[PATCH 39/41] validation: Test rtems_interrupt_cause_on()
Sebastian Huber
Mon Jul 12 12:50:01 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-cause-on.c | 710 ++++++++++++++++++
testsuites/validation/ts-default.h | 12 +-
testsuites/validation/ts-validation-0.c | 2 +-
4 files changed, 723 insertions(+), 2 deletions(-)
create mode 100644 testsuites/validation/tc-intr-cause-on.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index f432b89191..eba0954182 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
- testsuites/validation/tc-barrier-release.c
- testsuites/validation/tc-barrier-wait.c
- testsuites/validation/tc-intr-cause.c
+- testsuites/validation/tc-intr-cause-on.c
- testsuites/validation/tc-intr-clear.c
- testsuites/validation/tc-intr-entry-install.c
- testsuites/validation/tc-intr-entry-remove.c
diff --git a/testsuites/validation/tc-intr-cause-on.c b/testsuites/validation/tc-intr-cause-on.c
new file mode 100644
index 0000000000..d404a255e7
--- /dev/null
+++ b/testsuites/validation/tc-intr-cause-on.c
@@ -0,0 +1,710 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqCauseOn
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqCauseOn spec:/rtems/intr/req/cause-on
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqCauseOn_Pre_Vector_Valid,
+ RtemsIntrReqCauseOn_Pre_Vector_Invalid,
+ RtemsIntrReqCauseOn_Pre_Vector_NA
+} RtemsIntrReqCauseOn_Pre_Vector;
+typedef enum {
+ RtemsIntrReqCauseOn_Pre_CPU_Online,
+ RtemsIntrReqCauseOn_Pre_CPU_NotOnline,
+ RtemsIntrReqCauseOn_Pre_CPU_NotConf,
+ RtemsIntrReqCauseOn_Pre_CPU_NA
+} RtemsIntrReqCauseOn_Pre_CPU;
+typedef enum {
+ RtemsIntrReqCauseOn_Pre_CanCauseOn_Yes,
+ RtemsIntrReqCauseOn_Pre_CanCauseOn_No,
+ RtemsIntrReqCauseOn_Pre_CanCauseOn_NA
+} RtemsIntrReqCauseOn_Pre_CanCauseOn;
+typedef enum {
+ RtemsIntrReqCauseOn_Post_Status_Ok,
+ RtemsIntrReqCauseOn_Post_Status_InvId,
+ RtemsIntrReqCauseOn_Post_Status_NotConf,
+ RtemsIntrReqCauseOn_Post_Status_IncStat,
+ RtemsIntrReqCauseOn_Post_Status_Unsat,
+ RtemsIntrReqCauseOn_Post_Status_NA
+} RtemsIntrReqCauseOn_Post_Status;
+typedef enum {
+ RtemsIntrReqCauseOn_Post_Pending_Yes,
+ RtemsIntrReqCauseOn_Post_Pending_No,
+ RtemsIntrReqCauseOn_Post_Pending_NA
+} RtemsIntrReqCauseOn_Post_Pending;
+ * @brief Test context for spec:/rtems/intr/req/cause-on test case.
+typedef struct {
+ * @brief This member contains the count of serviced interrupts.
+ volatile uint32_t interrupt_count;
+ * @brief If this member is true, then the interrupt shall be cleared.
+ bool do_clear;
+ * @brief This member contains the current vector number.
+ rtems_vector_number vector;
+ * @brief This member contains some valid vector number.
+ rtems_vector_number some_vector;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member specifies the ``cpu_index`` parameter.
+ uint32_t cpu_index;
+ * @brief This member contains the return value of the
+ * rtems_interrupt_cause_on() call.
