[PATCH 35/41] validation: Test rtems_interrupt_entry_remove()
Mon Jul 12 12:49:57 UTC 2021
Update #3269.
 .../testsuites/validation/validation-0.yml    |    1 +
 testsuites/validation/tc-intr-entry-remove.c  | 1302 +++++++++++++++++
 2 files changed, 1303 insertions(+)
 create mode 100644 testsuites/validation/tc-intr-entry-remove.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index c536779f2d..08ef145c82 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
 - testsuites/validation/tc-barrier-release.c
 - testsuites/validation/tc-barrier-wait.c
 - testsuites/validation/tc-intr-entry-install.c
+- testsuites/validation/tc-intr-entry-remove.c
 - testsuites/validation/tc-intr-get-attributes.c
 - testsuites/validation/tc-intr-vector-disable.c
 - testsuites/validation/tc-intr-vector-enable.c
diff --git a/testsuites/validation/tc-intr-entry-remove.c b/testsuites/validation/tc-intr-entry-remove.c
new file mode 100644
index 0000000000..90f3701ef0
--- /dev/null
+++ b/testsuites/validation/tc-intr-entry-remove.c
@@ -0,0 +1,1302 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqEntryRemove
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqEntryRemove \
+ *   spec:/rtems/intr/req/entry-remove
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_Vector_Valid,
+  RtemsIntrReqEntryRemove_Pre_Vector_Invalid,
+  RtemsIntrReqEntryRemove_Pre_Vector_NA
+} RtemsIntrReqEntryRemove_Pre_Vector;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_Entry_Obj,
+  RtemsIntrReqEntryRemove_Pre_Entry_Null,
+  RtemsIntrReqEntryRemove_Pre_Entry_NA
+} RtemsIntrReqEntryRemove_Pre_Entry;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_Routine_Valid,
+  RtemsIntrReqEntryRemove_Pre_Routine_Null,
+  RtemsIntrReqEntryRemove_Pre_Routine_NA
+} RtemsIntrReqEntryRemove_Pre_Routine;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_EntryObj_Installed,
+  RtemsIntrReqEntryRemove_Pre_EntryObj_Match,
+  RtemsIntrReqEntryRemove_Pre_EntryObj_NoMatch,
+  RtemsIntrReqEntryRemove_Pre_EntryObj_NA
+} RtemsIntrReqEntryRemove_Pre_EntryObj;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_Init_Yes,
+  RtemsIntrReqEntryRemove_Pre_Init_No,
+  RtemsIntrReqEntryRemove_Pre_Init_NA
+} RtemsIntrReqEntryRemove_Pre_Init;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_ISR_Yes,
+  RtemsIntrReqEntryRemove_Pre_ISR_No,
+  RtemsIntrReqEntryRemove_Pre_ISR_NA
+} RtemsIntrReqEntryRemove_Pre_ISR;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_First_Yes,
+  RtemsIntrReqEntryRemove_Pre_First_No,
+  RtemsIntrReqEntryRemove_Pre_First_NA
+} RtemsIntrReqEntryRemove_Pre_First;
+typedef enum {
+  RtemsIntrReqEntryRemove_Pre_Last_Yes,
+  RtemsIntrReqEntryRemove_Pre_Last_No,
+  RtemsIntrReqEntryRemove_Pre_Last_NA
+} RtemsIntrReqEntryRemove_Pre_Last;
+typedef enum {
+  RtemsIntrReqEntryRemove_Post_Status_Ok,
+  RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+  RtemsIntrReqEntryRemove_Post_Status_IncStat,
+  RtemsIntrReqEntryRemove_Post_Status_InvId,
+  RtemsIntrReqEntryRemove_Post_Status_CalledFromISR,
+  RtemsIntrReqEntryRemove_Post_Status_Unsat,
+  RtemsIntrReqEntryRemove_Post_Status_NA
+} RtemsIntrReqEntryRemove_Post_Status;
+typedef enum {
+  RtemsIntrReqEntryRemove_Post_IsEnabled_Nop,
+  RtemsIntrReqEntryRemove_Post_IsEnabled_No,
+  RtemsIntrReqEntryRemove_Post_IsEnabled_NA
+} RtemsIntrReqEntryRemove_Post_IsEnabled;
+typedef enum {
+  RtemsIntrReqEntryRemove_Post_Installed_No,
+  RtemsIntrReqEntryRemove_Post_Installed_Nop,
+  RtemsIntrReqEntryRemove_Post_Installed_NA
+} RtemsIntrReqEntryRemove_Post_Installed;
+ * @brief Test context for spec:/rtems/intr/req/entry-remove test case.
