[PATCH] build: Use BSP family for options
Sebastian Huber
Wed Jul 14 06:20:05 UTC 2021
Close #4468.
wscript | 51 ++++++++++++++++++++++++++++-----------------------
1 file changed, 28 insertions(+), 23 deletions(-)
diff --git a/wscript b/wscript
index 6626fafb74..357e8918df 100755
--- a/wscript
+++ b/wscript
@@ -203,11 +203,11 @@ class Item(object):
def get_enabled_by(self):
return self.data["enabled-by"]
- def defaults(self, enable, variant):
+ def defaults(self, enable, variant, family):
if _is_enabled(enable, self.get_enabled_by()):
for p in self.links():
- p.defaults(enable, variant)
- self.do_defaults(variant)
+ p.defaults(enable, variant, family)
+ self.do_defaults(variant, family)
def configure(self, conf, cic):
if _is_enabled(conf.env.ENABLE, self.get_enabled_by()):
@@ -223,7 +223,7 @@ class Item(object):
p.build(bld, bic)
self.do_build(bld, bic)
- def do_defaults(self, variant):
+ def do_defaults(self, variant, family):
return
def prepare_configure(self, conf, cic):
@@ -592,9 +592,6 @@ class BSPItem(Item):
arch_bsps = bsps.setdefault(data["arch"].strip(), {})
arch_bsps[data["bsp"].strip()] = self
- def prepare_configure(self, conf, cic):
- conf.env.BSP_FAMILY = self.data["family"]
def prepare_build(self, bld, bic):
return BuildItemContext(
bic.includes + bld.env.BSP_INCLUDES.split(), [], [], []
@@ -689,16 +686,18 @@ class OptionItem(Item):
super(OptionItem, self).__init__(uid, data)
@staticmethod
- def _is_variant(variants, variant):
+ def _is_variant(variants, variant, family):
for pattern in variants:
if re.match(pattern + "$", variant):
return True
+ if re.match(pattern + "$", family):
+ return True
return False
- def default_value(self, variant):
+ def default_value(self, variant, family):
value = self.data["default"]
for default in self.data["default-by-variant"]:
- if OptionItem._is_variant(default["variants"], variant):
+ if OptionItem._is_variant(default["variants"], variant, family):
value = default["value"]
break
if value is None:
@@ -709,8 +708,8 @@ class OptionItem(Item):
return value
return self.data["format"].format(value)
- value = self.default_value(variant)
+ value = self.default_value(variant, family)
if value is None:
return
description = self.data["description"]
@@ -917,7 +916,7 @@ class OptionItem(Item):
value = cic.cp.getboolean(conf.variant, name)
cic.add_option(name)
except configparser.NoOptionError:
- value = self.default_value(conf.env.ARCH_BSP)
+ value = self.default_value(conf.env.ARCH_BSP, conf.env.ARCH_FAMILY)
except ValueError as ve:
conf.fatal(
"Invalid value for configuration option {}: {}".format(name, ve)
@@ -933,7 +932,7 @@ class OptionItem(Item):
value = cic.cp.get(conf.variant, name)
if value is None:
return value
try:
@@ -952,7 +951,7 @@ class OptionItem(Item):
value = no_unicode(value)
return value
def _script(self, conf, cic, value, arg):
@@ -1365,11 +1364,20 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
conf.setenv(variant)
arch, bsp_name = variant.split("/")
bsp_base = bsp_map.get(bsp_name, bsp_name)
- arch_bsp = arch + "/" + bsp_base
+ try:
+ bsp_item = bsps[arch][bsp_base]
+ except KeyError:
+ conf.fatal("No such base BSP: '{}'".format(variant))
+ bsp_family = self.data["family"]
+ arch_bsp = arch + "/" + bsp_base
+ arch_family = arch + "/" + bsp_family
conf.env["ARCH"] = arch
conf.env["ARCH_BSP"] = arch_bsp
+ conf.env["ARCH_FAMILY"] = arch_family
conf.env["BSP_BASE"] = bsp_base
+ conf.env["BSP_FAMILY"] = bsp_family
conf.env["BSP_NAME"] = bsp_name
conf.env["DEST_OS"] = "rtems"
@@ -1384,11 +1392,6 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
cic = ConfigItemContext(cp, path_list)
items[conf.env.TOPGROUP].configure(conf, cic)
- try:
- bsp_item = bsps[arch][bsp_base]
- except KeyError:
- conf.fatal("No such base BSP: '{}'".format(variant))
bsp_item.configure(conf, cic)
options = set([o[0].upper() for o in cp.items(variant)])
@@ -1558,8 +1561,10 @@ COMPILER = {}""".format(
enable = [compiler, arch, variant]
- items[top_group].defaults(enable, variant)
- bsps[arch][bsp].defaults(enable, variant)
+ bsp_item = bsps[arch][bsp]
+ family = arch + "/" + bsp_item.data["family"]
+ items[top_group].defaults(enable, variant, family)
+ bsp_item.defaults(enable, variant, family)
if first:
no_matches_error(ctx, white_list)
2.26.2
