
-  index = bsp_interrupt_handler_index(vector);
-  head = &bsp_interrupt_handler_table[index];
-  return bsp_interrupt_is_empty_handler_entry(head);
+  return bsp_interrupt_entry_load_first(vector) == NULL;
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 3b2998f533..6e2f5ed464 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -12,7 +12,7 @@
  * Copyright (C) 2016 Chris Johns <chrisj at rtems.org>
- * Copyright (C) 2008, 2017 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2008, 2021 embedded brains GmbH (http://www.embedded-brains.de)
  * modification, are permitted provided that the following conditions
@@ -70,20 +70,13 @@ extern "C" {
   #define BSP_INTERRUPT_HANDLER_TABLE_SIZE BSP_INTERRUPT_VECTOR_COUNT
 #endif
-/* Internal macros for SMP support, do not use externally */
-#ifdef RTEMS_SMP
-  #define bsp_interrupt_disable(level) do { (void) level; } while (0)
-  #define bsp_interrupt_enable(level) do { } while (0)
-  #define bsp_interrupt_fence(order) _Atomic_Fence(order)
-#else
-  #define bsp_interrupt_disable(level) rtems_interrupt_disable(level)
-  #define bsp_interrupt_enable(level) rtems_interrupt_enable(level)
-  #define bsp_interrupt_fence(order) do { } while (0)
-#endif
 #define bsp_interrupt_assert(e) _Assert(e)
-extern rtems_interrupt_entry bsp_interrupt_handler_table [];
+ * @brief Each member of this table references the first installed entry at the
+ *   corresponding interrupt vector or is NULL.
+extern rtems_interrupt_entry *bsp_interrupt_handler_table[];
 #ifdef BSP_INTERRUPT_USE_INDEX_TABLE
   #if BSP_INTERRUPT_HANDLER_TABLE_SIZE < 0x100
@@ -141,6 +134,12 @@ static inline rtems_vector_number bsp_interrupt_handler_index(
  * - bsp_interrupt_vector_disable()
  * - bsp_interrupt_handler_default()
+ * Optionally, the BSP may define the following macros to customize the vector
+ * installation after installing the first entry and the vector removal before
+ * removing the last entry:
+ * - bsp_interrupt_vector_install()
+ * - bsp_interrupt_vector_remove()
  * The following now deprecated functions are provided for backward
  * compatibility:
  * - BSP_get_current_rtems_irq_handler()
@@ -362,14 +361,114 @@ rtems_status_code bsp_interrupt_cause_on(
 rtems_status_code bsp_interrupt_clear( rtems_vector_number vector );
+#if defined(RTEMS_SMP)
+ * @brief Handles a spurious interrupt.
+ * @param vector is the vector number.
+void bsp_interrupt_spurious( rtems_vector_number vector );
+#endif
+ * @brief Loads the interrupt entry with atomic acquire semantic.
+ * @param ptr is the pointer to an ::rtems_interrupt_entry pointer.
+ * @return Returns the pointer value.
+static inline rtems_interrupt_entry *bsp_interrupt_entry_load_acquire(
+  rtems_interrupt_entry * const *ptr
+  return (rtems_interrupt_entry *) _Atomic_Load_uintptr(
+    (const Atomic_Uintptr *) ptr,
+    ATOMIC_ORDER_ACQUIRE
+#else
+  return *ptr;
+#endif
+ * @brief Stores the interrupt entry with atomic release semantic.
+ * @param[out] ptr is the pointer to an ::rtems_interrupt_entry pointer.
+ * @param value is the pointer value.
+static inline void bsp_interrupt_entry_store_release(
+  rtems_interrupt_entry **ptr,
+  rtems_interrupt_entry  *value
+  _Atomic_Store_uintptr(
+    (Atomic_Uintptr *) ptr,
+    (Atomic_Uintptr) value,
+    ATOMIC_ORDER_RELEASE
+#else
+  rtems_interrupt_level level;
+  rtems_interrupt_local_disable( level );
+  *ptr = value;
+  rtems_interrupt_local_enable( level );
+#endif
+ * @brief Loads the first interrupt entry installed at the interrupt vector.
+ * @return Returns the first entry or NULL.
+static inline rtems_interrupt_entry *bsp_interrupt_entry_load_first(
+  rtems_vector_number vector
+  rtems_vector_number index;
+  index = bsp_interrupt_handler_index( vector );
+  return bsp_interrupt_entry_load_acquire(
+    &bsp_interrupt_handler_table[ index ]
+ * @brief Sequentially calls all interrupt handlers of the entry its
+ *   successors.
