[PATCH v1] Reports: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Mon Jul 12 13:42:53 UTC 2021
tester/covoar/ReportsBase.cc | 296 ++++++------
tester/covoar/ReportsBase.h | 118 +++--
tester/covoar/ReportsHtml.cc | 1074 +++++++++++++++++-------------------------
tester/covoar/ReportsHtml.h | 94 ++--
tester/covoar/ReportsText.cc | 261 +++++-----
tester/covoar/ReportsText.h | 34 +-
6 files changed, 838 insertions(+), 1039 deletions(-)
diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
index 328980d..7fd3422 100644
--- a/tester/covoar/ReportsBase.cc
+++ b/tester/covoar/ReportsBase.cc
@@ -4,6 +4,9 @@
#include <sys/stat.h>
#include <sys/types.h>
+#include <iomanip>
+#include <sstream>
#include "ReportsBase.h"
#include "app_common.h"
#include "CoverageRanges.h"
@@ -20,7 +23,7 @@
namespace Coverage {
-ReportsBase::ReportsBase( time_t timestamp, std::string symbolSetName ):
+ReportsBase::ReportsBase( time_t timestamp, const std::string& symbolSetName ):
reportExtension_m(""),
symbolSetName_m(symbolSetName),
timestamp_m( timestamp )
@@ -31,13 +34,13 @@ ReportsBase::~ReportsBase()
-FILE* ReportsBase::OpenFile(
- const char* const fileName,
- const char* const symbolSetName
+void ReportsBase::OpenFile(
+ const std::string& fileName,
+ const std::string& symbolSetName,
+ std::ofstream& aFile
int sc;
- FILE *aFile;
std::string file;
std::string symbolSetOutputDirectory;
@@ -54,120 +57,131 @@ FILE* ReportsBase::OpenFile(
sc = mkdir( symbolSetOutputDirectory.c_str(),0755 );
#endif
if ( (sc == -1) && (errno != EEXIST) ) {
- fprintf(
- stderr,
- "Unable to create output directory %s\n",
- symbolSetOutputDirectory.c_str()
+ throw rld::error(
+ "Unable to create output directory",
+ "ReportsBase::OpenFile"
- return NULL;
+ return;
file = symbolSetOutputDirectory;
rld::path::path_join(file, fileName, file);
// Open the file.
- aFile = fopen( file.c_str(), "w" );
- if ( !aFile ) {
- fprintf( stderr, "Unable to open %s\n", file.c_str() );
+ aFile.open( file );
+ if ( !aFile.is_open() ) {
+ std::cerr << "Unable to open " << file << std::endl;
- return aFile;
+ return;
void ReportsBase::WriteIndex(
-FILE* ReportsBase::OpenAnnotatedFile(
+void ReportsBase::OpenAnnotatedFile(
- return OpenFile(fileName, symbolSetName_m.c_str());
+ OpenFile(fileName, symbolSetName_m, aFile);
+ return;
-FILE* ReportsBase::OpenBranchFile(
- bool hasBranches
+void ReportsBase::OpenBranchFile(
+ bool hasBranches,
+ return;
-FILE* ReportsBase::OpenCoverageFile(
+void ReportsBase::OpenCoverageFile(
+ return;
-FILE* ReportsBase::OpenNoRangeFile(
+void ReportsBase::OpenNoRangeFile(
+ return;
-FILE* ReportsBase::OpenSizeFile(
+void ReportsBase::OpenSizeFile(
+ return;
-FILE* ReportsBase::OpenSymbolSummaryFile(
+void ReportsBase::OpenSymbolSummaryFile(
+ return;
void ReportsBase::CloseFile(
- FILE* aFile
- fclose( aFile );
+ aFile.close();
void ReportsBase::CloseAnnotatedFile(
- FILE* aFile
CloseFile( aFile );
void ReportsBase::CloseBranchFile(
- FILE* aFile,
- bool hasBranches
+ std::ofstream& aFile,
+ bool hasBranches
CloseFile( aFile );
void ReportsBase::CloseCoverageFile(
- FILE* aFile
CloseFile( aFile );
void ReportsBase::CloseNoRangeFile(
- FILE* aFile
CloseFile( aFile );
void ReportsBase::CloseSizeFile(
- FILE* aFile
CloseFile( aFile );
void ReportsBase::CloseSymbolSummaryFile(
- FILE* aFile
CloseFile( aFile );
@@ -195,18 +209,23 @@ std::string expand_tabs(const std::string& in) {
* Write annotated report
void ReportsBase::WriteAnnotatedReport(
- FILE* aFile = NULL;
+ std::ofstream aFile;
Coverage::CoverageRanges* theBranches;
Coverage::CoverageRanges* theRanges;
Coverage::CoverageMapBase* theCoverageMap = NULL;
uint32_t bAddress = 0;
AnnotatedLineState_t state;
- aFile = OpenAnnotatedFile(fileName);
- if (!aFile)
+ OpenAnnotatedFile(fileName, aFile);
+ if (!aFile.is_open()) {
+ throw rld::error(
+ "Unable to open " + fileName,
+ "ReportsBase::WriteAnnotatedReport"
return;
// Process uncovered branches for each symbol.
const std::vector<std::string>& symbols = SymbolsToAnalyze->getSymbolsForSet(symbolSetName_m);
@@ -238,7 +257,8 @@ void ReportsBase::WriteAnnotatedReport(
std::string annotation = "";
std::string line;
const std::size_t LINE_LENGTH = 150;
- char textLine[LINE_LENGTH];
+ std::string textLine = "";
+ std::stringstream ss;
state = A_SOURCE;
@@ -264,7 +284,12 @@ void ReportsBase::WriteAnnotatedReport(
std::string textLineWithoutTabs = expand_tabs(instruction.line);
- snprintf( textLine, LINE_LENGTH, "%-90s", textLineWithoutTabs.c_str() );
+ ss << std::left << std::setw( 90 )
+ << textLineWithoutTabs.c_str();
+ textLine = ss.str().substr( 0, LINE_LENGTH );
line = textLine + annotation;
PutAnnotatedLine( aFile, state, line, id);
@@ -280,9 +305,9 @@ void ReportsBase::WriteAnnotatedReport(
* Write branch report
void ReportsBase::WriteBranchReport(
- FILE* report = NULL;
+ std::ofstream report;
unsigned int count;
bool hasBranches = true;
@@ -292,8 +317,8 @@ void ReportsBase::WriteBranchReport(
hasBranches = false;
// Open the branch report file
- report = OpenBranchFile( fileName, hasBranches );
- if (!report)
+ OpenBranchFile( fileName, hasBranches, report );
+ if (!report.is_open())
return;
// If no branches were found then branch coverage is not supported
@@ -324,26 +349,26 @@ void ReportsBase::WriteBranchReport(
* Write coverage report
void ReportsBase::WriteCoverageReport(
- FILE* report;
unsigned int count;
- FILE* NoRangeFile;
+ std::ofstream NoRangeFile;
std::string NoRangeName;
// Open special file that captures NoRange informaiton
NoRangeName = "no_range_";
NoRangeName += fileName;
- NoRangeFile = OpenNoRangeFile ( NoRangeName.c_str() );
- if (!NoRangeFile) {
+ OpenNoRangeFile( NoRangeName, NoRangeFile );
+ if ( !NoRangeFile.is_open() ) {
return;
// Open the coverage report file.
