[PATCH V2] closes #3889 new defect Test needed for timer_create with CLOCK_MONOTONIC
Mon Jul 19 14:47:14 UTC 2021
On Mon, Jul 19, 2021 at 8:08 AM zack leung <zakthertemsdev at gmail.com> wrote:
> The code i wrote is  not based on  my previous patch. I ran the same commands in the guide as well as my first patch:
> git add
> git commit
>  git send-email --to=devel at rtems.org -1
> is there a  way to only submit the second patch? I tried to delete the patch file before sending the first patch
> Also, I have made changes to reduce code duplication. The structure of the code has changed so I had to format things.
You can use git-rebase to modify your local git commit history. You
may need to spend some time to learn git better to do some more
advanced work with it. I don't know of any good, current tutorials.
> Thanks
> Zack
> On Thu, 15 Jul 2021 at 15:29, Gedare Bloom <gedare at rtems.org> wrote:
>> The first line of the commit should be shorter. Use a blank line, and
>> then close the ticket with the Closes #nnnn command.
>> https://devel.rtems.org/wiki/Developer/Git#GitCommits
>> We need to move this information into
>> https://docs.rtems.org/branches/master/eng/management.html
>> On Thu, Jul 8, 2021 at 1:50 PM Zacchaeus Leung <zakthertemsdev at gmail.com> wrote:
>> >  ...or-timer_create-with-clock_monotonic.patch | 234 ++++++++++++++++++
>> >  cpukit/include/rtems/posix/timer.h            |   2 +-
>> >  cpukit/posix/src/psxtimercreate.c             |  86 +++----
>> >  cpukit/posix/src/timergettime.c               |  76 ++----
>> >  4 files changed, 300 insertions(+), 98 deletions(-)
>> >  create mode 100644 0001-Addded-test-for-timer_create-with-clock_monotonic.patch
>> > diff --git a/0001-Addded-test-for-timer_create-with-clock_monotonic.patch b/0001-Addded-test-for-timer_create-with-clock_monotonic.patch
>> > new file mode 100644
>> > index 0000000000..33be528411
>> > --- /dev/null
>> > +++ b/0001-Addded-test-for-timer_create-with-clock_monotonic.patch
>> > @@ -0,0 +1,234 @@
>> > +From f1cac2a4b64e5076f0ceff014b78be41e5f00389 Mon Sep 17 00:00:00 2001
>> > +From: Zack <zakthertemsdev at outlook.com>
>> > +Date: Mon, 28 Jun 2021 14:23:42 -0400
>> > +Subject: [PATCH] Addded test for timer_create with clock_monotonic
>> It seems that you have included a patch within your patch. Please
>> check your commit before you email it, to make sure only the changes
>> you want included are there. Since I'm not sure what changes you are
>> intending to send, I'm going to stop here.
>> A few general comments:
>> Avoid reformatting existing code. Keep your changes limited to
>> functional changes only, and send reformatting/documentation changes
>> separately. Make sure you write new code consistently to our style
>> guide. (https://docs.rtems.org/branches/master/eng/coding.html) If in
>> doubt, write your code consistent with code near it.
>> Provide all the patches for your commits that go from the current HEAD
>> (most recent commit on master). We can't review commits that are based
>> on other commits on your local repo only, unless you include those
>> commits also for review.
