[PATCH 30/41] validation: Test rtems_interrupt_get_attributes()
Sebastian Huber
Mon Jul 12 12:49:52 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
.../validation/tc-intr-get-attributes.c | 445 ++++++++++++++++++
2 files changed, 446 insertions(+)
create mode 100644 testsuites/validation/tc-intr-get-attributes.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 653872320c..4e8ecfe1a0 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -15,6 +15,7 @@ source:
- testsuites/validation/tc-barrier-delete.c
- testsuites/validation/tc-barrier-release.c
- testsuites/validation/tc-barrier-wait.c
+- testsuites/validation/tc-intr-get-attributes.c
- testsuites/validation/tc-message-construct-errors.c
- testsuites/validation/tc-object.c
- testsuites/validation/tc-signal-catch.c
diff --git a/testsuites/validation/tc-intr-get-attributes.c b/testsuites/validation/tc-intr-get-attributes.c
new file mode 100644
index 0000000000..f5ce962b2b
--- /dev/null
+++ b/testsuites/validation/tc-intr-get-attributes.c
@@ -0,0 +1,445 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqGetAttributes
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqGetAttributes \
+ * spec:/rtems/intr/req/get-attributes
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqGetAttributes_Pre_Vector_Valid,
+ RtemsIntrReqGetAttributes_Pre_Vector_Invalid,
+ RtemsIntrReqGetAttributes_Pre_Vector_NA
+} RtemsIntrReqGetAttributes_Pre_Vector;
+typedef enum {
+ RtemsIntrReqGetAttributes_Pre_Attributes_Obj,
+ RtemsIntrReqGetAttributes_Pre_Attributes_Null,
+ RtemsIntrReqGetAttributes_Pre_Attributes_NA
+} RtemsIntrReqGetAttributes_Pre_Attributes;
+typedef enum {
+ RtemsIntrReqGetAttributes_Post_Status_Ok,
+ RtemsIntrReqGetAttributes_Post_Status_InvAddr,
+ RtemsIntrReqGetAttributes_Post_Status_InvId,
+ RtemsIntrReqGetAttributes_Post_Status_NA
+} RtemsIntrReqGetAttributes_Post_Status;
+typedef enum {
+ RtemsIntrReqGetAttributes_Post_Attributes_Nop,
+ RtemsIntrReqGetAttributes_Post_Attributes_Zero,
+ RtemsIntrReqGetAttributes_Post_Attributes_Set,
+ RtemsIntrReqGetAttributes_Post_Attributes_NA
+} RtemsIntrReqGetAttributes_Post_Attributes;
+ * @brief Test context for spec:/rtems/intr/req/get-attributes test case.
+typedef struct {
+ * @brief This member provides the rtems_interrupt_attributes object.
+ rtems_interrupt_attributes attributes_obj;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member specifies if the ``attributes`` parameter value.
+ rtems_interrupt_attributes *attributes;;
+ * @brief This member contains the return value of the
+ * rtems_interrupt_get_attributes() call.
+ rtems_status_code status;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 2 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqGetAttributes_Context;
+static RtemsIntrReqGetAttributes_Context
+ RtemsIntrReqGetAttributes_Instance;
+static const char * const RtemsIntrReqGetAttributes_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqGetAttributes_PreDesc_Attributes[] = {
+ "Obj",
+ "Null",
+ "NA"
+static const char * const * const RtemsIntrReqGetAttributes_PreDesc[] = {
+ RtemsIntrReqGetAttributes_PreDesc_Vector,
+ RtemsIntrReqGetAttributes_PreDesc_Attributes,
+ NULL
+static void RtemsIntrReqGetAttributes_Pre_Vector_Prepare(
+ RtemsIntrReqGetAttributes_Context *ctx,
+ RtemsIntrReqGetAttributes_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqGetAttributes_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqGetAttributes_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqGetAttributes_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqGetAttributes_Pre_Attributes_Prepare(
+ RtemsIntrReqGetAttributes_Pre_Attributes state
+ case RtemsIntrReqGetAttributes_Pre_Attributes_Obj: {
+ * While the ``attributes`` parameter references an object of type
+ * rtems_interrupt_attributes.
+ ctx->attributes = &ctx->attributes_obj;
+ break;
+ case RtemsIntrReqGetAttributes_Pre_Attributes_Null: {
+ * While the ``attributes`` parameter is equal to NULL.
+ ctx->attributes = NULL;
+ break;
+ case RtemsIntrReqGetAttributes_Pre_Attributes_NA:
+ break;
+static void RtemsIntrReqGetAttributes_Post_Status_Check(
+ RtemsIntrReqGetAttributes_Post_Status state
+ case RtemsIntrReqGetAttributes_Post_Status_Ok: {
+ * The return status of rtems_interrupt_get_attributes() shall be
+ * RTEMS_SUCCESSFUL.
+ T_rsc_success( ctx->status );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Status_InvAddr: {
+ * RTEMS_INVALID_ADDRESS.