+typedef struct {
+   * @brief If this member is true, then the service was initialized during
+   *   setup.
+  bool initialized_during_setup;
+   * @brief If this member is true, then an interrupt occurred.
+  bool interrupt_occurred;
+   * @brief This member provides a counter incremented by EntryRoutine().
+  uint32_t entry_counter;;
+   * @brief This member provides another rtems_interrupt_entry object.
+  rtems_interrupt_entry other_entry;
+   * @brief If this member is true, then another entry was installed.
+  bool other_installed;
+   * @brief This member provides a third rtems_interrupt_entry object.
+  rtems_interrupt_entry third_entry;
+   * @brief If this member is true, then a third entry was installed.
+  bool third_installed;
+   * @brief If this member is true, then the entry is installed.
+  bool installed;
+   * @brief If this member is true, then the entry is installed as the first
+   *   entry.
+  bool first;
+   * @brief If this member is true, then the entry is installed as the last
+   *   entry.
+  bool last;
+   * @brief If this member is true, then the entry matches with another
+   *   installed entry.
+  bool match;
+   * @brief This member provides a valid interrupt vector number.
+  rtems_vector_number valid_vector;
+   * @brief If this member is true, then the service shall be initialized.
+  bool initialized;
+   * @brief If this member is true, then rtems_interrupt_entry_remove() shall
+   *   be called from within interrupt context.
+  bool isr;
+   * @brief This member contains the enabled status before the
+   *   rtems_interrupt_entry_remove() call.
+  bool enabled_before;
+   * @brief This member contains the enabled status after the
+  bool enabled_after;
+   * @brief This member provides the count of visited entries.
+  uint32_t visited_entries;
+   * @brief This member provides the rtems_interrupt_entry object.
+  rtems_interrupt_entry entry_obj;
+   * @brief This member specifies if the ``vector`` parameter value.
+  rtems_vector_number vector;
+   * @brief This member specifies if the ``entry`` parameter value.
+  rtems_interrupt_entry *entry;;
+   * @brief This member contains the return value of the
+  rtems_status_code status;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 8 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsIntrReqEntryRemove_Context;
+static RtemsIntrReqEntryRemove_Context
+  RtemsIntrReqEntryRemove_Instance;
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Vector[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Entry[] = {
+  "Obj",
+  "Null",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Routine[] = {
+  "Valid",
+  "Null",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_EntryObj[] = {
+  "Installed",
+  "Match",
+  "NoMatch",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Init[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_ISR[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_First[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const RtemsIntrReqEntryRemove_PreDesc_Last[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsIntrReqEntryRemove_PreDesc[] = {
+  RtemsIntrReqEntryRemove_PreDesc_Vector,
+  RtemsIntrReqEntryRemove_PreDesc_Entry,
+  RtemsIntrReqEntryRemove_PreDesc_Routine,
+  RtemsIntrReqEntryRemove_PreDesc_EntryObj,
+  RtemsIntrReqEntryRemove_PreDesc_Init,
+  RtemsIntrReqEntryRemove_PreDesc_ISR,
+  RtemsIntrReqEntryRemove_PreDesc_First,
+  RtemsIntrReqEntryRemove_PreDesc_Last,
+  NULL
+typedef RtemsIntrReqEntryRemove_Context Context;
+static char entry_arg;
+static char other_arg;
+static char third_arg;
+static const char info[] = "Info";
+static void Install(
+  Context                *ctx,
+  rtems_interrupt_entry  *entry,
+  rtems_interrupt_handler routine,
+  void                   *arg
+  rtems_status_code sc;
+  rtems_interrupt_entry_initialize(
+    entry,
+    routine,
+    arg,
+    info
+  sc = rtems_interrupt_entry_install(
+    ctx->valid_vector,
+    RTEMS_INTERRUPT_SHARED,
+    entry
+  T_rsc_success( sc );
+static void OtherRoutine( void *arg )
