[PATCH v3] bsps: Move optfdt* files to shared parent directory
Fri Jul 16 04:32:39 UTC 2021
The patch need to add `default-by-family: []` to the places `default-by-variant`
are.
On 16/7/21 4:00 am, Joel Sherrill wrote:
> I was going to do a sweep of all BSPs and then push but had an issue
> with the patch. If something happened with the mail Pranav, please just
> compress it and send it to me privately as an attachment. If it needs
> rebasing, please take care of that.
> [joel at devel rtems]$ git am /tmp/x
> Applying: bsps: Move optfdt* files to shared parent directory
> error: patch failed: spec/build/bsps/arm/beagle/optfdtcpyro.yml:1
> error: spec/build/bsps/arm/beagle/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtmxsz.yml:1
> error: spec/build/bsps/arm/beagle/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtro.yml:1
> error: spec/build/bsps/arm/beagle/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/beagle/optfdtuboot.yml:1
> error: spec/build/bsps/arm/beagle/optfdtuboot.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtcpyro.yml:1
> error: spec/build/bsps/arm/imx/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtmxsz.yml:1
> error: spec/build/bsps/arm/imx/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtro.yml:1
> error: spec/build/bsps/arm/imx/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/arm/imx/optfdtuboot.yml:1
> error: spec/build/bsps/arm/imx/optfdtuboot.yml: patch does not apply
> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml:1
> error: spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/powerpc/qoriq/optfdtro.yml:1
> error: spec/build/bsps/powerpc/qoriq/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtcpyro.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtcpyro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtmxsz.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtmxsz.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtro.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtro.yml: patch does not apply
> error: patch failed: spec/build/bsps/riscv/riscv/optfdtuboot.yml:1
> error: spec/build/bsps/riscv/riscv/optfdtuboot.yml: patch does not apply
> Patch failed at 0001 bsps: Move optfdt* files to shared parent directory
> hint: Use 'git am --show-current-patch' to see the failed patch
> When you have resolved this problem, run "git am --continue".
> If you prefer to skip this patch, run "git am --skip" instead.
> To restore the original branch and stop patching, run "git am --abort".
> On Thu, Jul 15, 2021 at 10:13 AM Gedare Bloom <gedare at rtems.org> wrote:
>> This patch looks fine to me if someone can pick it up. It does touch a
>> lot of build BSPs though.
>> On Fri, Jul 9, 2021 at 12:16 AM Pranav Dangi <dangipranav at gmail.com> wrote:
>>> ping. (Apart from moving the files in a shared directory, a part of this patch also gets the RTEMS master branch to work on all the Pi's except 4.)
>>> On Fri, 2 Jul 2021, 09:35 Pranav Dangi, <dangipranav at gmail.com> wrote:
>>>> yes, I've built all of them
>>>> On Thu, Jul 1, 2021 at 10:01 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>>> Did you build all affected BSPs?
>>>>> On Thu, Jul 1, 2021 at 4:05 AM pranav <dangipranav at gmail.com> wrote:
>>>>>>  .../arm/altera-cyclone-v/bspalteracyclonev.yml   |  8 ++++----
>>>>>>  spec/build/bsps/arm/beagle/grp.yml               |  8 ++++----
>>>>>>  spec/build/bsps/arm/beagle/optfdtcpyro.yml       | 15 ---------------
>>>>>>  spec/build/bsps/arm/beagle/optfdtmxsz.yml        | 16 ----------------
>>>>>>  spec/build/bsps/arm/beagle/optfdtro.yml          | 15 ---------------
>>>>>>  spec/build/bsps/arm/beagle/optfdtuboot.yml       | 15 ---------------
>>>>>>  spec/build/bsps/arm/imx/bspimx.yml               |  8 ++++----
>>>>>>  spec/build/bsps/arm/imx/optfdtcpyro.yml          | 15 ---------------
>>>>>>  spec/build/bsps/arm/imx/optfdtmxsz.yml           | 16 ----------------
>>>>>>  spec/build/bsps/arm/imx/optfdtro.yml             | 15 ---------------
>>>>>>  spec/build/bsps/arm/imx/optfdtuboot.yml          | 15 ---------------
>>>>>>  spec/build/bsps/arm/raspberrypi/grp.yml          |  8 ++++++++
>>>>>>  .../{arm/altera-cyclone-v => }/optfdtcpyro.yml   |  0
>>>>>>  .../{arm/altera-cyclone-v => }/optfdtmxsz.yml    |  0
>>>>>>  .../bsps/{arm/altera-cyclone-v => }/optfdtro.yml |  0
>>>>>>  .../{arm/altera-cyclone-v => }/optfdtuboot.yml   |  0
>>>>>>  spec/build/bsps/powerpc/qoriq/grp.yml            |  4 ++--
>>>>>>  spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml     | 16 ----------------
>>>>>>  spec/build/bsps/powerpc/qoriq/optfdtro.yml       | 15 ---------------
>>>>>>  spec/build/bsps/riscv/riscv/grp.yml              |  8 ++++----
>>>>>>  spec/build/bsps/riscv/riscv/optfdtcpyro.yml      | 15 ---------------
>>>>>>  spec/build/bsps/riscv/riscv/optfdtmxsz.yml       | 16 ----------------