- report = OpenCoverageFile( fileName );
- if ( !report ) {
+ OpenCoverageFile( fileName, report );
+ if ( !report.is_open() ) {
return;
@@ -380,16 +405,16 @@ void ReportsBase::WriteCoverageReport(
* Write size report
void ReportsBase::WriteSizeReport(
- FILE* report;
unsigned int count;
// Open the report file.
- report = OpenSizeFile( fileName );
- if ( !report ) {
+ OpenSizeFile( fileName, report );
return;
@@ -414,15 +439,15 @@ void ReportsBase::WriteSizeReport(
void ReportsBase::WriteSymbolSummaryReport(
- FILE* report;
unsigned int count;
- report = OpenSymbolSummaryFile( fileName );
- if ( !report ) {
+ OpenSymbolSummaryFile( fileName , report );
return;
@@ -441,8 +466,8 @@ void ReportsBase::WriteSymbolSummaryReport(
void ReportsBase::WriteSummaryReport(
// Calculate coverage statistics and output results.
@@ -453,11 +478,11 @@ void ReportsBase::WriteSummaryReport(
double percentageBranches;
Coverage::CoverageMapBase* theCoverageMap;
uint32_t totalBytes = 0;
- FILE* report;
- report = OpenFile( fileName, symbolSetName );
- if ( !report ) {
+ OpenFile( fileName, symbolSetName, report );
return;
@@ -497,64 +522,45 @@ void ReportsBase::WriteSummaryReport(
(double) SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2;
percentageBranches *= 100.0;
- fprintf( report, "Bytes Analyzed : %d\n", totalBytes );
- fprintf( report, "Bytes Not Executed : %d\n", notExecuted );
- fprintf( report, "Percentage Executed : %5.4g\n", 100.0 - percentage );
- fprintf( report, "Percentage Not Executed : %5.4g\n", percentage );
- fprintf(
- report,
- "Unreferenced Symbols : %d\n",
- SymbolsToAnalyze->getNumberUnreferencedSymbols(symbolSetName)
- fprintf(
- report,
- "Uncovered ranges found : %d\n\n",
- SymbolsToAnalyze->getNumberUncoveredRanges(symbolSetName)
+ report << "Bytes Analyzed : " << totalBytes << std::endl
+ << "Bytes Not Executed : " << notExecuted << std::endl
+ << "Percentage Executed : "
+ << std::fixed << std::setprecision( 2 ) << std::setw( 5 )
+ << 100.0 - percentage << std::endl
+ << "Percentage Not Executed : " << percentage << std::endl
+ << "Unreferenced Symbols : "
+ << SymbolsToAnalyze->getNumberUnreferencedSymbols( symbolSetName )
+ << std::endl << "Uncovered ranges found : "
+ << SymbolsToAnalyze->getNumberUncoveredRanges( symbolSetName )
+ << std::endl << std::endl;
if ((SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) == 0) ||
(BranchInfoAvailable == false) ) {
- fprintf( report, "No branch information available\n" );
+ report << "No branch information available" << std::endl;
} else {
- fprintf(
- report,
- "Total conditional branches found : %d\n",
- SymbolsToAnalyze->getNumberBranchesFound(symbolSetName)
- fprintf(
- report,
- "Total branch paths found : %d\n",
- SymbolsToAnalyze->getNumberBranchesFound(symbolSetName) * 2
- fprintf(
- report,
- "Uncovered branch paths found : %d\n",
- SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
- SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
- (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
- fprintf(
- report,
- " %d branches always taken\n",
- fprintf(
- report,
- " %d branches never taken\n",
- fprintf(
- report,
- " %d branch paths not executed\n",
- SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
- fprintf(
- report,
- "Percentage branch paths covered : %4.4g\n",
- 100.0 - percentageBranches
+ report << "Total conditional branches found : "
+ << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName )
+ << std::endl << "Total branch paths found : "
+ << SymbolsToAnalyze->getNumberBranchesFound( symbolSetName ) * 2
+ << std::endl << "Uncovered branch paths found : "
+ << SymbolsToAnalyze->getNumberBranchesAlwaysTaken(symbolSetName) +
+ SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName) +
+ (SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2)
+ << std::endl << " "
+ << " branches always taken" << std::endl << " "
+ << SymbolsToAnalyze->getNumberBranchesNeverTaken(symbolSetName)
+ << " branches never taken" << std::endl << " "
+ << SymbolsToAnalyze->getNumberBranchesNotExecuted(symbolSetName) * 2
+ << " branch paths not executed" << std::endl
+ << "Percentage branch paths covered : "
+ << std::fixed << std::setprecision(2) << std::setw(4)
+ << 100.0 - percentageBranches << std::endl;
- fclose( report );
+ CloseFile( report );
void GenerateReports(const std::string& symbolSetName)
@@ -580,45 +586,33 @@ void GenerateReports(const std::string& symbolSetName)
reportName = "index" + reports->ReportExtension();
if (Verbose)
- fprintf(
- stderr, "Generate %s\n", reportName.c_str()
- reports->WriteIndex( reportName.c_str() );
+ std::cerr << "Generate " << reportName << std::endl;
+ reports->WriteIndex( reportName );
reportName = "annotated" + reports->ReportExtension();
if (Verbose)
- fprintf(
- reports->WriteAnnotatedReport( reportName.c_str() );
+ reports->WriteAnnotatedReport( reportName );
reportName = "branch" + reports->ReportExtension();
if (Verbose)
- fprintf(
- reports->WriteBranchReport(reportName.c_str() );
+ reports->WriteBranchReport( reportName );
reportName = "uncovered" + reports->ReportExtension();
if (Verbose)
- fprintf(
- reports->WriteCoverageReport(reportName.c_str() );
+ reports->WriteCoverageReport( reportName );
reportName = "sizes" + reports->ReportExtension();
if (Verbose)
- fprintf(
- reports->WriteSizeReport(reportName.c_str() );
+ reports->WriteSizeReport( reportName );
reportName = "symbolSummary" + reports->ReportExtension();
if (Verbose)
- fprintf(
- reports->WriteSymbolSummaryReport(reportName.c_str() );
+ reports->WriteSymbolSummaryReport( reportName );
for (ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
@@ -626,7 +620,7 @@ void GenerateReports(const std::string& symbolSetName)
delete reports;
- ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName.c_str() );
+ ReportsBase::WriteSummaryReport( "summary.txt", symbolSetName );
diff --git a/tester/covoar/ReportsBase.h b/tester/covoar/ReportsBase.h
index ab8f8dd..ed381fb 100644
--- a/tester/covoar/ReportsBase.h
+++ b/tester/covoar/ReportsBase.h
@@ -11,6 +11,8 @@
#include <stdint.h>
#include <string>
+#include <iostream>
+#include <fstream>
#include <time.h>
#include "DesiredSymbols.h"
@@ -24,7 +26,7 @@ namespace Coverage {
class ReportsBase {
public:
- ReportsBase( time_t timestamp, std::string symbolSetName );
+ ReportsBase( time_t timestamp, const std::string& symbolSetName );
virtual ~ReportsBase();
@@ -33,7 +35,7 @@ class ReportsBase {
* @param[in] fileName identifies the report file name
virtual void WriteIndex(
@@ -43,7 +45,7 @@ class ReportsBase {
* @param[in] fileName identifies the annotated report file name
void WriteAnnotatedReport(
@@ -53,7 +55,7 @@ class ReportsBase {
* @param[in] fileName identifies the branch report file name
void WriteBranchReport(
@@ -63,7 +65,7 @@ class ReportsBase {
* @param[in] fileName identifies the coverage report file name
void WriteCoverageReport(
@@ -73,7 +75,7 @@ class ReportsBase {
void WriteSizeReport(
@@ -83,15 +85,15 @@ class ReportsBase {
void WriteSymbolSummaryReport(
* This method produces a sumary report for the overall test run.
