Help with RTEMS Tester Results for uC5282
gerberhe11 at gmail.com
Tue Jul 20 19:13:59 UTC 2021
If you’d like I can send over the Git repo that has the Qemu that I’ve been working on that includes the current state of the uC5282 emulation! Let me know if this would be good, and I’ll make sure it is completely up to date with what I have working locally. I’ll continue to look into some of the other tests soon to see what I can find based on the advice given!
Thanks so much,
Harrison Gerber
<mailto:gerberhe11 at gmail.com> gerberhe11 at gmail.com
Sent: Tuesday, July 20, 2021 9:16 AM
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: Harrison Edward Gerber <gerberhe11 at gmail.com>; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: Help with RTEMS Tester Results for uC5282
On Tue, Jul 20, 2021, 12:22 AM Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de> > wrote:
Hello,
On 20/07/2021 00:43, gerberhe11 at gmail.com <mailto:gerberhe11 at gmail.com> wrote:
> Dr. Bloom mentioned that some of these results could likely be due to
> flawed TLS implementation of m68k.
this could be also an issue with the linker command file. If I can run
the test myself on Qemu I could try to debug the sptls02.
It would be good to know what is needed to work for each of the TLS tests. We just went through this on the new Microblaze port and this one may also be failing there.
--joel
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
devel mailing list
devel at rtems.org <mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210720/d2d64425/attachment.html>
