[PATCH 19/41] bsps/irq: Implement new directives for GICv2/3
Tue Jul 13 23:47:32 UTC 2021
On 13/7/21 10:55 pm, Kinsey Moore wrote:
> On 7/13/2021 00:16, Sebastian Huber wrote:
>> On 13/07/2021 04:46, Kinsey Moore wrote:
>>>> index a1ba5e9112..6f5d4015e4 100644
>>>> --- a/bsps/shared/dev/irq/arm-gicv2.c
>>>> +++ b/bsps/shared/dev/irq/arm-gicv2.c
>>>> @@ -1,5 +1,5 @@
>>>> - * Copyright (c) 2013, 2019 embedded brains GmbH.  All rights reserved.
>>>> + * Copyright (c) 2013, 2021 embedded brains GmbH.  All rights reserved.
>>>>    *  embedded brains GmbH
>>>>    *  Dornierstr. 4
>>>> @@ -69,6 +69,28 @@ rtems_status_code bsp_interrupt_get_attributes(
>>>>     rtems_interrupt_attributes *attributes
>>>> +  attributes->is_maskable = true;
>>>> +  attributes->maybe_enable = true;
>>>> +  if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
>>>> +    attributes->always_enabled = true;
>>> As far as I'm aware, SGIs can be enabled or disabled using GICD_ISENABLER0
>>> just like
>>> PPI or SPI interrupts for both GICv2 and GICv3. Section 3.1.2 of the GICv2
>>> architecture
>>> spec (IHI0048B) references this, though I have seen implementations where
>>> certain SGI
>>> and PPI interrupts are hard-wired enabled or disabled and that state can't be
>>> changed
>>> (which is also covered in this section).
>> Ok, on Qemu and the i.MX7D the SGI are always enabled. I would keep the
>> attributes like this until we have a system which is different.
Should a comment be added that says this?
>> I will remove
>> the check in bsp_interrupt_vector_enable/disable(). So, in the worst case, the
>> attributes are wrong.
> I only mention it because I've seen it on ZynqMP hardware. Interrupt enable bits
> for interrupts 0-24 are locked with 0-7 permanently enabled and 8-24 permanently
> disabled. I think the QEMU GICv3 driver allows all SGIs to be enabled or
> disabled. I tried to get more information about whether those bits can be
> unlocked, but nothing has been forthcoming:
> https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Zynq-Ultrascale-MPSoC-SGI-and-PPI-enable/td-p/1212370
I do not know about the GIC but I know with the ARM debug hardware the
implementers can wrap the IP in different ways and that means something that is
user controllable may be fixed in other implementation or brought out to
external pins in another.