static void WriteSummaryReport(
@@ -135,10 +137,12 @@ class ReportsBase {
* @param[in] symbolSetName identifies the name of the report's symbol set
+ * @param[in] aFile identifies the file to open
- static FILE* OpenFile(
+ static void OpenFile(
@@ -146,9 +150,11 @@ class ReportsBase {
* Then appedns any necessary header information onto the file.
- virtual FILE* OpenAnnotatedFile(
+ virtual void OpenAnnotatedFile(
@@ -157,10 +163,12 @@ class ReportsBase {
* @param[in] hasBranches indicates if there are branches to report
- virtual FILE* OpenBranchFile(
- bool hasBranches
+ virtual void OpenBranchFile(
+ bool hasBranches,
@@ -168,9 +176,11 @@ class ReportsBase {
- virtual FILE* OpenCoverageFile(
+ virtual void OpenCoverageFile(
@@ -178,9 +188,11 @@ class ReportsBase {
* Then appends any necessary header information onto the file.
- virtual FILE* OpenNoRangeFile(
+ virtual void OpenNoRangeFile(
@@ -188,9 +200,11 @@ class ReportsBase {
- virtual FILE* OpenSizeFile(
+ virtual void OpenSizeFile(
@@ -198,39 +212,41 @@ class ReportsBase {
- virtual FILE* OpenSymbolSummaryFile(
+ virtual void OpenSymbolSummaryFile(
* This method Closes a report file.
- * @param[in] aFile identifies the report file name
+ * @param[in] aFile identifies the file to close
static void CloseFile(
- FILE* aFile
* This method puts any necessary footer information into
* the report then closes the file.
virtual void CloseAnnotatedFile(
- FILE* aFile
virtual void CloseBranchFile(
- FILE* aFile,
bool hasBranches
@@ -238,40 +254,40 @@ class ReportsBase {
virtual void CloseCoverageFile(
- FILE* aFile
void CloseNoRangeFile(
- FILE* aFile
virtual void CloseSizeFile(
- FILE* aFile
virtual void CloseSymbolSummaryFile(
- FILE* aFile
@@ -284,9 +300,9 @@ class ReportsBase {
* @param[in] id identifies the branch or range id.
virtual void PutAnnotatedLine(
- FILE* aFile,
AnnotatedLineState_t state,
- std::string line,
+ const std::string& line,
uint32_t id
)=0;
@@ -297,7 +313,7 @@ class ReportsBase {
virtual void AnnotatedStart(
- FILE* aFile
)=0;
@@ -307,7 +323,7 @@ class ReportsBase {
virtual void AnnotatedEnd(
- FILE* aFile
)=0;
@@ -318,7 +334,7 @@ class ReportsBase {
* @param[in] report identifies the report file name
virtual bool PutNoBranchInfo(
- FILE* report
+ std::ofstream& report
) = 0;
@@ -331,7 +347,7 @@ class ReportsBase {
* @param[in] range is the range information.
virtual bool PutBranchEntry(
- FILE* report,
+ std::ofstream& report,
unsigned int number,
const std::string& symbolName,
const SymbolInformation& symbolInfo,
@@ -347,10 +363,10 @@ class ReportsBase {
* @param[in] symbol is a pointer to the symbol information
virtual void putCoverageNoRange(
- FILE* report,
- FILE* noRangeFile,
+ std::ofstream& noRangeFile,
- std::string symbol
)=0;
@@ -363,7 +379,7 @@ class ReportsBase {
virtual bool PutCoverageLine(
- FILE* report,
@@ -379,7 +395,7 @@ class ReportsBase {
virtual bool PutSizeLine(
- FILE* report,
const CoverageRanges::coverageRange_t& range
@@ -394,7 +410,7 @@ class ReportsBase {
* @param[in] symbolInfo is the symbol's information.