+ * In uniprocessor configurations, you can call this function within every
+ * context which can be disabled via rtems_interrupt_local_disable().
+ * In SMP configurations, you can call this function in every context.
+ * @param entry is the first entry.
+static inline void bsp_interrupt_dispatch_entries(
+  const rtems_interrupt_entry *entry
+  do {
+    ( *entry->handler )( entry->arg );
+    entry = bsp_interrupt_entry_load_acquire( &entry->next );
+  } while ( RTEMS_PREDICT_FALSE( entry != NULL ) );
  * @brief Sequentially calls all interrupt handlers installed at the vector.
  * This function does not validate the vector number.  If the vector number is
  * out of range, then the behaviour is undefined.
- * You can call this function within every context which can be disabled via
- * rtems_interrupt_local_disable().
@@ -377,21 +476,19 @@ static inline void bsp_interrupt_handler_dispatch_unchecked(
-  const rtems_interrupt_entry *e;
-  e = &bsp_interrupt_handler_table[ bsp_interrupt_handler_index( vector ) ];
+  const rtems_interrupt_entry *entry;
-  do {
-    rtems_interrupt_handler handler;
-    void *arg;
-    arg = e->arg;
-    bsp_interrupt_fence( ATOMIC_ORDER_ACQUIRE );
-    handler = e->handler;
-    ( *handler )( arg );
+  entry = bsp_interrupt_entry_load_first( vector );
-    e = e->next;
-  } while ( e != NULL );
+  if ( RTEMS_PREDICT_TRUE( entry != NULL ) ) {
+    bsp_interrupt_dispatch_entries( entry );
+  } else {
+    bsp_interrupt_spurious( vector );
+#else
+    bsp_interrupt_handler_default( vector );
+#endif
@@ -401,8 +498,10 @@ static inline void bsp_interrupt_handler_dispatch_unchecked(
  * bsp_interrupt_handler_default() will be called with the vector number as
  * argument.
@@ -448,6 +547,21 @@ rtems_status_code bsp_interrupt_check_and_lock(
+/* For internal use only */
+rtems_interrupt_entry *bsp_interrupt_entry_find(
+  rtems_vector_number      vector,
+  rtems_interrupt_handler  routine,
+  void                    *arg,
+  rtems_interrupt_entry ***previous_next
+void bsp_interrupt_entry_remove(
+  rtems_interrupt_entry  *entry,
+  rtems_interrupt_entry **previous_next
  * @brief This table contains a bit map which indicates if an entry is unique
  *   or shared.
@@ -480,29 +594,39 @@ static inline bool bsp_interrupt_is_handler_unique( rtems_vector_number index )
- * @brief Checks if the interrupt support is initialized.
+ * @brief Sets the unique status of the handler entry.
- * @return Returns true, if the interrupt support is initialized, otherwise
- *   false.
+ * @param index is the handler index.
+ * @param unique is the unique status to set.
-static inline bool bsp_interrupt_is_initialized( void )
+static inline void bsp_interrupt_set_handler_unique(
+  rtems_vector_number index,
+  bool                unique
-  return bsp_interrupt_is_handler_unique( BSP_INTERRUPT_HANDLER_TABLE_SIZE );
+  rtems_vector_number table_index;
+  uint8_t             bit;
- * @brief This handler routine is used for empty entries.
-void bsp_interrupt_handler_empty( void *arg );
+  table_index = index / 8;
+  bit = (uint8_t) ( 1U << ( index % 8 ) );
+  if (unique) {
+    bsp_interrupt_handler_unique_table[ table_index ] |= bit;
+  } else {
+    bsp_interrupt_handler_unique_table[ table_index ] &= ~bit;
- * @brief Checks if a handler entry is empty.
+ * @brief Checks if the interrupt support is initialized.
+ * @return Returns true, if the interrupt support is initialized, otherwise
+ *   false.
