[PATCH rtems-libbsd v1] nexus: Added SDHCI driver to ZynqMP
Gedare Bloom
gedare at rtems.org
Thu Jul 15 15:10:00 UTC 2021
looks fine to me
On Mon, Jul 12, 2021 at 5:14 PM Stephen Clark <stephen.clark at oarcorp.com> wrote:
> Made ZynqMP build with the SDHCI driver.
> rtemsbsd/include/bsp/nexus-devices.h | 4 +++
> .../include/machine/rtems-bsd-nexus-bus.h | 29 +++++++++++++++++++
> 2 files changed, 33 insertions(+)
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index 5b51de7e..fdc845c1 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -119,6 +119,10 @@ RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(ZYNQMP_IRQ_ETHERNET_3);
> RTEMS_BSD_DRIVER_E1000PHY;
> RTEMS_BSD_DRIVER_UKPHY;
> +RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0;
> +RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1;
> +RTEMS_BSD_DRIVER_MMC;
> #elif defined(LIBBSP_ARM_ATSAM_BSP_H)
> RTEMS_BSD_DRIVER_USB;
> diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> index ccf8efa6..103d5b1d 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> @@ -139,6 +139,35 @@ extern "C" {
> &zynqmp_slcr_res[0])
> #endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR */
> + * Xilinx ZynqMP Arasan SDIO Driver.
> +#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI)
> + #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(_num, _base, _irq) \
> + static const rtems_bsd_device_resource arasan_sdhci ## _num ## _res[] = { \
> + .type = RTEMS_BSD_RES_MEMORY, \
> + .start_request = 0, \
> + .start_actual = (_base) \
> + .type = RTEMS_BSD_RES_IRQ, \
> + .start_actual = (_irq) \
> + RTEMS_BSD_DEFINE_NEXUS_DEVICE(arasan_sdhci, _num, \
> + RTEMS_ARRAY_SIZE(arasan_sdhci ## _num ## _res), \
> + &arasan_sdhci ## _num ## _res[0])
> +#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI */
> +#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0)
> + #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0 \
> + RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(0, 0xFF160000, 80)
> +#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI0 */
> +#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1)
> + #define RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1 \
> + RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI(1, 0xFF170000, 81)
> +#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SDHCI1 */
> * Xilinx Zynq Arasan SDIO Driver.
> 2.27.0
> devel mailing list
> devel at rtems.org