virtual bool PutSymbolSummaryLine(
- FILE* report,
diff --git a/tester/covoar/ReportsHtml.cc b/tester/covoar/ReportsHtml.cc
index fe75cdd..f9bd21f 100644
--- a/tester/covoar/ReportsHtml.cc
+++ b/tester/covoar/ReportsHtml.cc
@@ -2,6 +2,9 @@
+#include <sstream>
+#include <iomanip>
#include <rld.h>
#include "ReportsHtml.h"
@@ -25,13 +28,13 @@
"</tr>\n" \
"</tfoot>\n"
#else
-#define TABLE_HEADER_CLASS
-#define TABLE_FOOTER
+#define TABLE_HEADER_CLASS ""
+#define TABLE_FOOTER ""
#endif
- ReportsHtml::ReportsHtml( time_t timestamp, std::string symbolSetName ):
+ ReportsHtml::ReportsHtml( time_t timestamp, const std::string& symbolSetName ):
ReportsBase( timestamp, symbolSetName )
reportExtension_m = ".html";
@@ -42,63 +45,46 @@ namespace Coverage {
void ReportsHtml::WriteIndex(
#define PRINT_ITEM( _t, _n ) \
- fprintf( \
- aFile, \
- "<li>%s (<a href=\"%s.html\">html</a> or "\
- "<a href=\"%s.txt\">text</a>)</li>\n", \
- _t, _n, _n );
+ aFile << "<li>" \
+ << _t << " (<a href=\"" \
+ << _n << ".html\">html</a> or <a href=\"" \
+ << _n << ".txt\">text</a>)</li>" << std::endl;
#define PRINT_TEXT_ITEM( _t, _n ) \
- fprintf( \
- aFile, \
- "<li>%s (<a href=\"%s\">text</a>)</li>\n", \
- _t, _n );
+ aFile << "<li>" \
+ << _n << "\">text</a>)</li>" << std::endl;
- FILE* aFile;
// Open the file
- aFile = OpenFile( fileName );
+ OpenFile(fileName, aFile);
- fprintf(
- aFile,
- "<title>Index</title>\n"
- "<div class=\"heading-title\">"
+ aFile << "<title>Index</title>" << std::endl
+ << "<div class=\"heading-title\">";
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Coverage Analysis Reports</div>\n"
- "<div class =\"datetime\">%s</div>\n",
- asctime( localtime(×tamp_m) )
+ aFile << projectName << "<br>";
- fprintf( aFile, "<ul>\n" );
+ aFile << "Coverage Analysis Reports</div>" << std::endl
+ << "<div class =\"datetime\">"
+ << asctime( localtime( ×tamp_m ) ) << "</div>" << std::endl
+ << "<ul>" << std::endl;
- PRINT_TEXT_ITEM( "Summary", "summary.txt" );
- PRINT_ITEM( "Coverage Report", "uncovered" );
- PRINT_ITEM( "Branch Report", "branch" );
- PRINT_ITEM( "Annotated Assembly", "annotated" );
- PRINT_ITEM( "Symbol Summary", "symbolSummary" );
- PRINT_ITEM( "Uncovered Range Size Report", "sizes" );
+ PRINT_TEXT_ITEM( "Summary", "summary.txt" );
+ PRINT_ITEM( "Coverage Report", "uncovered" );
+ PRINT_ITEM( "Branch Report", "branch" );
+ PRINT_ITEM( "Annotated Assembly", "annotated" );
+ PRINT_ITEM( "Symbol Summary", "symbolSummary" );
+ PRINT_ITEM( "Uncovered Range Size Report", "sizes" );
+ PRINT_TEXT_ITEM( "Explanations Not Found", "ExplanationsNotFound.txt" );
- PRINT_TEXT_ITEM( "Explanations Not Found", "ExplanationsNotFound.txt" );
- fprintf(
- aFile,
- "</ul>\n"
- "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->\n"
- "</html>\n"
+ aFile << "</ul>" << std::endl
+ << "<!-- INSERT PROJECT SPECIFIC ITEMS HERE -->" << std::endl
+ << "</html>" << std::endl;
CloseFile( aFile );
@@ -106,332 +92,273 @@ namespace Coverage {
#undef PRINT_TEXT_ITEM
- FILE* ReportsHtml::OpenFile(
+ void ReportsHtml::OpenFile(
- FILE* aFile;
// Open the file
- aFile = ReportsBase::OpenFile( fileName, symbolSetName_m.c_str() );
+ ReportsBase::OpenFile(fileName, symbolSetName_m, aFile);
// Put Header information on the file
- fprintf(
- aFile,
- "<html>\n"
- "<meta http-equiv=\"Content-Language\" content=\"English\" >\n"
- "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >\n"
- "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >\n"
- "<script type=\"text/javascript\" src=\"../table.js\"></script>\n"
- return aFile;
+ aFile << "<html>" << std::endl
+ << "<meta http-equiv=\"Content-Language\" content=\"English\" >"
+ << std::endl
+ << "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=us-ascii\" >"
+ << std::endl
+ << "<link rel=\"stylesheet\" type=\"text/css\" href=\"../covoar.css\" media=\"screen\" >"
+ << std::endl
+ << "<script type=\"text/javascript\" src=\"../table.js\"></script>"
+ << std::endl;
- FILE* ReportsHtml::OpenAnnotatedFile(
+ void ReportsHtml::OpenAnnotatedFile(
- FILE *aFile;
// Open the file
- aFile = OpenFile(fileName);
- fprintf(
- aFile,
- "<title>Annotated Report</title>\n"
+ aFile << "<title>Annotated Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Annotated Report</div>\n"
- "<body>\n"
- "<pre class=\"code\">\n",
- return aFile;
+ aFile << "Annotated Report</div>" << std::endl
+ << "<body>" << std::endl
+ << "<pre class=\"code\">" << std::endl;
- FILE* ReportsHtml::OpenBranchFile(
- bool hasBranches
+ void ReportsHtml::OpenBranchFile(
+ bool hasBranches,
- FILE *aFile;
// Open the file
// Put header information into the file
- fprintf(
- aFile,
- "<title>Branch Report</title>\n"
+ aFile << "<title>Branch Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Branch Report</div>\n"
- "<body>\n"
- "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
- TABLE_HEADER_CLASS "\">\n"
- "<thead>\n"
- "<tr>\n"
- "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>\n"
- "<th class=\"table-sortable:default\" align=\"left\">Line</th>\n"
- "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>\n"
- "<th class=\"table-sortable:default\" align=\"left\">Reason</th>\n"
- "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>\n"
- "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>\n"
- "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>\n"
- "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>\n"
- "</tr>\n"
- "</thead>\n"
- "<tbody>\n",
- return aFile;
+ aFile << "Branch Report</div>" << std::endl
+ << "<table class=\"covoar table-autosort:0 table-autofilter table-stripeclass:covoar-tr-odd"
+ << TABLE_HEADER_CLASS << "\">" << std::endl
+ << "<thead>" << std::endl
+ << "<tr>" << std::endl
+ << "<th class=\"table-sortable:default\" align=\"left\">Symbol</th>" << std::endl
+ << "<th class=\"table-sortable:default\" align=\"left\">Line</th>"
+ << std::endl
+ << "<th class=\"table-filterable table-sortable:default\" align=\"left\">File</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Bytes</th>"
+ << std::endl
+ << "<th class=\"table-sortable:default\" align=\"left\">Reason</th>"
+ << std::endl
+ << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Taken</th>"
+ << std::endl
+ << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Not Taken</th>"
+ << std::endl
+ << "<th class=\"table-filterable table-sortable:default\" align=\"left\">Classification</th>"
+ << std::endl
+ << "<th class=\"table-sortable:default\" align=\"left\">Explanation</th>"
+ << std::endl
+ << "</tr>" << std::endl
+ << "</thead>" << std::endl
+ << "<tbody>" << std::endl;
- FILE* ReportsHtml::OpenCoverageFile(
+ void ReportsHtml::OpenCoverageFile(
- FILE *aFile;
// Open the file
- fprintf(
- aFile,
- "<title>Coverage Report</title>\n"
+ aFile << "<title>Coverage Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Coverage Report</div>\n"
- "<body>\n"
- "<thead>\n"
