[PATCH rtems-docs v1 2/2] user/bsps/aarch64: Minor formatting fix
Stephen Clark stephen.clark at oarcorp.com
Wed Jul 14 15:16:37 UTC 2021
Fixed formatting error in user/bsps/aarch64/a53.rst
and user/bsps/aarch64/xilinx-zynqmp.rst.
 user/bsps/aarch64/a53.rst           | 8 +++++---
 user/bsps/aarch64/xilinx-zynqmp.rst | 8 +++++---
 2 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/user/bsps/aarch64/a53.rst b/user/bsps/aarch64/a53.rst
index 52e1509..9d8e1ce 100644
--- a/user/bsps/aarch64/a53.rst
+++ b/user/bsps/aarch64/a53.rst
@@ -29,7 +29,9 @@ The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART.
 Running Executables
-Executables generated by these BSPs can be run using the following command::
+Executables generated by these BSPs can be run using the following command:
-qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
- -machine virt,gic-version=3 -cpu cortex-a53 -m 4096 -kernel example.exe
+.. code-block:: shell
+  qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio \
+   -machine virt,gic-version=3 -cpu cortex-a53 -m 4096 -kernel example.exe
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 30ae8a3..85c70e0 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -85,7 +85,9 @@ Most ZynqMP dev boards use CGEM3. None of the interfaces are enabled by default.
 Running Executables on QEMU
- -machine xlnx-zcu102 -m 4096 -kernel example.exe
+   -machine xlnx-zcu102 -m 4096 -kernel example.exe
2.27.0
