Help with RTEMS Tester Results for uC5282
Tue Jul 20 15:15:47 UTC 2021
On Tue, Jul 20, 2021, 12:22 AM Sebastian Huber <
> Hello,
> On 20/07/2021 00:43, gerberhe11 at gmail.com wrote:
> > Dr. Bloom mentioned that some of these results could likely be due to
> > flawed TLS implementation of m68k.
> this could be also an issue with the linker command file. If I can run
> the test myself on Qemu I could try to debug the sptls02.
It would be good to know what is needed to work for each of the TLS tests.
We just went through this on the new Microblaze port and this one may also
be failing there.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210720/57eecfd7/attachment.html>