-static inline bool bsp_interrupt_is_empty_handler_entry(
-  const rtems_interrupt_entry *entry
+static inline bool bsp_interrupt_is_initialized( void )
-  return entry->handler == bsp_interrupt_handler_empty;
+  return bsp_interrupt_is_handler_unique( BSP_INTERRUPT_HANDLER_TABLE_SIZE );
 #ifdef __cplusplus
diff --git a/bsps/m68k/genmcf548x/include/bsp/irq.h b/bsps/m68k/genmcf548x/include/bsp/irq.h
index 4c90c6ad0e..140868f022 100644
--- a/bsps/m68k/genmcf548x/include/bsp/irq.h
+++ b/bsps/m68k/genmcf548x/include/bsp/irq.h
@@ -99,4 +99,12 @@ static inline bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
     && vector < (rtems_vector_number) BSP_INTERRUPT_VECTOR_COUNT;
+void mcf548x_interrupt_vector_install(rtems_vector_number vector);
+void mcf548x_interrupt_vector_remove(rtems_vector_number vector);
+#define bsp_interrupt_vector_install(v) mcf548x_interrupt_vector_install(v)
+#define bsp_interrupt_vector_remove(v) mcf548x_interrupt_vector_remove(v)
 #endif /* LIBBSP_M68K_MCF548X_IRQ_H */
diff --git a/bsps/m68k/genmcf548x/irq/irq.c b/bsps/m68k/genmcf548x/irq/irq.c
index 9d483918e4..bcac012723 100644
--- a/bsps/m68k/genmcf548x/irq/irq.c
+++ b/bsps/m68k/genmcf548x/irq/irq.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013, 2021 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -20,14 +20,6 @@ void asm_default_interrupt(void);
 typedef void (*void_func)(void);
-typedef struct {
-  void *arg;
-  const char *info;
-} interrupt_control;
-static interrupt_control interrupt_controls[BSP_INTERRUPT_VECTOR_COUNT];
 static uint32_t vector_to_reg(rtems_vector_number vector)
   return ((vector + 32U) >> 5) & 0x1;
@@ -131,18 +123,6 @@ rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
   return RTEMS_SUCCESSFUL;
-static void_func get_exception_handler(rtems_vector_number vector)
-  void **vbr;
-  void_func *exception_table;
-  m68k_get_vbr(vbr);
-  exception_table = (void_func *)vbr;
-  return exception_table[vector_to_exception_vector(vector)];
 static void set_exception_handler(rtems_vector_number vector, void_func handler)
   void **vbr;
@@ -157,119 +137,19 @@ static void set_exception_handler(rtems_vector_number vector, void_func handler)
 static void dispatch_handler(rtems_vector_number exception_vector)
-  const interrupt_control *ic =
-    &interrupt_controls[exception_vector_to_vector(exception_vector)];
-  (*ic->handler)(ic->arg);
+  bsp_interrupt_handler_dispatch_unchecked(
+    exception_vector_to_vector(exception_vector)
-static uint8_t get_intc_icr(rtems_vector_number vector)
-  volatile uint8_t *icr = &MCF548X_INTC_ICR0;
-  return icr[vector];
+  _ISR_Vector_table[vector_to_exception_vector(vector)]
+    = dispatch_handler;
+  set_exception_handler(vector, _ISR_Handler);
-rtems_status_code rtems_interrupt_handler_install(
-  rtems_vector_number vector,
-  const char *info,
-  rtems_option options,
-  rtems_interrupt_handler handler,
-  void *arg
-  rtems_status_code sc = RTEMS_SUCCESSFUL;
-  if (bsp_interrupt_is_valid_vector(vector)) {
-    rtems_interrupt_level level;
-    rtems_interrupt_disable(level);
-    if (
-      get_exception_handler(vector) == asm_default_interrupt
-        && get_intc_icr(vector) != 0
-      interrupt_control *ic = &interrupt_controls[vector];
-      ic->handler = handler;
-      ic->arg = arg;
-      ic->info = info;
-      _ISR_Vector_table[vector_to_exception_vector(vector)]
-        = dispatch_handler;
-      set_exception_handler(vector, _ISR_Handler);
-      bsp_interrupt_vector_enable(vector);
-    } else {
-      sc = RTEMS_RESOURCE_IN_USE;
-    rtems_interrupt_enable(level);
-  } else {
-    sc = RTEMS_INVALID_ID;
-  return sc;
-static bool is_occupied_by_us(rtems_vector_number vector)
-  return get_exception_handler(vector) == _ISR_Handler
-    && _ISR_Vector_table[vector_to_exception_vector(vector)]
-      == dispatch_handler;
-rtems_status_code rtems_interrupt_handler_remove(
-  void *arg
-    if (
-      is_occupied_by_us(vector)
-        && ic->handler == handler