- "<tr>\n"
- "<th class=\"table-sortable:default\" align=\"left\">Range</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>\n"
- "</tr>\n"
- "</thead>\n"
- "<tbody>\n",
- return aFile;
+ aFile << "Coverage Report</div>" << std::endl
+ << std::endl
+ << "<th class=\"table-sortable:default\" align=\"left\">Range</th>"
+ << std::endl
+ << std::endl
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"left\">Size <br>Instructions</th>"
+ << std::endl
+ << std::endl
+ << std::endl
- FILE* ReportsHtml::OpenNoRangeFile(
+ void ReportsHtml::OpenNoRangeFile(
- FILE *aFile;
// Open the file
- fprintf(
- aFile,
- "<title> Report</title>\n"
+ aFile << "<title> Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "No Range Report</div>\n"
- "<body>\n"
- "<thead>\n"
- "<tr>\n"
- "</tr>\n"
- "</thead>\n"
- "<tbody>\n",
- return aFile;
+ aFile << "No Range Report</div>" << std::endl
+ << std::endl
- FILE* ReportsHtml::OpenSizeFile(
+ void ReportsHtml::OpenSizeFile(
- FILE *aFile;
// Open the file
- fprintf(
- aFile,
- "<title>Uncovered Range Size Report</title>\n"
+ aFile << "<title>Uncovered Range Size Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Uncovered Range Size Report</div>\n"
- "<body>\n"
- "<thead>\n"
- "<tr>\n"
- "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>\n"
- "</tr>\n"
- "</thead>\n"
- "<tbody>\n",
- return aFile;
+ aFile << "Uncovered Range Size Report</div>" << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"left\">Size</th>"
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
- FILE* ReportsHtml::OpenSymbolSummaryFile(
+ void ReportsHtml::OpenSymbolSummaryFile(
- FILE *aFile;
// Open the file
- fprintf(
- aFile,
- "<title>Symbol Summary Report</title>\n"
+ aFile << "<title>Symbol Summary Report</title>" << std::endl
if (projectName)
- fprintf(
- aFile,
- "%s<br>",
- projectName
- fprintf(
- aFile,
- "Symbol Summary Report</div>\n"
- "<body>\n"
- "<thead>\n"
- "<tr>\n"
- "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>\n"
- "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>\n"
- "</tr>\n"
- "</thead>\n"
- "<tbody>\n",
- return aFile;
+ aFile << "Symbol Summary Report</div>" << std::endl
+ << "<th class=\"table-sortable:default\" align=\"center\">Symbol</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Bytes</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Total<br>Size<br>Instr</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Ranges</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Bytes</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Uncovered<br>Size<br>Instr</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Branches</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Always<br>Taken</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">#<br>Never<br>Taken</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Instructions</th>"
+ << std::endl
+ << "<th class=\"table-sortable:numeric\" align=\"center\">Percent<br>Uncovered<br>Bytes</th>"
+ << std::endl
- void ReportsHtml::AnnotatedStart(
- FILE* aFile
+ void ReportsHtml::AnnotatedStart( std::ofstream& aFile )
- fprintf(
- aFile,
- "<hr>\n"
+ aFile << "<hr>" << std::endl;
- void ReportsHtml::AnnotatedEnd(
- FILE* aFile
+ void ReportsHtml::AnnotatedEnd( std::ofstream& aFile )
void ReportsHtml::PutAnnotatedLine(
- FILE* aFile,
- std::string line,
uint32_t id
std::string stateText;
- char number[10];
+ std::string number;
- sprintf(number,"%d", id);
+ number = std::to_string( id );
// Set the stateText based upon the current state.
switch (state) {
@@ -460,7 +387,7 @@ namespace Coverage {
stateText += "\"></a><pre class=\"codeNeverTaken\">\n";
break;
default:
- throw rld::error( "Unknown state", "ReportsHtml::PutAnnotatedLine");
+ throw rld::error("Unknown state", "ReportsHtml::PutAnnotatedLine");
break;
@@ -468,7 +395,7 @@ namespace Coverage {
// format. If it has changed close out the old format and open up the
// new format.
if ( state != lastState_m ) {
- fprintf( aFile, "%s", stateText.c_str() );
+ aFile << stateText;
lastState_m = state;
@@ -477,27 +404,27 @@ namespace Coverage {
// is only a '<' symbol.
for (unsigned int i=0; i<line.size(); i++ ) {
if ( line[i] == '<' )
- fprintf( aFile, "<" );
+ aFile << "<";
else
- fprintf( aFile, "%c", line[i] );
+ aFile << line[i];
- fprintf( aFile, "\n");
+ aFile << std::endl;
bool ReportsHtml::PutNoBranchInfo(
- FILE* report
if (BranchInfoAvailable &&
SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0)
- fprintf( report, "All branch paths taken.\n" );
+ report << "All branch paths taken." << std::endl;
else
- fprintf( report, "No branch information found.\n" );
+ report << "No branch information found." << std::endl;
return true;
bool ReportsHtml::PutBranchEntry(
- FILE* report,
unsigned int count,
@@ -513,124 +440,99 @@ namespace Coverage {
// Mark the background color different for odd and even lines.
if ( ( count%2 ) != 0 )
- fprintf( report, "<tr class=\"covoar-tr-odd\">\n");
+ report << "<tr class=\"covoar-tr-odd\">\n";
else
- fprintf( report, "<tr>\n");
+ report << "<tr>" << std::endl;
// symbol
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">%s</td>\n",
- symbolName.c_str()
+ report << "<td class=\"covoar-td\" align=\"center\">"
+ << symbolName << "</td>" << std::endl;
// line
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s</td>\n",
- range.id,
- range.lowSourceLine.c_str()
+ report << "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range"
+ << range.id << "\">"
+ << range.lowSourceLine << "</td>" << std::endl;
// File
i = range.lowSourceLine.find(":");
temp = range.lowSourceLine.substr (0, i);
- fprintf(
- report,
- temp.c_str()
+ << temp << "</td>" << std::endl;
// Size in bytes
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">%d</td>\n",
- range.highAddress - range.lowAddress + 1
+ << range.highAddress - range.lowAddress + 1 << "</td>" << std::endl;
// Reason Branch was uncovered
if (range.reason ==
Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">Always Taken</td>\n"
+ report << "<td class=\"covoar-td\" align=\"center\">Always Taken</td>"
+ << std::endl;
else if (range.reason ==
Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">Never Taken</td>\n"
+ report << "<td class=\"covoar-td\" align=\"center\">Never Taken</td>"
+ << std::endl;
// Taken / Not taken counts
lowAddress = range.lowAddress;
bAddress = symbolInfo.baseAddress;
theCoverageMap = symbolInfo.unifiedCoverageMap;
- fprintf(
- report,
- theCoverageMap->getWasTaken( lowAddress - bAddress )
- fprintf(
- report,
- theCoverageMap->getWasNotTaken( lowAddress - bAddress )
+ << theCoverageMap->getWasTaken( lowAddress - bAddress )
+ << "</td>" << std::endl
+ << "<td class=\"covoar-td\" align=\"center\">"
+ << theCoverageMap->getWasNotTaken( lowAddress - bAddress )
+ << "</td>" << std::endl;
// See if an explanation is available and write the Classification and
// the Explination Columns.
