[PATCH V2] closes #3889 new defect Test needed for timer_create with CLOCK_MONOTONIC
zack leung
zakthertemsdev at gmail.com
Mon Jul 19 14:08:39 UTC 2021
The code i wrote is not based on my previous patch. I ran the same
commands in the guide as well as my first patch:
git add
git commit
git send-email --to=devel at rtems.org -1
is there a way to only submit the second patch? I tried to delete the
patch file before sending the first patch
Also, I have made changes to reduce code duplication. The structure of the
code has changed so I had to format things.
Thanks
Zack
On Thu, 15 Jul 2021 at 15:29, Gedare Bloom <gedare at rtems.org> wrote:
> The first line of the commit should be shorter. Use a blank line, and
> then close the ticket with the Closes #nnnn command.
> https://devel.rtems.org/wiki/Developer/Git#GitCommits
> We need to move this information into
> https://docs.rtems.org/branches/master/eng/management.html
> On Thu, Jul 8, 2021 at 1:50 PM Zacchaeus Leung <zakthertemsdev at gmail.com>
> wrote:
> > ...or-timer_create-with-clock_monotonic.patch | 234 ++++++++++++++++++
> > cpukit/include/rtems/posix/timer.h | 2 +-
> > cpukit/posix/src/psxtimercreate.c | 86 +++----
> > cpukit/posix/src/timergettime.c | 76 ++----
> > 4 files changed, 300 insertions(+), 98 deletions(-)
> > create mode 100644
> 0001-Addded-test-for-timer_create-with-clock_monotonic.patch
> > diff --git
> a/0001-Addded-test-for-timer_create-with-clock_monotonic.patch
> b/0001-Addded-test-for-timer_create-with-clock_monotonic.patch
> > new file mode 100644
> > index 0000000000..33be528411
> > --- /dev/null
> > +++ b/0001-Addded-test-for-timer_create-with-clock_monotonic.patch
> > @@ -0,0 +1,234 @@
> > +From f1cac2a4b64e5076f0ceff014b78be41e5f00389 Mon Sep 17 00:00:00 2001
> > +From: Zack <zakthertemsdev at outlook.com>
> > +Date: Mon, 28 Jun 2021 14:23:42 -0400
> > +Subject: [PATCH] Addded test for timer_create with clock_monotonic
> It seems that you have included a patch within your patch. Please
> check your commit before you email it, to make sure only the changes
> you want included are there. Since I'm not sure what changes you are
> intending to send, I'm going to stop here.
> A few general comments:
> Avoid reformatting existing code. Keep your changes limited to
> functional changes only, and send reformatting/documentation changes
> separately. Make sure you write new code consistently to our style
> guide. (https://docs.rtems.org/branches/master/eng/coding.html) If in
> doubt, write your code consistent with code near it.
> Provide all the patches for your commits that go from the current HEAD
> (most recent commit on master). We can't review commits that are based
> on other commits on your local repo only, unless you include those
> commits also for review.
> > + cpukit/include/rtems/posix/timer.h | 1 +
> > + cpukit/posix/src/psxtimercreate.c | 5 +-
> > + cpukit/posix/src/timergettime.c | 79 ++++++++++++++++-------
> > + testsuites/psxtests/psxtimer02/psxtimer.c | 38 ++++++++++-
> > + 4 files changed, 98 insertions(+), 25 deletions(-)
> > +diff --git a/cpukit/include/rtems/posix/timer.h
> b/cpukit/include/rtems/posix/timer.h
> > +index bcbf07a65a..839fe3293c 100644
> > +--- a/cpukit/include/rtems/posix/timer.h
> > ++++ b/cpukit/include/rtems/posix/timer.h
> > +@@ -48,6 +48,7 @@ typedef struct {
> > + uint32_t ticks; /* Number of ticks of the
> initialization */
> > + uint32_t overrun; /* Number of expirations of the timer
> > + struct timespec time; /* Time at which the timer was
> started */
> > ++ clockid_t clock_type;
> > + } POSIX_Timer_Control;
> > +diff --git a/cpukit/posix/src/psxtimercreate.c
> b/cpukit/posix/src/psxtimercreate.c
> > +index a63cf1d100..b60be3f229 100644
> > +--- a/cpukit/posix/src/psxtimercreate.c
> > ++++ b/cpukit/posix/src/psxtimercreate.c
> > +@@ -40,7 +40,7 @@ int timer_create(
> > + POSIX_Timer_Control *ptimer;
