[PATCH v1 5/6] ReportsText.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Wed Jul 14 14:59:57 UTC 2021
tester/covoar/ReportsText.cc | 103 +++++++++++++++++++++++--------------------
1 file changed, 54 insertions(+), 49 deletions(-)
diff --git a/tester/covoar/ReportsText.cc b/tester/covoar/ReportsText.cc
index 35ad786..146fc35 100644
--- a/tester/covoar/ReportsText.cc
+++ b/tester/covoar/ReportsText.cc
@@ -23,17 +23,13 @@ ReportsText::~ReportsText()
-void ReportsText::AnnotatedStart(
- std::ofstream& aFile
+void ReportsText::AnnotatedStart( std::ofstream& aFile )
aFile << "========================================"
<< "=======================================" << std::endl;
-void ReportsText::AnnotatedEnd(
+void ReportsText::AnnotatedEnd( std::ofstream& aFile )
@@ -47,25 +43,27 @@ void ReportsText::PutAnnotatedLine(
aFile << line << std::endl;
-bool ReportsText::PutNoBranchInfo(
- std::ofstream& report
+bool ReportsText::PutNoBranchInfo( std::ofstream& report )
- if ( BranchInfoAvailable &&
- SymbolsToAnalyze->getNumberBranchesFound(symbolSetName_m) != 0 )
+ if (
+ BranchInfoAvailable &&
+ SymbolsToAnalyze->getNumberBranchesFound( symbolSetName_m ) != 0
report << "All branch paths taken." << std::endl;
- else
+ } else {
report << "No branch information found." << std::endl;
return true;
bool ReportsText::PutBranchEntry(
- std::ofstream& report,
- unsigned int number,
- const std::string& symbolName,
- const SymbolInformation& symbolInfo,
- const CoverageRanges::coverageRange_t& range
+ std::ofstream& report,
+ unsigned int number,
+ const std::string& symbolName,
+ const SymbolInformation& symbolInfo,
+ const CoverageRanges::coverageRange_t& range
const Coverage::Explanation* explanation;
@@ -79,14 +77,19 @@ bool ReportsText::PutBranchEntry(
<< "Size in Bytes : " << range.highAddress - range.lowAddress + 1
<< std::dec << std::endl;
- if (range.reason ==
- Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN)
+ if (
+ range.reason ==
+ Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_ALWAYS_TAKEN
report << "Reason : ALWAYS TAKEN"
<< std::endl << std::endl;
- else if (range.reason ==
- Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN)
- report << "Reason : NEVER TAKEN"
- << std::endl << std::endl;
+ } else if (
+ range.reason ==
+ Coverage::CoverageRanges::UNCOVERED_REASON_BRANCH_NEVER_TAKEN
+ report << "Reason : NEVER TAKEN"
+ << std::endl << std::endl;
// See if an explanation is available
explanation = AllExplanations->lookupExplanation( range.lowSourceLine );
@@ -100,9 +103,7 @@ bool ReportsText::PutBranchEntry(
<< "Explanation:" << std::endl;
- for ( unsigned int i=0;
- i < explanation->explanation.size();
- i++) {
+ for ( unsigned int i=0; i < explanation->explanation.size(); i++ ) {
report << explanation->explanation[i] << std::endl;
@@ -115,7 +116,7 @@ bool ReportsText::PutBranchEntry(
void ReportsText::putCoverageNoRange(
std::ofstream& noRangeFile,
@@ -135,14 +136,14 @@ void ReportsText::putCoverageNoRange(
bool ReportsText::PutCoverageLine(
- const Coverage::Explanation* explanation;
+ const Coverage::Explanation* explanation;
report << "============================================" << std::endl
<< "Index : " << range.id << std::endl
@@ -175,14 +176,15 @@ bool ReportsText::PutCoverageLine(
report << "============================================" << std::endl;
return true;
bool ReportsText::PutSizeLine(
report << range.highAddress - range.lowAddress + 1 << '\t'
@@ -193,16 +195,16 @@ bool ReportsText::PutSizeLine(
bool ReportsText::PutSymbolSummaryLine(
float uncoveredBytes;
float uncoveredInstructions;
- if (symbolInfo.stats.sizeInBytes == 0) {
+ if ( symbolInfo.stats.sizeInBytes == 0 ) {
<< "Symbol : " << symbolName << std::endl
<< " *** NEVER REFERENCED ***"
@@ -216,17 +218,20 @@ bool ReportsText::PutSymbolSummaryLine(
<< "this symbol." << std::endl
} else {
- if ( symbolInfo.stats.sizeInInstructions == 0 )
+ if ( symbolInfo.stats.sizeInInstructions == 0 ) {
uncoveredInstructions = 0;
- else
- uncoveredInstructions = (symbolInfo.stats.uncoveredInstructions*100.0)/
- symbolInfo.stats.sizeInInstructions;
+ } else {
+ uncoveredInstructions =
+ ( symbolInfo.stats.uncoveredInstructions * 100.0 ) /
+ symbolInfo.stats.sizeInInstructions;
- if ( symbolInfo.stats.sizeInBytes == 0 )
uncoveredBytes = 0;
- else
- uncoveredBytes = (symbolInfo.stats.uncoveredBytes*100.0)/
+ } else {
+ uncoveredBytes = ( symbolInfo.stats.uncoveredBytes * 100.0 ) /
symbolInfo.stats.sizeInBytes;
<< "Symbol : "
1.8.3.1