>> > + cpukit/include/rtems/posix/timer.h        |  1 +
>> > + cpukit/posix/src/psxtimercreate.c         |  5 +-
>> > + cpukit/posix/src/timergettime.c           | 79 ++++++++++++++++-------
>> > + testsuites/psxtests/psxtimer02/psxtimer.c | 38 ++++++++++-
>> > + 4 files changed, 98 insertions(+), 25 deletions(-)
>> > +diff --git a/cpukit/include/rtems/posix/timer.h b/cpukit/include/rtems/posix/timer.h
>> > +index bcbf07a65a..839fe3293c 100644
>> > +--- a/cpukit/include/rtems/posix/timer.h
>> > ++++ b/cpukit/include/rtems/posix/timer.h
>> > +@@ -48,6 +48,7 @@ typedef struct {
>> > +   uint32_t          ticks;      /* Number of ticks of the initialization */
>> > +   uint32_t          overrun;    /* Number of expirations of the timer    */
>> > +   struct timespec   time;       /* Time at which the timer was started   */
>> > ++    clockid_t     clock_type;
>> > + } POSIX_Timer_Control;
>> > +diff --git a/cpukit/posix/src/psxtimercreate.c b/cpukit/posix/src/psxtimercreate.c
>> > +index a63cf1d100..b60be3f229 100644
>> > +--- a/cpukit/posix/src/psxtimercreate.c
>> > ++++ b/cpukit/posix/src/psxtimercreate.c
>> > +@@ -40,7 +40,7 @@ int timer_create(
>> > +   POSIX_Timer_Control *ptimer;
>> > +-  if ( clock_id != CLOCK_REALTIME )
>> > ++  if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC  )
>> > +     rtems_set_errno_and_return_minus_one( EINVAL );
>> > +   if ( !timerid )
>> > +@@ -91,7 +91,8 @@ int timer_create(
>> > +   ptimer->timer_data.it_value.tv_nsec    = 0;
>> > +   ptimer->timer_data.it_interval.tv_sec  = 0;
>> > +   ptimer->timer_data.it_interval.tv_nsec = 0;
>> > ++  ptimer->clock_type=clock_id;
>> > +   _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>> > +   _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
>> > +   _Objects_Open_u32(&_POSIX_Timer_Information, &ptimer->Object, 0);
>> > +diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
>> > +index ee2a566f0e..57b0ab4918 100644
>> > +--- a/cpukit/posix/src/timergettime.c
>> > ++++ b/cpukit/posix/src/timergettime.c
>> > +@@ -6,6 +6,14 @@
>> > +  * @brief Function Fetches State of POSIX Per-Process Timers
>> > ++ * @file
>> > ++ * @ingroup POSIXAPI
>> > ++ * @brief Function Fetches State of POSIX Per-Process Timers
>> > +  *  14.2.4 Per-Process Timers, P1003.1b-1993, p. 267
>> > +@@ -21,13 +29,13 @@
>> > + #include "config.h"
>> > + #endif
>> > +-#include <time.h>
>> > + #include <errno.h>
>> > + #include <rtems/posix/timerimpl.h>
>> > + #include <rtems/score/todimpl.h>
>> > + #include <rtems/score/watchdogimpl.h>
>> > + #include <rtems/seterr.h>
>> > ++#include <rtems/timespec.h>
>> > ++#include <time.h>
>> > +  *          - When a timer is initialized, the value of the time in
>> > +@@ -36,38 +44,65 @@
>> > +  *            between the current time and the initialization time.
>> > +-int timer_gettime(
>> > +-  timer_t            timerid,
>> > +-  struct itimerspec *value
>> > ++int timer_gettime(timer_t timerid, struct itimerspec *value) {
>> > +-  ISR_lock_Context     lock_context;
>> > +-  uint64_t             now;
>> > +-  uint32_t             remaining;
>> > ++  ISR_lock_Context lock_context;
>> > ++  uint32_t remaining;
>> > ++  Per_CPU_Control *cpu;
>> > ++  struct timespec *now;    // get time now either with
>> > ++  struct timespec *expire; // expire
>> > ++  struct timespec *result;
