[PATCH 32/41] validation: Test rtems_interrupt_vector_enable()
Sebastian Huber
Mon Jul 12 12:49:54 UTC 2021
Update #3269.
.../testsuites/validation/validation-0.yml | 1 +
testsuites/validation/tc-intr-vector-enable.c | 641 ++++++++++++++++++
2 files changed, 642 insertions(+)
create mode 100644 testsuites/validation/tc-intr-vector-enable.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 0fbd4d808f..36d2a0f388 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -16,6 +16,7 @@ source:
- testsuites/validation/tc-barrier-release.c
- testsuites/validation/tc-barrier-wait.c
- testsuites/validation/tc-intr-get-attributes.c
+- testsuites/validation/tc-intr-vector-enable.c
- testsuites/validation/tc-intr-vector-is-enabled.c
- testsuites/validation/tc-message-construct-errors.c
- testsuites/validation/tc-object.c
diff --git a/testsuites/validation/tc-intr-vector-enable.c b/testsuites/validation/tc-intr-vector-enable.c
new file mode 100644
index 0000000000..47f53b4728
--- /dev/null
+++ b/testsuites/validation/tc-intr-vector-enable.c
@@ -0,0 +1,641 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsIntrReqVectorEnable
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <bsp/irq-generic.h>
+#include <rtems/irq-extension.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsIntrReqVectorEnable \
+ * spec:/rtems/intr/req/vector-enable
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+ RtemsIntrReqVectorEnable_Pre_Vector_Valid,
+ RtemsIntrReqVectorEnable_Pre_Vector_Invalid,
+ RtemsIntrReqVectorEnable_Pre_Vector_NA
+} RtemsIntrReqVectorEnable_Pre_Vector;
+typedef enum {
+ RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes,
+ RtemsIntrReqVectorEnable_Pre_IsEnabled_No,
+ RtemsIntrReqVectorEnable_Pre_IsEnabled_NA
+} RtemsIntrReqVectorEnable_Pre_IsEnabled;
+typedef enum {
+ RtemsIntrReqVectorEnable_Pre_CanEnable_Yes,
+ RtemsIntrReqVectorEnable_Pre_CanEnable_Maybe,
+ RtemsIntrReqVectorEnable_Pre_CanEnable_No,
+ RtemsIntrReqVectorEnable_Pre_CanEnable_NA
+} RtemsIntrReqVectorEnable_Pre_CanEnable;
+typedef enum {
+ RtemsIntrReqVectorEnable_Post_Status_Ok,
+ RtemsIntrReqVectorEnable_Post_Status_InvId,
+ RtemsIntrReqVectorEnable_Post_Status_Unsat,
+ RtemsIntrReqVectorEnable_Post_Status_NA
+} RtemsIntrReqVectorEnable_Post_Status;
+typedef enum {
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Nop,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Yes,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_NA
+} RtemsIntrReqVectorEnable_Post_IsEnabled;
+ * @brief Test context for spec:/rtems/intr/req/vector-enable test case.
+typedef struct {
+ * @brief If this member is true, then an interrupt occurred.
+ bool interrupt_occurred;
+ * @brief This member contains the current vector number.
+ rtems_vector_number vector;
+ * @brief If this member is true, then the ``vector`` parameter shall be
+ * valid.
+ bool valid_vector;
+ * @brief This member may contain the return value of the
+ * rtems_interrupt_vector_enable() call.
+ rtems_status_code status;
+ * @brief This member defines the pre-condition states for the next action.
+ size_t pcs[ 3 ];
+ * @brief This member indicates if the test action loop is currently
+ * executed.
