[PATCH 22/41] bsps/irq: Use rtems_interrupt_entry
Sebastian Huber
Mon Jul 12 12:49:44 UTC 2021
Update #3269.
bsps/include/bsp/irq-generic.h | 15 +++------------
bsps/shared/irq/irq-generic.c | 24 ++++++++++++------------
bsps/shared/irq/irq-handler-iterate.c | 2 +-
3 files changed, 16 insertions(+), 25 deletions(-)
diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
index 68332d20b9..b553ac30bf 100644
--- a/bsps/include/bsp/irq-generic.h
+++ b/bsps/include/bsp/irq-generic.h
@@ -83,16 +83,7 @@ extern "C" {
#define bsp_interrupt_assert(e) _Assert(e)
-struct bsp_interrupt_handler_entry {
- rtems_interrupt_handler handler;
- void *arg;
- const char *info;
- struct bsp_interrupt_handler_entry *next;
-typedef struct bsp_interrupt_handler_entry bsp_interrupt_handler_entry;
-extern bsp_interrupt_handler_entry bsp_interrupt_handler_table [];
+extern rtems_interrupt_entry bsp_interrupt_handler_table [];
#ifdef BSP_INTERRUPT_USE_INDEX_TABLE
#if BSP_INTERRUPT_HANDLER_TABLE_SIZE < 0x100
@@ -386,7 +377,7 @@ static inline void bsp_interrupt_handler_dispatch_unchecked(
rtems_vector_number vector
- const bsp_interrupt_handler_entry *e;
+ const rtems_interrupt_entry *e;
e = &bsp_interrupt_handler_table[ bsp_interrupt_handler_index( vector ) ];
@@ -494,7 +485,7 @@ void bsp_interrupt_handler_empty( void *arg );
* @brief Checks if a handler entry is empty.
static inline bool bsp_interrupt_is_empty_handler_entry(
- const bsp_interrupt_handler_entry *entry
+ const rtems_interrupt_entry *entry
return entry->handler == bsp_interrupt_handler_empty;
diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
index 81da647228..a7e8c1163f 100644
--- a/bsps/shared/irq/irq-generic.c
+++ b/bsps/shared/irq/irq-generic.c
@@ -46,7 +46,7 @@
[BSP_INTERRUPT_VECTOR_COUNT];
#endif
-bsp_interrupt_handler_entry bsp_interrupt_handler_table
+rtems_interrupt_entry bsp_interrupt_handler_table
[BSP_INTERRUPT_HANDLER_TABLE_SIZE];
/* The last entry indicates if everything is initialized */
@@ -87,7 +87,7 @@ static inline void bsp_interrupt_set_initialized(void)
static inline void bsp_interrupt_clear_handler_entry(
- bsp_interrupt_handler_entry *e,
+ rtems_interrupt_entry *e,
@@ -108,7 +108,7 @@ static inline bool bsp_interrupt_allocate_handler_index(
/* The first entry will remain empty */
for (i = 1; i < BSP_INTERRUPT_HANDLER_TABLE_SIZE; ++i) {
- const bsp_interrupt_handler_entry *e = &bsp_interrupt_handler_table [i];
+ const rtems_interrupt_entry *e = &bsp_interrupt_handler_table [i];
if (bsp_interrupt_is_empty_handler_entry(e)) {
*index = i;
return true;
@@ -164,7 +164,7 @@ static rtems_status_code bsp_interrupt_handler_install(
rtems_interrupt_level level;
rtems_vector_number index = 0;
- bsp_interrupt_handler_entry *head = NULL;
+ rtems_interrupt_entry *head = NULL;
bool enable_vector = false;
bool replace = RTEMS_INTERRUPT_IS_REPLACE(options);
@@ -218,9 +218,9 @@ static rtems_status_code bsp_interrupt_handler_install(
/* This is the first handler so enable the vector later */
enable_vector = true;
} else {
- bsp_interrupt_handler_entry *current = head;
- bsp_interrupt_handler_entry *tail = NULL;
- bsp_interrupt_handler_entry *match = NULL;
+ rtems_interrupt_entry *current = head;
+ rtems_interrupt_entry *tail = NULL;
+ rtems_interrupt_entry *match = NULL;
/* Ensure that a unique handler remains unique */
if (
@@ -327,10 +327,10 @@ static rtems_status_code bsp_interrupt_handler_remove(
- bsp_interrupt_handler_entry *current = NULL;
- bsp_interrupt_handler_entry *previous = NULL;
+ rtems_interrupt_entry *current = NULL;
+ rtems_interrupt_entry *previous = NULL;
/* Check parameters and system state */
if (!bsp_interrupt_is_initialized()) {
@@ -454,7 +454,7 @@ rtems_status_code rtems_interrupt_handler_remove(
bool bsp_interrupt_handler_is_empty(rtems_vector_number vector)
bool empty;
/* For use in interrupts so no lock. */
diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
index 8adbdb4679..3c642b075e 100644
--- a/bsps/shared/irq/irq-handler-iterate.c
+++ b/bsps/shared/irq/irq-handler-iterate.c
@@ -52,7 +52,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
void *arg
rtems_option options = 0;
2.26.2
