[PATCH rtems-docs v2 2/2] README: Added centOS 8 instructions
Stephen Clark
stephen.clark at oarcorp.com
Thu Jul 15 17:28:57 UTC 2021
Added some instructions for setting up CentOS 8.
README.txt | 11 +++++++++++
1 file changed, 11 insertions(+)
diff --git a/README.txt b/README.txt
index 13bf8e6..828c9e7 100644
--- a/README.txt
+++ b/README.txt
@@ -287,6 +287,17 @@ PATH:
export PATH=/usr/local/texlive/2016/bin/i386-linux/:${PATH}
export PATH=${HOME}/.local/bin:${PATH}
+CentOS 8
+The steps for Centos 8 are similar to the steps for CentOS 7.
+There are just a couple differences.
+First, CentOS 8 uses Python 3.x as the default, so intalling the
+centos-release-scl and rh-python36 packages is unnecessary.
+Second, Centos 8 uses dnf as its package manager instead of yum, so
+packages such as npm should be installed using dnf instead.
Arch Linux
2.27.0