+ bool in_action_loop;
+} RtemsIntrReqVectorEnable_Context;
+static RtemsIntrReqVectorEnable_Context
+ RtemsIntrReqVectorEnable_Instance;
+static const char * const RtemsIntrReqVectorEnable_PreDesc_Vector[] = {
+ "Valid",
+ "Invalid",
+ "NA"
+static const char * const RtemsIntrReqVectorEnable_PreDesc_IsEnabled[] = {
+ "Yes",
+ "No",
+ "NA"
+static const char * const RtemsIntrReqVectorEnable_PreDesc_CanEnable[] = {
+ "Yes",
+ "Maybe",
+ "No",
+ "NA"
+static const char * const * const RtemsIntrReqVectorEnable_PreDesc[] = {
+ RtemsIntrReqVectorEnable_PreDesc_Vector,
+ RtemsIntrReqVectorEnable_PreDesc_IsEnabled,
+ RtemsIntrReqVectorEnable_PreDesc_CanEnable,
+ NULL
+typedef RtemsIntrReqVectorEnable_Context Context;
+static bool IsEnabled( const Context *ctx )
+ rtems_status_code sc;
+ bool enabled;
+ enabled = false;
+ sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled );
+ T_rsc_success( sc );
+ return enabled;
+static void Enable( const Context *ctx )
+ sc = rtems_interrupt_vector_enable( ctx->vector );
+static void Disable( const Context *ctx )
+ sc = rtems_interrupt_vector_disable( ctx->vector );
+static void EntryRoutine( void *arg )
+ Context *ctx;
+ (void) arg;
+ ctx = T_fixture_context();
+ T_true( IsEnabled( ctx ) );
+ Enable( ctx );
+ Disable( ctx );
+ T_false( IsEnabled( ctx ) );
+ ctx->interrupt_occurred = true;
+static void CheckUnsatisfied( const Context *ctx )
+ bool enabled_before;
+ bool enabled_after;
+ enabled_before = true;
+ sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled_before );
+ T_rsc( sc, RTEMS_UNSATISFIED );
+ enabled_after = !enabled_before;
+ sc = rtems_interrupt_vector_is_enabled( ctx->vector, &enabled_after );
+ T_eq( enabled_before, enabled_after );
+static void CheckVectorEnable(
+ Context *ctx,
+ const rtems_interrupt_attributes *attr,
+ bool has_installed_entries
+ if ( !attr->maybe_enable ) {
+ CheckUnsatisfied( ctx );
+ } else if ( has_installed_entries ) {
+ if ( attr->can_disable ) {
+ Disable( ctx );
+ Enable( ctx );
+ } else if (
+ attr->is_maskable && attr->maybe_enable &&
+ ( attr->always_enabled || attr->can_disable )
+ rtems_interrupt_entry entry;
+ bool enabled;
+ ctx->interrupt_occurred = false;
+ rtems_interrupt_entry_initialize( &entry, EntryRoutine, ctx, "Info" );
+ sc = rtems_interrupt_entry_install(
+ ctx->vector,
+ RTEMS_INTERRUPT_UNIQUE,
+ &entry
+ Disable( ctx );
+ Enable( ctx );
+ Enable( ctx );
+ enabled = false;
+ T_true( enabled || ctx->interrupt_occurred || attr->maybe_enable );
+ sc = rtems_interrupt_entry_remove( ctx->vector, &entry );
+ T_true( !attr->can_disable || !IsEnabled( ctx ) );
+static void RtemsIntrReqVectorEnable_Pre_Vector_Prepare(
+ RtemsIntrReqVectorEnable_Context *ctx,
+ RtemsIntrReqVectorEnable_Pre_Vector state
+ switch ( state ) {
+ case RtemsIntrReqVectorEnable_Pre_Vector_Valid: {
+ * While the ``vector`` parameter is associated with an interrupt vector.
+ ctx->valid_vector = true;
+ break;
+ case RtemsIntrReqVectorEnable_Pre_Vector_Invalid: {
+ * While the ``vector`` parameter is not associated with an interrupt
+ * vector.
+ ctx->valid_vector = false;
+ break;
+ case RtemsIntrReqVectorEnable_Pre_Vector_NA:
+ break;
+static void RtemsIntrReqVectorEnable_Pre_IsEnabled_Prepare(
+ RtemsIntrReqVectorEnable_Pre_IsEnabled state
+ case RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes: {
+ * While the interrupt vector associated with the ``vector`` parameter is
+ * enabled.
+ * This pre-condition depends on the attributes of an interrupt vector,
+ * see CheckVectorEnable().
