How defines RTEMS_COVERAGE?
Wed Jul 14 12:27:30 UTC 2021
On 14/07/2021 14:25, Joel Sherrill wrote:
> On Wed, Jul 14, 2021, 7:15 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello,
>     I had a bit of time to work on the gcov support for RTEMS:
>     https://gcc.gnu.org/pipermail/gcc-patches/2021-July/575122.html
>     <https://gcc.gnu.org/pipermail/gcc-patches/2021-July/575122.html>
>     I tried to add an RTEMS_COVERAGE build option to enable gcov. Then I
>     noticed that such a define is already used in RTEMS:
>     testsuites/sptests/spcoverage/init.c:  #if defined(RTEMS_COVERAGE)
>     Who provides this define?
> I have no idea what this does. The covoar reports require no special
> defines. The most you might do is use -Os to make the analysis easier
> since the code is easier to follow when optimising for size.
> What does that test even do?
rtems_task Init(
   rtems_task_argument ignored
   TEST_BEGIN();
   puts( "Init - If coverage enabled, call coverage marker methods" );
     start_coverage();
     end_coverage();
   #endif
   TEST_END();
   rtems_test_exit(0);
 From looking at the git log, the start_coverage() and end_coverage()
were never defined in RTEMS. I guess we can remove this test program.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
