[PATCH 24/41] bsps/irq: Move bsp_interrupt_handler_is_empty()
Sebastian Huber
Mon Jul 12 12:49:46 UTC 2021
This function is only used by one BSP.
Update #3269.
bsps/i386/shared/irq/irq.c | 11 +++++++++++
bsps/include/bsp/irq-generic.h | 11 -----------
bsps/shared/irq/irq-generic.c | 19 -------------------
3 files changed, 11 insertions(+), 30 deletions(-)
diff --git a/bsps/i386/shared/irq/irq.c b/bsps/i386/shared/irq/irq.c
index 9aab9d27f2..d0004698e7 100644
--- a/bsps/i386/shared/irq/irq.c
+++ b/bsps/i386/shared/irq/irq.c
@@ -351,6 +351,17 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
return RTEMS_SUCCESSFUL;
+static bool bsp_interrupt_handler_is_empty(rtems_vector_number vector)
+ rtems_vector_number index;
+ rtems_interrupt_entry *head;
+ index = bsp_interrupt_handler_index(vector);
+ head = &bsp_interrupt_handler_table[index];
+ return bsp_interrupt_is_empty_handler_entry(head);
* Global so the asm handler can call it.
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 9babc4cfb5..3b2998f533 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -415,17 +415,6 @@ static inline void bsp_interrupt_handler_dispatch( rtems_vector_number vector )
- * @brief Is interrupt handler empty.
- * This routine returns true if the handler is empty and has not been
- * initialised else false is returned. The interrupt lock is not used
- * so this call can be used from within interrupts.
- * @return If empty true shall be returned else false is returned.
-bool bsp_interrupt_handler_is_empty(rtems_vector_number vector);
/* For internal use only */
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index 59963182ab..df57c99ae3 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -462,22 +462,3 @@ rtems_status_code rtems_interrupt_handler_remove(
return bsp_interrupt_handler_remove(vector, handler, arg);
- rtems_vector_number index = 0;
- rtems_interrupt_entry *head = NULL;
- bool empty;
- /* For use in interrupts so no lock. */
- /* Get handler table index */
- index = bsp_interrupt_handler_index(vector);
- /* Get head entry of the handler list for the vector */
- head = &bsp_interrupt_handler_table [index];
- empty = bsp_interrupt_is_empty_handler_entry(head);
- return empty;
2.26.2
