[PATCH 40/41] validation: Test rtems_interrupt_get_affinity()
Sebastian Huber
Mon Jul 12 12:50:02 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-get-affinity.c | 639 ++++++++++++++++++
2 files changed, 640 insertions(+)
create mode 100644 testsuites/validation/tc-intr-get-affinity.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index eba0954182..89c0f408d6 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -20,6 +20,7 @@ source:
- testsuites/validation/tc-intr-clear.c
- testsuites/validation/tc-intr-entry-install.c
- testsuites/validation/tc-intr-entry-remove.c
+- testsuites/validation/tc-intr-get-affinity.c
- testsuites/validation/tc-intr-get-attributes.c
- testsuites/validation/tc-intr-is-pending.c
- testsuites/validation/tc-intr-vector-disable.c
diff --git a/testsuites/validation/tc-intr-get-affinity.c b/testsuites/validation/tc-intr-get-affinity.c
new file mode 100644
index 0000000000..43d8c75fec
--- /dev/null
+++ b/testsuites/validation/tc-intr-get-affinity.c
@@ -0,0 +1,639 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqGetAffinity
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqGetAffinity \
+ * spec:/rtems/intr/req/get-affinity
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqGetAffinity_Pre_Vector_Valid,
+ RtemsIntrReqGetAffinity_Pre_Vector_Invalid,
+ RtemsIntrReqGetAffinity_Pre_Vector_NA
+} RtemsIntrReqGetAffinity_Pre_Vector;
+typedef enum {
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid,
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize_TooSmall,
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize_Askew,
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA
+} RtemsIntrReqGetAffinity_Pre_CPUSetSize;
+typedef enum {
+ RtemsIntrReqGetAffinity_Pre_CPUSet_Valid,
+ RtemsIntrReqGetAffinity_Pre_CPUSet_Null,
+ RtemsIntrReqGetAffinity_Pre_CPUSet_NA
+} RtemsIntrReqGetAffinity_Pre_CPUSet;
+typedef enum {
+ RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes,
+ RtemsIntrReqGetAffinity_Pre_CanGetAffinity_No,
+ RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA
+} RtemsIntrReqGetAffinity_Pre_CanGetAffinity;
+typedef enum {
+ RtemsIntrReqGetAffinity_Post_Status_Ok,
+ RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+ RtemsIntrReqGetAffinity_Post_Status_InvId,
+ RtemsIntrReqGetAffinity_Post_Status_InvSize,
+ RtemsIntrReqGetAffinity_Post_Status_Unsat,
+ RtemsIntrReqGetAffinity_Post_Status_NA
+} RtemsIntrReqGetAffinity_Post_Status;
+typedef enum {
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_Set,
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop,
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_NA
+} RtemsIntrReqGetAffinity_Post_CPUSetObj;
+ * @brief Test context for spec:/rtems/intr/req/get-affinity test case.
+typedef struct {
+ * @brief This member contains the current vector number.
+ rtems_vector_number vector;
+ * @brief This member contains some valid vector number.
+ rtems_vector_number some_vector;
+ * @brief This member provides the object referenced by the ``affinity``
+ * parameter.
+ cpu_set_t cpuset_obj;
+ * @brief This member contains the return value of the
+ * rtems_interrupt_get_affinity() call.
+ rtems_status_code status;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member specifies if the ``affinity_size`` parameter value.
+ size_t cpusetsize;
+ * @brief This member specifies if the ``affinity`` parameter value.
+ cpu_set_t *cpuset;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 4 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqGetAffinity_Context;
+static RtemsIntrReqGetAffinity_Context
+ RtemsIntrReqGetAffinity_Instance;
+static const char * const RtemsIntrReqGetAffinity_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CPUSetSize[] = {
+ "Valid",
+ "TooSmall",
+ "Askew",
+ "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CPUSet[] = {
+ "Valid",
+ "Null",
+ "NA"
+static const char * const RtemsIntrReqGetAffinity_PreDesc_CanGetAffinity[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqGetAffinity_PreDesc[] = {
+ RtemsIntrReqGetAffinity_PreDesc_Vector,
+ RtemsIntrReqGetAffinity_PreDesc_CPUSetSize,
+ RtemsIntrReqGetAffinity_PreDesc_CPUSet,
+ RtemsIntrReqGetAffinity_PreDesc_CanGetAffinity,
+ NULL
+typedef RtemsIntrReqGetAffinity_Context Context;
+static void CheckGetAffinity(
+ Context *ctx,
+ const rtems_interrupt_attributes *attr
+ rtems_status_code sc;
+ sc = rtems_interrupt_get_affinity(
+ ctx->vector,
+ ctx->cpusetsize,
+ ctx->cpuset
+ if ( attr->can_get_affinity ) {
+ T_rsc_success( sc );
+ } else {
+ T_rsc( sc, RTEMS_UNSATISFIED );
+static void RtemsIntrReqGetAffinity_Pre_Vector_Prepare(
+ RtemsIntrReqGetAffinity_Context *ctx,
+ RtemsIntrReqGetAffinity_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqGetAffinity_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Pre_CPUSetSize_Prepare(
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize state
+ case RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid: {
+ * While the ``affinity_size`` parameter is an integral multiple of the
+ * size of long, while the ``affinity_size`` parameter specifies a
+ * processor set which is large enough to contain the processor affinity
+ * set of the interrupt specified by ``vector``.
