[PATCH rtems-docs] user: Update ZynqMP network configuration
Chris Johns
chrisj at rtems.org
Thu Jul 15 02:01:37 UTC 2021
OK
On 15/7/21 5:56 am, Kinsey Moore wrote:
> Network configuration is now automatic and requires no user
> configuration.
> user/bsps/aarch64/xilinx-zynqmp.rst | 11 +++--------
> 1 file changed, 3 insertions(+), 8 deletions(-)
> diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
> index 71b6842..90270db 100644
> --- a/user/bsps/aarch64/xilinx-zynqmp.rst
> +++ b/user/bsps/aarch64/xilinx-zynqmp.rst
> @@ -59,14 +59,9 @@ Network Configuration
> When used with LibBSD, these BSP variants support networking via the four
> -Cadence GEM instances present on all ZynqMP hardware variants. These are enabled
> -using config.inc in LibBSD by setting any of the following constants to 1:
> -NET_CFG_ZYNQMP_USE_CGEM0 = 1
> -NET_CFG_ZYNQMP_USE_CGEM1 = 1
> -NET_CFG_ZYNQMP_USE_CGEM2 = 1
> -NET_CFG_ZYNQMP_USE_CGEM3 = 1
> -Most ZynqMP dev boards use CGEM3. None of the interfaces are enabled by default.
> +Cadence GEM instances present on all ZynqMP hardware variants. All interfaces
> +are enabled by default, but only interfaces with operational MII busses will be
> +recognized and usable in RTEMS. Most ZynqMP dev boards use CGEM3.
> Running Executables on QEMU