+ break;
+ case RtemsIntrReqVectorEnable_Pre_IsEnabled_No: {
+ * enabled.
+ break;
+ case RtemsIntrReqVectorEnable_Pre_IsEnabled_NA:
+ break;
+static void RtemsIntrReqVectorEnable_Pre_CanEnable_Prepare(
+ RtemsIntrReqVectorEnable_Pre_CanEnable state
+ case RtemsIntrReqVectorEnable_Pre_CanEnable_Yes: {
+ * can be enabled.
+ break;
+ case RtemsIntrReqVectorEnable_Pre_CanEnable_Maybe: {
+ * may be enabled.
+ break;
+ case RtemsIntrReqVectorEnable_Pre_CanEnable_No: {
+ * cannot be enabled.
+ break;
+ case RtemsIntrReqVectorEnable_Pre_CanEnable_NA:
+ break;
+static void RtemsIntrReqVectorEnable_Post_Status_Check(
+ RtemsIntrReqVectorEnable_Post_Status state
+ case RtemsIntrReqVectorEnable_Post_Status_Ok: {
+ * The return status of rtems_interrupt_vector_enable() shall be
+ * RTEMS_SUCCESSFUL.
+ * Validation is done by CheckVectorEnable() for each interrupt
+ * vector.
+ break;
+ case RtemsIntrReqVectorEnable_Post_Status_InvId: {
+ * RTEMS_INVALID_ID.
+ T_rsc( ctx->status, RTEMS_INVALID_ID );
+ break;
+ case RtemsIntrReqVectorEnable_Post_Status_Unsat: {
+ * RTEMS_UNSATISFIED.
+ * vector.
+ break;
+ case RtemsIntrReqVectorEnable_Post_Status_NA:
+ break;
+static void RtemsIntrReqVectorEnable_Post_IsEnabled_Check(
+ RtemsIntrReqVectorEnable_Post_IsEnabled state
+ case RtemsIntrReqVectorEnable_Post_IsEnabled_Nop: {
+ * The enabled status of the interrupt vector specified by ``vector``
+ * shall not be modified by the rtems_interrupt_vector_enable() call.
+ * Validation is done by CheckUnsatisfied() for each interrupt
+ * vector which cannot be enabled.
+ break;
+ case RtemsIntrReqVectorEnable_Post_IsEnabled_Yes: {
+ * The interrupt vector specified by ``vector`` shall be enabled.
+ * vector.
+ break;
+ case RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe: {
+ * The interrupt vector specified by ``vector`` may be enabled.
+ * vector.
+ break;
+ case RtemsIntrReqVectorEnable_Post_IsEnabled_NA:
+ break;
+static void RtemsIntrReqVectorEnable_Action(
+ if ( ctx->valid_vector ) {
+ for (
+ ctx->vector = 0;
+ ctx->vector < BSP_INTERRUPT_VECTOR_COUNT;
+ ++ctx->vector
+ rtems_interrupt_attributes attr;
+ bool has_installed_entries;
+ memset( &attr, 0, sizeof( attr ) );
+ sc = rtems_interrupt_get_attributes( ctx->vector, &attr );
+ if ( sc == RTEMS_INVALID_ID ) {
+ continue;
+ has_installed_entries = HasInterruptVectorEntriesInstalled( ctx->vector );
+ CheckVectorEnable( ctx, &attr, has_installed_entries );
+ } else {
+ ctx->vector = BSP_INTERRUPT_VECTOR_COUNT;
+ ctx->status = rtems_interrupt_vector_enable( ctx->vector );
+typedef struct {
+ uint8_t Skip : 1;
+ uint8_t Pre_Vector_NA : 1;
+ uint8_t Pre_IsEnabled_NA : 1;
+ uint8_t Pre_CanEnable_NA : 1;
+ uint8_t Post_Status : 2;
