[PATCH 21/41] rtems: Add rtems_interrupt_entry_install()
Wed Jul 21 18:36:24 UTC 2021
On Mon, Jul 12, 2021 at 6:51 AM Sebastian Huber
> Add RTEMS_INTERRUPT_ENTRY_INITIALIZER(),
> rtems_interrupt_entry_initialize(), and
> rtems_interrupt_entry_remove().  This allows to install interrupt
> handlers using user-provides storage as an alternative to
nit: user-provided
> rtems_interrupt_handler_install() which has to allocate memory.
> Update #3269.
>  cpukit/include/rtems/irq-extension.h | 237 +++++++++++++++++++++++++++
>  1 file changed, 237 insertions(+)
> diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
> index c96dfd7d5c..c012a26452 100644
> --- a/cpukit/include/rtems/irq-extension.h
> +++ b/cpukit/include/rtems/irq-extension.h
> @@ -166,6 +166,243 @@ typedef void ( *rtems_interrupt_per_handler_routine )(
>  #define RTEMS_INTERRUPT_IS_REPLACE( _options ) \
>    ( ( _options ) & RTEMS_INTERRUPT_REPLACE )
> +/* Generated from spec:/rtems/intr/if/entry */
> + * @ingroup RTEMSAPIClassicIntr
> + * @brief This structure represents an interrupt entry.
> + * @par Notes
> + * This structure shall be treated as an opaque data type from the API point of
> + * view.  Members shall not be accessed directly.  An entry may be initialized
> + * by RTEMS_INTERRUPT_ENTRY_INITIALIZER() or
> + * rtems_interrupt_entry_initialize().  It may be installed for an interrupt
> + * vector with rtems_interrupt_entry_install() and removed from an interrupt
> + * vector by rtems_interrupt_entry_remove().
> +typedef struct rtems_interrupt_entry {
> +   * @brief This member is the interrupt handler routine.
> +  rtems_interrupt_handler handler;
> +   * @brief This member is the interrupt handler argument.
> +  void *arg;
> +   * @brief This member is the reference to the next entry or NULL.
> +  struct rtems_interrupt_entry *next;
> +   * @brief This member is the descriptive information of the entry
nit: missing period
> +  const char *info;
> +} rtems_interrupt_entry;
> +/* Generated from spec:/rtems/intr/if/entry-initializer */
> + * @brief Statically initializes an interrupt entry object.
> + * @param _routine is the interrupt handler routine for the entry.
> + * @param _arg is the interrupt handler argument for the entry.
> + * @param _info is the descriptive information for the entry.
> + * @par Notes
> + * Alternatively, rtems_interrupt_entry_initialize() may be used to dynamically
> + * initialize an interrupt entry.
> +#define RTEMS_INTERRUPT_ENTRY_INITIALIZER( _routine, _arg, _info ) \
> +  { _routine,  _arg, NULL, _info }
> +/* Generated from spec:/rtems/intr/if/entry-initialize */
> + * @brief Initializes the interrupt entry.
> + * @param[out] entry is the interrupt entry to initialize.
> + * @param routine is the interrupt handler routine for the entry.
> + * @param arg is the interrupt handler argument for the entry.
> + * @param info is the descriptive information for the entry.
> + * @par Notes
> + * Alternatively, RTEMS_INTERRUPT_ENTRY_INITIALIZER() may be used to statically
> + * @par Constraints
> + * @parblock
> + * The following constraints apply to this directive:
> + * * The directive may be called from within any runtime context.
> + * * The directive will not cause the calling task to be preempted.
> + * @endparblock
> +static inline void rtems_interrupt_entry_initialize(
> +  rtems_interrupt_entry  *entry,
> +  rtems_interrupt_handler routine,
> +  void                   *arg,
> +  const char             *info
> +  entry->handler = routine;
> +  entry->arg = arg;
> +  entry->next = NULL;
> +  entry->info = info;
> +/* Generated from spec:/rtems/intr/if/entry-install */
> + * @brief Installs the interrupt entry at the interrupt vector.
> + * @param vector is the interrupt vector number.
> + * @param options is the interrupt entry install option set.
> + * @param entry is the interrupt entry to install
missing period
> + * One of the following mutually exclusive options
> + * * #RTEMS_INTERRUPT_UNIQUE, and
> + * * #RTEMS_INTERRUPT_SHARED
> + * shall be set in the ``options`` parameter.
> + * The handler routine of the entry specified by ``entry`` will be called with
> + * the handler argument of the entry when dispatched.  The order in which
> + * shared interrupt handlers are dispatched for one vector is defined by the
> + * installation order.  The first installed handler is dispatched first.
> + * If the option #RTEMS_INTERRUPT_UNIQUE is set, then it will be ensured that
> + * the handler will be the only one for the interrupt vector.
> + * If the option #RTEMS_INTERRUPT_SHARED is set, then multiple handler may be
s/handler/handlers
> + * installed for the interrupt vector.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``entry`` parameter was NULL.
> + * @retval ::RTEMS_INCORRECT_STATE The service was not initialized.
> + * @retval ::RTEMS_INVALID_ADDRESS The handler routine of the entry was NULL.
> + * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
> + *   number specified by ``vector``.
> + * @retval ::RTEMS_CALLED_FROM_ISR The directive was called from within
> + *   interrupt context.
> + * @retval ::RTEMS_INVALID_NUMBER An option specified by ``options`` was not
> + *   applicable.
> + * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_UNIQUE option was set
> + *   in ``entry`` and the interrupt vector was already occupied by a handler.
> + * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_SHARED option was set
> + *   in ``entry`` and the interrupt vector was already occupied by a unique
> + *   handler.
> + * @retval ::RTEMS_TOO_MANY The handler routine of the entry specified by
> + *   ``entry`` was already installed for the interrupt vector specified by
> + *   ``vector`` with an argument equal to the handler argument of the entry.
> + * @par Notes
> + * When the directive call was successful, the ownership of the interrupt entry
> + * has been transferred from the caller to the interrupt service.  An installed
> + * interrupt entry may be removed from the interrupt service by calling
> + * rtems_interrupt_entry_remove().
> + * @parblock
> + * * The directive may be called from within device driver initialization
> + *   context.
> + * * The directive may be called from within task context.
> + * * The directive may obtain and release the object allocator mutex.  This may
> + *   cause the calling task to be preempted.
> + * * The interrupt entry shall have been initialized by
> + *   rtems_interrupt_entry_initialize() or RTEMS_INTERRUPT_ENTRY_INITIALIZER().
> + * @endparblock
> +rtems_status_code rtems_interrupt_entry_install(
> +  rtems_vector_number    vector,
> +  rtems_option           options,
> +/* Generated from spec:/rtems/intr/if/entry-remove */
> + * @brief Removes the interrupt entry from the interrupt vector.
> + * @param entry is the interrupt entry to remove.
> + * @retval ::RTEMS_UNSATISFIED The entry specified by ``entry`` was not
> + *   installed at the interrupt vector specified by ``vector``.
> + * @par Notes
> + * has been transferred from the interrupt service to the caller.
> + * @parblock
> + *   context.
> + * * The interrupt entry shall have been installed by
> + *   rtems_interrupt_entry_install().
> + * @endparblock
> +rtems_status_code rtems_interrupt_entry_remove(
>  /* Generated from spec:/rtems/intr/if/handler-install */
> 2.26.2
> devel mailing list
> devel at rtems.org