+  Context          *ctx;
+  (void) arg;
+  ctx = T_fixture_context();
+  sc = rtems_interrupt_vector_disable( ctx->valid_vector );
+  ctx->interrupt_occurred = true;
+static void ThirdRoutine( void *arg )
+  T_eq_ptr( arg, &third_arg );
+  OtherRoutine( NULL );
+static void EntryRoutine( void *arg )
+  Context *ctx;
+  ++ctx->entry_counter;
+  T_eq_ptr( arg, &entry_arg );
+static void Action( void *arg )
+  Context          *ctx;
+  ctx = arg;
+  sc = rtems_interrupt_vector_is_enabled(
+    &ctx->enabled_before
+  bsp_interrupt_set_handler_unique(
+    BSP_INTERRUPT_HANDLER_TABLE_SIZE,
+    ctx->initialized
+  ctx->status = rtems_interrupt_entry_remove( ctx->vector, ctx->entry );
+    ctx->initialized_during_setup
+    &ctx->enabled_after
+static void VisitInstalledNo(
+  void                   *arg,
+  const char             *entry_info,
+  rtems_option            options,
+  rtems_interrupt_handler handler_routine,
+  void                   *handler_arg
+  Context *ctx;
+  ctx = arg;
+  visited_entries = ctx->visited_entries;
+  T_eq_u32( options, RTEMS_INTERRUPT_SHARED );
+  T_eq_ptr( entry_info, info );
+  if ( visited_entries == 0 ) {
+    T_eq_ptr( handler_routine, ctx->other_entry.handler );
+    T_eq_ptr( handler_arg, ctx->other_entry.arg );
+  } else if ( visited_entries == 1 ) {
+    T_eq_ptr( handler_routine, ctx->third_entry.handler );
+    T_eq_ptr( handler_arg, ctx->third_entry.arg );
+  ctx->visited_entries = visited_entries + 1;
+static void VisitInstalledNop(
+  void                   *arg,
+  void                   *handler_arg
+  Context *ctx;
+  ctx = arg;
+    if ( ctx->installed && ctx->first ) {
+      T_eq_ptr( handler_routine, ctx->entry_obj.handler );
+      T_eq_ptr( handler_arg, ctx->entry_obj.arg );
+    } else {
+      T_eq_ptr( info, ctx->other_entry.info );
+    if (
+      ctx->installed && ( ( !ctx->first && ctx->last ) ||
+        ( !ctx->first && !ctx->last ) )
+    } else {
+  } else if ( visited_entries == 2 ) {
+    if ( ctx->installed && !ctx->first && ctx->last ) {
+    } else {
+static void RtemsIntrReqEntryRemove_Pre_Vector_Prepare(
+  RtemsIntrReqEntryRemove_Context   *ctx,
+  RtemsIntrReqEntryRemove_Pre_Vector state
+  switch ( state ) {
+    case RtemsIntrReqEntryRemove_Pre_Vector_Valid: {
+       * While the ``vector`` parameter is associated with an interrupt vector.
+      ctx->vector = ctx->valid_vector;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Vector_Invalid: {
+       * While the ``vector`` parameter is not associated with an interrupt
+       * vector.
+      ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Vector_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_Entry_Prepare(
+  RtemsIntrReqEntryRemove_Pre_Entry state
+    case RtemsIntrReqEntryRemove_Pre_Entry_Obj: {
+       * While the ``entry`` parameter references an object of type
+       * rtems_interrupt_entry.
+      ctx->entry = &ctx->entry_obj;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Entry_Null: {
+       * While the ``entry`` parameter is equal to NULL.
+      ctx->entry = NULL;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Entry_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_Routine_Prepare(
+  RtemsIntrReqEntryRemove_Pre_Routine state
+    case RtemsIntrReqEntryRemove_Pre_Routine_Valid: {
+       * While the handler routine of the entry referenced by the ``options``
+       * parameter is valid.
+        &ctx->entry_obj,
+        EntryRoutine,
+        &entry_arg,
+        info
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Routine_Null: {
+       * parameter is equal to NULL.
+        &ctx->entry_obj,
+        NULL,
+        &entry_arg,
+        info
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Routine_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_EntryObj_Prepare(
+  RtemsIntrReqEntryRemove_Pre_EntryObj state
+    case RtemsIntrReqEntryRemove_Pre_EntryObj_Installed: {
+       * While the entry referenced by the ``options`` parameter is installed
+       * at the interrupt vector specified by the ``vector`` parameter.
