[PATCH rtems-libbsd v1] nexus: Added SDHCI driver to ZynqMP
Stephen Clark stephen.clark at oarcorp.com
Mon Jul 12 22:55:20 UTC 2021
Made ZynqMP build with the SDHCI driver.
 rtemsbsd/include/bsp/nexus-devices.h          |  4 +++
 .../include/machine/rtems-bsd-nexus-bus.h     | 29 +++++++++++++++++++
 2 files changed, 33 insertions(+)
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 5b51de7e..fdc845c1 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -119,6 +119,10 @@ RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(ZYNQMP_IRQ_ETHERNET_3);
 RTEMS_BSD_DRIVER_E1000PHY;
 RTEMS_BSD_DRIVER_UKPHY;
+RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0;
+RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1;
+RTEMS_BSD_DRIVER_MMC;
 #elif defined(LIBBSP_ARM_ATSAM_BSP_H)
 RTEMS_BSD_DRIVER_USB;
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index ccf8efa6..103d5b1d 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -139,6 +139,35 @@ extern "C" {
                                   &zynqmp_slcr_res[0])
 #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR */
+ * Xilinx ZynqMP Arasan SDIO Driver.
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI)
+  #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(_num, _base, _irq)                     \
+    static const rtems_bsd_device_resource arasan_sdhci ## _num ## _res[] = {       \
+        .type = RTEMS_BSD_RES_MEMORY,                                               \
+        .start_request = 0,                                                         \
+        .start_actual = (_base)                                                     \
+        .type = RTEMS_BSD_RES_IRQ,                                                  \
+        .start_actual = (_irq)                                                      \
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(arasan_sdhci, _num,                               \
+                                  RTEMS_ARRAY_SIZE(arasan_sdhci ## _num ## _res),      \
+                                  &arasan_sdhci ## _num ## _res[0])
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0)
+  #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0                \
+    RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(0, 0xFF160000, 80)
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0 */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1)
+  #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1                \
+    RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(1, 0xFF170000, 81)
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1 */
  * Xilinx Zynq Arasan SDIO Driver.
2.27.0
