[PATCH 19/41] bsps/irq: Implement new directives for GICv2/3
Wed Jul 21 19:01:20 UTC 2021
On Wed, Jul 21, 2021 at 12:28 PM Sebastian Huber
> On 21/07/2021 20:25, Gedare Bloom wrote:
> >>>>> As far as I'm aware, SGIs can be enabled or disabled using GICD_ISENABLER0
> >>>>> just like
> >>>>> PPI or SPI interrupts for both GICv2 and GICv3. Section 3.1.2 of the GICv2
> >>>>> architecture
> >>>>> spec (IHI0048B) references this, though I have seen implementations where
> >>>>> certain SGI
> >>>>> and PPI interrupts are hard-wired enabled or disabled and that state can't be
> >>>>> changed
> >>>>> (which is also covered in this section).
> >>>> Ok, on Qemu and the i.MX7D the SGI are always enabled. I would keep the
> >>>> attributes like this until we have a system which is different.
> >> Should a comment be added that says this?
> > Yes, in case someone else comes along to add support for a system that
> > is different, it will help to give them some pointers.
> I addressed this with new attributes in the v2 patch versions:
> https://lists.rtems.org/pipermail/devel/2021-July/068276.html
Aha. Thanks. We currently prefer a full patch set post after review,
but this is fine with me. I would like to see the comment made in the
gic sources themselves where the attributes get initialized
specifically for this case of the SGI on these devices.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