+      ctx->installed = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_EntryObj_Match: {
+       * While the entry referenced by the ``options`` parameter not installed
+       * at the interrupt vector specified by the ``vector`` parameter, while
+       * the entry referenced by the ``options`` has a handler routine and
+       * argument pair which is equal to the handler routine and argument pair
+       * of an entry installed at the interrupt vector specified by the
+       * ``vector`` parameter.
+      ctx->installed = false;
+      ctx->other_installed = true;
+      ctx->match = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_EntryObj_NoMatch: {
+       * argument pair which is not equal to the handler routine and argument
+       * pairs of all entries installed at the interrupt vector specified by
+       * the ``vector`` parameter.
+      ctx->match = false;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_EntryObj_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_Init_Prepare(
+  RtemsIntrReqEntryRemove_Pre_Init state
+    case RtemsIntrReqEntryRemove_Pre_Init_Yes: {
+       * While the service is initialized.
+      ctx->initialized = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Init_No: {
+       * While the service is not initialized.
+      ctx->initialized = false;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Init_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_ISR_Prepare(
+  RtemsIntrReqEntryRemove_Pre_ISR  state
+    case RtemsIntrReqEntryRemove_Pre_ISR_Yes: {
+       * While rtems_interrupt_entry_remove() is called from within interrupt
+       * context.
+      ctx->isr = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_ISR_No: {
+       * While rtems_interrupt_entry_remove() is not called from within
+       * interrupt context.
+      ctx->isr = false;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_ISR_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_First_Prepare(
+  RtemsIntrReqEntryRemove_Pre_First state
+    case RtemsIntrReqEntryRemove_Pre_First_Yes: {
+       * While the entry referenced by the ``entry`` parameter is installed as
+       * the first entry at the interrupt vector specified by the ``vector``
+       * parameter.
+      ctx->first = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_First_No: {
+       * not the first entry at the interrupt vector specified by the
+      ctx->first = false;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_First_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Pre_Last_Prepare(
+  RtemsIntrReqEntryRemove_Pre_Last state
+    case RtemsIntrReqEntryRemove_Pre_Last_Yes: {
+       * the last entry at the interrupt vector specified by the ``vector``
+       * parameter.
+      ctx->last = true;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Last_No: {
+       * not the last entry at the interrupt vector specified by the ``vector``
+       * parameter.
+      ctx->last = false;
+      break;
+    case RtemsIntrReqEntryRemove_Pre_Last_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Post_Status_Check(
+  RtemsIntrReqEntryRemove_Post_Status state
+    case RtemsIntrReqEntryRemove_Post_Status_Ok: {
+       * The return status of rtems_interrupt_entry_remove() shall be
+       * RTEMS_SUCCESSFUL.
+      T_rsc_success( ctx->status );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_InvAddr: {
+       * RTEMS_INVALID_ADDRESS.
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_IncStat: {
+       * RTEMS_INCORRECT_STATE.
+      T_rsc( ctx->status, RTEMS_INCORRECT_STATE );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_InvId: {
+       * RTEMS_INVALID_ID.
+      T_rsc( ctx->status, RTEMS_INVALID_ID );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_CalledFromISR: {
+       * RTEMS_CALLED_FROM_ISR.
+      T_rsc( ctx->status, RTEMS_CALLED_FROM_ISR );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_Unsat: {
+       * RTEMS_UNSATISFIED.
+      T_rsc( ctx->status, RTEMS_UNSATISFIED );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Status_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Post_IsEnabled_Check(
+  RtemsIntrReqEntryRemove_Post_IsEnabled state
+    case RtemsIntrReqEntryRemove_Post_IsEnabled_Nop: {
+       * The enabled status of the interrupt vector specified by ``vector``
+       * shall not be modified by the rtems_interrupt_entry_remove() call.
+      if ( !ctx->interrupt_occurred ) {
+        T_eq( ctx->enabled_before, ctx->enabled_after );
+      break;
+    case RtemsIntrReqEntryRemove_Post_IsEnabled_No: {
+       * The interrupt vector specified by ``vector`` shall be disabled.
+      T_true( ctx->enabled_before || ctx->interrupt_occurred );
+      T_false( ctx->enabled_after );
+      break;
+    case RtemsIntrReqEntryRemove_Post_IsEnabled_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Post_Installed_Check(
+  RtemsIntrReqEntryRemove_Post_Installed state
+  uint32_t          expected_entries;
+    case RtemsIntrReqEntryRemove_Post_Installed_No: {
+       * The entry referenced by ``entry`` shall not be installed at the
+       * interrupt vector specified by ``vector``.
