[PATCH rtems-docs] user: Update ZynqMP network configuration
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Jul 14 19:56:24 UTC 2021
Network configuration is now automatic and requires no user
configuration.
user/bsps/aarch64/xilinx-zynqmp.rst | 11 +++--------
1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 71b6842..90270db 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -59,14 +59,9 @@ Network Configuration
When used with LibBSD, these BSP variants support networking via the four
-Cadence GEM instances present on all ZynqMP hardware variants. These are enabled
-using config.inc in LibBSD by setting any of the following constants to 1:
-NET_CFG_ZYNQMP_USE_CGEM0 = 1
-NET_CFG_ZYNQMP_USE_CGEM1 = 1
-NET_CFG_ZYNQMP_USE_CGEM2 = 1
-NET_CFG_ZYNQMP_USE_CGEM3 = 1
-Most ZynqMP dev boards use CGEM3. None of the interfaces are enabled by default.
+Cadence GEM instances present on all ZynqMP hardware variants. All interfaces
+are enabled by default, but only interfaces with operational MII busses will be
+recognized and usable in RTEMS. Most ZynqMP dev boards use CGEM3.
Running Executables on QEMU
2.20.1
