[PATCH 37/41] validation: Test rtems_interrupt_clear()
Mon Jul 12 12:49:59 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |   1 +
 testsuites/validation/tc-intr-clear.c         | 586 ++++++++++++++++++
 2 files changed, 587 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-clear.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index fc7b2830e4..c47cd93234 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
 - testsuites/validation/tc-barrier-release.c
 - testsuites/validation/tc-barrier-wait.c
 - testsuites/validation/tc-intr-cause.c
+- testsuites/validation/tc-intr-clear.c
 - testsuites/validation/tc-intr-entry-install.c
 - testsuites/validation/tc-intr-entry-remove.c
 - testsuites/validation/tc-intr-get-attributes.c
diff --git a/testsuites/validation/tc-intr-clear.c b/testsuites/validation/tc-intr-clear.c
new file mode 100644
index 0000000000..6fc917e2ad
--- /dev/null
+++ b/testsuites/validation/tc-intr-clear.c
@@ -0,0 +1,586 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqClear
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqClear spec:/rtems/intr/req/clear
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqClear_Pre_Vector_Valid,
+  RtemsIntrReqClear_Pre_Vector_Invalid,
+  RtemsIntrReqClear_Pre_Vector_NA
+} RtemsIntrReqClear_Pre_Vector;
+typedef enum {
+  RtemsIntrReqClear_Pre_CanClear_Yes,
+  RtemsIntrReqClear_Pre_CanClear_No,
+  RtemsIntrReqClear_Pre_CanClear_NA
+} RtemsIntrReqClear_Pre_CanClear;
+typedef enum {
+  RtemsIntrReqClear_Post_Status_Ok,
+  RtemsIntrReqClear_Post_Status_InvId,
+  RtemsIntrReqClear_Post_Status_Unsat,
+  RtemsIntrReqClear_Post_Status_NA
+} RtemsIntrReqClear_Post_Status;
+typedef enum {
+  RtemsIntrReqClear_Post_Cleared_Yes,
+  RtemsIntrReqClear_Post_Cleared_No,
+  RtemsIntrReqClear_Post_Cleared_NA
+} RtemsIntrReqClear_Post_Cleared;
+ * @brief Test context for spec:/rtems/intr/req/clear test case.
+typedef struct {
+   * @brief This member contains the count of serviced interrupts.
+  volatile uint32_t interrupt_count;
+   * @brief If this member is true, then the interrupt shall be cleared.
+  bool do_clear;
+   * @brief This member contains the current vector number.
+  rtems_vector_number vector;
+   * @brief If this member is true, then the ``vector`` parameter shall be
+   *   valid.
+  bool valid_vector;
+   * @brief This member contains the return value of the
+   *   rtems_interrupt_clear() call.
+  rtems_status_code status;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 2 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqClear_Context;
+static RtemsIntrReqClear_Context
+  RtemsIntrReqClear_Instance;
+static const char * const RtemsIntrReqClear_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqClear_PreDesc_CanClear[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqClear_PreDesc[] = {
+  RtemsIntrReqClear_PreDesc_Vector,
+  RtemsIntrReqClear_PreDesc_CanClear,
+  NULL
+typedef RtemsIntrReqClear_Context Context;
+static bool IsEnabled( const Context *ctx )
+  rtems_status_code sc;
+  bool              enabled;
+  enabled = false;
+  sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled );
+  T_rsc_success( sc );
+  return enabled;
+static bool IsPending( const Context *ctx )
+  bool              pending;
+  pending = false;
+  sc = rtems_interrupt_is_pending( ctx->vector, &pending );
+  return pending;
+static void Disable( const Context *ctx )
+  sc = rtems_interrupt_vector_disable( ctx->vector );
+static void Cause( const Context *ctx )
+  sc = rtems_interrupt_cause( ctx->vector );
+static void Clear( const Context *ctx )
+  sc = rtems_interrupt_clear( ctx->vector );
+static void EntryRoutine( void *arg )
