[PATCH 31/41] validation: rtems_interrupt_vector_is_enabled()
Mon Jul 12 12:49:53 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |   1 +
 .../validation/tc-intr-vector-is-enabled.c    | 627 ++++++++++++++++++
 2 files changed, 628 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-vector-is-enabled.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 4e8ecfe1a0..0fbd4d808f 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
 - testsuites/validation/tc-barrier-release.c
 - testsuites/validation/tc-barrier-wait.c
 - testsuites/validation/tc-intr-get-attributes.c
+- testsuites/validation/tc-intr-vector-is-enabled.c
 - testsuites/validation/tc-message-construct-errors.c
 - testsuites/validation/tc-object.c
 - testsuites/validation/tc-signal-catch.c
diff --git a/testsuites/validation/tc-intr-vector-is-enabled.c b/testsuites/validation/tc-intr-vector-is-enabled.c
new file mode 100644
index 0000000000..15f13a132b
--- /dev/null
+++ b/testsuites/validation/tc-intr-vector-is-enabled.c
@@ -0,0 +1,627 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqVectorIsEnabled
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqVectorIsEnabled \
+ *   spec:/rtems/intr/req/vector-is-enabled
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqVectorIsEnabled_Pre_Vector_Valid,
+  RtemsIntrReqVectorIsEnabled_Pre_Vector_Invalid,
+  RtemsIntrReqVectorIsEnabled_Pre_Vector_NA
+} RtemsIntrReqVectorIsEnabled_Pre_Vector;
+typedef enum {
+  RtemsIntrReqVectorIsEnabled_Pre_Enabled_Obj,
+  RtemsIntrReqVectorIsEnabled_Pre_Enabled_Null,
+  RtemsIntrReqVectorIsEnabled_Pre_Enabled_NA
+} RtemsIntrReqVectorIsEnabled_Pre_Enabled;
+typedef enum {
+  RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Yes,
+  RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_No,
+  RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_NA
+} RtemsIntrReqVectorIsEnabled_Pre_IsEnabled;
+typedef enum {
+  RtemsIntrReqVectorIsEnabled_Post_Status_Ok,
+  RtemsIntrReqVectorIsEnabled_Post_Status_InvAddr,
+  RtemsIntrReqVectorIsEnabled_Post_Status_InvId,
+  RtemsIntrReqVectorIsEnabled_Post_Status_NA
+} RtemsIntrReqVectorIsEnabled_Post_Status;
+typedef enum {
+  RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Nop,
+  RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Yes,
+  RtemsIntrReqVectorIsEnabled_Post_IsEnabled_No,
+  RtemsIntrReqVectorIsEnabled_Post_IsEnabled_NA
+} RtemsIntrReqVectorIsEnabled_Post_IsEnabled;
+ * @brief Test context for spec:/rtems/intr/req/vector-is-enabled test case.
+typedef struct {
+   * @brief If this member is true, then an interrupt occurred.
+  bool interrupt_occurred;
+   * @brief This member contains the current vector number.
+  rtems_vector_number vector;
+   * @brief If this member is true, then the interrupt vector shall be enabled
+   *   before the rtems_interrupt_vector_is_enabled() call.
+  bool is_enabled;
+   * @brief This member provides the ``bool`` object.
+  bool enabled_obj;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief This member specifies if the ``enabled`` parameter value.
+  bool *enabled;;
+   * @brief This member contains the return value of the
+   *   rtems_interrupt_vector_is_enabled() call.
