[PATCH 36/41] validation: Test rtems_interrupt_cause()
Sebastian Huber
Mon Jul 12 12:49:58 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-cause.c | 577 ++++++++++++++++++
2 files changed, 578 insertions(+)
create mode 100644 testsuites/validation/tc-intr-cause.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 08ef145c82..fc7b2830e4 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -15,6 +15,7 @@ source:
- testsuites/validation/tc-barrier-delete.c
- testsuites/validation/tc-barrier-release.c
- testsuites/validation/tc-barrier-wait.c
+- testsuites/validation/tc-intr-cause.c
- testsuites/validation/tc-intr-entry-install.c
- testsuites/validation/tc-intr-entry-remove.c
- testsuites/validation/tc-intr-get-attributes.c
diff --git a/testsuites/validation/tc-intr-cause.c b/testsuites/validation/tc-intr-cause.c
new file mode 100644
index 0000000000..00ea2c8415
--- /dev/null
+++ b/testsuites/validation/tc-intr-cause.c
@@ -0,0 +1,577 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqCause
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqCause spec:/rtems/intr/req/cause
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqCause_Pre_Vector_Valid,
+ RtemsIntrReqCause_Pre_Vector_Invalid,
+ RtemsIntrReqCause_Pre_Vector_NA
+} RtemsIntrReqCause_Pre_Vector;
+typedef enum {
+ RtemsIntrReqCause_Pre_CanCause_Yes,
+ RtemsIntrReqCause_Pre_CanCause_No,
+ RtemsIntrReqCause_Pre_CanCause_NA
+} RtemsIntrReqCause_Pre_CanCause;
+typedef enum {
+ RtemsIntrReqCause_Post_Status_Ok,
+ RtemsIntrReqCause_Post_Status_InvId,
+ RtemsIntrReqCause_Post_Status_Unsat,
+ RtemsIntrReqCause_Post_Status_NA
+} RtemsIntrReqCause_Post_Status;
+typedef enum {
+ RtemsIntrReqCause_Post_Pending_Yes,
+ RtemsIntrReqCause_Post_Pending_No,
+ RtemsIntrReqCause_Post_Pending_NA
+} RtemsIntrReqCause_Post_Pending;
+ * @brief Test context for spec:/rtems/intr/req/cause test case.
+typedef struct {
+ * @brief This member contains the count of serviced interrupts.
+ volatile uint32_t interrupt_count;
+ * @brief If this member is true, then the interrupt shall be cleared.
+ bool do_clear;
+ * @brief This member contains the current vector number.
+ rtems_vector_number vector;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member contains the return value of the
+ * rtems_interrupt_cause() call.
+ rtems_status_code status;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 2 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqCause_Context;
+static RtemsIntrReqCause_Context
+ RtemsIntrReqCause_Instance;
+static const char * const RtemsIntrReqCause_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqCause_PreDesc_CanCause[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqCause_PreDesc[] = {
+ RtemsIntrReqCause_PreDesc_Vector,
+ RtemsIntrReqCause_PreDesc_CanCause,
+ NULL
+typedef RtemsIntrReqCause_Context Context;
+static bool IsEnabled( const Context *ctx )
+ rtems_status_code sc;
+ bool enabled;
+ enabled = false;
+ sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled );
+ T_rsc_success( sc );
+ return enabled;
+static bool IsPending( const Context *ctx )
+ bool pending;
+ pending = false;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending );
+ return pending;
+static void Disable( const Context *ctx )
+ sc = rtems_interrupt_vector_disable( ctx->vector );
+static void Cause( const Context *ctx )
+ sc = rtems_interrupt_cause( ctx->vector );
+static void EntryRoutine( void *arg )
+ Context *ctx;
+ uint32_t count;
+ (void) arg;
+ ctx = T_fixture_context();
+ count = ctx->interrupt_count;
+ ctx->interrupt_count = count + 1;
+ if ( ctx->do_clear ) {
+ sc = rtems_interrupt_clear( ctx->vector );
+ if ( count > 2 ) {
+ /* Some interrupts are probably cased by a peripheral */
+ Disable( ctx );
+static void CheckUnsatisfied( const Context *ctx )
+ bool pending_before;
+ bool pending_after;
+ pending_before = true;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending_before );
+ T_rsc( sc, RTEMS_UNSATISFIED );
+ pending_after = !pending_before;
+ sc = rtems_interrupt_is_pending( ctx->vector, &pending_after );
+ T_eq( pending_before, pending_after );
+static void CheckCause(
+ Context *ctx,
+ const rtems_interrupt_attributes *attr,
+ bool has_installed_entries
+ if ( !attr->can_cause ) {
+ CheckUnsatisfied( ctx );
+ } else if ( has_installed_entries ) {
+ /* We cannot test this vector, since it is used by a device driver */
+ } else if ( !attr->is_maskable ) {
+ /* We can only safely test maskable interrupts */
+ } else if ( IsPending( ctx ) ) {
+ * If there is already an interrupt pending, then it is probably caused
+ * by a peripheral which we cannot control.
