Help with RTEMS Tester Results for uC5282
Mon Jul 19 23:32:35 UTC 2021
On Mon, Jul 19, 2021, 5:43 PM <gerberhe11 at gmail.com> wrote:
> Hello all,
> I’ve been working on getting support into Qemu for the uC5282 board
> recently, and today got the rtems-test tool running with this Qemu
> emulation for that board. The results with the first run of the full test
> suite since the emulation has been operational appears very promising,
> which is great news! However, there are a couple tests that either fail or
> (in the case of sptests specifically) always timeout. Included at the
> bottom of this email are the results of running the tests through this
> emulation. Dr. Bloom mentioned that some of these results could likely be
> due to flawed TLS implementation of m68k. Any input, guidance, or
> suggestions about these results (especially the tests that failed/timed
> out) would be really valuable to this work of getting truly reliable uC5282
> emulation running!
> Thanks so much,
> *Harrison Gerber*
> TEST RESULTS:
> Passed:        547
Quite good!
> Failed:          7
> User Input:      6
> Expected Fail:   1
> Indeterminate:   0
> Benchmark:       3
> Timeout:         7
> Test too long:   0
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         571
> Failures:
> sppercpudata01.exe
> sptimecounter02.exe     ß Passes when run individually
> Qemu us a mystery on this. We have seen tests passing when run alone but
not in parallel batches. It would be good to know why this happens. But I
wouldn't punish you for that. ;)
> ttest02.exe                         ß Passes when run individually
> sptls02.exe
> ts-validation-0.exe
This requires support in the port itself to clobber registers in a
particular way and validate they context switch ok. See the arm or SPARC
ports for examples.
> stringto01.exe
This needs to be looked into. Shouldn't normally fail for something related
to a.port or BSP.
> dl06.exe
Perhaps a relocation type not supported yet?
> User Input:
> dl10.exe
> fileio.exe
> monitor.exe
> capture.exe
> termios.exe
> top.exe
> Expected Fail:
> psxfenv01.exe
> Benchmark:
> whetstone.exe
> dhrystone.exe
> linpack.exe
> Timeouts:
> spinternalerror01.exe
> spfatal26.exe
> spsysinit01.exe
> spfatal33.exe
> sptimecounter01.exe
> spfatal12.exe
> spfatal09.exe
> Average test time: 0:00:01.901600
> Testing time     : 0:18:05.814003
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> Virus-free.
> www.avast.com
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
> <#m_-784980626469659469_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210719/a2fe79d0/attachment-0001.html>