+  rtems_status_code status;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 3 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqVectorIsEnabled_Context;
+static RtemsIntrReqVectorIsEnabled_Context
+  RtemsIntrReqVectorIsEnabled_Instance;
+static const char * const RtemsIntrReqVectorIsEnabled_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqVectorIsEnabled_PreDesc_Enabled[] = {
+  "Obj",
+  "Null",
+  "NA"
+static const char * const RtemsIntrReqVectorIsEnabled_PreDesc_IsEnabled[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqVectorIsEnabled_PreDesc[] = {
+  RtemsIntrReqVectorIsEnabled_PreDesc_Vector,
+  RtemsIntrReqVectorIsEnabled_PreDesc_Enabled,
+  RtemsIntrReqVectorIsEnabled_PreDesc_IsEnabled,
+  NULL
+typedef RtemsIntrReqVectorIsEnabled_Context Context;
+static void CheckIsEnabled( Context *ctx, bool expected )
+  ctx->enabled_obj = !expected;
+  ctx->status = rtems_interrupt_vector_is_enabled(
+    ctx->vector,
+    ctx->enabled
+  T_rsc_success( ctx->status );
+  T_eq( ctx->enabled_obj, expected );
+static void Enable( const Context *ctx )
+  rtems_status_code sc;
+  sc = rtems_interrupt_vector_enable( ctx->vector );
+ T_rsc_success( sc );
+static void Disable( const Context *ctx )
+  sc = rtems_interrupt_vector_disable( ctx->vector );
+static void EntryRoutine( void *arg )
+  Context *ctx;
+  (void) arg;
+  ctx = T_fixture_context();
+  CheckIsEnabled( ctx, true );
+  Disable( ctx );
+  ctx->interrupt_occurred = true;
+static void WhileIsEnabled(
+  Context                          *ctx,
+  const rtems_interrupt_attributes *attr,
+  bool                              has_installed_entries
+  if ( has_installed_entries ) {
+  } else if ( attr->can_enable && attr->can_disable && attr->is_maskable ) {
+    rtems_interrupt_entry entry;
+    ctx->interrupt_occurred = false;
+    rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+    sc = rtems_interrupt_entry_install(
+      ctx->vector,
+      RTEMS_INTERRUPT_UNIQUE,
+      &entry
+    ctx->enabled_obj = false;
+    sc = rtems_interrupt_vector_is_enabled( ctx->vector, ctx->enabled );
+    T_true( ctx->enabled_obj || ctx->interrupt_occurred );
+    sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+    CheckIsEnabled( ctx, false );
+  } else {
+static void WhileIsDisabled(
+  Context                          *ctx,
+    if ( attr->can_enable && attr->can_disable ) {
+      Disable( ctx );
+      Enable( ctx );
+  } else if ( attr->can_disable ) {
+  } else {
+static void RtemsIntrReqVectorIsEnabled_Pre_Vector_Prepare(
+  RtemsIntrReqVectorIsEnabled_Context   *ctx,
+  RtemsIntrReqVectorIsEnabled_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqVectorIsEnabled_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqVectorIsEnabled_Pre_Enabled_Prepare(
+  RtemsIntrReqVectorIsEnabled_Pre_Enabled state
+    case RtemsIntrReqVectorIsEnabled_Pre_Enabled_Obj: {
+       * While the ``enabled`` parameter references an object of type ``bool``.
+      ctx->enabled = &ctx->enabled_obj;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_Enabled_Null: {
+       * While the ``enabled`` parameter is equal to NULL.
+      ctx->enabled = NULL;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_Enabled_NA:
+      break;
+static void RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Prepare(
+  RtemsIntrReqVectorIsEnabled_Pre_IsEnabled state
+    case RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Yes: {
+       * While the interrupt associated with the interrupt vector specified by
+       * ``vector`` was enabled for the processor executing the
+       * rtems_interrupt_vector_is_enabled() call at some time point during the
+       * call.
+      ctx->is_enabled = true;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_No: {
+       * ``vector`` was disabled for the processor executing the
+       * call.
+      ctx->is_enabled = false;
+      ctx->enabled_obj = true;
+      break;
+    case RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_NA:
+      break;
+static void RtemsIntrReqVectorIsEnabled_Post_Status_Check(
+  RtemsIntrReqVectorIsEnabled_Post_Status state
+    case RtemsIntrReqVectorIsEnabled_Post_Status_Ok: {
+       * The return status of rtems_interrupt_vector_is_enabled() shall be
+       * RTEMS_SUCCESSFUL.
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_Status_InvAddr: {
+       * RTEMS_INVALID_ADDRESS.
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_Status_NA:
+      break;
+static void RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Check(
+  RtemsIntrReqVectorIsEnabled_Post_IsEnabled state
+    case RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Nop: {
+       * Objects referenced by the ``enabled`` parameter in past calls to
+       * rtems_interrupt_vector_is_enabled() shall not be accessed by the
+      T_eq( ctx->is_enabled, !ctx->enabled_obj );
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Yes: {
+       * The value of the object referenced by the ``enabled`` parameter shall
+       * be set to true.
+      /* Validation is done by WhileIsEnabled() for each interrupt vector */
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_IsEnabled_No: {
+       * be set to false.
