New Defects reported by Coverity Scan for RTEMS
Thu Jul 15 14:09:01 UTC 2021
I think we have been excluding testsuites. The setting appears to
still be there:
Tests     */testsuites/*     Ignored=Yes
I think maybe the pattern needs to be updated to put a dot before each
asterisk: .*/testsuites/.*
However, these could probably be fixed mostly without trouble.
On Thu, Jul 15, 2021 at 7:24 AM Joel Sherrill <joel at rtems.org> wrote:
> I am not sure why these popped up now but some indicate logic errors
> in the code cited.
> --joel
> ---------- Forwarded message ---------
> From: <scan-admin at coverity.com>
> Date: Thu, Jul 15, 2021 at 12:26 AM
> Subject: New Defects reported by Coverity Scan for RTEMS
> To: <build at rtems.org>
> Hi,
> Please find the latest report on new defect(s) introduced to RTEMS
> found with Coverity Scan.
> 9 new defect(s) introduced to RTEMS found with Coverity Scan.
> New defect(s) Reported-by: Coverity Scan
> Showing 9 of 9 defect(s)
> ** CID 1468693:  Insecure data handling  (TAINTED_SCALAR)
> ________________________________________________________________________________________________________
> *** CID 1468693:  Insecure data handling  (TAINTED_SCALAR)
> /testsuites/samples/fileio/init.c: 992 in fileio_read_file()
> 986        */
> 987       if (!failed) {
> 988         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> for bytes:\n"
> 989                "Enter block size to use for read calls ==>");
> 990         fflush(stdout);
> 991         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> >>>     Passing tainted expression "tmp_str" to "fileio_str2size", which uses it as an offset.
> 992         failed = fileio_str2size(tmp_str,&buf_size);
> 993         if (failed) {
> 994           printf("*** illegal block size, aborted\n");
> 995         }
> 996       }
> 997
> ** CID 1468692:  Integer handling issues  (DIVIDE_BY_ZERO)
> /testsuites/samples/fileio/init.c: 401 in create_ramdisk()
> *** CID 1468692:  Integer handling issues  (DIVIDE_BY_ZERO)
> 395               printf ("error: invalid option: %s\n", argv[arg]);
> 396               return 1;
> 397           }
> 398         }
> 399       }
> 400
> >>>     In expression "size / block_size", division by expression "block_size" which may be zero has undefined behavior.
> 401       block_count = size / block_size;
> 402
> 403       /*
> 404        * Register the RAM Disk driver.
> 405        */
> 406       printf ("Register RAM Disk Driver [blocks=%" PRIu32 \
> ** CID 1468691:  Resource leaks  (RESOURCE_LEAK)
> /testsuites/samples/fileio/init.c: 209 in shell_nvdisk_erase()
> *** CID 1468691:  Resource leaks  (RESOURCE_LEAK)
> 203         return 1;
> 204       }
> 205
> 206       if (ioctl (fd, RTEMS_NVDISK_IOCTL_ERASE_DISK) < 0)
> 207       {
> 208         printf ("error: nvdisk driver erase failed: %s\n",
> strerror (errno));
> >>>     Handle variable "fd" going out of scope leaks the handle.
> 209         return 1;
> 210       }
> 211
> 212       close (fd);
> 213
> 214       printf ("nvdisk erased successful\n");
> ** CID 1468689:    (TAINTED_SCALAR)
> *** CID 1468689:    (TAINTED_SCALAR)
> /testsuites/samples/fileio/init.c: 846 in fileio_write_file()
> 840        */
> 841       if (!failed) {
> 842         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> for bytes:\n"
> 843                "Enter block size to use for write calls ==>");
> 844         fflush(stdout);
> 845         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> 846         failed = fileio_str2size(tmp_str,&buf_size);
> 847         if (failed) {
> 848           printf("*** illegal block size, aborted\n");
> 849         }
> 850       }
> 851
> /testsuites/samples/fileio/init.c: 833 in fileio_write_file()
> 827        */
> 828       if (!failed) {
> 829         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> for bytes:\n"
> 830                "Enter filesize to write ==>");
> 831         fflush(stdout);
> 832         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> 833         failed = fileio_str2size(tmp_str,&file_size);
> 834         if (failed) {
> 835           printf("*** illegal file size, aborted\n");
> 836         }
> 837       }
> 838       /*
> ** CID 1468687:  Incorrect expression  (COPY_PASTE_ERROR)
> /testsuites/samples/paranoia/paranoia.c: 584 in paranoia()
> *** CID 1468687:  Incorrect expression  (COPY_PASTE_ERROR)
> 578                 Precision = Y;
> 579         }
> 580         if ((Precision != FLOOR (Precision)) || (Radix == One)) {
> 581             printf ("Precision cannot be characterized by an
> Integer number\n");
> 582             printf ("of significant digits but, by itself, this is
> a minor flaw.\n");
> 583         }
> >>>     "Radix" in "Radix == One" looks like a copy-paste error.