-        && ic->arg == arg
-      bsp_interrupt_vector_disable(vector);
-      set_exception_handler(vector, asm_default_interrupt);
-      memset(ic, 0, sizeof(*ic));
-    } else {
-      sc = RTEMS_UNSATISFIED;
-  } else {
-  return sc;
-rtems_status_code rtems_interrupt_handler_iterate(
-  rtems_interrupt_per_handler_routine routine,
-  void *arg
-    if (is_occupied_by_us(vector)) {
-      const interrupt_control *ic = &interrupt_controls[vector];
-      (*routine)(arg, ic->info, RTEMS_INTERRUPT_UNIQUE, ic->handler, ic->arg);
-  } else {
-  return sc;
+  set_exception_handler(vector, asm_default_interrupt);
diff --git a/bsps/shared/irq-default-sources.am b/bsps/shared/irq-default-sources.am
index c739be5f97..fb25c90ae5 100644
--- a/bsps/shared/irq-default-sources.am
+++ b/bsps/shared/irq-default-sources.am
@@ -3,8 +3,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-cause-clear.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-enable-disable.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-entry-remove.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-generic.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-install.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-iterate.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-remove.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-info.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-lock.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-server.c
diff --git a/bsps/shared/irq-sources.am b/bsps/shared/irq-sources.am
index fddb47599c..b0bdea3d3a 100644
--- a/bsps/shared/irq-sources.am
+++ b/bsps/shared/irq-sources.am
@@ -1,8 +1,11 @@
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-affinity.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-legacy.c
diff --git a/bsps/shared/irq/irq-entry-remove.c b/bsps/shared/irq/irq-entry-remove.c
new file mode 100644
index 0000000000..3e5fd33fbe
--- /dev/null
+++ b/bsps/shared/irq/irq-entry-remove.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup bsp_interrupt
+ * @brief This source file contains the implementation of
+ *   rtems_interrupt_entry_remove() and bsp_interrupt_entry_remove().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <bsp/irq-generic.h>
+  rtems_interrupt_entry *first;
+  rtems_interrupt_entry *entry_next;
+  first = bsp_interrupt_handler_table[ index ];
+  entry_next = entry->next;
+  if ( entry == first && entry_next == NULL ) {
+    /* We remove the last installed entry */
+    bsp_interrupt_vector_disable( vector );
+#if defined(bsp_interrupt_vector_remove)
+    bsp_interrupt_vector_remove( vector );
+#else
+#endif
+    bsp_interrupt_set_handler_unique( index, false );
+#if defined(BSP_INTERRUPT_USE_INDEX_TABLE)
+    bsp_interrupt_handler_index_table[ vector ] = 0;
+#endif
+  bsp_interrupt_entry_store_release( previous_next, entry_next );
+static rtems_status_code bsp_interrupt_entry_do_remove(
+  rtems_interrupt_entry  *installed;
+  rtems_interrupt_entry **previous_next;
+  installed = bsp_interrupt_entry_find(
+    vector,
+    entry->handler,
+    entry->arg,
+    &previous_next
+  if ( installed != entry ) {
+    return RTEMS_UNSATISFIED;
+  bsp_interrupt_entry_remove( vector, entry, previous_next );
+  return RTEMS_SUCCESSFUL;
+rtems_status_code rtems_interrupt_entry_remove(
+  rtems_status_code sc;
+  if ( entry == NULL ) {
+    return RTEMS_INVALID_ADDRESS;
+  sc = bsp_interrupt_check_and_lock( vector, entry->handler );
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    return sc;
+  sc = bsp_interrupt_entry_do_remove( vector, entry );
+  bsp_interrupt_unlock();
+  return sc;
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index df57c99ae3..eddb887d15 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2008, 2018 embedded brains GmbH (http://www.embedded-brains.de)
@@ -46,92 +46,75 @@
 #endif
-rtems_interrupt_entry bsp_interrupt_handler_table
-  [BSP_INTERRUPT_HANDLER_TABLE_SIZE];
+bsp_interrupt_handler_table[ BSP_INTERRUPT_HANDLER_TABLE_SIZE ];