>> > ++  if (!value)
>> > ++    rtems_set_errno_and_return_minus_one(EINVAL);
>> > +-  if ( !value )
>> > +-    rtems_set_errno_and_return_minus_one( EINVAL );
>> > ++  ptimer = _POSIX_Timer_Get(timerid, &lock_context);
>> > ++  if (ptimer == NULL) {
>> > ++  if (ptimer->clock_type == CLOCK_REALTIME) {
>> > +-  ptimer = _POSIX_Timer_Get( timerid, &lock_context );
>> > +-  if ( ptimer != NULL ) {
>> > +-    Per_CPU_Control *cpu;
>> > ++    cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
>> > +-    cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
>> > +-    now = cpu->Watchdog.ticks;
>> > ++    _TOD_Get(now); // get current time
>> > ++    rtems_timespec_from_ticks(ptimer->Timer.expire,
>> > ++                              expire);
>> > +-    if ( now < ptimer->Timer.expire ) {
>> > +-      remaining = (uint32_t) ( ptimer->Timer.expire - now );
>> > ++    if (now->tv_nsec + now->tv_sec >
>> > ++        expire->tv_nsec + expire->tv_sec) {
>> > ++      rtems_timespec_subtract(now, expire, result);
>> > ++      remaining = (uint32_t)result->tv_nsec + result->tv_sec;
>> > +     } else {
>> > +       remaining = 0;
>> > +-    _Timespec_From_ticks( remaining, &value->it_value );
>> > ++    _Timespec_From_ticks(remaining, &value->it_value);
>> > +     value->it_interval = ptimer->timer_data.it_interval;
>> > ++     _POSIX_Timer_Release(cpu, &lock_context);
>> > ++    return 0;
>> > ++  if (ptimer->clock_type == CLOCK_MONOTONIC) {
>> > ++    rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
>> > +-    _POSIX_Timer_Release( cpu, &lock_context );
>> > ++    if (now->tv_nsec + now->tv_sec > expire->tv_nsec + expire->tv_sec) {
>> > ++    } else {
>> > ++      remaining = 0;
>> > ++    value->it_interval = ptimer->timer_data.it_interval;
>> > +     return 0;
>> > +diff --git a/testsuites/psxtests/psxtimer02/psxtimer.c b/testsuites/psxtests/psxtimer02/psxtimer.c
>> > +index 9f79d33c42..6aea61c498 100644
>> > +--- a/testsuites/psxtests/psxtimer02/psxtimer.c
>> > ++++ b/testsuites/psxtests/psxtimer02/psxtimer.c
>> > +@@ -20,6 +20,7 @@
>> > +  *  http://www.rtems.org/license/LICENSE.
>> > + #ifdef HAVE_CONFIG_H
>> > + #endif
>> > +@@ -63,7 +64,7 @@ void *POSIX_Init (
>> > +   fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>> > +   puts( "timer_create - OK" );
>> > +-  status = timer_create( CLOCK_REALTIME, NULL, &timer );
>> > ++  status = timer_create( CLOCK_REALTIME , NULL, &timer );
>> > +   posix_service_failed( status, "timer_create OK" );
>> > +   puts( "timer_create - too many - EAGAIN" );
>> > +@@ -127,6 +128,41 @@ void *POSIX_Init (
>> > +   status = timer_delete( timer );
>> > +   fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>> > ++   *  If these are not filled in correctly, we don't pass its error checking.
>> > ++puts( "timer_create - bad timer id pointer - EINVAL" );
>> > ++  status = timer_create( CLOCK_MONOTONIC, &event, NULL );
>> > ++  fatal_posix_service_status_errno( status, EINVAL, "bad timer id" );
>> > ++  puts( "timer_create - OK" );
>> > ++  status = timer_create( CLOCK_MONOTONIC, NULL, &timer );
>> > ++  posix_service_failed( status, "timer_create OK" );
>> > ++  puts( "timer_create - too many - EAGAIN" );
>> > ++  status = timer_create( CLOCK_MONOTONIC, NULL, &timer1 );
