[PATCH v4] bsps: Move optfdt* files to shared parent directory
pranav
dangipranav at gmail.com
Fri Jul 16 14:51:03 UTC 2021
.../arm/altera-cyclone-v/bspalteracyclonev.yml | 8 ++++----
spec/build/bsps/arm/beagle/grp.yml | 8 ++++----
spec/build/bsps/arm/beagle/optfdtcpyro.yml | 16 ----------------
spec/build/bsps/arm/beagle/optfdtmxsz.yml | 17 -----------------
spec/build/bsps/arm/beagle/optfdtro.yml | 16 ----------------
spec/build/bsps/arm/beagle/optfdtuboot.yml | 16 ----------------
spec/build/bsps/arm/imx/bspimx.yml | 8 ++++----
spec/build/bsps/arm/imx/optfdtcpyro.yml | 16 ----------------
spec/build/bsps/arm/imx/optfdtmxsz.yml | 17 -----------------
spec/build/bsps/arm/imx/optfdtro.yml | 16 ----------------
spec/build/bsps/arm/imx/optfdtuboot.yml | 16 ----------------
spec/build/bsps/arm/raspberrypi/grp.yml | 8 ++++++++
.../{arm/altera-cyclone-v => }/optfdtcpyro.yml | 0
.../{arm/altera-cyclone-v => }/optfdtmxsz.yml | 0
.../{arm/altera-cyclone-v => }/optfdtro.yml | 0
.../{arm/altera-cyclone-v => }/optfdtuboot.yml | 0
spec/build/bsps/powerpc/qoriq/grp.yml | 4 ++--
spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml | 17 -----------------
spec/build/bsps/powerpc/qoriq/optfdtro.yml | 16 ----------------
spec/build/bsps/riscv/riscv/grp.yml | 8 ++++----
spec/build/bsps/riscv/riscv/optfdtcpyro.yml | 16 ----------------
spec/build/bsps/riscv/riscv/optfdtmxsz.yml | 17 -----------------
spec/build/bsps/riscv/riscv/optfdtro.yml | 16 ----------------
spec/build/bsps/riscv/riscv/optfdtuboot.yml | 16 ----------------
24 files changed, 26 insertions(+), 246 deletions(-)
delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index da567ddd79..a9f3f7dabf 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -73,15 +73,15 @@ links:
- role: build-dependency
uid: optconuart1
- uid: optfdtcpyro
+ uid: ../../optfdtcpyro
uid: optfdten
- uid: optfdtmxsz
+ uid: ../../optfdtmxsz
- uid: optfdtro
+ uid: ../../optfdtro
- uid: optfdtuboot
+ uid: ../../optfdtuboot
uid: opti2cspeed
diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
index 1375913fd0..3452c3e5c8 100644
--- a/spec/build/bsps/arm/beagle/grp.yml
+++ b/spec/build/bsps/arm/beagle/grp.yml
@@ -22,13 +22,13 @@ links:
uid: optdm3730
- uid: optfdtcpyro
- uid: optfdtmxsz
- uid: optfdtro
- uid: optfdtuboot
uid: ../grp
diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
deleted file mode 100644
index 5ec59adf4d..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-actions:
-- get-boolean: null
-- define-condition: null
-build-type: option
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-default: true
-default-by-family: []
-default-by-variant: []
-description: |
- copy the FDT blob into the read-only load area via bsp_fdt_copy()
-enabled-by: true
-links: []
-name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
index f3b2504e02..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
+++ /dev/null
@@ -1,17 +0,0 @@
-actions:
-- get-integer: null
-- define: null
-build-type: option
-copyrights:
-default: 262144
-description: |
- maximum size of the FDT blob in bytes
-enabled-by: true
-format: '{}'
-links: []
-name: BSP_FDT_BLOB_SIZE_MAX
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
index a72bc23c0e..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
- place the FDT blob into the read-only data area
-enabled-by: true
-links: []
-name: BSP_FDT_BLOB_READ_ONLY
-type: build
diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
index cfe94e577c..0000000000
--- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
- copy the U-Boot provided FDT to an internal storage
-enabled-by: true
-links: []
-name: BSP_START_COPY_FDT_FROM_U_BOOT
-type: build
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index c65e02db2b..14719745f0 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -61,13 +61,13 @@ links:
uid: optconirq
- uid: optfdtcpyro
- uid: optfdtmxsz
- uid: optfdtro
- uid: optfdtuboot
uid: optresetvec
diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
--- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
--- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
+++ /dev/null
@@ -1,17 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default: 262144
-description: |
-enabled-by: true
-format: '{}'
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
--- a/spec/build/bsps/arm/imx/optfdtro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
--- a/spec/build/bsps/arm/imx/optfdtuboot.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
index 7291e8b178..94627a9526 100644
--- a/spec/build/bsps/arm/raspberrypi/grp.yml
+++ b/spec/build/bsps/arm/raspberrypi/grp.yml
@@ -41,6 +41,14 @@ links:
uid: linkcmds
uid: ../../bspopts
+- role: build-dependency
type: build
use-after: []
use-before: []
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
similarity index 100%
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
rename to spec/build/bsps/optfdtcpyro.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
rename to spec/build/bsps/optfdtmxsz.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
rename to spec/build/bsps/optfdtro.yml
diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
rename to spec/build/bsps/optfdtuboot.yml
diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
index 3e295cb599..08533ded6f 100644
--- a/spec/build/bsps/powerpc/qoriq/grp.yml
+++ b/spec/build/bsps/powerpc/qoriq/grp.yml
@@ -68,9 +68,9 @@ links:
uid: optexcfixdhdlr
- uid: optfdtmxsz
- uid: optfdtro
uid: opthid0
diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
--- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
+++ /dev/null
@@ -1,17 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default: 262144
-description: |
-enabled-by: true
-format: '{}'
-links: []
-type: build
diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
--- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
index 396f8986ec..77583d351e 100644
--- a/spec/build/bsps/riscv/riscv/grp.yml
+++ b/spec/build/bsps/riscv/riscv/grp.yml
@@ -32,13 +32,13 @@ links:
uid: optextirqmax
- uid: optfdtcpyro
- uid: optfdtmxsz
- uid: optfdtro
- uid: optfdtuboot
uid: optfrdme310arty
diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
--- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
index 8a07a2ad08..0000000000
--- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
+++ /dev/null
@@ -1,17 +0,0 @@
-actions:
-- define: null
-build-type: option
-copyrights:
-default: 65536
-description: |
-enabled-by: true
-format: '{}'
-links: []
-type: build
diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
--- a/spec/build/bsps/riscv/riscv/optfdtro.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
--- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
+++ /dev/null
@@ -1,16 +0,0 @@
-actions:
-build-type: option
-copyrights:
-default: true
-description: |
-enabled-by: true
-links: []
-type: build
2.30.2