 /* The last entry indicates if everything is initialized */
 uint8_t bsp_interrupt_handler_unique_table
   [ ( BSP_INTERRUPT_HANDLER_TABLE_SIZE + 7 + 1 ) / 8 ];
-  rtems_vector_number vector = (rtems_vector_number) (uintptr_t) arg;
-  bsp_interrupt_handler_default( vector );
-#ifdef RTEMS_SMP
-  static void bsp_interrupt_handler_do_nothing(void *arg)
-    (void) arg;
-#endif
-static inline void bsp_interrupt_set_handler_unique(
-  rtems_vector_number index,
-  bool unique
-  rtems_vector_number i = index / 8;
-  rtems_vector_number s = index % 8;
-  if (unique) {
-    bsp_interrupt_handler_unique_table [i] |= (uint8_t) (0x1U << s);
-  } else {
-    bsp_interrupt_handler_unique_table [i] &= (uint8_t) ~(0x1U << s);
 static inline void bsp_interrupt_set_initialized(void)
   bsp_interrupt_set_handler_unique(BSP_INTERRUPT_HANDLER_TABLE_SIZE, true);
-static inline void bsp_interrupt_clear_handler_entry(
-  rtems_interrupt_entry *e,
+static inline rtems_vector_number bsp_interrupt_allocate_handler_index(
-  e->handler = bsp_interrupt_handler_empty;
-  bsp_interrupt_fence(ATOMIC_ORDER_RELEASE);
-  e->arg = (void *) (uintptr_t) vector;
-  e->info = NULL;
-  e->next = NULL;
+  rtems_vector_number i;
-static inline bool bsp_interrupt_allocate_handler_index(
-  rtems_vector_number *index
-  #ifdef BSP_INTERRUPT_USE_INDEX_TABLE
-    rtems_vector_number i = 0;
-    /* The first entry will remain empty */
-    for (i = 1; i < BSP_INTERRUPT_HANDLER_TABLE_SIZE; ++i) {
-      const rtems_interrupt_entry *e = &bsp_interrupt_handler_table [i];
-      if (bsp_interrupt_is_empty_handler_entry(e)) {
-        *index = i;
-        return true;
+  /* The first entry will remain empty */
+  for ( i = 1; i < BSP_INTERRUPT_HANDLER_TABLE_SIZE; ++i ) {
+    if (  bsp_interrupt_handler_table[ i ] == NULL ) {
+      break;
+  return i;
+#endif
+RTEMS_STATIC_ASSERT(
+  sizeof( Atomic_Uintptr ) == sizeof( rtems_interrupt_entry * ),
+  rtems_interrupt_entry_pointer_size
-    return false;
-  #else
-    *index = bsp_interrupt_handler_index(vector);
-    return true;
-  #endif
+  Atomic_Uintptr        *ptr;
+   * In order to get the last written pointer value to the first entry, we have
+   * to carry out an atomic read-modify-write operation.
+  ptr = (Atomic_Uintptr *) &bsp_interrupt_handler_table[
+    bsp_interrupt_handler_index( vector )
+  first = (rtems_interrupt_entry *)
+    _Atomic_Fetch_add_uintptr( ptr, 0, ATOMIC_ORDER_ACQUIRE );
+  if ( first == NULL ) {
+  } else {
+    bsp_interrupt_dispatch_entries( first );
+#endif
   if ( !bsp_interrupt_is_initialized() ) {
     return RTEMS_INCORRECT_STATE;
-  if ( handler == NULL ) {
+  if ( routine == NULL ) {
@@ -148,317 +131,160 @@ rtems_status_code bsp_interrupt_check_and_lock(
-void bsp_interrupt_initialize(void)
+  void                    *arg,
-  size_t i = 0;
+  rtems_interrupt_entry *entry;
-  /* Initialize handler table */
-  for (i = 0; i < BSP_INTERRUPT_HANDLER_TABLE_SIZE; ++i) {
-    bsp_interrupt_handler_table [i].handler = bsp_interrupt_handler_empty;
-    bsp_interrupt_handler_table [i].arg = (void *) i;
+  bsp_interrupt_assert( bsp_interrupt_is_valid_vector( vector ) );
+  *previous_next = &bsp_interrupt_handler_table[ index ];
+  entry = bsp_interrupt_handler_table[ index ];
+  while ( entry != NULL ) {
+    if ( entry->handler == routine && entry->arg == arg ) {
+      return entry;
+    *previous_next = &entry->next;
+    entry = entry->next;
+  return NULL;
+void bsp_interrupt_initialize( void )
   sc = bsp_interrupt_facility_initialize();
-  if (sc != RTEMS_SUCCESSFUL) {
-    bsp_fatal(BSP_FATAL_INTERRUPT_INITIALIZATION);
+    bsp_fatal( BSP_FATAL_INTERRUPT_INITIALIZATION );
   bsp_interrupt_set_initialized();
- * @brief Installs an interrupt handler.
- * @ingroup bsp_interrupt
- * @return In addition to the standard status codes this function returns:
- * - If the BSP interrupt support is not initialized RTEMS_INTERNAL_ERROR will
- * be returned.