+      ctx->visited_entries = 0;
+      sc = rtems_interrupt_handler_iterate(
+        VisitInstalledNo,
+        ctx
+      if ( ctx->other_installed && ctx->third_installed ) {
+        expected_entries = 2;
+      } else if ( ctx->other_installed ) {
+        expected_entries = 1;
+      } else {
+        expected_entries = 0;
+      T_eq_u32( ctx->visited_entries, expected_entries );
+      if ( expected_entries > 0 ) {
+        ctx->entry_counter = 0;
+        bsp_interrupt_handler_dispatch( ctx->valid_vector );
+        T_eq_u32( ctx->entry_counter, 0 );
+      } else {
+        rtems_interrupt_entry *first;
+        first = bsp_interrupt_handler_table[
+          bsp_interrupt_handler_index( ctx->valid_vector )
+        T_null( first );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Installed_Nop: {
+       * The entries installed at the interrupt vector specified by ``vector``
+        VisitInstalledNop,
+        ctx
+      if ( ctx->installed && ctx->other_installed && ctx->third_installed ) {
+        expected_entries = 3;
+      } else if ( ctx->installed && ctx->other_installed ) {
+      } else if ( ctx->installed || ctx->other_installed ) {
+      } else {
+      if ( ctx->installed ) {
+        T_eq_u32( ctx->entry_counter, 1 );
+      break;
+    case RtemsIntrReqEntryRemove_Post_Installed_NA:
+      break;
+static void RtemsIntrReqEntryRemove_Setup(
+  ctx->initialized_during_setup = bsp_interrupt_is_initialized();
+  /* Find a valid interrupt vector for this test */
+  for (
+    ctx->valid_vector = 0;
+    ctx->valid_vector < BSP_INTERRUPT_VECTOR_COUNT;
+    ++ctx->valid_vector
+    rtems_interrupt_attributes attr;
+    sc = rtems_interrupt_get_attributes( ctx->valid_vector, &attr );
+    if (
+      sc == RTEMS_SUCCESSFUL && attr.can_enable && attr.can_disable &&
+      attr.is_maskable &&
+      !HasInterruptVectorEntriesInstalled( ctx->valid_vector )
+      break;
+static void RtemsIntrReqEntryRemove_Setup_Wrap( void *arg )
+  RtemsIntrReqEntryRemove_Context *ctx;
+  ctx = arg;
+  ctx->in_action_loop = false;
+  RtemsIntrReqEntryRemove_Setup( ctx );
+static void RtemsIntrReqEntryRemove_Prepare(
+  ctx->interrupt_occurred = false;
+  ctx->other_installed = false;
+  ctx->third_installed = false;
+static void RtemsIntrReqEntryRemove_Action(
+    if ( ctx->first && ctx->last ) {
+      Install( ctx, &ctx->entry_obj, EntryRoutine, &entry_arg );
+    } else if ( ctx->first ) {
+      Install( ctx, &ctx->other_entry, OtherRoutine, &other_arg );
+    } else if ( ctx->last ) {
+    } else {
+      ctx->third_installed = true;
+      Install( ctx, &ctx->third_entry, ThirdRoutine, &third_arg );
+    if ( ctx->match ) {
+      Install( ctx, &ctx->other_entry, EntryRoutine, &entry_arg );
+    } else {
+  if ( ctx->isr ) {
+    CallWithinISR( Action, ctx );
+  } else {
+    Action( ctx );
+static void RtemsIntrReqEntryRemove_Cleanup(
+  if ( ctx->third_installed ) {
+    sc = rtems_interrupt_entry_remove( ctx->valid_vector, &ctx->third_entry );
+  if ( ctx->other_installed ) {
+    sc = rtems_interrupt_entry_remove( ctx->valid_vector, &ctx->other_entry );
+  if ( ctx->installed && ctx->status != RTEMS_SUCCESSFUL ) {
+    sc = rtems_interrupt_entry_remove( ctx->valid_vector, ctx->entry );
+typedef struct {
+  uint16_t Skip : 1;
+  uint16_t Pre_Vector_NA : 1;
