New Defects reported by Coverity Scan for RTEMS
Thu Jul 15 15:10:39 UTC 2021
On Thu, Jul 15, 2021, 9:09 AM Gedare Bloom <gedare at rtems.org> wrote:
> I think we have been excluding testsuites. The setting appears to
> still be there:
> Tests     */testsuites/*     Ignored=Yes
> I think maybe the pattern needs to be updated to put a dot before each
> asterisk: .*/testsuites/.*
No idea why this broke after years though.
> However, these could probably be fixed mostly without trouble.
That's what I thought. At.keast one looked like a real bug.
--joel
> On Thu, Jul 15, 2021 at 7:24 AM Joel Sherrill <joel at rtems.org> wrote:
> > I am not sure why these popped up now but some indicate logic errors
> > in the code cited.
> > --joel
> > ---------- Forwarded message ---------
> > From: <scan-admin at coverity.com>
> > Date: Thu, Jul 15, 2021 at 12:26 AM
> > Subject: New Defects reported by Coverity Scan for RTEMS
> > To: <build at rtems.org>
> > Hi,
> > Please find the latest report on new defect(s) introduced to RTEMS
> > found with Coverity Scan.
> > 9 new defect(s) introduced to RTEMS found with Coverity Scan.
> > New defect(s) Reported-by: Coverity Scan
> > Showing 9 of 9 defect(s)
> > ** CID 1468693:  Insecure data handling  (TAINTED_SCALAR)
> ________________________________________________________________________________________________________
> > *** CID 1468693:  Insecure data handling  (TAINTED_SCALAR)
> > /testsuites/samples/fileio/init.c: 992 in fileio_read_file()
> > 986        */
> > 987       if (!failed) {
> > 988         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> > for bytes:\n"
> > 989                "Enter block size to use for read calls ==>");
> > 990         fflush(stdout);
> > 991         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> > >>>     Passing tainted expression "tmp_str" to "fileio_str2size", which
> uses it as an offset.
> > 992         failed = fileio_str2size(tmp_str,&buf_size);
> > 993         if (failed) {
> > 994           printf("*** illegal block size, aborted\n");
> > 995         }
> > 996       }
> > 997
> > ** CID 1468692:  Integer handling issues  (DIVIDE_BY_ZERO)
> > /testsuites/samples/fileio/init.c: 401 in create_ramdisk()
> > *** CID 1468692:  Integer handling issues  (DIVIDE_BY_ZERO)
> > 395               printf ("error: invalid option: %s\n", argv[arg]);
> > 396               return 1;
> > 397           }
> > 398         }
> > 399       }
> > 400
> > >>>     In expression "size / block_size", division by expression
> "block_size" which may be zero has undefined behavior.
> > 401       block_count = size / block_size;
> > 402
> > 403       /*
> > 404        * Register the RAM Disk driver.
> > 405        */
> > 406       printf ("Register RAM Disk Driver [blocks=%" PRIu32 \
> > ** CID 1468691:  Resource leaks  (RESOURCE_LEAK)
> > /testsuites/samples/fileio/init.c: 209 in shell_nvdisk_erase()
> > *** CID 1468691:  Resource leaks  (RESOURCE_LEAK)
> > 203         return 1;
> > 204       }
> > 205
> > 206       if (ioctl (fd, RTEMS_NVDISK_IOCTL_ERASE_DISK) < 0)
> > 207       {
> > 208         printf ("error: nvdisk driver erase failed: %s\n",
> > strerror (errno));
> > >>>     Handle variable "fd" going out of scope leaks the handle.
> > 209         return 1;
> > 210       }
> > 211
> > 212       close (fd);
> > 213
> > 214       printf ("nvdisk erased successful\n");
> > ** CID 1468689:    (TAINTED_SCALAR)
> > *** CID 1468689:    (TAINTED_SCALAR)
> > /testsuites/samples/fileio/init.c: 846 in fileio_write_file()
> > 840        */
> > 841       if (!failed) {
> > 842         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> > for bytes:\n"
> > 843                "Enter block size to use for write calls ==>");
> > 844         fflush(stdout);
> > 845         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> > 846         failed = fileio_str2size(tmp_str,&buf_size);
> > 847         if (failed) {
> > 848           printf("*** illegal block size, aborted\n");
> > 849         }
> > 850       }
> > 851
> > /testsuites/samples/fileio/init.c: 833 in fileio_write_file()
> > 827        */
> > 828       if (!failed) {
> > 829         printf("use suffix K for Kbytes, M for Mbytes or no suffix
> > for bytes:\n"
> > 830                "Enter filesize to write ==>");
> > 831         fflush(stdout);
> > 832         fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> > 833         failed = fileio_str2size(tmp_str,&file_size);
> > 834         if (failed) {
> > 835           printf("*** illegal file size, aborted\n");
> > 836         }
> > 837       }
> > 838       /*
> > ** CID 1468687:  Incorrect expression  (COPY_PASTE_ERROR)
> > /testsuites/samples/paranoia/paranoia.c: 584 in paranoia()
> > *** CID 1468687:  Incorrect expression  (COPY_PASTE_ERROR)
> > 578                 Precision = Y;
> > 579         }
> > 580         if ((Precision != FLOOR (Precision)) || (Radix == One)) {
> > 581             printf ("Precision cannot be characterized by an
> > Integer number\n");
> > 582             printf ("of significant digits but, by itself, this is
> > a minor flaw.\n");
> > 583         }
> > >>>     "Radix" in "Radix == One" looks like a copy-paste error.