+ } else if (
+ ( attr->always_enabled || attr->can_disable ) &&
+ ( attr->can_clear || attr->cleared_by_acknowledge )
+ rtems_interrupt_entry entry;
+ rtems_interrupt_level level;
+ ctx->interrupt_count = 0;
+ ctx->do_clear = attr->can_clear && !attr->cleared_by_acknowledge;
+ rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+ sc = rtems_interrupt_entry_install(
+ ctx->vector,
+ RTEMS_INTERRUPT_UNIQUE,
+ &entry
+ if ( !IsPending( ctx) && ( attr->can_enable || IsEnabled( ctx ) ) ) {
+ T_false( IsPending( ctx ) );
+ if ( attr->can_disable ) {
+ Disable( ctx );
+ Cause( ctx );
+ T_true( IsPending( ctx ) );
+ sc = rtems_interrupt_vector_enable( ctx->vector );
+ while ( ctx->interrupt_count < 1 ) {
+ /* Wait */
+ } else {
+ ++ctx->interrupt_count;
+ rtems_interrupt_local_disable( level );
+ Cause( ctx );
+ rtems_interrupt_local_enable( level );
+ while ( ctx->interrupt_count < 2 ) {
+ /* Wait */
+ sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+static void RtemsIntrReqCause_Pre_Vector_Prepare(
+ RtemsIntrReqCause_Context *ctx,
+ RtemsIntrReqCause_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqCause_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqCause_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqCause_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqCause_Pre_CanCause_Prepare(
+ RtemsIntrReqCause_Pre_CanCause state
+ case RtemsIntrReqCause_Pre_CanCause_Yes: {
+ * While the interrupt vector associated with the ``vector`` parameter
+ * can be caused.
+ * This pre-condition depends on the attributes of an interrupt vector,
+ * see CheckCause().
+ break;
+ case RtemsIntrReqCause_Pre_CanCause_No: {
+ * cannot be caused.
+ break;
+ case RtemsIntrReqCause_Pre_CanCause_NA:
+ break;
+static void RtemsIntrReqCause_Post_Status_Check(
+ RtemsIntrReqCause_Post_Status state
+ case RtemsIntrReqCause_Post_Status_Ok: {
+ * The return status of rtems_interrupt_cause() shall be
+ * RTEMS_SUCCESSFUL.
+ /* Validation is done by CheckCause() for each interrupt vector */
+ break;
+ case RtemsIntrReqCause_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqCause_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ break;
+ case RtemsIntrReqCause_Post_Status_NA:
+ break;
+static void RtemsIntrReqCause_Post_Pending_Check(
+ RtemsIntrReqCause_Post_Pending state
+ case RtemsIntrReqCause_Post_Pending_Yes: {
+ * The interrupt associated with the interrupt vector specified by
+ * ``vector`` shall be made pending by the rtems_interrupt_cause() call.
+ break;
+ case RtemsIntrReqCause_Post_Pending_No: {
+ * ``vector`` shall not be made pending by the rtems_interrupt_cause()
+ * call.
+ break;
+ case RtemsIntrReqCause_Post_Pending_NA:
+ break;
+static void RtemsIntrReqCause_Action( RtemsIntrReqCause_Context *ctx )
+ if ( ctx->valid_vector ) {
+ for (
+ ctx->vector = 0;
+ ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+ ++ctx->vector
+ rtems_interrupt_attributes attr;
+ bool has_installed_entries;
+ memset( &attr, 0, sizeof( attr ) );
+ sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+ CheckCause( ctx, &attr, has_installed_entries );
+ } else {
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ ctx->status = rtems_interrupt_cause( ctx->vector );
+typedef struct {
+ uint8_t Skip : 1;
+ uint8_t Pre_Vector_NA : 1;
+ uint8_t Pre_CanCause_NA : 1;
+ uint8_t Post_Status : 2;
+ uint8_t Post_Pending : 2;
+} RtemsIntrReqCause_Entry;
+static const RtemsIntrReqCause_Entry
+RtemsIntrReqCause_Entries[] = {
+ { 0, 0, 1, RtemsIntrReqCause_Post_Status_InvId,
+ RtemsIntrReqCause_Post_Pending_NA },
+ { 0, 0, 0, RtemsIntrReqCause_Post_Status_Ok,
+ RtemsIntrReqCause_Post_Pending_Yes },
+ { 0, 0, 0, RtemsIntrReqCause_Post_Status_Unsat,
+ RtemsIntrReqCause_Post_Pending_No }
+static const uint8_t
+RtemsIntrReqCause_Map[] = {
+ 1, 2, 0, 0
+static size_t RtemsIntrReqCause_Scope( void *arg, char *buf, size_t n )
+ RtemsIntrReqCause_Context *ctx;
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqCause_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqCause_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqCause_Scope,
+ .initial_context = &RtemsIntrReqCause_Instance
+static inline RtemsIntrReqCause_Entry RtemsIntrReqCause_GetEntry(
+ size_t index
+ return RtemsIntrReqCause_Entries[
+ RtemsIntrReqCause_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqCause( void )
+T_TEST_CASE_FIXTURE( RtemsIntrReqCause, &RtemsIntrReqCause_Fixture )
+ size_t index;
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqCause_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqCause_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqCause_Pre_CanCause_Yes;
+ ctx->pcs[ 1 ] < RtemsIntrReqCause_Pre_CanCause_NA;
+ ++ctx->pcs[ 1 ]
+ RtemsIntrReqCause_Entry entry;
+ size_t pcs[ 2 ];
+ entry = RtemsIntrReqCause_GetEntry( index );
+ ++index;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_CanCause_NA ) {
+ ctx->pcs[ 1 ] = RtemsIntrReqCause_Pre_CanCause_NA;
+ RtemsIntrReqCause_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqCause_Pre_CanCause_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqCause_Action( ctx );
+ RtemsIntrReqCause_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqCause_Post_Pending_Check( ctx, entry.Post_Pending );
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