+  uint16_t Pre_Entry_NA : 1;
+  uint16_t Pre_Routine_NA : 1;
+  uint16_t Pre_EntryObj_NA : 1;
+  uint16_t Pre_Init_NA : 1;
+  uint16_t Pre_ISR_NA : 1;
+  uint16_t Pre_First_NA : 1;
+  uint16_t Pre_Last_NA : 1;
+  uint16_t Post_Status : 3;
+  uint16_t Post_IsEnabled : 2;
+  uint16_t Post_Installed : 2;
+} RtemsIntrReqEntryRemove_Entry;
+static const RtemsIntrReqEntryRemove_Entry
+RtemsIntrReqEntryRemove_Entries[] = {
+  { 0, 0, 0, 0, 1, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_IncStat,
+    RtemsIntrReqEntryRemove_Post_Installed_NA },
+  { 0, 0, 0, 1, 1, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+    RtemsIntrReqEntryRemove_Post_IsEnabled_NA,
+  { 0, 0, 0, 0, 1, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvAddr,
+  { 0, 0, 0, 0, 1, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_InvId,
+  { 0, 0, 0, 0, 0, 0, 0, 1, 1,
+  { 0, 0, 0, 0, 0, 0, 0, 1, 1, RtemsIntrReqEntryRemove_Post_Status_Unsat,
+  { 0, 0, 0, 0, 0, 0, 0, 0, 0,
+    RtemsIntrReqEntryRemove_Post_Installed_Nop },
+  { 0, 0, 0, 0, 0, 0, 0, 0, 0, RtemsIntrReqEntryRemove_Post_Status_Ok,
+    RtemsIntrReqEntryRemove_Post_Installed_No },
+static const uint8_t
+RtemsIntrReqEntryRemove_Map[] = {
+  8, 8, 8, 8, 10, 9, 9, 9, 0, 0, 0, 0, 0, 0, 0, 0, 6, 6, 6, 6, 7, 7, 7, 7, 0,
+  0, 0, 0, 0, 0, 0, 0, 6, 6, 6, 6, 7, 7, 7, 7, 0, 0, 0, 0, 0, 0, 0, 0, 3, 3, 3,
+  3, 3, 3, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 3, 3, 3, 3, 3, 3, 3, 3, 0, 0, 0, 0, 0,
+  0, 0, 0, 3, 3, 3, 3, 3, 3, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1,
+  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
+  1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 4, 4, 4, 4, 4, 4, 4, 4, 0, 0, 0, 0, 0, 0, 0,
+  0, 4, 4, 4, 4, 4, 4, 4, 4, 0, 0, 0, 0, 0, 0, 0, 0, 4, 4, 4, 4, 4, 4, 4, 4, 0,
+  0, 0, 0, 0, 0, 0, 0, 5, 5, 5, 5, 5, 5, 5, 5, 0, 0, 0, 0, 0, 0, 0, 0, 5, 5, 5,
+  5, 5, 5, 5, 5, 0, 0, 0, 0, 0, 0, 0, 0, 5, 5, 5, 5, 5, 5, 5, 5, 0, 0, 0, 0, 0,
+  0, 0, 0, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+  2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
+static size_t RtemsIntrReqEntryRemove_Scope( void *arg, char *buf, size_t n )
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope( RtemsIntrReqEntryRemove_PreDesc, buf, n, ctx->pcs );
+  return 0;
+static T_fixture RtemsIntrReqEntryRemove_Fixture = {
+  .setup = RtemsIntrReqEntryRemove_Setup_Wrap,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsIntrReqEntryRemove_Scope,
+  .initial_context = &RtemsIntrReqEntryRemove_Instance
+static inline RtemsIntrReqEntryRemove_Entry RtemsIntrReqEntryRemove_GetEntry(
+  size_t index
+  return RtemsIntrReqEntryRemove_Entries[
+    RtemsIntrReqEntryRemove_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqEntryRemove( void )
+T_TEST_CASE_FIXTURE(
+  RtemsIntrReqEntryRemove,
+  &RtemsIntrReqEntryRemove_Fixture
+  size_t index;
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsIntrReqEntryRemove_Pre_Vector_Valid;
+    ctx->pcs[ 0 ] < RtemsIntrReqEntryRemove_Pre_Vector_NA;
+    ++ctx->pcs[ 0 ]
+    for (
+      ctx->pcs[ 1 ] = RtemsIntrReqEntryRemove_Pre_Entry_Obj;
+      ctx->pcs[ 1 ] < RtemsIntrReqEntryRemove_Pre_Entry_NA;
+      ++ctx->pcs[ 1 ]
+      for (
+        ctx->pcs[ 2 ] = RtemsIntrReqEntryRemove_Pre_Routine_Valid;
+        ctx->pcs[ 2 ] < RtemsIntrReqEntryRemove_Pre_Routine_NA;
+        ++ctx->pcs[ 2 ]