+ rtems_status_code status;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 3 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqCauseOn_Context;
+static RtemsIntrReqCauseOn_Context
+ RtemsIntrReqCauseOn_Instance;
+static const char * const RtemsIntrReqCauseOn_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqCauseOn_PreDesc_CPU[] = {
+ "Online",
+ "NotOnline",
+ "NotConf",
+ "NA"
+static const char * const RtemsIntrReqCauseOn_PreDesc_CanCauseOn[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqCauseOn_PreDesc[] = {
+ RtemsIntrReqCauseOn_PreDesc_Vector,
+ RtemsIntrReqCauseOn_PreDesc_CPU,
+ RtemsIntrReqCauseOn_PreDesc_CanCauseOn,
+ NULL
+typedef RtemsIntrReqCauseOn_Context Context;
+static bool IsEnabled( const Context *ctx )
+ rtems_status_code sc;
+ bool enabled;
+ enabled = false;
+ sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled );
+ T_rsc_success( sc );
+ return enabled;
+static bool IsPending( const Context *ctx )
+ bool pending;
+ pending = false;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending );
+ return pending;
+static void Disable( const Context *ctx )
+ sc = rtems_interrupt_vector_disable( ctx->vector );
+static void CauseOn( const Context *ctx )
+ sc = rtems_interrupt_cause_on( ctx->vector, ctx->cpu_index );
+static void EntryRoutine( void *arg )
+ Context *ctx;
+ uint32_t count;
+ (void) arg;
+ ctx = T_fixture_context();
+ count = ctx->interrupt_count;
+ ctx->interrupt_count = count + 1;
+ if ( ctx->do_clear ) {
+ sc = rtems_interrupt_clear( ctx->vector );
+ if ( count > 2 ) {
+ /* Some interrupts are probably cased by a peripheral */
+ Disable( ctx );
+static void CheckUnsatisfied( const Context *ctx )
+ bool pending_before;
+ bool pending_after;
+ pending_before = true;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending_before );
+ T_rsc( sc, RTEMS_UNSATISFIED );
+ pending_after = !pending_before;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending_after );
+ T_eq( pending_before, pending_after );
+static void CheckCauseOn(
+ Context *ctx,
+ const rtems_interrupt_attributes *attr,
+ bool has_installed_entries
+ if ( !attr->can_cause_on ) {
+ CheckUnsatisfied( ctx );
+ } else if ( has_installed_entries ) {
+ /* We cannot test this vector, since it is used by a device driver */
+ } else if ( !attr->is_maskable ) {
+ /* We can only safely test maskable interrupts */
+ } else if ( IsPending( ctx ) ) {
+ * If there is already an interrupt pending, then it is probably caused
+ * by a peripheral which we cannot control.
+ } else if (
+ ( attr->always_enabled || attr->can_disable ) &&
+ ( attr->can_clear || attr->cleared_by_acknowledge )
+ rtems_interrupt_entry entry;
+ rtems_interrupt_level level;
+ ctx->interrupt_count = 0;
+ ctx->do_clear = attr->can_clear && !attr->cleared_by_acknowledge;
+ rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+ sc = rtems_interrupt_entry_install(
+ ctx->vector,
+ RTEMS_INTERRUPT_UNIQUE,
+ &entry
+ if ( !IsPending( ctx) && ( attr->can_enable || IsEnabled( ctx ) ) ) {
+ T_false( IsPending( ctx ) );
+ if ( attr->can_disable ) {
+ Disable( ctx );
+ CauseOn( ctx );
+ T_true( IsPending( ctx ) );
+ sc = rtems_interrupt_vector_enable( ctx->vector );
+ while ( ctx->interrupt_count < 1 ) {
+ /* Wait */
+ } else {
+ ++ctx->interrupt_count;
+ rtems_interrupt_local_disable( level );
+ CauseOn( ctx );
+ rtems_interrupt_local_enable( level );
+ while ( ctx->interrupt_count < 2 ) {
+ /* Wait */
+ sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+static void RtemsIntrReqCauseOn_Pre_Vector_Prepare(
+ RtemsIntrReqCauseOn_Context *ctx,
+ RtemsIntrReqCauseOn_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqCauseOn_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqCauseOn_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqCauseOn_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqCauseOn_Pre_CPU_Prepare(
+ RtemsIntrReqCauseOn_Pre_CPU state
+ case RtemsIntrReqCauseOn_Pre_CPU_Online: {
+ * While the ``cpu_index`` parameter is associated with a configured
+ * processor, while the processor specified by ``cpu_index`` is not
+ * online.
+ ctx->cpu_index = 0;
+ break;
+ case RtemsIntrReqCauseOn_Pre_CPU_NotOnline: {
+ * online.
+ ctx->cpu_index = 4;
+ break;
+ case RtemsIntrReqCauseOn_Pre_CPU_NotConf: {
+ * While the ``cpu_index`` parameter is not associated with a configured
+ * processor.