> 584         if (Radix == One)
> 585             printf ("logarithmic encoding has precision
> characterized solely by U1.\n");
> 586         else
> 587             printf ("The number of significant digits of the Radix
> is %f .\n",
> 588                 Precision);
> 589         TstCond (Serious, U2 * Nine * Nine * TwoForty < One,
> ** CID 1468686:  Control flow issues  (DEADCODE)
> /testsuites/samples/fileio/init.c: 392 in create_ramdisk()
> *** CID 1468686:  Control flow issues  (DEADCODE)
> 386               {
> 387                 printf ("error: -b needs a size\n");
> 388                 return 1;
> 389               }
> 390               block_size = parse_size_arg (argv[arg]);
> 391               if (size == 0)
> >>>     Execution cannot reach this statement: "return 1;".
> 392                 return 1;
> 393               break;
> 394             default:
> 396               return 1;
> 397           }
> ** CID 1468685:  Resource leaks  (RESOURCE_LEAK)
> /testsuites/samples/fileio/init.c: 163 in shell_nvdisk_trace()
> *** CID 1468685:  Resource leaks  (RESOURCE_LEAK)
> 157         return 1;
> 158       }
> 159
> 160       if (ioctl (fd, RTEMS_NVDISK_IOCTL_INFO_LEVEL, level) < 0)
> 161       {
> 162         printf ("error: driver set level failed: %s\n", strerror (errno));
> 163         return 1;
> 164       }
> 165
> 166       close (fd);
> 167
> 168       return 0;
> ** CID 1468679:  Incorrect expression  (NO_EFFECT)
> /testsuites/samples/paranoia/paranoia.c: 1492 in paranoia()
> *** CID 1468679:  Incorrect expression  (NO_EFFECT)
> 1486             printf ("print out as Q = %.17e, Y = %.17e .\n", Q, Y2);
> 1487             printf ("|Q - Y| = %.17e .\n", FABS (Q - Y2));
> 1488             UfThold = Q;
> 1489             break;
> 1490
> 1491         case 3:
> >>>     Assigning "X" to itself has no effect.
> 1492             X = X;
> 1493             break;
> 1494
> 1495         case 4:
> 1496             if ((Q == UfThold) && (E1 == E0)
> 1497                 && (FABS (UfThold - E1 / E9) <= E1)) {
> ** CID 1468677:  Uninitialized variables  (UNINIT)
> /testsuites/samples/capture/test1.c: 78 in capture_CT1b()
> *** CID 1468677:  Uninitialized variables  (UNINIT)
> 72     static void
> 73     capture_CT1b (rtems_task_argument arg)
> 74     {
> 75       volatile int i;
> 76
> 77       while (!capture_CT1c_deleted)
> >>>     Using uninitialized value "i".
> 78         i++;
> 79
> 80       capture_CT1b_deleted = 1;
> 81
> 82       rtems_task_exit();
> 83     }
> To view the defects in Coverity Scan visit,
> https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DhaSM_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMoyD0JEs4cQVPs7yModO9iS3KZmOTMtFerKpWJTESZ9XSy9bw2fNvjKFGKtVfArZIqrPcBx6KD5m2cYyPfuBRUlwl84oo0u5GaEKs-2FEiV5-2BOPirAYHmPdhb88irmeK9V0lU3GUWr0Z8zNQlCYoFZw1Rqng5dhEax-2FWHTiswmaiSJQ-3D-3D
> build mailing list
> build at rtems.org
> http://lists.rtems.org/mailman/listinfo/build
> devel mailing list
> devel at rtems.org