+ ctx->cpusetsize = sizeof( ctx->cpuset_obj );
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CPUSetSize_TooSmall: {
+ * processor set which is not large enough to contain the processor
+ * affinity set of the interrupt specified by ``vector``.
+ ctx->cpusetsize = 0;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CPUSetSize_Askew: {
+ * While the ``affinity_size`` parameter is not an integral multiple of
+ * the size of long.
+ ctx->cpusetsize = SIZE_MAX;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Pre_CPUSet_Prepare(
+ RtemsIntrReqGetAffinity_Pre_CPUSet state
+ case RtemsIntrReqGetAffinity_Pre_CPUSet_Valid: {
+ * While the ``affinity`` parameter references an object of type
+ * cpu_set_t.
+ ctx->cpuset = &ctx->cpuset_obj;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CPUSet_Null: {
+ * While the ``affinity`` parameter is equal to NULL.
+ ctx->cpuset = NULL;
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CPUSet_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Prepare(
+ RtemsIntrReqGetAffinity_Pre_CanGetAffinity state
+ case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes: {
+ * While getting the affinity for the interrupt vector specified by
+ * ``vector`` parameter is supported.
+ /* Validation done by CheckGetAffinity() for each interrupt vector */
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_No: {
+ * ``vector`` parameter is not supported.
+ break;
+ case RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Post_Status_Check(
+ RtemsIntrReqGetAffinity_Post_Status state
+ case RtemsIntrReqGetAffinity_Post_Status_Ok: {
+ * The return status of rtems_interrupt_get_affinity() shall be
+ * RTEMS_SUCCESSFUL.
+ break;
+ case RtemsIntrReqGetAffinity_Post_Status_InvAddr: {
+ * RTEMS_INVALID_ADDRESS.
+ T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+ break;
+ case RtemsIntrReqGetAffinity_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqGetAffinity_Post_Status_InvSize: {
+ * RTEMS_INVALID_SIZE.
+ T_rsc( ctx->status, RTEMS_INVALID_SIZE );
+ break;
+ case RtemsIntrReqGetAffinity_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ break;
+ case RtemsIntrReqGetAffinity_Post_Status_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Post_CPUSetObj_Check(
+ RtemsIntrReqGetAffinity_Post_CPUSetObj state
+ case RtemsIntrReqGetAffinity_Post_CPUSetObj_Set: {
+ * The value of the object referenced by the ``affinity`` parameter shall
+ * be set to the processor affinity set of the interrupt specified by the
+ * ``vector`` parameter at some point during the call after the return of
+ * the rtems_interrupt_get_affinity() call.
+ break;
+ case RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop: {
+ * Objects referenced by the ``affinity`` parameter in past calls to
+ * rtems_interrupt_get_affinity() shall not be accessed by the
+ * Validation done by CheckGetAffinity() for each interrupt vector and in
+ * the action code.
