How defines RTEMS_COVERAGE?
Joel Sherrill
joel at rtems.org
Wed Jul 14 12:47:53 UTC 2021
On Wed, Jul 14, 2021, 7:27 AM Sebastian Huber <
> On 14/07/2021 14:25, Joel Sherrill wrote:
> > On Wed, Jul 14, 2021, 7:15 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > Hello,
> > I had a bit of time to work on the gcov support for RTEMS:
> > https://gcc.gnu.org/pipermail/gcc-patches/2021-July/575122.html
> > <https://gcc.gnu.org/pipermail/gcc-patches/2021-July/575122.html>
> > I tried to add an RTEMS_COVERAGE build option to enable gcov. Then I
> > noticed that such a define is already used in RTEMS:
> > testsuites/sptests/spcoverage/init.c: #if defined(RTEMS_COVERAGE)
> > Who provides this define?
> > I have no idea what this does. The covoar reports require no special
> > defines. The most you might do is use -Os to make the analysis easier
> > since the code is easier to follow when optimising for size.
> > What does that test even do?
> rtems_task Init(
> rtems_task_argument ignored
> TEST_BEGIN();
> puts( "Init - If coverage enabled, call coverage marker methods" );
> start_coverage();
> end_coverage();
> #endif
> TEST_END();
> rtems_test_exit(0);
> From looking at the git log, the start_coverage() and end_coverage()
> were never defined in RTEMS. I guess we can remove this test program.
I've honestly got no idea. Removing it seems right.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210714/a539415f/attachment.html>