- * - If not enough memory for a new handler is available RTEMS_NO_MEMORY will
- * be returned
- * @see rtems_interrupt_handler_install()
-static rtems_status_code bsp_interrupt_handler_install(
-  const char *info,
-  void *arg
+static rtems_status_code bsp_interrupt_entry_install_first(
+  rtems_option              options,
-  rtems_status_code sc;
-  rtems_vector_number index = 0;
-  rtems_interrupt_entry *head = NULL;
-  bool enable_vector = false;
-  bool replace = RTEMS_INTERRUPT_IS_REPLACE(options);
-  sc = bsp_interrupt_check_and_lock( vector, handler );
+#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
+  index = bsp_interrupt_allocate_handler_index( vector );
-  if ( sc != RTEMS_SUCCESSFUL ) {
-    return sc;
+  if ( index == BSP_INTERRUPT_HANDLER_TABLE_SIZE ) {
+    /* Handler table is full */
+    return RTEMS_NO_MEMORY;
+#else
+  index = vector;
+#endif
-  /* Get handler table index */
+  bsp_interrupt_handler_index_table[ vector ] = index;
+#endif
+    &bsp_interrupt_handler_table[ index ],
+    entry
+    index,
+    RTEMS_INTERRUPT_IS_UNIQUE( options )
+#if defined(bsp_interrupt_vector_install)
+  bsp_interrupt_vector_install( vector );
+#else
+  bsp_interrupt_vector_enable( vector );
+#endif
-  /* Get head entry of the handler list for current vector */
-  head = &bsp_interrupt_handler_table [index];
-  if (bsp_interrupt_is_empty_handler_entry(head)) {
-    if (replace) {
-      /* No handler to replace exists */
-      bsp_interrupt_unlock();
-      return RTEMS_UNSATISFIED;
+static rtems_status_code bsp_interrupt_entry_install(
+  rtems_interrupt_entry  *other;
-     * No real handler installed yet.  So allocate a new index in
-     * the handler table and fill the entry with life.
-    if (bsp_interrupt_allocate_handler_index(vector, &index)) {
-      bsp_interrupt_disable(level);
-      bsp_interrupt_handler_table [index].arg = arg;
-      bsp_interrupt_handler_table [index].handler = handler;
-        bsp_interrupt_handler_index_table [vector] = index;
-      #endif
-      bsp_interrupt_enable(level);
-      bsp_interrupt_handler_table [index].info = info;
-    } else {
-      /* Handler table is full */
-      return RTEMS_NO_MEMORY;
+  if ( RTEMS_INTERRUPT_IS_REPLACE( options ) ) {
+    return RTEMS_INVALID_NUMBER;
-    /* This is the first handler so enable the vector later */
-    enable_vector = true;
-  } else {
-    rtems_interrupt_entry *current = head;
-    rtems_interrupt_entry *tail = NULL;
-    rtems_interrupt_entry *match = NULL;
-    /* Ensure that a unique handler remains unique */
-    if (
-      !replace
-        && (RTEMS_INTERRUPT_IS_UNIQUE(options)
-          || bsp_interrupt_is_handler_unique(index))
-       * Tried to install a unique handler on a not empty
-       * list or there is already a unique handler installed.
-      return RTEMS_RESOURCE_IN_USE;
+    return bsp_interrupt_entry_install_first( vector, options, entry );
+  if ( RTEMS_INTERRUPT_IS_UNIQUE( options ) ) {
+    /* Cannot install a unique entry if there is already an entry installed */
+    return RTEMS_RESOURCE_IN_USE;
+  if ( bsp_interrupt_is_handler_unique( index ) ) {
-     * Search for the list tail and check if the handler is already
+     * Cannot install another entry if there is already an unique entry
      * installed.
-    do {
-      if (
-        match == NULL
-          && (current->handler == handler || replace)
-          && current->arg == arg
-        match = current;
-      tail = current;
-      current = current->next;
-    } while (current != NULL);
-    if (replace) {
-      /* Ensure that a handler to replace exists */
-      if (match == NULL) {
-      /* Use existing entry */
-      current = match;
-    } else {
-      /* Ensure the handler is not already installed */
-      if (match != NULL) {
-        /* The handler is already installed */
-        return RTEMS_TOO_MANY;
-      /* Allocate a new entry */
-      current = rtems_malloc(sizeof(*current));
-      if (current == NULL) {
-        /* Not enough memory */
-    /* Update existing entry or set new entry */
-    current->handler = handler;
-    current->info = info;
-    if (!replace) {
-      /* Set new entry */
-      current->arg = arg;
-      current->next = NULL;
-      /* Link to list tail */
-      tail->next = current;
-  /* Make the handler unique if necessary */
-  bsp_interrupt_set_handler_unique(index, RTEMS_INTERRUPT_IS_UNIQUE(options));
+  other = bsp_interrupt_entry_find(
+    vector,
+    entry->handler,
+    entry->arg,
+    &previous_next
-  /* Enable the vector if necessary */
-  if (enable_vector) {
+  if ( other != NULL ) {
+     * Cannot install an entry which has the same routine and argument as an
+     * already installed entry.