+      /* Validation is done by WhileIsDisabled() for each interrupt vector */
+      break;
+    case RtemsIntrReqVectorIsEnabled_Post_IsEnabled_NA:
+      break;
+static void RtemsIntrReqVectorIsEnabled_Action(
+  if ( ctx->valid_vector && ctx->enabled != NULL ) {
+    for (
+      ctx->vector = 0;
+      ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+      ++ctx->vector
+      rtems_interrupt_attributes attr;
+      bool                       has_installed_entries;
+      memset( &attr, 0, sizeof( attr ) );
+      sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+      if ( ctx->is_enabled ) {
+        WhileIsEnabled( ctx, &attr, has_installed_entries );
+      } else {
+        WhileIsDisabled( ctx, &attr, has_installed_entries );
+  } else {
+    if ( ctx->valid_vector ) {
+      ctx->vector = 0;
+    } else {
+      ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+      ctx->vector,
+      ctx->enabled
+typedef struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Vector_NA : 1;
+  uint8_t Pre_Enabled_NA : 1;
+  uint8_t Pre_IsEnabled_NA : 1;
+  uint8_t Post_Status : 2;
+  uint8_t Post_IsEnabled : 2;
+} RtemsIntrReqVectorIsEnabled_Entry;
+static const RtemsIntrReqVectorIsEnabled_Entry
+RtemsIntrReqVectorIsEnabled_Entries[] = {
+  { 0, 0, 0, 0, RtemsIntrReqVectorIsEnabled_Post_Status_InvAddr,
+    RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Nop },
+  { 0, 0, 0, 1, RtemsIntrReqVectorIsEnabled_Post_Status_InvId,
+  { 0, 0, 0, 1, RtemsIntrReqVectorIsEnabled_Post_Status_InvAddr,
+  { 0, 0, 0, 0, RtemsIntrReqVectorIsEnabled_Post_Status_Ok,
+    RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Yes },
+    RtemsIntrReqVectorIsEnabled_Post_IsEnabled_No }
+static const uint8_t
+RtemsIntrReqVectorIsEnabled_Map[] = {
+  3, 4, 0, 0, 1, 1, 2, 2
+static size_t RtemsIntrReqVectorIsEnabled_Scope(
+  void  *arg,
+  char  *buf,
+  size_t n
+  RtemsIntrReqVectorIsEnabled_Context *ctx;
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope(
+      RtemsIntrReqVectorIsEnabled_PreDesc,
+      buf,
+      n,
+      ctx->pcs
+  return 0;
+static T_fixture RtemsIntrReqVectorIsEnabled_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqVectorIsEnabled_Scope,
+  .initial_context = &RtemsIntrReqVectorIsEnabled_Instance
+static inline RtemsIntrReqVectorIsEnabled_Entry
+RtemsIntrReqVectorIsEnabled_GetEntry( size_t index )
+  return RtemsIntrReqVectorIsEnabled_Entries[
+    RtemsIntrReqVectorIsEnabled_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqVectorIsEnabled( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqVectorIsEnabled,
+  &RtemsIntrReqVectorIsEnabled_Fixture
+  size_t index;
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqVectorIsEnabled_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqVectorIsEnabled_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqVectorIsEnabled_Pre_Enabled_Obj;
+      ctx->pcs[ 1 ] < RtemsIntrReqVectorIsEnabled_Pre_Enabled_NA;
+      ++ctx->pcs[ 1 ]
+      for (
+        ctx->pcs[ 2 ] = RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Yes;
+        ctx->pcs[ 2 ] < RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_NA;
+        ++ctx->pcs[ 2 ]
+        RtemsIntrReqVectorIsEnabled_Entry entry;
+        size_t pcs[ 3 ];
+        entry = RtemsIntrReqVectorIsEnabled_GetEntry( index );
+        ++index;
+        memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+        if ( entry.Pre_IsEnabled_NA ) {
+          ctx->pcs[ 2 ] = RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_NA;
+        RtemsIntrReqVectorIsEnabled_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+        RtemsIntrReqVectorIsEnabled_Pre_Enabled_Prepare( ctx, ctx->pcs[ 1 ] );
+        RtemsIntrReqVectorIsEnabled_Pre_IsEnabled_Prepare(
+          ctx,
+          ctx->pcs[ 2 ]
+        RtemsIntrReqVectorIsEnabled_Action( ctx );
+        RtemsIntrReqVectorIsEnabled_Post_Status_Check(
+          ctx,
+          entry.Post_Status
+        RtemsIntrReqVectorIsEnabled_Post_IsEnabled_Check(
+          ctx,
+          entry.Post_IsEnabled
+        memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