+  Context *ctx;
+  uint32_t count;
+  (void) arg;
+  ctx = T_fixture_context();
+  count = ctx->interrupt_count;
+  ctx->interrupt_count = count + 1;
+  if ( ctx->do_clear ) {
+  if ( count > 2 ) {
+    /* Some interrupts are probably cased by a peripheral */
+    Disable( ctx );
+static void CheckUnsatisfied( const Context *ctx )
+  bool              pending_before;
+  bool              pending_after;
+  pending_before = true;
+  sc = rtems_interrupt_is_pending( ctx->vector, &pending_before );
+  T_rsc( sc, RTEMS_UNSATISFIED );
+  pending_after = !pending_before;
+  sc = rtems_interrupt_is_pending( ctx->vector, &pending_after );
+  T_eq( pending_before, pending_after );
+static void CheckClear(
+  Context                          *ctx,
+  const rtems_interrupt_attributes *attr,
+  bool                              has_installed_entries
+  if ( !attr->can_clear ) {
+    CheckUnsatisfied( ctx );
+  } else if ( has_installed_entries ) {
+    /* We cannot test this vector, since it is used by a device driver */
+  } else if ( !attr->is_maskable ) {
+    /* We can only safely test maskable interrupts */
+  } else if ( IsPending( ctx ) ) {
+     * If there is already an interrupt pending, then it is probably cleard
+     * by a peripheral which we cannot control.
+  } else if ( attr->always_enabled || attr->can_disable ) {
+    rtems_interrupt_entry entry;
+    rtems_interrupt_level level;
+    ctx->interrupt_count = 0;
+    ctx->do_clear = !attr->cleared_by_acknowledge;
+    rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+    sc = rtems_interrupt_entry_install(
+      ctx->vector,
+      RTEMS_INTERRUPT_UNIQUE,
+      &entry
+    Clear( ctx );
+    if ( !IsPending( ctx) && ( attr->can_enable || IsEnabled( ctx ) ) ) {
+      T_false( IsPending( ctx ) );
+      Clear( ctx );
+      if ( attr->can_disable ) {
+        Disable( ctx );
+        Cause( ctx );
+        T_true( IsPending( ctx ) );
+        Clear( ctx );
+        sc = rtems_interrupt_vector_enable( ctx->vector );
+      Clear( ctx );
+      rtems_interrupt_local_disable( level );
+      Cause( ctx );
+      Clear( ctx );
+      rtems_interrupt_local_enable( level );
+      Clear( ctx );
+    sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+static void RtemsIntrReqClear_Pre_Vector_Prepare(
+  RtemsIntrReqClear_Context   *ctx,
+  RtemsIntrReqClear_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqClear_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->valid_vector = true;
+      break;
+    case RtemsIntrReqClear_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->valid_vector = false;
+      break;
+    case RtemsIntrReqClear_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqClear_Pre_CanClear_Prepare(
+  RtemsIntrReqClear_Pre_CanClear state
+    case RtemsIntrReqClear_Pre_CanClear_Yes: {
+       * While the interrupt vector associated with the ``vector`` parameter
+       * can be cleard.
+       * This pre-condition depends on the attributes of an interrupt vector,
+       * see CheckClear().
+      break;
+    case RtemsIntrReqClear_Pre_CanClear_No: {
+       * cannot be cleard.
+      break;
+    case RtemsIntrReqClear_Pre_CanClear_NA:
+      break;
+static void RtemsIntrReqClear_Post_Status_Check(
+  RtemsIntrReqClear_Post_Status state
+    case RtemsIntrReqClear_Post_Status_Ok: {
+       * The return status of rtems_interrupt_clear() shall be
+       * RTEMS_SUCCESSFUL.
+      /* Validation is done by CheckClear() for each interrupt vector */
+      break;
+    case RtemsIntrReqClear_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqClear_Post_Status_Unsat: {
+       * RTEMS_UNSATISFIED.