>> > ++  fatal_posix_service_status_errno( status, EAGAIN, "too many" );
>> > ++  clock_gettime( CLOCK_MONOTONIC, &now );
>> > ++  itimer.it_value = now;
>> > ++  itimer.it_value.tv_sec = itimer.it_value.tv_sec - 1;
>> > ++  puts( "timer_settime - bad itimer value - previous time - EINVAL" );
>> > ++  status = timer_settime( timer, TIMER_ABSTIME, &itimer, NULL );
>> > ++  fatal_posix_service_status_errno( status, EINVAL, "bad itimer value #3" );
>> > ++  itimer.it_value.tv_sec = itimer.it_value.tv_sec + 1;
>> > ++  puts( "timer_settime - bad id - EINVAL" );
>> > ++  status = timer_settime( timer1, TIMER_ABSTIME, &itimer, NULL );
>> > ++  fatal_posix_service_status_errno( status, EINVAL, "bad id" );
>> > +   TEST_END();
>> > +   rtems_test_exit (0);
>> > +2.31.1
>> > index 839fe3293c..fdfa1e0b2f 100644
>> > @@ -48,7 +48,7 @@ typedef struct {
>> > -    clockid_t     clock_type;
>> > +  clockid_t     clock_type;  /* The type of timer */
>> > index b60be3f229..18af8a6582 100644
>> > @@ -21,9 +21,9 @@
>> >  #include "config.h"
>> >  #endif
>> > -#include <time.h>
>> >  #include <errno.h>
>> >  #include <signal.h>
>> > +#include <time.h>
>> >  #include <rtems/posix/sigset.h>
>> > @@ -32,83 +32,73 @@
>> >  #include <rtems/sysinit.h>
>> > -int timer_create(
>> > -  clockid_t        clock_id,
>> > -  struct sigevent *__restrict evp,
>> > -  timer_t         *__restrict timerid
>> > +int timer_create(clockid_t clock_id, struct sigevent *__restrict evp,
>> > +                 timer_t *__restrict timerid) {
>> > -  if ( clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC  )
>> > +  if (clock_id != CLOCK_REALTIME && clock_id != CLOCK_MONOTONIC)
>> > -  if ( !timerid )
>> > +  if (!timerid)
>> > -  *  The data of the structure evp are checked in order to verify if they
>> > -  *  are coherent.
>> > +   *  The data of the structure evp are checked in order to verify if they
>> > +   *  are coherent.
>> >    if (evp != NULL) {
>> >      /* The structure has data */
>> > -    if ( ( evp->sigev_notify != SIGEV_NONE ) &&
>> > -         ( evp->sigev_notify != SIGEV_SIGNAL ) ) {
>> > -       /* The value of the field sigev_notify is not valid */
>> > +    if ((evp->sigev_notify != SIGEV_NONE) &&
>> > +        (evp->sigev_notify != SIGEV_SIGNAL)) {
>> > +      /* The value of the field sigev_notify is not valid */
>> > -     if ( !evp->sigev_signo )
>> > +    if (!evp->sigev_signo)
>> > -     if ( !is_valid_signo(evp->sigev_signo) )
>> > +    if (!is_valid_signo(evp->sigev_signo))
>> >     *  Allocate a timer
>> >    ptimer = _POSIX_Timer_Allocate();
>> > -  if ( !ptimer ) {
>> > +  if (!ptimer) {
>> >      _Objects_Allocator_unlock();
>> > -    rtems_set_errno_and_return_minus_one( EAGAIN );
>> > +    rtems_set_errno_and_return_minus_one(EAGAIN);
>> >    /* The data of the created timer are stored to use them later */
>> > -  ptimer->state     = POSIX_TIMER_STATE_CREATE_NEW;
>> > +  ptimer->state = POSIX_TIMER_STATE_CREATE_NEW;
>> >    ptimer->thread_id = _Thread_Get_executing()->Object.id;
>> > -  if ( evp != NULL ) {
>> > +  if (evp != NULL) {
>> >      ptimer->inf.sigev_notify = evp->sigev_notify;
>> > -    ptimer->inf.sigev_signo  = evp->sigev_signo;
>> > -    ptimer->inf.sigev_value  = evp->sigev_value;
>> > +    ptimer->inf.sigev_signo = evp->sigev_signo;
>> > +    ptimer->inf.sigev_value = evp->sigev_value;