explanation = AllExplanations->lookupExplanation( range.lowSourceLine );
if ( !explanation ) {
// Write Classificationditr->second.baseAddress
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">NONE</td>\n"
- "<td class=\"covoar-td\" align=\"center\">No Explanation</td>\n"
+ report << "<td class=\"covoar-td\" align=\"center\">NONE</td>"
+ << std::endl
+ << "<td class=\"covoar-td\" align=\"center\">No Explanation</td>"
+ << std::endl;
} else {
- char explanationFile[48];
- sprintf( explanationFile, "explanation%d.html", range.id );
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">"
- "<a href=\"%s\">Explanation</a></td>\n",
- explanation->classification.c_str(),
- explanationFile
- WriteExplationFile( explanationFile, explanation );
+ std::stringstream explanationFile( "explanation" );
+ explanationFile << range.id << ".html";
+ << explanation->classification << "</td>" << std::endl
+ << "<a href=\"" << explanationFile.str()
+ << "\">Explanation</a></td>" << std::endl;
+ WriteExplanationFile( explanationFile.str(), explanation );
- fprintf( report, "</tr>\n");
+ report << "</tr>" << std::endl;
return true;
- bool ReportsHtml::WriteExplationFile(
- const char* fileName,
+ bool ReportsHtml::WriteExplanationFile(
const Coverage::Explanation* explanation
- FILE* report;
- report = OpenFile( fileName );
+ OpenFile(fileName, report);
for ( unsigned int i=0 ; i < explanation->explanation.size(); i++) {
- fprintf(
- report,
- "%s\n",
- explanation->explanation[i].c_str()
+ report << explanation->explanation[i] << std::endl;
return true;
void ReportsHtml::putCoverageNoRange(
- FILE* report,
unsigned int count,
Coverage::Explanation explanation;
@@ -646,64 +548,50 @@ namespace Coverage {
if ( ( count%2 ) != 0 ){
- fprintf( noRangeFile, "<tr class=\"covoar-tr-odd\">\n");
+ report << "<tr class=\"covoar-tr-odd\">" << std::endl;
+ noRangeFile << "<tr class=\"covoar-tr-odd\">" << std::endl;
} else {
- fprintf( noRangeFile, "<tr>\n");
+ noRangeFile << "<tr>" << std::endl;
// symbol
- fprintf(
- report,
- symbol.c_str()
- fprintf(
- noRangeFile,
- symbol.c_str()
+ << symbol << "</td>" << std::endl;
+ noRangeFile << "<td class=\"covoar-td\" align=\"center\">"
// starting line
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">unknown</td>\n"
+ report << "<td class=\"covoar-td\" align=\"center\">unknown</td>"
+ << std::endl;
// file
- fprintf(
- report,
+ << std::endl;
// Size in bytes
- fprintf(
- report,
+ << std::endl;
// Size in instructions
- fprintf(
- report,
+ << std::endl;
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">Unknown</td>\n"
- "<a href=\"NotReferenced.html\">No data</a></td>\n"
- WriteExplationFile( "NotReferenced.html", &explanation );
+ report << "<td class=\"covoar-td\" align=\"center\">Unknown</td>"
+ << std::endl
+ << "<a href=\"NotReferenced.html\">No data</a></td>"
+ << std::endl;
+ WriteExplanationFile( "NotReferenced.html", &explanation );
- fprintf( noRangeFile, "</tr>\n");
+ noRangeFile << "</tr>" << std::endl;
bool ReportsHtml::PutCoverageLine(
- FILE* report,
unsigned int count,
@@ -715,83 +603,65 @@ namespace Coverage {
int i;
- if ( ( count%2 ) != 0 )
+ if ( ( count% 2) != 0 )
else
// symbol
- fprintf(
- report,
// Range
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\"><a href =\"annotated.html#range%d\">%s <br>%s</td>\n",
- range.id,
- range.lowSourceLine.c_str(),
- range.highSourceLine.c_str()
+ << range.lowSourceLine << " <br>"
+ << range.highSourceLine << "</td>" << std::endl;
// File
- fprintf(
- report,
- temp.c_str()
// Size in bytes
- fprintf(
- report,
- fprintf(
- report,
- range.instructionCount
+ << range.instructionCount << "</td>" << std::endl;
- fprintf(
- report,
- fprintf(
- report,
+ << std::endl
+ << std::endl;
} else {
- fprintf(
- report,
- explanationFile
+ << "<a href=\""
+ << explanationFile.str() << "\">Explanation</a></td>"
+ << std::endl;
return true;
bool ReportsHtml::PutSizeLine(
- FILE* report,
unsigned int count,
@@ -802,48 +672,35 @@ namespace Coverage {
else
// size
- fprintf(
- report,
// symbol
- fprintf(
- report,
// line
- fprintf(
- report,
- range.id,
// File
- fprintf(
- report,
- temp.c_str()
+ << "</tr>" << std::endl;
return true;
bool ReportsHtml::PutSymbolSummaryLine(
- FILE* report,
unsigned int count,
@@ -852,216 +709,173 @@ namespace Coverage {
else
// symbol
- fprintf(
- report,
if (symbolInfo.stats.sizeInBytes == 0) {
// The symbol has never been seen. Write "unknown" for all columns.