> > +- if ( clock_id != CLOCK_REALTIME )
> > ++ if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> > + rtems_set_errno_and_return_minus_one( EINVAL );
> > + if ( !timerid )
> > +@@ -91,7 +91,8 @@ int timer_create(
> > + ptimer->timer_data.it_value.tv_nsec = 0;
> > + ptimer->timer_data.it_interval.tv_sec = 0;
> > + ptimer->timer_data.it_interval.tv_nsec = 0;
> > ++ ptimer->clock_type=clock_id;
> > + _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> > + _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> > + _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
> > +diff --git a/cpukit/posix/src/timergettime.c
> b/cpukit/posix/src/timergettime.c
> > +index ee2a566f0e..57b0ab4918 100644
> > +--- a/cpukit/posix/src/timergettime.c
> > ++++ b/cpukit/posix/src/timergettime.c
> > +@@ -6,6 +6,14 @@
> > + * @brief Function Fetches State of POSIX Per-Process Timers
> > ++ * @file
> > ++ * @ingroup POSIXAPI
> > ++ * @brief Function Fetches State of POSIX Per-Process Timers
> > + * 14.2.4 Per-Process Timers, P1003.1b-1993, p. 267
> > +@@ -21,13 +29,13 @@
> > + #include "config.h"
> > + #endif
> > +-#include <time.h>
> > + #include <errno.h>
> > + #include <rtems/posix/timerimpl.h>
> > + #include <rtems/score/todimpl.h>
> > + #include <rtems/score/watchdogimpl.h>
> > + #include <rtems/seterr.h>
> > ++#include <rtems/timespec.h>
> > ++#include <time.h>
> > + * - When a timer is initialized, the value of the time in
> > +@@ -36,38 +44,65 @@
> > + * between the current time and the initialization time.
> > +-int timer_gettime(
> > +- timer_t timerid,
> > +- struct itimerspec *value
> > ++int timer_gettime(timer_t timerid, struct itimerspec *value) {
> > +- ISR_lock_Context lock_context;
> > +- uint64_t now;
> > +- uint32_t remaining;
> > ++ ISR_lock_Context lock_context;
> > ++ uint32_t remaining;
> > ++ Per_CPU_Control *cpu;
> > ++ struct timespec *now; // get time now either with
> > ++ struct timespec *expire; // expire
> > ++ struct timespec *result;
> > ++ if (!value)
> > ++ rtems_set_errno_and_return_minus_one(EINVAL);
> > +- if ( !value )
> > +- rtems_set_errno_and_return_minus_one( EINVAL );
> > ++ ptimer = _POSIX_Timer_Get(timerid, &lock_context);
> > ++ if (ptimer == NULL) {
> > ++ if (ptimer->clock_type == CLOCK_REALTIME) {
> > +- ptimer = _POSIX_Timer_Get( timerid, &lock_context );
> > +- if ( ptimer != NULL ) {
> > +- Per_CPU_Control *cpu;
> > ++ cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
> > +- cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
> > +- now = cpu->Watchdog.ticks;
> > ++ _TOD_Get(now); // get current time
> > ++ rtems_timespec_from_ticks(ptimer->Timer.expire,
> > ++ expire);
> > +- if ( now < ptimer->Timer.expire ) {
> > +- remaining = (uint32_t) ( ptimer->Timer.expire - now );
> > ++ if (now->tv_nsec + now->tv_sec >
> > ++ expire->tv_nsec + expire->tv_sec) {
> > ++ rtems_timespec_subtract(now, expire, result);
> > ++ remaining = (uint32_t)result->tv_nsec + result->tv_sec;
> > + } else {
> > + remaining = 0;
> > +- _Timespec_From_ticks( remaining, &value->it_value );
> > ++ _Timespec_From_ticks(remaining, &value->it_value);
> > + value->it_interval = ptimer->timer_data.it_interval;
> > ++ _POSIX_Timer_Release(cpu, &lock_context);
> > ++ return 0;
> > ++ if (ptimer->clock_type == CLOCK_MONOTONIC) {
> > ++ rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
> > +- _POSIX_Timer_Release( cpu, &lock_context );
> > ++ if (now->tv_nsec + now->tv_sec > expire->tv_nsec + expire->tv_sec)
> > ++ } else {
> > ++ remaining = 0;
> > ++ value->it_interval = ptimer->timer_data.it_interval;
> > + return 0;
> > +diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c
> b/testsuites/psxtests/psxtimer02/psxtimer.c
> > +index 9f79d33c42..6aea61c498 100644
> > +--- a/testsuites/psxtests/psxtimer02/psxtimer.c
> > ++++ b/testsuites/psxtests/psxtimer02/psxtimer.c
> > +@@ -20,6 +20,7 @@
> > + * http://www.rtems.org/license/LICENSE.