> > 584         if (Radix == One)
> > 585             printf ("logarithmic encoding has precision
> > characterized solely by U1.\n");
> > 586         else
> > 587             printf ("The number of significant digits of the Radix
> > is %f .\n",
> > 588                 Precision);
> > 589         TstCond (Serious, U2 * Nine * Nine * TwoForty < One,
> > ** CID 1468686:  Control flow issues  (DEADCODE)
> > /testsuites/samples/fileio/init.c: 392 in create_ramdisk()
> > *** CID 1468686:  Control flow issues  (DEADCODE)
> > 386               {
> > 387                 printf ("error: -b needs a size\n");
> > 388                 return 1;
> > 389               }
> > 390               block_size = parse_size_arg (argv[arg]);
> > 391               if (size == 0)
> > >>>     Execution cannot reach this statement: "return 1;".
> > 392                 return 1;
> > 393               break;
> > 394             default:
> > 396               return 1;
> > 397           }
> > ** CID 1468685:  Resource leaks  (RESOURCE_LEAK)
> > /testsuites/samples/fileio/init.c: 163 in shell_nvdisk_trace()
> > *** CID 1468685:  Resource leaks  (RESOURCE_LEAK)
> > 157         return 1;
> > 158       }
> > 159
> > 160       if (ioctl (fd, RTEMS_NVDISK_IOCTL_INFO_LEVEL, level) < 0)
> > 161       {
> > 162         printf ("error: driver set level failed: %s\n", strerror
> (errno));
> > 163         return 1;
> > 164       }
> > 165
> > 166       close (fd);
> > 167
> > 168       return 0;
> > ** CID 1468679:  Incorrect expression  (NO_EFFECT)
> > /testsuites/samples/paranoia/paranoia.c: 1492 in paranoia()
> > *** CID 1468679:  Incorrect expression  (NO_EFFECT)
> > 1486             printf ("print out as Q = %.17e, Y = %.17e .\n", Q, Y2);
> > 1487             printf ("|Q - Y| = %.17e .\n", FABS (Q - Y2));
> > 1488             UfThold = Q;
> > 1489             break;
> > 1490
> > 1491         case 3:
> > >>>     Assigning "X" to itself has no effect.
> > 1492             X = X;
> > 1493             break;
> > 1494
> > 1495         case 4:
> > 1496             if ((Q == UfThold) && (E1 == E0)
> > 1497                 && (FABS (UfThold - E1 / E9) <= E1)) {
> > ** CID 1468677:  Uninitialized variables  (UNINIT)
> > /testsuites/samples/capture/test1.c: 78 in capture_CT1b()
> > *** CID 1468677:  Uninitialized variables  (UNINIT)
> > 72     static void
> > 73     capture_CT1b (rtems_task_argument arg)
> > 74     {
> > 75       volatile int i;
> > 76
> > 77       while (!capture_CT1c_deleted)
> > >>>     Using uninitialized value "i".
> > 78         i++;
> > 79
> > 80       capture_CT1b_deleted = 1;
> > 81
> > 82       rtems_task_exit();
> > 83     }
> > To view the defects in Coverity Scan visit,
> https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DhaSM_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMoyD0JEs4cQVPs7yModO9iS3KZmOTMtFerKpWJTESZ9XSy9bw2fNvjKFGKtVfArZIqrPcBx6KD5m2cYyPfuBRUlwl84oo0u5GaEKs-2FEiV5-2BOPirAYHmPdhb88irmeK9V0lU3GUWr0Z8zNQlCYoFZw1Rqng5dhEax-2FWHTiswmaiSJQ-3D-3D
> > build mailing list
> > build at rtems.org
> > http://lists.rtems.org/mailman/listinfo/build
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210715/66bb3710/attachment-0001.html>