- fprintf(
- report,
+ << std::endl
+ << "<td class=\"covoar-td\" align=\"center\">unknown</td>"
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
+ << std::endl;
} else {
// Total Size in Bytes
- fprintf(
- report,
- symbolInfo.stats.sizeInBytes
+ << symbolInfo.stats.sizeInBytes << "</td>" << std::endl;
// Total Size in Instructions
- fprintf(
- report,
- symbolInfo.stats.sizeInInstructions
+ << symbolInfo.stats.sizeInInstructions << "</td>" << std::endl;
// Total Uncovered Ranges
- fprintf(
- report,
- symbolInfo.stats.uncoveredRanges
+ << symbolInfo.stats.uncoveredRanges << "</td>" << std::endl;
// Uncovered Size in Bytes
- fprintf(
- report,
- symbolInfo.stats.uncoveredBytes
+ << symbolInfo.stats.uncoveredBytes << "</td>" << std::endl;
// Uncovered Size in Instructions
- fprintf(
- report,
- symbolInfo.stats.uncoveredInstructions
+ << symbolInfo.stats.uncoveredInstructions << "</td>" << std::endl;
// Total number of branches
- fprintf(
- report,
- symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted
+ << symbolInfo.stats.branchesNotExecuted +
// Total Always Taken
- fprintf(
- report,
- symbolInfo.stats.branchesAlwaysTaken
+ << symbolInfo.stats.branchesAlwaysTaken << "</td>" << std::endl;
// Total Never Taken
- fprintf(
- report,
- symbolInfo.stats.branchesNeverTaken
+ << symbolInfo.stats.branchesNeverTaken << "</td>" << std::endl;
// % Uncovered Instructions
if ( symbolInfo.stats.sizeInInstructions == 0 )
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">100.00</td>\n"
+ report << "<td class=\"covoar-td\" align=\"center\">100.00</td>"
+ << std::endl;
else
- fprintf(
- report,
- "<td class=\"covoar-td\" align=\"center\">%.2f</td>\n",
- (symbolInfo.stats.uncoveredInstructions*100.0)/
+ << ( symbolInfo.stats.uncoveredInstructions * 100.0 ) /
+ symbolInfo.stats.sizeInInstructions
// % Uncovered Bytes
if ( symbolInfo.stats.sizeInBytes == 0 )
- fprintf(
- report,
+ << std::endl;
else
- fprintf(
- report,
- (symbolInfo.stats.uncoveredBytes*100.0)/
+ << ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
+ symbolInfo.stats.sizeInBytes
return true;
void ReportsHtml::CloseAnnotatedFile(
- FILE* aFile
- fprintf(
- aFile,
- "</pre>\n"
- "</body>\n"
- "</html>"
+ aFile << "</pre>" << std::endl
+ << "</body>" << std::endl
CloseFile(aFile);
void ReportsHtml::CloseBranchFile(
- FILE* aFile,
bool hasBranches
- fprintf(
- aFile,
- TABLE_FOOTER
- "</tbody>\n"
- "</table>\n"
+ aFile << TABLE_FOOTER
+ << "</tbody>" << std::endl
+ << "</table>" << std::endl;
CloseFile(aFile);
void ReportsHtml::CloseCoverageFile(
- FILE* aFile
- fprintf(
- aFile,
- TABLE_FOOTER
- "</tbody>\n"
- "</table>\n"
- "</pre>\n"
- "</body>\n"
- "</html>"
+ << "</pre>" << std::endl
+ << "</html>";
CloseFile(aFile);
void ReportsHtml::CloseNoRangeFile(
- FILE* aFile
- fprintf(
- aFile,
- TABLE_FOOTER
- "</tbody>\n"
- "</table>\n"
- "</pre>\n"
- "</body>\n"
- "</html>"
+ << "</html>";
CloseFile(aFile);
void ReportsHtml::CloseSizeFile(
- FILE* aFile
- fprintf(
- aFile,
- TABLE_FOOTER
- "</tbody>\n"
- "</table>\n"
- "</pre>\n"
- "</body>\n"
- "</html>"
+ << "</html>";
- CloseFile( aFile );
+ CloseFile(aFile);
void ReportsHtml::CloseSymbolSummaryFile(
- FILE* aFile
- fprintf(
- aFile,
- TABLE_FOOTER
- "</tbody>\n"
- "</table>\n"
- "</pre>\n"
- "</body>\n"
- "</html>"
+ << "</html>";
CloseFile( aFile );
diff --git a/tester/covoar/ReportsHtml.h b/tester/covoar/ReportsHtml.h
index 8d209ae..21ca8bd 100644
--- a/tester/covoar/ReportsHtml.h
+++ b/tester/covoar/ReportsHtml.h
@@ -9,6 +9,9 @@
#ifndef __REPORTSHTML_H__
#define __REPORTSHTML_H__
+#include <string>
+#include <fstream>
#include <stdint.h>
#include "Explanations.h"
@@ -22,7 +25,7 @@ namespace Coverage {
class ReportsHtml: public ReportsBase {
public:
- ReportsHtml( time_t timestamp, std::string symbolSetName );
+ ReportsHtml( time_t timestamp, const std::string& symbolSetName );
~ReportsHtml();
@@ -31,8 +34,8 @@ class ReportsHtml: public ReportsBase {
* @param[in] fileName identifies the file name.
void WriteIndex(
+ ) override;
* This method produces a report that contains information about each
@@ -41,7 +44,7 @@ class ReportsHtml: public ReportsBase {
@@ -51,7 +54,7 @@ class ReportsHtml: public ReportsBase {
@@ -61,7 +64,7 @@ class ReportsHtml: public ReportsBase {
* @param[in] fileName identifies the size report file name
protected:
@@ -75,93 +78,99 @@ class ReportsHtml: public ReportsBase {
AnnotatedLineState_t lastState_m;
/* Inherit documentation from base class. */
- bool hasBranches
+ bool hasBranches,
- FILE* OpenNoRangeFile(
+ void OpenNoRangeFile(
- FILE* aFile
- FILE* aFile,
bool hasBranches
- FILE* aFile
- FILE* aFile
- FILE* aFile
- FILE* aFile
- FILE* aFile,
- std::string line,
uint32_t id
- FILE* aFile
- FILE* aFile
- FILE* report
- FILE* report,
@@ -170,15 +179,15 @@ class ReportsHtml: public ReportsBase {
- FILE* report,
- unsigned int number,
+ unsigned int number,
- FILE* report,
@@ -187,7 +196,7 @@ class ReportsHtml: public ReportsBase {
- FILE* report,
@@ -195,20 +204,21 @@ class ReportsHtml: public ReportsBase {
- FILE* report,
- virtual FILE* OpenFile(
+ virtual void OpenFile(
- virtual bool WriteExplationFile(
+ virtual bool WriteExplanationFile(
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 33be32f..35ad786 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -1,6 +1,8 @@
+#include <iomanip>
#include "ReportsText.h"
@@ -11,7 +13,7 @@
-ReportsText::ReportsText( time_t timestamp, std::string symbolSetName ):
+ReportsText::ReportsText( time_t timestamp, const std::string& symbolSetName ):
reportExtension_m = ".txt";
@@ -22,47 +24,44 @@ ReportsText::~ReportsText()
void ReportsText::AnnotatedStart(
- FILE* aFile
- fprintf(
- aFile,
- "=======================================\n"
+ aFile << "========================================"
+ << "=======================================" << std::endl;
void ReportsText::AnnotatedEnd(
- FILE* aFile
void ReportsText::PutAnnotatedLine(
- FILE* aFile,
- std::string line,
uint32_t id
- fprintf( aFile, "%s\n", line.c_str());
+ aFile << line << std::endl;
bool ReportsText::PutNoBranchInfo(
- FILE* report
if ( BranchInfoAvailable &&
SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
else
return true;
bool ReportsText::PutBranchEntry(
- FILE* report,
@@ -72,90 +71,71 @@ bool ReportsText::PutBranchEntry(
const Coverage::Explanation* explanation;
// Add an entry to the report
- fprintf(
- report,
- "============================================\n"
- "Symbol : %s (0x%x)\n"
- "Line : %s (0x%x)\n"
- "Size in Bytes : %d\n",
- symbolName.c_str(),
- symbolInfo.baseAddress,
- range.lowAddress,
+ report << "============================================" << std::endl
+ << "Symbol : " << symbolName
+ << std::hex << " (0x" << symbolInfo.baseAddress << ")" << std::endl
+ << "Line : " << range.lowSourceLine
+ << " (0x" << range.lowAddress << ")" << std::endl
+ << "Size in Bytes : " << range.highAddress - range.lowAddress + 1
+ << std::dec << std::endl;
if (range.reason ==
- fprintf(
- report, "Reason : %s\n\n", "ALWAYS TAKEN"
+ report << "Reason : ALWAYS TAKEN"
- fprintf( report, "Reason : %s\n\n", "NEVER TAKEN" );
+ report << "Reason : NEVER TAKEN"
- fprintf(
- report,
- "Classification: NONE\n"
- "\n"
- "Explanation:\n"
- "No Explanation\n"
+ report << "Classification: NONE" << std::endl << std::endl
+ << "Explanation:" << std::endl
+ << "No Explanation" << std::endl;
} else {
- fprintf(
- report,
- "Classification: %s\n"
- "\n"
- "Explanation:\n",
- for ( unsigned int i=0 ;
+ report << "Classification: " << explanation->classification
+ << "Explanation:" << std::endl;
+ for ( unsigned int i=0;
i++) {
- fprintf(
- report,
- "%s\n",
- fprintf(
- report, "============================================\n"
+ report << "============================================" << std::endl;
return true;
void ReportsText::putCoverageNoRange(
- FILE* report,
- fprintf(
- report,
- "Symbol : %s\n\n"
- " *** NEVER REFERENCED ***\n\n"
- "This symbol was never referenced by an analyzed executable.\n"
- "Therefore there is no size or disassembly for this symbol.\n"
- "This could be due to symbol misspelling or lack of a test for\n"
- "this symbol.\n"
- "============================================\n",
- symbol.c_str()
- fprintf( noRangeFile, "%s\n", symbol.c_str() );
+ << "Symbol : " << symbol << std::endl << std::endl
+ << " *** NEVER REFERENCED ***" << std::endl << std::endl
+ << "This symbol was never referenced by an analyzed executable."