+ ctx->cpu_index = 5;
+ break;
+ case RtemsIntrReqCauseOn_Pre_CPU_NA:
+ break;
+static void RtemsIntrReqCauseOn_Pre_CanCauseOn_Prepare(
+ RtemsIntrReqCauseOn_Pre_CanCauseOn state
+ case RtemsIntrReqCauseOn_Pre_CanCauseOn_Yes: {
+ * While the interrupt vector associated with the ``vector`` parameter
+ * can be caused on a processor.
+ * This pre-condition depends on the attributes of an interrupt vector,
+ * see CheckCauseOn().
+ break;
+ case RtemsIntrReqCauseOn_Pre_CanCauseOn_No: {
+ * cannot be caused on a processor.
+ break;
+ case RtemsIntrReqCauseOn_Pre_CanCauseOn_NA:
+ break;
+static void RtemsIntrReqCauseOn_Post_Status_Check(
+ RtemsIntrReqCauseOn_Post_Status state
+ case RtemsIntrReqCauseOn_Post_Status_Ok: {
+ * The return status of rtems_interrupt_cause_on() shall be
+ * RTEMS_SUCCESSFUL.
+ /* Validation is done by CheckCauseOn() for each interrupt vector */
+ break;
+ case RtemsIntrReqCauseOn_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqCauseOn_Post_Status_NotConf: {
+ * RTEMS_NOT_CONFIGURED.
+ T_rsc( ctx->status, RTEMS_NOT_CONFIGURED );
+ break;
+ case RtemsIntrReqCauseOn_Post_Status_IncStat: {
+ * RTEMS_INCORRECT_STATE.
+ T_rsc( ctx->status, RTEMS_INCORRECT_STATE );
+ break;
+ case RtemsIntrReqCauseOn_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ break;
+ case RtemsIntrReqCauseOn_Post_Status_NA:
+ break;
+static void RtemsIntrReqCauseOn_Post_Pending_Check(
+ RtemsIntrReqCauseOn_Post_Pending state
+ case RtemsIntrReqCauseOn_Post_Pending_Yes: {
+ * The interrupt associated with the interrupt vector specified by
+ * ``vector`` shall be made pending by the rtems_interrupt_cause_on()
+ * call.
+ break;
+ case RtemsIntrReqCauseOn_Post_Pending_No: {
+ * ``vector`` shall not be made pending by the rtems_interrupt_cause_on()
+ * call.
+ break;
+ case RtemsIntrReqCauseOn_Post_Pending_NA:
+ break;
+static void RtemsIntrReqCauseOn_Setup( RtemsIntrReqCauseOn_Context *ctx )
+ ctx->some_vector = GetValidInterruptVectorNumber( NULL );
+static void RtemsIntrReqCauseOn_Setup_Wrap( void *arg )
+ RtemsIntrReqCauseOn_Context *ctx;
+ ctx = arg;
+ ctx->in_action_loop = false;
+ RtemsIntrReqCauseOn_Setup( ctx );
+static void RtemsIntrReqCauseOn_Action( RtemsIntrReqCauseOn_Context *ctx )
+ if ( ctx->valid_vector && ctx->cpu_index == 0 ) {
+ for (
+ ctx->vector = 0;
+ ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+ ++ctx->vector
+ rtems_interrupt_attributes attr;
+ bool has_installed_entries;
+ memset( &attr, 0, sizeof( attr ) );
+ sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+ CheckCauseOn( ctx, &attr, has_installed_entries );
+ } else {
+ if ( ctx->valid_vector ) {
+ ctx->vector = ctx->some_vector;
+ } else {
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ ctx->status = rtems_interrupt_cause_on( ctx->vector, ctx->cpu_index );
+typedef struct {
+ uint16_t Skip : 1;
+ uint16_t Pre_Vector_NA : 1;
+ uint16_t Pre_CPU_NA : 1;
+ uint16_t Pre_CanCauseOn_NA : 1;
+ uint16_t Post_Status : 3;
+ uint16_t Post_Pending : 2;
+} RtemsIntrReqCauseOn_Entry;
+static const RtemsIntrReqCauseOn_Entry
+RtemsIntrReqCauseOn_Entries[] = {
+ { 0, 0, 0, 1, RtemsIntrReqCauseOn_Post_Status_InvId,
+ RtemsIntrReqCauseOn_Post_Pending_NA },
+#if defined(RTEMS_SMP)
+ { 0, 0, 0, 0, RtemsIntrReqCauseOn_Post_Status_IncStat,
+ RtemsIntrReqCauseOn_Post_Pending_No },
+#else
+ { 1, 0, 0, 0, RtemsIntrReqCauseOn_Post_Status_NA,