+    return RTEMS_TOO_MANY;
-  /* Unlock */
+  bsp_interrupt_entry_store_release( previous_next, entry );
- * @brief Removes an interrupt handler.
- * RTEMS_INTERNAL_ERROR if the BSP interrupt support is not initialized.
- * @see rtems_interrupt_handler_remove().
-static rtems_status_code bsp_interrupt_handler_remove(
-  void *arg
+rtems_status_code rtems_interrupt_entry_install(
-  rtems_interrupt_entry *current = NULL;
-  rtems_interrupt_entry *previous = NULL;
-    return sc;
-  /* Search for a matching entry */
-  current = head;
-  do {
-    if (current->handler == handler && current->arg == arg) {
-      match = current;
-      break;
-    previous = current;
-  /* Remove the matching entry */
-    if (match->next != NULL) {
-       * The match has a successor.  A successor is always
-       * allocated.  So replace the match with its successor
-       * and free the successor entry.
-      current = match->next;
-      #ifdef RTEMS_SMP
-        match->handler = bsp_interrupt_handler_do_nothing;
-      #endif
-      match->arg = current->arg;
-      match->handler = current->handler;
-      match->info = current->info;
-      match->next = current->next;
-      free(current);
-    } else if (match == head) {
-       * The match is the list head and has no successor.
-       * The list head is stored in a static table so clear
-       * this entry.  Since now the list is empty disable the
-       * vector.
-      /* Disable the vector */
-      /* Clear entry */
-      bsp_interrupt_clear_handler_entry(head, vector);
-        bsp_interrupt_handler_index_table [vector] = 0;
-      #endif
-      /* Allow shared handlers */
-      bsp_interrupt_set_handler_unique(index, false);
-    } else {
-       * The match is the list tail and has a predecessor.
-       * So terminate the predecessor and free the match.
-      previous->next = NULL;
-      free(match);
-  } else {
-    /* No matching entry found */
+    return sc;
-  /* Unlock */
+  sc = bsp_interrupt_entry_install( vector, options, entry );
-  return RTEMS_SUCCESSFUL;
-  const char *info,
-  void *arg
-  return bsp_interrupt_handler_install(vector, info, options, handler, arg);
-  void *arg
-  return bsp_interrupt_handler_remove(vector, handler, arg);
+  return sc;
diff --git a/bsps/shared/irq/irq-handler-install.c b/bsps/shared/irq/irq-handler-install.c
index 0000000000..2474d792e6
--- /dev/null
+++ b/bsps/shared/irq/irq-handler-install.c
@@ -0,0 +1,114 @@
+ * @file
+ * @brief This source file contains the rtems_interrupt_handler_install()
+ *   implementation.
+ * are met:
+#include <rtems/malloc.h>
+#include <stdlib.h>
+static rtems_status_code bsp_interrupt_handler_do_replace(
+  const char             *info,
+  void                   *arg
+  rtems_interrupt_entry **unused;
+  entry = bsp_interrupt_entry_find( vector, routine, arg, &unused );
+  entry->handler = routine;
+  entry->info = info;
+static rtems_status_code bsp_interrupt_handler_replace(
+  const char             *info,
+  void                   *arg
+  sc = bsp_interrupt_check_and_lock( vector, routine );
+    return sc;
+  sc = bsp_interrupt_handler_do_replace( vector, info, routine, arg );
+  return sc;
+rtems_status_code rtems_interrupt_handler_install(
+  const char             *info,
+  void                   *arg
+    return bsp_interrupt_handler_replace( vector, info, routine, arg );
+  entry = rtems_malloc( sizeof( *entry ) );
+  rtems_interrupt_entry_initialize( entry, routine, arg, info );
+  sc = rtems_interrupt_entry_install( vector, options, entry );
+    free( entry );
+  return sc;
diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
index 385cb8db2d..8bb29191fd 100644
--- a/bsps/shared/irq/irq-handler-iterate.c
+++ b/bsps/shared/irq/irq-handler-iterate.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2017 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2017, 2021 embedded brains GmbH (http://www.embedded-brains.de)
@@ -45,7 +45,7 @@ rtems_status_code rtems_interrupt_handler_iterate(
   rtems_option           options;
-  rtems_interrupt_entry *current;
     vector,
@@ -56,15 +56,14 @@ rtems_status_code rtems_interrupt_handler_iterate(
     return sc;
-  current = &bsp_interrupt_handler_table [index];
-  if (!bsp_interrupt_is_empty_handler_entry(current)) {
-    do {
-      options = bsp_interrupt_is_handler_unique(index) ?
-        RTEMS_INTERRUPT_UNIQUE : RTEMS_INTERRUPT_SHARED;
-      routine(arg, current->info, options, current->handler, current->arg);
+  options = bsp_interrupt_is_handler_unique( index ) ?