>>>>>>  spec/build/bsps/riscv/riscv/optfdtro.yml         | 15 ---------------
>>>>>>  spec/build/bsps/riscv/riscv/optfdtuboot.yml      | 15 ---------------
>>>>>>  24 files changed, 26 insertions(+), 232 deletions(-)
>>>>>>  delete mode 100644 spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/beagle/optfdtro.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/beagle/optfdtuboot.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/imx/optfdtcpyro.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/imx/optfdtmxsz.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/imx/optfdtro.yml
>>>>>>  delete mode 100644 spec/build/bsps/arm/imx/optfdtuboot.yml
>>>>>>  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtcpyro.yml (100%)
>>>>>>  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtmxsz.yml (100%)
>>>>>>  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtro.yml (100%)
>>>>>>  rename spec/build/bsps/{arm/altera-cyclone-v => }/optfdtuboot.yml (100%)
>>>>>>  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>>>>>  delete mode 100644 spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>>>>>  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>>>>>  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>>>>>  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtro.yml
>>>>>>  delete mode 100644 spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>>>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>>>>> index da567ddd79..a9f3f7dabf 100644
>>>>>> --- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>>>>> +++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
>>>>>> @@ -73,15 +73,15 @@ links:
>>>>>>  - role: build-dependency
>>>>>>    uid: optconuart1
>>>>>> -  uid: optfdtcpyro
>>>>>> +  uid: ../../optfdtcpyro
>>>>>>    uid: optfdten
>>>>>> -  uid: optfdtmxsz
>>>>>> +  uid: ../../optfdtmxsz
>>>>>> -  uid: optfdtro
>>>>>> +  uid: ../../optfdtro
>>>>>> -  uid: optfdtuboot
>>>>>> +  uid: ../../optfdtuboot
>>>>>>    uid: opti2cspeed
>>>>>> diff --git a/spec/build/bsps/arm/beagle/grp.yml b/spec/build/bsps/arm/beagle/grp.yml
>>>>>> index 1375913fd0..3452c3e5c8 100644
>>>>>> --- a/spec/build/bsps/arm/beagle/grp.yml
>>>>>> +++ b/spec/build/bsps/arm/beagle/grp.yml
>>>>>> @@ -22,13 +22,13 @@ links:
>>>>>>    uid: optdm3730
>>>>>> -  uid: optfdtcpyro
>>>>>> -  uid: optfdtmxsz
>>>>>> -  uid: optfdtro
>>>>>> -  uid: optfdtuboot
>>>>>>    uid: ../grp
>>>>>> diff --git a/spec/build/bsps/arm/beagle/optfdtcpyro.yml b/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>>>>> deleted file mode 100644
>>>>>> index c26b1ae051..0000000000
>>>>>> --- a/spec/build/bsps/arm/beagle/optfdtcpyro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>>>>> -actions:
>>>>>> -- get-boolean: null
>>>>>> -- define-condition: null
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>>>>> -default: true
>>>>>> -default-by-variant: []
>>>>>> -description: |
>>>>>> -  copy the FDT blob into the read-only load area via bsp_fdt_copy()
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -name: BSP_FDT_BLOB_COPY_TO_READ_ONLY_LOAD_AREA
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/beagle/optfdtmxsz.yml b/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>>>>> index 14af766230..0000000000
>>>>>> --- a/spec/build/bsps/arm/beagle/optfdtmxsz.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,16 +0,0 @@
>>>>>> -actions:
>>>>>> -- get-integer: null
>>>>>> -- define: null
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: 262144
>>>>>> -description: |
>>>>>> -  maximum size of the FDT blob in bytes
>>>>>> -enabled-by: true
>>>>>> -format: '{}'
>>>>>> -links: []
>>>>>> -name: BSP_FDT_BLOB_SIZE_MAX
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/beagle/optfdtro.yml b/spec/build/bsps/arm/beagle/optfdtro.yml
>>>>>> index a61bb2924b..0000000000
>>>>>> --- a/spec/build/bsps/arm/beagle/optfdtro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -  place the FDT blob into the read-only data area
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -name: BSP_FDT_BLOB_READ_ONLY
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/beagle/optfdtuboot.yml b/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>>>>> index 5805e912ff..0000000000
>>>>>> --- a/spec/build/bsps/arm/beagle/optfdtuboot.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -  copy the U-Boot provided FDT to an internal storage
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -name: BSP_START_COPY_FDT_FROM_U_BOOT
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
>>>>>> index c65e02db2b..14719745f0 100644
>>>>>> --- a/spec/build/bsps/arm/imx/bspimx.yml
>>>>>> +++ b/spec/build/bsps/arm/imx/bspimx.yml
>>>>>> @@ -61,13 +61,13 @@ links:
>>>>>>    uid: optconirq
>>>>>> -  uid: optfdtcpyro
>>>>>> -  uid: optfdtmxsz
>>>>>> -  uid: optfdtro
>>>>>> -  uid: optfdtuboot
>>>>>>    uid: optresetvec
