[PATCH rtems-docs v2 2/2] README: Added centOS 8 instructions
Gedare Bloom
gedare at rtems.org
Mon Jul 19 18:46:59 UTC 2021
These both look fine to me.
On Thu, Jul 15, 2021 at 11:48 AM Stephen Clark
<stephen.clark at oarcorp.com> wrote:
> Added some instructions for setting up CentOS 8.
> README.txt | 11 +++++++++++
> 1 file changed, 11 insertions(+)
> diff --git a/README.txt b/README.txt
> index 13bf8e6..828c9e7 100644
> --- a/README.txt
> +++ b/README.txt
> @@ -287,6 +287,17 @@ PATH:
> export PATH=/usr/local/texlive/2016/bin/i386-linux/:${PATH}
> export PATH=${HOME}/.local/bin:${PATH}
> +CentOS 8
> +The steps for Centos 8 are similar to the steps for CentOS 7.
> +There are just a couple differences.
> +First, CentOS 8 uses Python 3.x as the default, so intalling the
> +centos-release-scl and rh-python36 packages is unnecessary.
> +Second, Centos 8 uses dnf as its package manager instead of yum, so
> +packages such as npm should be installed using dnf instead.
> Arch Linux
> 2.27.0
> devel mailing list
> devel at rtems.org