+ << std::endl
+ << "Therefore there is no size or disassembly for this symbol."
+ << std::endl
+ << "This could be due to symbol misspelling or lack of a test for"
+ << std::endl
+ << "this symbol." << std::endl
+ << "============================================" << std::endl;
+ noRangeFile << symbol << std::endl;
bool ReportsText::PutCoverageLine(
- FILE* report,
@@ -164,73 +144,56 @@ bool ReportsText::PutCoverageLine(
- fprintf(
- report,
- "Index : %d\n"
- "Starting Line : %s (0x%x)\n"
- "Ending Line : %s (0x%x)\n"
- "Size in Instructions : %d\n\n",
- range.id,
- range.lowAddress,
- range.highSourceLine.c_str(),
- range.highAddress,
- range.highAddress - range.lowAddress + 1,
+ << "Index : " << range.id << std::endl
+ << "Starting Line : " << range.lowSourceLine
+ << "Ending Line : " << range.highSourceLine
+ << " (0x" << range.highAddress << ")" << std::endl
+ << std::dec
+ << range.highAddress - range.lowAddress + 1 << std::endl
+ << "Size in Instructions : " << range.instructionCount
- fprintf(
- report,
- "\n"
- "Explanation:\n"
} else {
- fprintf(
- report,
- "\n"
- "Explanation:\n",
+ report << "Classification: " << explanation->classification << std::endl
+ << std::endl
for ( unsigned int i=0; i < explanation->explanation.size(); i++) {
- fprintf( report,"%s\n", explanation->explanation[i].c_str() );
- fprintf(report, "============================================\n");
return true;
bool ReportsText::PutSizeLine(
- FILE* report,
- fprintf(
- report,
- "%d\t%s\t%s\n",
+ report << range.highAddress - range.lowAddress + 1 << '\t'
+ << symbolName << '\t'
+ << range.lowSourceLine << std::endl;
return true;
bool ReportsText::PutSymbolSummaryLine(
- FILE* report,
@@ -240,17 +203,18 @@ bool ReportsText::PutSymbolSummaryLine(
float uncoveredInstructions;
- fprintf(
- report,
- "Symbol : %s\n"
- "this symbol.\n",
+ << "Symbol : " << symbolName << std::endl
+ << std::endl
+ << std::endl
+ << std::endl
} else {
uncoveredInstructions = 0;
@@ -264,29 +228,30 @@ bool ReportsText::PutSymbolSummaryLine(
uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
symbolInfo.stats.sizeInBytes;
- fprintf(
- report,
- "Symbol : %s\n"
- "Total Size in Bytes : %d\n"
- "Total Size in Instructions : %d\n"
- "Total number Branches : %d\n"
- "Total Always Taken : %d\n"
- "Total Never Taken : %d\n"
- "Percentage Uncovered Instructions : %.2f\n"
- "Percentage Uncovered Bytes : %.2f\n",
- symbolInfo.stats.sizeInBytes,
- symbolInfo.stats.sizeInInstructions,
- symbolInfo.stats.branchesNotExecuted + symbolInfo.stats.branchesExecuted,
- symbolInfo.stats.branchesAlwaysTaken,
- symbolInfo.stats.branchesNeverTaken,
- uncoveredInstructions,
- uncoveredBytes
+ << "Symbol : "
+ << symbolName << std::endl
+ << "Total Size in Bytes : "
+ << symbolInfo.stats.sizeInBytes << std::endl
+ << "Total Size in Instructions : "
+ << symbolInfo.stats.sizeInInstructions << std::endl
+ << "Total number Branches : "
+ << std::endl
+ << "Total Always Taken : "
+ << symbolInfo.stats.branchesAlwaysTaken << std::endl
+ << "Total Never Taken : "
+ << symbolInfo.stats.branchesNeverTaken << std::endl
+ << "Percentage Uncovered Instructions : "
+ << uncoveredInstructions << std::endl
+ << "Percentage Uncovered Bytes : "
+ << uncoveredBytes << std::endl;
return true;
diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
index 23a1003..3e33be9 100644
--- a/tester/covoar/ReportsText.h
+++ b/tester/covoar/ReportsText.h
@@ -21,7 +21,7 @@ namespace Coverage {
class ReportsText: public ReportsBase {
public:
- ReportsText( time_t timestamp, std::string symbolSetName );
+ ReportsText( time_t timestamp, const std::string& symbolSetName );
virtual ~ReportsText();
@@ -31,7 +31,7 @@ class ReportsText: public ReportsBase {
@@ -41,7 +41,7 @@ class ReportsText: public ReportsBase {
@@ -51,37 +51,37 @@ class ReportsText: public ReportsBase {
protected:
- FILE* aFile,
- std::string line,
uint32_t id
- FILE* aFile
- FILE* aFile
- FILE* report
- FILE* report,
@@ -90,15 +90,15 @@ class ReportsText: public ReportsBase {
- FILE* report,
- FILE* report,
@@ -107,7 +107,7 @@ class ReportsText: public ReportsBase {
- FILE* report,
@@ -115,7 +115,7 @@ class ReportsText: public ReportsBase {
- FILE* report,
1.8.3.1
