Help with RTEMS Tester Results for uC5282
gerberhe11 at gmail.com
Mon Jul 19 22:43:03 UTC 2021
Hello all,
I've been working on getting support into Qemu for the uC5282 board
recently, and today got the rtems-test tool running with this Qemu emulation
for that board. The results with the first run of the full test suite since
the emulation has been operational appears very promising, which is great
news! However, there are a couple tests that either fail or (in the case of
sptests specifically) always timeout. Included at the bottom of this email
are the results of running the tests through this emulation. Dr. Bloom
mentioned that some of these results could likely be due to flawed TLS
implementation of m68k. Any input, guidance, or suggestions about these
results (especially the tests that failed/timed out) would be really
valuable to this work of getting truly reliable uC5282 emulation running!
Thanks so much,
Harrison Gerber
<mailto:gerberhe11 at gmail.com> gerberhe11 at gmail.com
TEST RESULTS:
Passed: 547
Failed: 7
User Input: 6
Expected Fail: 1
Indeterminate: 0
Benchmark: 3
Timeout: 7
Test too long: 0
Invalid: 0
Wrong Version: 0
Wrong Build: 0
Wrong Tools: 0
Total: 571
Failures:
sppercpudata01.exe
sptimecounter02.exe <-- Passes when run individually
ttest02.exe <-- Passes when run individually
sptls02.exe
ts-validation-0.exe
stringto01.exe
dl06.exe
User Input:
dl10.exe
fileio.exe
monitor.exe
capture.exe
termios.exe
top.exe
Expected Fail:
psxfenv01.exe
Benchmark:
whetstone.exe
dhrystone.exe
linpack.exe
Timeouts:
spinternalerror01.exe
spfatal26.exe
spsysinit01.exe
spfatal33.exe
sptimecounter01.exe
spfatal12.exe
spfatal09.exe
Average test time: 0:00:01.901600
Testing time : 0:18:05.814003
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210719/ff98f37d/attachment.html>
