[PATCH v1 6/6] ReportsText.h: Fix formatting
Ryan Long ryan.long at oarcorp.com
Wed Jul 14 14:59:58 UTC 2021
 tester/covoar/ReportsText.h | 60 ++++++++++++++++++---------------------------
 1 file changed, 24 insertions(+), 36 deletions(-)
diff --git a/tester/covoar/ReportsText.h b/tester/covoar/ReportsText.h
index 3e33be9..9ad80ef 100644
--- a/tester/covoar/ReportsText.h
+++ b/tester/covoar/ReportsText.h
@@ -30,9 +30,7 @@ class ReportsText: public ReportsBase {
    *  @param[in] fileName identifies the branch report file name
-  void WriteBranchReport(
-    const std::string& fileName
+  void WriteBranchReport( const std::string& fileName );
    *  This method produces a report that contains information about each
@@ -40,9 +38,7 @@ class ReportsText: public ReportsBase {
    *  @param[in] fileName identifies the coverage report file name
-  void WriteCoverageReport(
+  void WriteCoverageReport( const std::string& fileName );
    *  This method produces a summary report that lists each uncovered
@@ -50,9 +46,7 @@ class ReportsText: public ReportsBase {
    *  @param[in] fileName identifies the size report file name
-  void WriteSizeReport(
+  void WriteSizeReport( const std::string& fileName );
   protected:
@@ -65,27 +59,21 @@ class ReportsText: public ReportsBase {
    /* Inherit documentation from base class. */
-     virtual void AnnotatedStart(
-       std::ofstream& aFile
+     virtual void AnnotatedStart( std::ofstream& aFile );
-     virtual void AnnotatedEnd(
+     virtual void AnnotatedEnd( std::ofstream& aFile );
-    virtual bool PutNoBranchInfo(
-      std::ofstream& report
+    virtual bool PutNoBranchInfo( std::ofstream& report );
     virtual bool PutBranchEntry(
-      std::ofstream&                                   report,
-      unsigned int                                     number,
-      const std::string&                               symbolName,
-      const SymbolInformation&                         symbolInfo,
-      const CoverageRanges::coverageRange_t&           range
+      std::ofstream&                         report,
+      unsigned int                           number,
+      const std::string&                     symbolName,
+      const SymbolInformation&               symbolInfo,
+      const CoverageRanges::coverageRange_t& range
@@ -98,27 +86,27 @@ class ReportsText: public ReportsBase {
     virtual bool PutCoverageLine(
     virtual bool PutSizeLine(
     virtual bool PutSymbolSummaryLine(
1.8.3.1