+#endif
+ { 0, 0, 0, 0, RtemsIntrReqCauseOn_Post_Status_NotConf,
+#else
+#endif
+ { 0, 0, 0, 0, RtemsIntrReqCauseOn_Post_Status_Ok,
+ RtemsIntrReqCauseOn_Post_Pending_Yes },
+ { 0, 0, 0, 0, RtemsIntrReqCauseOn_Post_Status_Unsat,
+static const uint8_t
+RtemsIntrReqCauseOn_Map[] = {
+ 4, 5, 1, 1, 2, 2, 0, 0, 3, 3, 0, 0
+static size_t RtemsIntrReqCauseOn_Scope( void *arg, char *buf, size_t n )
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqCauseOn_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqCauseOn_Fixture = {
+ .setup = RtemsIntrReqCauseOn_Setup_Wrap,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqCauseOn_Scope,
+ .initial_context = &RtemsIntrReqCauseOn_Instance
+static inline RtemsIntrReqCauseOn_Entry RtemsIntrReqCauseOn_GetEntry(
+ size_t index
+ return RtemsIntrReqCauseOn_Entries[
+ RtemsIntrReqCauseOn_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqCauseOn( void )
+T_TEST_CASE_FIXTURE( RtemsIntrReqCauseOn, &RtemsIntrReqCauseOn_Fixture )
+ size_t index;
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqCauseOn_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqCauseOn_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqCauseOn_Pre_CPU_Online;
+ ctx->pcs[ 1 ] < RtemsIntrReqCauseOn_Pre_CPU_NA;
+ ++ctx->pcs[ 1 ]
+ for (
+ ctx->pcs[ 2 ] = RtemsIntrReqCauseOn_Pre_CanCauseOn_Yes;
+ ctx->pcs[ 2 ] < RtemsIntrReqCauseOn_Pre_CanCauseOn_NA;
+ ++ctx->pcs[ 2 ]
+ RtemsIntrReqCauseOn_Entry entry;
+ size_t pcs[ 3 ];
+ entry = RtemsIntrReqCauseOn_GetEntry( index );
+ ++index;
+ if ( entry.Skip ) {
+ continue;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_CanCauseOn_NA ) {
+ ctx->pcs[ 2 ] = RtemsIntrReqCauseOn_Pre_CanCauseOn_NA;
+ RtemsIntrReqCauseOn_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqCauseOn_Pre_CPU_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqCauseOn_Pre_CanCauseOn_Prepare( ctx, ctx->pcs[ 2 ] );
+ RtemsIntrReqCauseOn_Action( ctx );
+ RtemsIntrReqCauseOn_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqCauseOn_Post_Pending_Check( ctx, entry.Post_Pending );
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
index d519df09ff..addf1866f5 100644
--- a/testsuites/validation/ts-default.h
+++ b/testsuites/validation/ts-default.h
@@ -177,7 +177,8 @@ static void task_stack_deallocate( void *stack )
#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE TASK_STORAGE_SIZE
-#if defined(RTEMS_SMP) && CONFIGURE_MAXIMUM_PROCESSORS == 4
+#if defined( RTEMS_SMP ) && \
+ ( CONFIGURE_MAXIMUM_PROCESSORS == 4 || CONFIGURE_MAXIMUM_PROCESSORS == 5 )
#define CONFIGURE_SCHEDULER_EDF_SMP
@@ -194,11 +195,20 @@ RTEMS_SCHEDULER_EDF_SMP(c);
RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
+#if CONFIGURE_MAXIMUM_PROCESSORS == 5
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+ RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+ RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+ RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER
+#else
+#endif
#endif /* RTEMS_SMP */
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index 4e0459edf8..b80c09d47f 100644
--- a/testsuites/validation/ts-validation-0.c
+++ b/testsuites/validation/ts-validation-0.c
@@ -70,7 +70,7 @@
const char rtems_test_name[] = "Validation0";
-#define CONFIGURE_MAXIMUM_PROCESSORS 4
+#define CONFIGURE_MAXIMUM_PROCESSORS 5
#include "ts-default.h"
2.26.2