> > + #ifdef HAVE_CONFIG_H
> > + #endif
> > +@@ -63,7 +64,7 @@ void *POSIX_Init (
> > + fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> > + puts( "timer_create - OK" );
> > +- status = timer_create( CLOCK_REALTIME, NULL, &timer );
> > ++ status = timer_create( CLOCK_REALTIME , NULL, &timer );
> > + posix_service_failed( status, "timer_create OK" );
> > + puts( "timer_create - too many - EAGAIN" );
> > +@@ -127,6 +128,41 @@ void *POSIX_Init (
> > + status = timer_delete( timer );
> > + fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> > ++ * If these are not filled in correctly, we don't pass its error
> checking.
> > ++puts( "timer_create - bad timer id pointer - EINVAL" );
> > ++ status = timer_create( CLOCK_MONOTONIC, &event, NULL );
> > ++ fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
> > ++ puts( "timer_create - OK" );
> > ++ status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
> > ++ posix_service_failed( status, "timer_create OK" );
> > ++ puts( "timer_create - too many - EAGAIN" );
> > ++ status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
> > ++ fatal_posix_service_status_errno( status, EAGAIN, "too many" );
> > ++ clock_gettime( CLOCK_MONOTONIC, &now );
> > ++ itimer.it_value = now;
> > ++ itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
> > ++ puts( "timer_settime - bad itimer value - previous time - EINVAL" );
> > ++ status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
> > ++ fatal_posix_service_status_errno( status, EINVAL, "bad itimer value
> #3" );
> > ++ itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
> > ++ puts( "timer_settime - bad id - EINVAL" );
> > ++ status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
> > ++ fatal_posix_service_status_errno( status, EINVAL, "bad id" );
> > + TEST_END();
> > + rtems_test_exit (0);
> > +2.31.1
> > index 839fe3293c..fdfa1e0b2f 100644
> > @@ -48,7 +48,7 @@ typedef struct {
> initialization */
> > struct timespec time; /* Time at which the timer was started
> > - clockid_t clock_type;
> > + clockid_t clock_type; /* The type of timer */
> > index b60be3f229..18af8a6582 100644
> > @@ -21,9 +21,9 @@
> > #include "config.h"
> > #endif
> > -#include <time.h>
> > #include <errno.h>
> > #include <signal.h>
> > +#include <time.h>
> > #include <rtems/posix/sigset.h>
> > @@ -32,83 +32,73 @@
> > #include <rtems/sysinit.h>
> > -int timer_create(
> > - clockid_t clock_id,
> > - struct sigevent *__restrict evp,
> > - timer_t *__restrict timerid
> > +int timer_create(clockid_t clock_id, struct sigevent *__restrict evp,
> > + timer_t *__restrict timerid) {
> > - if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC )
> > + if (clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC)
> > - if ( !timerid )
> > + if (!timerid)
> > - * The data of the structure evp are checked in order to verify if
> they
> > - * are coherent.
> > + * The data of the structure evp are checked in order to verify if
> they
> > + * are coherent.