+    RTEMS_INTERRUPT_UNIQUE : RTEMS_INTERRUPT_SHARED;
+    ( *routine )( arg, entry->info, options, entry->handler, entry->arg );
diff --git a/bsps/shared/irq/irq-handler-remove.c b/bsps/shared/irq/irq-handler-remove.c
index 0000000000..cb32ba3b7c
--- /dev/null
+++ b/bsps/shared/irq/irq-handler-remove.c
@@ -0,0 +1,80 @@
+ * @file
+ *   rtems_interrupt_handler_remove().
+ * are met:
+static rtems_status_code bsp_interrupt_handler_do_remove(
+  void                   *arg
+  entry = bsp_interrupt_entry_find( vector, routine, arg, &previous_next );
+  free( entry );
+rtems_status_code rtems_interrupt_handler_remove(
+  void                   *arg
+    return sc;
+  sc = bsp_interrupt_handler_do_remove( vector, routine, arg );
+  return sc;
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
index 2c8c75f6d6..0ee5eafedf 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
+++ b/c/src/lib/libbsp/m68k/genmcf548x/Makefile.am
@@ -38,16 +38,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/console/console.
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/btimer/btimer.c
 # IRQ
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-affinity.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-cause-clear.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-enable-disable.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-handler-iterate.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-info.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-legacy.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-lock.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-server.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-shell.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/irq/irq.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/irq/intc-icr-init-values.c
@@ -59,5 +50,6 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/mcdma/MCD_tasksI
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/mcdma/mcdma_glue.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/genmcf548x/start/cache.c
+include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
 include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
 include $(srcdir)/../../../../../../bsps/m68k/genmcf548x/headers.am
diff --git a/c/src/lib/libbsp/powerpc/ss555/Makefile.am b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
index ec16b492ee..ca25aa1d65 100644
--- a/c/src/lib/libbsp/powerpc/ss555/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/ss555/Makefile.am
@@ -51,8 +51,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-cause-clear.c
diff --git a/spec/build/bsps/m68k/genmcf548x/grp.yml b/spec/build/bsps/m68k/genmcf548x/grp.yml
index 0a3a463513..57bdb23566 100644
--- a/spec/build/bsps/m68k/genmcf548x/grp.yml
+++ b/spec/build/bsps/m68k/genmcf548x/grp.yml
@@ -27,6 +27,8 @@ links:
   uid: ../grp
 - role: build-dependency
   uid: ../../obj
+- role: build-dependency
+  uid: ../../objirq
   uid: ../../optconsolebaud
diff --git a/spec/build/bsps/m68k/genmcf548x/obj.yml b/spec/build/bsps/m68k/genmcf548x/obj.yml
index 07e3760ad9..e65e0c8934 100644
--- a/spec/build/bsps/m68k/genmcf548x/obj.yml
+++ b/spec/build/bsps/m68k/genmcf548x/obj.yml
@@ -38,16 +38,7 @@ source:
 - bsps/m68k/shared/m68kidle.c
 - bsps/m68k/shared/memProbe.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
-- bsps/shared/irq/irq-affinity.c
-- bsps/shared/irq/irq-cause-clear.c
 - bsps/shared/irq/irq-default-handler.c
-- bsps/shared/irq/irq-enable-disable.c
-- bsps/shared/irq/irq-handler-iterate.c
-- bsps/shared/irq/irq-info.c
-- bsps/shared/irq/irq-legacy.c
-- bsps/shared/irq/irq-lock.c
-- bsps/shared/irq/irq-server.c
-- bsps/shared/irq/irq-shell.c
 - bsps/shared/start/bspfatal-default.c
 - bsps/shared/start/bspgetworkarea-default.c
 - bsps/shared/start/bspreset-loop.c
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index 4dda48d465..46afb79b08 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -13,8 +13,11 @@ source:
+- bsps/shared/irq/irq-entry-remove.c
 - bsps/shared/irq/irq-generic.c
+- bsps/shared/irq/irq-handler-install.c
+- bsps/shared/irq/irq-handler-remove.c
diff --git a/spec/build/bsps/powerpc/ss555/bspss555.yml b/spec/build/bsps/powerpc/ss555/bspss555.yml
index a3bc8a6226..3257706a3f 100644
--- a/spec/build/bsps/powerpc/ss555/bspss555.yml
+++ b/spec/build/bsps/powerpc/ss555/bspss555.yml
@@ -72,8 +72,11 @@ source:
 - bsps/shared/irq/irq-default.c
2.26.2