+ uint8_t Post_IsEnabled : 2;
+} RtemsIntrReqVectorEnable_Entry;
+static const RtemsIntrReqVectorEnable_Entry
+RtemsIntrReqVectorEnable_Entries[] = {
+ { 0, 0, 1, 1, RtemsIntrReqVectorEnable_Post_Status_InvId,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_NA },
+ { 0, 0, 0, 0, RtemsIntrReqVectorEnable_Post_Status_Ok,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Yes },
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Maybe },
+ { 0, 0, 0, 0, RtemsIntrReqVectorEnable_Post_Status_Unsat,
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Nop }
+static const uint8_t
+RtemsIntrReqVectorEnable_Map[] = {
+ 1, 2, 3, 1, 2, 3, 0, 0, 0, 0, 0, 0
+static size_t RtemsIntrReqVectorEnable_Scope( void *arg, char *buf, size_t n )
+ RtemsIntrReqVectorEnable_Context *ctx;
+ ctx = arg;
+ if ( ctx->in_action_loop ) {
+ return T_get_scope( RtemsIntrReqVectorEnable_PreDesc, buf, n, ctx->pcs );
+ return 0;
+static T_fixture RtemsIntrReqVectorEnable_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = RtemsIntrReqVectorEnable_Scope,
+ .initial_context = &RtemsIntrReqVectorEnable_Instance
+static inline RtemsIntrReqVectorEnable_Entry RtemsIntrReqVectorEnable_GetEntry(
+ size_t index
+ return RtemsIntrReqVectorEnable_Entries[
+ RtemsIntrReqVectorEnable_Map[ index ]
+ * @fn void T_case_body_RtemsIntrReqVectorEnable( void )
+T_TEST_CASE_FIXTURE(
+ RtemsIntrReqVectorEnable,
+ &RtemsIntrReqVectorEnable_Fixture
+ size_t index;
+ ctx->in_action_loop = true;
+ index = 0;
+ for (
+ ctx->pcs[ 0 ] = RtemsIntrReqVectorEnable_Pre_Vector_Valid;
+ ctx->pcs[ 0 ] < RtemsIntrReqVectorEnable_Pre_Vector_NA;
+ ++ctx->pcs[ 0 ]
+ for (
+ ctx->pcs[ 1 ] = RtemsIntrReqVectorEnable_Pre_IsEnabled_Yes;
+ ctx->pcs[ 1 ] < RtemsIntrReqVectorEnable_Pre_IsEnabled_NA;
+ ++ctx->pcs[ 1 ]
+ for (
+ ctx->pcs[ 2 ] = RtemsIntrReqVectorEnable_Pre_CanEnable_Yes;
+ ctx->pcs[ 2 ] < RtemsIntrReqVectorEnable_Pre_CanEnable_NA;
+ ++ctx->pcs[ 2 ]
+ RtemsIntrReqVectorEnable_Entry entry;
+ size_t pcs[ 3 ];
+ entry = RtemsIntrReqVectorEnable_GetEntry( index );
+ ++index;
+ memcpy( pcs, ctx->pcs, sizeof( pcs ) );
+ if ( entry.Pre_IsEnabled_NA ) {
+ ctx->pcs[ 1 ] = RtemsIntrReqVectorEnable_Pre_IsEnabled_NA;
+ if ( entry.Pre_CanEnable_NA ) {
+ ctx->pcs[ 2 ] = RtemsIntrReqVectorEnable_Pre_CanEnable_NA;
+ RtemsIntrReqVectorEnable_Pre_Vector_Prepare( ctx, ctx->pcs[ 0 ] );
+ RtemsIntrReqVectorEnable_Pre_IsEnabled_Prepare( ctx, ctx->pcs[ 1 ] );
+ RtemsIntrReqVectorEnable_Pre_CanEnable_Prepare( ctx, ctx->pcs[ 2 ] );
+ RtemsIntrReqVectorEnable_Action( ctx );
+ RtemsIntrReqVectorEnable_Post_Status_Check( ctx, entry.Post_Status );
+ RtemsIntrReqVectorEnable_Post_IsEnabled_Check(
+ ctx,
+ entry.Post_IsEnabled
+ memcpy( ctx->pcs, pcs, sizeof( ctx->pcs ) );
2.26.2