+      break;
+    case RtemsIntrReqClear_Post_Status_NA:
+      break;
+static void RtemsIntrReqClear_Post_Cleared_Check(
+  RtemsIntrReqClear_Post_Cleared state
+    case RtemsIntrReqClear_Post_Cleared_Yes: {
+       * The pending state of the interrupt associated with the interrupt
+       * vector specified by ``vector`` shall be cleared for the processor
+       * executing the rtems_interrupt_clear() call at some time point during
+       * the call.
+      break;
+    case RtemsIntrReqClear_Post_Cleared_No: {
+       * vector specified by ``vector`` shall not be cleared by the
+      break;
+    case RtemsIntrReqClear_Post_Cleared_NA:
+      break;
+static void RtemsIntrReqClear_Action( RtemsIntrReqClear_Context *ctx )
+  if ( ctx->valid_vector ) {
+    for (
+      ctx->vector = 0;
+      ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+      ++ctx->vector
+      rtems_interrupt_attributes attr;
+      bool                       has_installed_entries;
+      memset( &attr, 0, sizeof( attr ) );
+      sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+      if ( sc == RTEMS_INVALID_ID ) {
+        continue;
+      has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+      CheckClear( ctx, &attr, has_installed_entries );
+  } else {
+    ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+    ctx->status = rtems_interrupt_clear( ctx->vector );
+typedef struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Vector_NA : 1;
+  uint8_t Pre_CanClear_NA : 1;
+  uint8_t Post_Status : 2;
+  uint8_t Post_Cleared : 2;
+} RtemsIntrReqClear_Entry;
+static const RtemsIntrReqClear_Entry
+RtemsIntrReqClear_Entries[] = {
+  { 0, 0, 1, RtemsIntrReqClear_Post_Status_InvId,
+    RtemsIntrReqClear_Post_Cleared_NA },
+  { 0, 0, 0, RtemsIntrReqClear_Post_Status_Ok,
+    RtemsIntrReqClear_Post_Cleared_Yes },
+  { 0, 0, 0, RtemsIntrReqClear_Post_Status_Unsat,
+    RtemsIntrReqClear_Post_Cleared_No }
+static const uint8_t
+RtemsIntrReqClear_Map[] = {
+  1, 2, 0, 0
+static size_t RtemsIntrReqClear_Scope( void *arg, char *buf, size_t n )
+  RtemsIntrReqClear_Context *ctx;
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope( RtemsIntrReqClear_PreDesc, buf, n, ctx->pcs );
+  return 0;
+static T_fixture RtemsIntrReqClear_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqClear_Scope,
+  .initial_context = &RtemsIntrReqClear_Instance
+static inline RtemsIntrReqClear_Entry RtemsIntrReqClear_GetEntry(
+  size_t index
+  return RtemsIntrReqClear_Entries[
+    RtemsIntrReqClear_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqClear( void )
+T_TEST_CASE_FIXTURE( RtemsIntrReqClear, &RtemsIntrReqClear_Fixture )
+  size_t index;
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqClear_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqClear_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqClear_Pre_CanClear_Yes;
+      ctx->pcs[ 1 ] < RtemsIntrReqClear_Pre_CanClear_NA;
+      ++ctx->pcs[ 1 ]
+      RtemsIntrReqClear_Entry entry;
+      size_t pcs[ 2 ];
+      entry = RtemsIntrReqClear_GetEntry( index );
+      ++index;
+      memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+      if ( entry.Pre_CanClear_NA ) {
+        ctx->pcs[ 1 ] = RtemsIntrReqClear_Pre_CanClear_NA;
+      RtemsIntrReqClear_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+      RtemsIntrReqClear_Pre_CanClear_Prepare( ctx, ctx->pcs[ 1 ] );
+      RtemsIntrReqClear_Action( ctx );
+      RtemsIntrReqClear_Post_Status_Check( ctx, entry.Post_Status );
+      RtemsIntrReqClear_Post_Cleared_Check( ctx, entry.Post_Cleared );
+      memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