>>>>>> diff --git a/spec/build/bsps/arm/imx/optfdtcpyro.yml b/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>>>>> --- a/spec/build/bsps/arm/imx/optfdtcpyro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/imx/optfdtmxsz.yml b/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>>>>> --- a/spec/build/bsps/arm/imx/optfdtmxsz.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,16 +0,0 @@
>>>>>> -actions:
>>>>>> -- define: null
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: 262144
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -format: '{}'
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/imx/optfdtro.yml b/spec/build/bsps/arm/imx/optfdtro.yml
>>>>>> --- a/spec/build/bsps/arm/imx/optfdtro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/imx/optfdtuboot.yml b/spec/build/bsps/arm/imx/optfdtuboot.yml
>>>>>> --- a/spec/build/bsps/arm/imx/optfdtuboot.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/arm/raspberrypi/grp.yml b/spec/build/bsps/arm/raspberrypi/grp.yml
>>>>>> index 7291e8b178..3c59ad77c1 100644
>>>>>> --- a/spec/build/bsps/arm/raspberrypi/grp.yml
>>>>>> +++ b/spec/build/bsps/arm/raspberrypi/grp.yml
>>>>>> @@ -31,6 +31,14 @@ links:
>>>>>>    uid: optrpi2
>>>>>>    uid: optspiiomode
>>>>>> +- role: build-dependency
>>>>>>    uid: ../start
>>>>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml b/spec/build/bsps/optfdtcpyro.yml
>>>>>> similarity index 100%
>>>>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtcpyro.yml
>>>>>> rename to spec/build/bsps/optfdtcpyro.yml
>>>>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml b/spec/build/bsps/optfdtmxsz.yml
>>>>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtmxsz.yml
>>>>>> rename to spec/build/bsps/optfdtmxsz.yml
>>>>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml b/spec/build/bsps/optfdtro.yml
>>>>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtro.yml
>>>>>> rename to spec/build/bsps/optfdtro.yml
>>>>>> diff --git a/spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml b/spec/build/bsps/optfdtuboot.yml
>>>>>> rename from spec/build/bsps/arm/altera-cyclone-v/optfdtuboot.yml
>>>>>> rename to spec/build/bsps/optfdtuboot.yml
>>>>>> diff --git a/spec/build/bsps/powerpc/qoriq/grp.yml b/spec/build/bsps/powerpc/qoriq/grp.yml
>>>>>> index 3e295cb599..08533ded6f 100644
>>>>>> --- a/spec/build/bsps/powerpc/qoriq/grp.yml
>>>>>> +++ b/spec/build/bsps/powerpc/qoriq/grp.yml
>>>>>> @@ -68,9 +68,9 @@ links:
>>>>>>    uid: optexcfixdhdlr
>>>>>> -  uid: optfdtmxsz
>>>>>> -  uid: optfdtro
>>>>>>    uid: opthid0
>>>>>> diff --git a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml b/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>>>>> --- a/spec/build/bsps/powerpc/qoriq/optfdtmxsz.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,16 +0,0 @@
>>>>>> -actions:
>>>>>> -- define: null
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: 262144
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -format: '{}'
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/powerpc/qoriq/optfdtro.yml b/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>>>>> --- a/spec/build/bsps/powerpc/qoriq/optfdtro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/riscv/riscv/grp.yml b/spec/build/bsps/riscv/riscv/grp.yml
>>>>>> index 396f8986ec..77583d351e 100644
>>>>>> --- a/spec/build/bsps/riscv/riscv/grp.yml
>>>>>> +++ b/spec/build/bsps/riscv/riscv/grp.yml
>>>>>> @@ -32,13 +32,13 @@ links:
>>>>>>    uid: optextirqmax
>>>>>> -  uid: optfdtcpyro
>>>>>> -  uid: optfdtmxsz
>>>>>> -  uid: optfdtro
>>>>>> -  uid: optfdtuboot
>>>>>>    uid: optfrdme310arty
>>>>>> diff --git a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml b/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>>>>> --- a/spec/build/bsps/riscv/riscv/optfdtcpyro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml b/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>>>>> index 63a42f5a29..0000000000
>>>>>> --- a/spec/build/bsps/riscv/riscv/optfdtmxsz.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,16 +0,0 @@
>>>>>> -actions:
>>>>>> -- define: null
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: 65536
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -format: '{}'
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/riscv/riscv/optfdtro.yml b/spec/build/bsps/riscv/riscv/optfdtro.yml
>>>>>> --- a/spec/build/bsps/riscv/riscv/optfdtro.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> diff --git a/spec/build/bsps/riscv/riscv/optfdtuboot.yml b/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>>>>> --- a/spec/build/bsps/riscv/riscv/optfdtuboot.yml
>>>>>> +++ /dev/null
>>>>>> @@ -1,15 +0,0 @@
>>>>>> -actions:
>>>>>> -build-type: option
>>>>>> -copyrights:
>>>>>> -default: true
>>>>>> -description: |
>>>>>> -enabled-by: true
>>>>>> -links: []
>>>>>> -type: build
>>>>>> 2.27.0
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