+ T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Status_NA:
+ break;
+static void RtemsIntrReqGetAttributes_Post_Attributes_Check(
+ RtemsIntrReqGetAttributes_Post_Attributes state
+ rtems_interrupt_attributes attr;
+ case RtemsIntrReqGetAttributes_Post_Attributes_Nop: {
+ * Objects referenced by the ``attributes`` parameter in past calls to
+ * rtems_interrupt_get_attributes() shall not be accessed by the
+ memset( &attr, 0xa5, sizeof( attr ) );
+ T_eq_mem( &ctx->attributes_obj, &attr, sizeof( attr ) );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Attributes_Zero: {
+ * The object referenced by the ``attributes`` parameter shall cleared to
+ * zero.
+ memset( &attr, 0, sizeof( attr ) );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Attributes_Set: {
+ * The members of the object referenced by the ``attributes`` parameter
+ * shall be set to the attributes of the interrupt vector specified by
+ * ``vector``.
+ T_ne_mem( &ctx->attributes_obj, &attr, sizeof( attr ) );
+ break;
+ case RtemsIntrReqGetAttributes_Post_Attributes_NA:
+ break;
+static void RtemsIntrReqGetAttributes_Prepare(
+ memset( &ctx->attributes_obj, 0xa5, sizeof( ctx->attributes_obj ) );
+static void RtemsIntrReqGetAttributes_Action(
+ rtems_vector_number vector;
+ if ( ctx->valid_vector && ctx->attributes != NULL ) {
+ ctx->status = RTEMS_INTERNAL_ERROR;
+ for ( vector = 0; vector < BSP_INTERRUPT_VECTOR_COUNT; ++vector ) {
+ rtems_status_code sc;
+ memset( &ctx->attributes_obj, 0xff, sizeof( ctx->attributes_obj ) );
+ sc = rtems_interrupt_get_attributes( vector, ctx->attributes );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ T_rsc_success( sc );
+ ctx->status = sc;
+ if ( ctx->attributes_obj.always_enabled ) {
+ T_true( ctx->attributes_obj.can_enable );
+ T_true( ctx->attributes_obj.maybe_enable );
+ T_false( ctx->attributes_obj.can_disable );
+ if ( ctx->attributes_obj.can_enable ) {
+ if ( ctx->attributes_obj.can_disable ) {
+ T_true(
+ ctx->attributes_obj.can_enable || ctx->attributes_obj.maybe_enable
+ } else {
+ if ( ctx->valid_vector ) {
+ vector = 0;
+ } else {
+ vector = BSP_INTERRUPT_VECTOR_COUNT;
+ ctx->status = rtems_interrupt_get_attributes( vector, ctx->attributes );
+typedef struct {
+ uint8_t Skip : 1;
+ uint8_t Pre_Vector_NA : 1;
+ uint8_t Pre_Attributes_NA : 1;
+ uint8_t Post_Status : 2;
+ uint8_t Post_Attributes : 2;
+} RtemsIntrReqGetAttributes_Entry;
+static const RtemsIntrReqGetAttributes_Entry
+RtemsIntrReqGetAttributes_Entries[] = {
+ { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_InvAddr,
+ RtemsIntrReqGetAttributes_Post_Attributes_Nop },
+ { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_Ok,
+ RtemsIntrReqGetAttributes_Post_Attributes_Set },
+ { 0, 0, 0, RtemsIntrReqGetAttributes_Post_Status_InvId,
+ RtemsIntrReqGetAttributes_Post_Attributes_Zero }
+static const uint8_t
+RtemsIntrReqGetAttributes_Map[] = {
+ 1, 0, 2, 0
+static size_t RtemsIntrReqGetAttributes_Scope( void *arg, char *buf, size_t n )
+ RtemsIntrReqGetAttributes_Context *ctx;
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqGetAttributes_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqGetAttributes_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqGetAttributes_Scope,
+ .initial_context = &RtemsIntrReqGetAttributes_Instance
+static inline RtemsIntrReqGetAttributes_Entry
+RtemsIntrReqGetAttributes_GetEntry( size_t index )
+ return RtemsIntrReqGetAttributes_Entries[
+ RtemsIntrReqGetAttributes_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqGetAttributes( void )
+T_TEST_CASE_FIXTURE(
+ RtemsIntrReqGetAttributes,
+ &RtemsIntrReqGetAttributes_Fixture
+ size_t index;
+ ctx = T_fixture_context();
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqGetAttributes_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqGetAttributes_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqGetAttributes_Pre_Attributes_Obj;
+ ctx->pcs[ 1 ] < RtemsIntrReqGetAttributes_Pre_Attributes_NA;
+ ++ctx->pcs[ 1 ]
+ RtemsIntrReqGetAttributes_Entry entry;
+ entry = RtemsIntrReqGetAttributes_GetEntry( index );
+ ++index;
+ RtemsIntrReqGetAttributes_Prepare( ctx );
+ RtemsIntrReqGetAttributes_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqGetAttributes_Pre_Attributes_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqGetAttributes_Action( ctx );
+ RtemsIntrReqGetAttributes_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqGetAttributes_Post_Attributes_Check(
+ ctx,
+ entry.Post_Attributes
2.26.2