+ break;
+ case RtemsIntrReqGetAffinity_Post_CPUSetObj_NA:
+ break;
+static void RtemsIntrReqGetAffinity_Setup(
+ rtems_interrupt_attributes required;
+ memset( &required, 0, sizeof( required ) );
+ required.can_get_affinity = true;
+ ctx->some_vector = GetValidInterruptVectorNumber( &required );
+static void RtemsIntrReqGetAffinity_Setup_Wrap( void *arg )
+ RtemsIntrReqGetAffinity_Context *ctx;
+ ctx = arg;
+ ctx->in_action_loop = false;
+ RtemsIntrReqGetAffinity_Setup( ctx );
+static void RtemsIntrReqGetAffinity_Action(
+ if (
+ ctx->valid_vector && ctx->cpusetsize == sizeof( ctx->cpuset_obj ) &&
+ ctx->cpuset == &ctx->cpuset_obj
+ for (
+ ctx->vector = 0;
+ ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+ ++ctx->vector
+ rtems_interrupt_attributes attr;
+ memset( &attr, 0, sizeof( attr ) );
+ sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ CheckGetAffinity( ctx, &attr );
+ } else {
+ cpu_set_t set;
+ if ( ctx->valid_vector ) {
+ ctx->vector = ctx->some_vector;
+ } else {
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ CPU_ZERO( &ctx->cpuset_obj );
+ ctx->status = rtems_interrupt_get_affinity(
+ ctx->vector,
+ ctx->cpusetsize,
+ ctx->cpuset
+ CPU_ZERO( &set );
+ T_eq_int( CPU_CMP( &ctx->cpuset_obj, &set ), 0 );
+typedef struct {
+ uint16_t Skip : 1;
+ uint16_t Pre_Vector_NA : 1;
+ uint16_t Pre_CPUSetSize_NA : 1;
+ uint16_t Pre_CPUSet_NA : 1;
+ uint16_t Pre_CanGetAffinity_NA : 1;
+ uint16_t Post_Status : 3;
+ uint16_t Post_CPUSetObj : 2;
+} RtemsIntrReqGetAffinity_Entry;
+static const RtemsIntrReqGetAffinity_Entry
+RtemsIntrReqGetAffinity_Entries[] = {
+ { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_Nop },
+ { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvId,
+ { 0, 0, 0, 0, 1, RtemsIntrReqGetAffinity_Post_Status_InvAddr,
+ { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_InvSize,
+ { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_Unsat,
+ { 0, 0, 0, 0, 0, RtemsIntrReqGetAffinity_Post_Status_Ok,
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_Set }
+static const uint8_t
+RtemsIntrReqGetAffinity_Map[] = {
+ 5, 4, 0, 0, 3, 4, 0, 0, 3, 3, 0, 0, 1, 1, 2, 2, 1, 1, 2, 2, 1, 1, 2, 2
+static size_t RtemsIntrReqGetAffinity_Scope( void *arg, char *buf, size_t n )
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqGetAffinity_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqGetAffinity_Fixture = {
+ .setup = RtemsIntrReqGetAffinity_Setup_Wrap,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqGetAffinity_Scope,
+ .initial_context = &RtemsIntrReqGetAffinity_Instance
+static inline RtemsIntrReqGetAffinity_Entry RtemsIntrReqGetAffinity_GetEntry(
+ size_t index
+ return RtemsIntrReqGetAffinity_Entries[
+ RtemsIntrReqGetAffinity_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqGetAffinity( void )
+T_TEST_CASE_FIXTURE(
+ RtemsIntrReqGetAffinity,
+ &RtemsIntrReqGetAffinity_Fixture
+ size_t index;
+ ctx = T_fixture_context();
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqGetAffinity_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqGetAffinity_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqGetAffinity_Pre_CPUSetSize_Valid;
+ ctx->pcs[ 1 ] < RtemsIntrReqGetAffinity_Pre_CPUSetSize_NA;
+ ++ctx->pcs[ 1 ]
+ for (
+ ctx->pcs[ 2 ] = RtemsIntrReqGetAffinity_Pre_CPUSet_Valid;
+ ctx->pcs[ 2 ] < RtemsIntrReqGetAffinity_Pre_CPUSet_NA;
+ ++ctx->pcs[ 2 ]
+ for (
+ ctx->pcs[ 3 ] = RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Yes;
+ ctx->pcs[ 3 ] < RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA;
+ ++ctx->pcs[ 3 ]
+ RtemsIntrReqGetAffinity_Entry entry;
+ size_t pcs[ 4 ];
+ entry = RtemsIntrReqGetAffinity_GetEntry( index );
+ ++index;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_CanGetAffinity_NA ) {
+ ctx->pcs[ 3 ] = RtemsIntrReqGetAffinity_Pre_CanGetAffinity_NA;
+ RtemsIntrReqGetAffinity_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqGetAffinity_Pre_CPUSetSize_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqGetAffinity_Pre_CPUSet_Prepare( ctx, ctx->pcs[ 2 ] );
+ RtemsIntrReqGetAffinity_Pre_CanGetAffinity_Prepare(
+ ctx,
+ ctx->pcs[ 3 ]
+ RtemsIntrReqGetAffinity_Action( ctx );
+ RtemsIntrReqGetAffinity_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqGetAffinity_Post_CPUSetObj_Check(
+ ctx,
+ entry.Post_CPUSetObj
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
