[PATCH 23/41] bsps/irq: Add bsp_interrupt_check_and_lock()
Wed Jul 21 18:38:51 UTC 2021
On Mon, Jul 12, 2021 at 6:51 AM Sebastian Huber
> Return RTEMS_INCORRECT_STATE instead of RTEMS_INCORRECT_STATE in case the
Second RTEMS_INCORRECT_STATE should be RTEMS_INTERNAL_ERROR
> interrupt support is not initialized.  This is similar to
> rtems_timer_server_fire_after() for example.
> Update #3269.
>  bsps/include/bsp/irq-generic.h        | 25 +++++++++++
>  bsps/shared/irq/irq-generic.c         | 60 ++++++++++++++++-----------
>  bsps/shared/irq/irq-handler-iterate.c | 51 +++++++----------------
>  3 files changed, 75 insertions(+), 61 deletions(-)
> diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
> index b553ac30bf..9babc4cfb5 100644
> --- a/bsps/include/bsp/irq-generic.h
> +++ b/bsps/include/bsp/irq-generic.h
> @@ -434,6 +434,31 @@ void bsp_interrupt_lock(void);
>  /* For internal use only */
>  void bsp_interrupt_unlock(void);
> + * @brief Checks the vector and routine.  When the checks were successful, the
> + *   interrupt support lock will be obtained.
> + * @param vector is the interrupt vector number to check.
> + * @param routine is the routine to check.
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> + * @retval ::RTEMS_INCORRECT_STATE The interrupt support was not initialized.
> + * @retval ::RTEMS_CALLED_FROM_ISR The function was called from within
> + *   interrupt context.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``routine`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
> + *   number specified by ``vector``.
> +rtems_status_code bsp_interrupt_check_and_lock(
> +  rtems_vector_number     vector,
> +  rtems_interrupt_handler handler
>   * @brief This table contains a bit map which indicates if an entry is unique
>   *   or shared.
> diff --git a/bsps/shared/irq/irq-generic.c b/bsps/shared/irq/irq-generic.c
> index a7e8c1163f..59963182ab 100644
> --- a/bsps/shared/irq/irq-generic.c
> +++ b/bsps/shared/irq/irq-generic.c
> @@ -122,6 +122,32 @@ static inline bool bsp_interrupt_allocate_handler_index(
>    #endif
> +  if ( !bsp_interrupt_is_initialized() ) {
> +    return RTEMS_INCORRECT_STATE;
> +  if ( handler == NULL ) {
> +    return RTEMS_INVALID_ADDRESS;
> +  if ( !bsp_interrupt_is_valid_vector( vector ) ) {
> +    return RTEMS_INVALID_ID;
> +  if ( rtems_interrupt_is_in_progress() ) {
> +    return RTEMS_CALLED_FROM_ISR;
> +  bsp_interrupt_lock();
> +  return RTEMS_SUCCESSFUL;
>  void bsp_interrupt_initialize(void)
>    rtems_status_code sc = RTEMS_SUCCESSFUL;
> @@ -162,25 +188,18 @@ static rtems_status_code bsp_interrupt_handler_install(
>    void *arg
> +  rtems_status_code sc;
>    rtems_interrupt_level level;
>    rtems_vector_number index = 0;
>    rtems_interrupt_entry *head = NULL;
>    bool enable_vector = false;
>    bool replace = RTEMS_INTERRUPT_IS_REPLACE(options);
> -  /* Check parameters and system state */
> -  if (!bsp_interrupt_is_initialized()) {
> -    return RTEMS_INTERNAL_ERROR;
> -  } else if (!bsp_interrupt_is_valid_vector(vector)) {
> -    return RTEMS_INVALID_ID;
> -  } else if (handler == NULL) {
> -    return RTEMS_INVALID_ADDRESS;
> -  } else if (rtems_interrupt_is_in_progress()) {
> -    return RTEMS_CALLED_FROM_ISR;
> +  sc = bsp_interrupt_check_and_lock( vector, handler );
> -  /* Lock */
> -  bsp_interrupt_lock();
> +  if ( sc != RTEMS_SUCCESSFUL ) {
> +    return sc;
>    /* Get handler table index */
>    index = bsp_interrupt_handler_index(vector);
> @@ -325,6 +344,7 @@ static rtems_status_code bsp_interrupt_handler_remove(
>    void *arg
> @@ -332,19 +352,11 @@ static rtems_status_code bsp_interrupt_handler_remove(
>    rtems_interrupt_entry *previous = NULL;
>    rtems_interrupt_entry *match = NULL;
> -  /* Lock */
> +    return sc;
> diff --git a/bsps/shared/irq/irq-handler-iterate.c b/bsps/shared/irq/irq-handler-iterate.c
> index 3c642b075e..385cb8db2d 100644
> --- a/bsps/shared/irq/irq-handler-iterate.c
> +++ b/bsps/shared/irq/irq-handler-iterate.c
> @@ -36,39 +36,26 @@
>  #include <bsp/irq-generic.h>
> - * @brief Iterates over all installed interrupt handler of a vector.
> - * @ingroup bsp_interrupt
> - * @return In addition to the standard status codes this function returns
> - * RTEMS_INTERNAL_ERROR if the BSP interrupt support is not initialized.
> - * @see rtems_interrupt_handler_iterate().
> -static rtems_status_code bsp_interrupt_handler_iterate(
> -  rtems_vector_number vector,
> +rtems_status_code rtems_interrupt_handler_iterate(
>    rtems_interrupt_per_handler_routine routine,
> -  void *arg
> +  void                               *arg
> -  rtems_interrupt_entry *current = NULL;
> -  rtems_option options = 0;
> -  rtems_vector_number index = 0;
> +  rtems_vector_number    index;
> +  rtems_option           options;
> +  rtems_interrupt_entry *current;
> +    vector,
> +    (rtems_interrupt_handler) routine
> -  /* Lock */
> +    return sc;
> -  /* Interate */
>    current = &bsp_interrupt_handler_table [index];
>    if (!bsp_interrupt_is_empty_handler_entry(current)) {
> @@ -80,17 +67,7 @@ static rtems_status_code bsp_interrupt_handler_iterate(
>      } while (current != NULL);
> -  /* Unlock */
>    bsp_interrupt_unlock();
> -rtems_status_code rtems_interrupt_handler_iterate(
> -  rtems_interrupt_per_handler_routine routine,
> -  void *arg
> -  return bsp_interrupt_handler_iterate(vector, routine, arg);
> 2.26.2
> devel mailing list
> devel at rtems.org