>> > -  ptimer->overrun  = 0;
>> > -  ptimer->timer_data.it_value.tv_sec     = 0;
>> > -  ptimer->timer_data.it_value.tv_nsec    = 0;
>> > -  ptimer->timer_data.it_interval.tv_sec  = 0;
>> > +  ptimer->overrun = 0;
>> > +  ptimer->timer_data.it_value.tv_sec = 0;
>> > -  ptimer->clock_type=clock_id;
>> > -  _Watchdog_Preinitialize( &ptimer->Timer, _Per_CPU_Get_snapshot() );
>> > -  _Watchdog_Initialize( &ptimer->Timer, _POSIX_Timer_TSR );
>> > +  ptimer->clock_type = clock_id;
>> > +  _Watchdog_Preinitialize(&ptimer->Timer, _Per_CPU_Get_snapshot());
>> > +  _Watchdog_Initialize(&ptimer->Timer, _POSIX_Timer_TSR);
>> > -  *timerid  = ptimer->Object.id;
>> > +  *timerid = ptimer->Object.id;
>> >    return 0;
>> > -static void _POSIX_Timer_Manager_initialization( void )
>> > -  _Objects_Initialize_information( &_POSIX_Timer_Information );
>> > +static void _POSIX_Timer_Manager_initialization(void) {
>> > +  _Objects_Initialize_information(&_POSIX_Timer_Information);
>> > -RTEMS_SYSINIT_ITEM(
>> > -  _POSIX_Timer_Manager_initialization,
>> > -  RTEMS_SYSINIT_POSIX_TIMER,
>> > -  RTEMS_SYSINIT_ORDER_MIDDLE
>> > +RTEMS_SYSINIT_ITEM(_POSIX_Timer_Manager_initialization,
>> > +                   RTEMS_SYSINIT_POSIX_TIMER, RTEMS_SYSINIT_ORDER_MIDDLE);
>> > index 57b0ab4918..ee9d37ccdd 100644
>> > @@ -1,10 +1,3 @@
>> > - * @file
>> > - * @ingroup POSIXAPI
>> > - * @brief Function Fetches State of POSIX Per-Process Timers
>> >   * @file
>> > @@ -30,12 +23,13 @@
>> >  #endif
>> >  #include <errno.h>
>> > +#include <time.h>
>> > -#include <time.h>
>> > @@ -44,15 +38,18 @@
>> > -int timer_gettime(timer_t timerid, struct itimerspec *value) {
>> > +int timer_gettime(
>> > +  timer_t            timerid,
>> > +  struct itimerspec *value
>> >    uint32_t remaining;
>> > -  struct timespec *now;    // get time now either with
>> > -  struct timespec *expire; // expire
>> > -  struct timespec *result;
>> >    if (!value)
>> > @@ -62,47 +59,28 @@ int timer_gettime(timer_t timerid, struct itimerspec *value) {
>> > -  if (ptimer->clock_type == CLOCK_REALTIME) {
>> > -    cpu = _POSIX_Timer_Acquire_critical(ptimer, &lock_context);
>> > -    _TOD_Get(now); // get current time
>> > -    rtems_timespec_from_ticks(ptimer->Timer.expire,
>> > -                              expire);
>> > -    if (now->tv_nsec + now->tv_sec >
>> > -        expire->tv_nsec + expire->tv_sec) {
>> > -      rtems_timespec_subtract(now, expire, result);
>> > -      remaining = (uint32_t)result->tv_nsec + result->tv_sec;
>> > -    } else {
>> > -      remaining = 0;
>> > -    _Timespec_From_ticks(remaining, &value->it_value);
>> > -    value->it_interval = ptimer->timer_data.it_interval;
>> > -     _POSIX_Timer_Release(cpu, &lock_context);
>> > -    return 0;
>> > +  _Timecounter_Nanouptime(now);
>> > +    _TOD_Get(now);
>> > -    rtems_timespec_from_ticks(ptimer->Timer.expire, expire);
>> > -    if (now->tv_nsec + now->tv_sec > expire->tv_nsec + expire->tv_sec) {
>> > + if( rtems_timespec_less_than( now, expire )) {
>> >      } else {
>> > -      remaining = 0;
>> > +      result->tv_nsec=0;
>> > +      result->tv_sec=0;
>> > -    return 0;
>> > -  rtems_set_errno_and_return_minus_one(EINVAL);
>> > +  (*value).it_value=*result;
>> > +  return 0;
>> > 2.32.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