> > if (evp != NULL) {
> > /* The structure has data */
> > - if ( ( evp->sigev_notify != SIGEV_NONE ) &&
> > - ( evp->sigev_notify != SIGEV_SIGNAL ) ) {
> > - /* The value of the field sigev_notify is not valid */
> > + if ((evp->sigev_notify != SIGEV_NONE) &&
> > + (evp->sigev_notify != SIGEV_SIGNAL)) {
> > + /* The value of the field sigev_notify is not valid */
> > - if ( !evp->sigev_signo )
> > + if (!evp->sigev_signo)
> > - if ( !is_valid_signo(evp->sigev_signo) )
> > + if (!is_valid_signo(evp->sigev_signo))
> > * Allocate a timer
> > ptimer = _POSIX_Timer_Allocate();
> > - if ( !ptimer ) {
> > + if (!ptimer) {
> > _Objects_Allocator_unlock();
> > - rtems_set_errno_and_return_minus_one( EAGAIN );
> > + rtems_set_errno_and_return_minus_one(EAGAIN);
> > /* The data of the created timer are stored to use them later */
> > - ptimer->state = POSIX_TIMER_STATE_CREATE_NEW;
> > + ptimer->state = POSIX_TIMER_STATE_CREATE_NEW;
> > ptimer->thread_id = _Thread_Get_executing()->Object.id;
> > - if ( evp != NULL ) {
> > + if (evp != NULL) {
> > ptimer->inf.sigev_notify = evp->sigev_notify;
> > - ptimer->inf.sigev_signo = evp->sigev_signo;
> > - ptimer->inf.sigev_value = evp->sigev_value;
> > + ptimer->inf.sigev_signo = evp->sigev_signo;
> > + ptimer->inf.sigev_value = evp->sigev_value;
> > - ptimer->overrun = 0;
> > - ptimer->timer_data.it_value.tv_sec = 0;
> > - ptimer->timer_data.it_value.tv_nsec = 0;
> > - ptimer->timer_data.it_interval.tv_sec = 0;
> > + ptimer->overrun = 0;
> > + ptimer->timer_data.it_value.tv_sec = 0;
> > - ptimer->clock_type=clock_id;
> > - _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
> > - _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
> > + ptimer->clock_type = clock_id;
> > + _Watchdog_Preinitialize(&ptimer->Timer, _Per_CPU_Get_snapshot());
> > + _Watchdog_Initialize(&ptimer->Timer, _POSIX_Timer_TSR);
> > - *timerid = ptimer->Object.id;
> > + *timerid = ptimer->Object.id;
> > return 0;
> > -static void _POSIX_Timer_Manager_initialization( void )
> > - _Objects_Initialize_information( &_POSIX_Timer_Information );
> > +static void _POSIX_Timer_Manager_initialization(void) {
> > + _Objects_Initialize_information(&_POSIX_Timer_Information);
> > -RTEMS_SYSINIT_ITEM(
> > - _POSIX_Timer_Manager_initialization,
> > - RTEMS_SYSINIT_POSIX_TIMER,
> > - RTEMS_SYSINIT_ORDER_MIDDLE
> > +RTEMS_SYSINIT_ITEM(_POSIX_Timer_Manager_initialization,
> > + RTEMS_SYSINIT_POSIX_TIMER,
> RTEMS_SYSINIT_ORDER_MIDDLE);
> > index 57b0ab4918..ee9d37ccdd 100644
> > @@ -1,10 +1,3 @@
> > - * @file
> > - * @ingroup POSIXAPI
> > - * @brief Function Fetches State of POSIX Per-Process Timers
> > * @file
> > @@ -30,12 +23,13 @@
> > #endif
> > #include <errno.h>
> > +#include <time.h>
> > -#include <time.h>
> > @@ -44,15 +38,18 @@
> > -int timer_gettime(timer_t timerid, struct itimerspec *value) {
> > +int timer_gettime(
> > + timer_t timerid,
> > + struct itimerspec *value
> > uint32_t remaining;
> > - struct timespec *now; // get time now either with
> > - struct timespec *expire; // expire
> > - struct timespec *result;
> > if (!value)
> > @@ -62,47 +59,28 @@ int timer_gettime(timer_t timerid, struct itimerspec
> *value) {
> > - if (ptimer->clock_type == CLOCK_REALTIME) {
> > - cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
> > - _TOD_Get(now); // get current time
> > - rtems_timespec_from_ticks(ptimer->Timer.expire,
> > - expire);
> > - if (now->tv_nsec + now->tv_sec >
> > - expire->tv_nsec + expire->tv_sec) {
> > - rtems_timespec_subtract(now, expire, result);
> > - remaining = (uint32_t)result->tv_nsec + result->tv_sec;
> > - } else {
> > - remaining = 0;
> > - _Timespec_From_ticks(remaining, &value->it_value);
> > - value->it_interval = ptimer->timer_data.it_interval;
> > - _POSIX_Timer_Release(cpu, &lock_context);
> > - return 0;
> > + _Timecounter_Nanouptime(now);
> > + _TOD_Get(now);
> > - rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
> > - if (now->tv_nsec + now->tv_sec > expire->tv_nsec + expire->tv_sec) {
> > + if( rtems_timespec_less_than( now, expire )) {
> > } else {
> > - remaining = 0;
> > + result->tv_nsec=0;
> > + result->tv_sec=0;
> > - return 0;
> > - rtems_set_errno_and_return_minus_one(EINVAL);
> > + (*value).it_value=*result;
> > + return 0;
> > 2.32.0
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210719/85411e3b/attachment-0001.html>