+        for (
+          ctx->pcs[ 3 ] = RtemsIntrReqEntryRemove_Pre_EntryObj_Installed;
+          ctx->pcs[ 3 ] < RtemsIntrReqEntryRemove_Pre_EntryObj_NA;
+          ++ctx->pcs[ 3 ]
+          for (
+            ctx->pcs[ 4 ] = RtemsIntrReqEntryRemove_Pre_Init_Yes;
+            ctx->pcs[ 4 ] < RtemsIntrReqEntryRemove_Pre_Init_NA;
+            ++ctx->pcs[ 4 ]
+            for (
+              ctx->pcs[ 5 ] = RtemsIntrReqEntryRemove_Pre_ISR_Yes;
+              ctx->pcs[ 5 ] < RtemsIntrReqEntryRemove_Pre_ISR_NA;
+              ++ctx->pcs[ 5 ]
+              for (
+                ctx->pcs[ 6 ] = RtemsIntrReqEntryRemove_Pre_First_Yes;
+                ctx->pcs[ 6 ] < RtemsIntrReqEntryRemove_Pre_First_NA;
+                ++ctx->pcs[ 6 ]
+                for (
+                  ctx->pcs[ 7 ] = RtemsIntrReqEntryRemove_Pre_Last_Yes;
+                  ctx->pcs[ 7 ] < RtemsIntrReqEntryRemove_Pre_Last_NA;
+                  ++ctx->pcs[ 7 ]
+                  RtemsIntrReqEntryRemove_Entry entry;
+                  size_t pcs[ 8 ];
+                  entry = RtemsIntrReqEntryRemove_GetEntry( index );
+                  ++index;
+                  memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+                  if ( entry.Pre_Routine_NA ) {
+                    ctx->pcs[ 2 ] = RtemsIntrReqEntryRemove_Pre_Routine_NA;
+                  if ( entry.Pre_EntryObj_NA ) {
+                    ctx->pcs[ 3 ] = RtemsIntrReqEntryRemove_Pre_EntryObj_NA;
+                  if ( entry.Pre_First_NA ) {
+                    ctx->pcs[ 6 ] = RtemsIntrReqEntryRemove_Pre_First_NA;
+                  if ( entry.Pre_Last_NA ) {
+                    ctx->pcs[ 7 ] = RtemsIntrReqEntryRemove_Pre_Last_NA;
+                  RtemsIntrReqEntryRemove_Prepare( ctx );
+                  RtemsIntrReqEntryRemove_Pre_Vector_Prepare(
+                    ctx,
+                    ctx->pcs[ 0 ]
+                  RtemsIntrReqEntryRemove_Pre_Entry_Prepare(
+                    ctx,
+                    ctx->pcs[ 1 ]
+                  RtemsIntrReqEntryRemove_Pre_Routine_Prepare(
+                    ctx,
+                    ctx->pcs[ 2 ]
+                  RtemsIntrReqEntryRemove_Pre_EntryObj_Prepare(
+                    ctx,
+                    ctx->pcs[ 3 ]
+                  RtemsIntrReqEntryRemove_Pre_Init_Prepare(
+                    ctx,
+                    ctx->pcs[ 4 ]
+                  RtemsIntrReqEntryRemove_Pre_ISR_Prepare(
+                    ctx,
+                    ctx->pcs[ 5 ]
+                  RtemsIntrReqEntryRemove_Pre_First_Prepare(
+                    ctx,
+                    ctx->pcs[ 6 ]
+                  RtemsIntrReqEntryRemove_Pre_Last_Prepare(
+                    ctx,
+                    ctx->pcs[ 7 ]
+                  RtemsIntrReqEntryRemove_Action( ctx );
+                  RtemsIntrReqEntryRemove_Post_Status_Check(
+                    ctx,
+                    entry.Post_Status
+                  RtemsIntrReqEntryRemove_Post_IsEnabled_Check(
+                    ctx,
+                    entry.Post_IsEnabled
+                  RtemsIntrReqEntryRemove_Post_Installed_Check(
+                    ctx,
+                    entry.Post_Installed
+                  RtemsIntrReqEntryRemove_Cleanup( ctx );
+                  memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
