[PATCH 20/41] sparc/irq: Implement new interrupt directives
Sebastian Huber
Mon Jul 12 12:49:42 UTC 2021
Update #3269.
bsps/sparc/leon3/start/eirq.c | 86 +++++++++++++++++++++++++++---
bsps/sparc/shared/irq/irq-shared.c | 17 ++++--
2 files changed, 91 insertions(+), 12 deletions(-)
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index d6373bf00a..4f5f910106 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -66,6 +66,19 @@ rtems_status_code bsp_interrupt_get_attributes(
rtems_interrupt_attributes *attributes
+ bool is_standard_interrupt;
+ is_standard_interrupt = (vector <= BSP_INTERRUPT_VECTOR_MAX_STD);
+ attributes->is_maskable = (vector != 15);
+ attributes->can_enable = true;
+ attributes->maybe_enable = true;
+ attributes->can_disable = true;
+ attributes->can_cause = true;
+ attributes->can_cause_on = is_standard_interrupt;
+ attributes->can_clear = true;
+ attributes->cleared_by_acknowledge = true;
+ attributes->can_get_affinity = is_standard_interrupt;
+ attributes->can_set_affinity = is_standard_interrupt;
return RTEMS_SUCCESSFUL;
@@ -74,16 +87,56 @@ rtems_status_code bsp_interrupt_is_pending(
bool *pending
+#if defined(RTEMS_SMP)
+ rtems_interrupt_level level;
+ uint32_t bit;
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
bsp_interrupt_assert(pending != NULL);
- *pending = false;
- return RTEMS_UNSATISFIED;
+ bit = 1U << vector;
+ rtems_interrupt_local_disable(level);
+ *pending = (LEON3_IrqCtrl_Regs->ipend & bit) != 0 ||
+ (LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] & bit) != 0;
+ rtems_interrupt_local_enable(level);
+ return RTEMS_SUCCESSFUL;
+#else
+ bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+ *pending = !BSP_Is_interrupt_pending(vector);
+#endif
rtems_status_code bsp_interrupt_cause(rtems_vector_number vector)
+ uint32_t bit;
+ if ( vector <= BSP_INTERRUPT_VECTOR_MAX_STD ) {
+ uint32_t cpu_count;
+ uint32_t cpu_index;
+ cpu_count = rtems_scheduler_get_processor_maximum();
+ for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
+ LEON3_IrqCtrl_Regs->force[cpu_index] = bit;
+ } else {
+ rtems_interrupt_lock_context lock_context;
+ * This is a very dangerous operation and should only be used for test
+ * software. We may accidentally clear the pending state set by
+ * peripherals with this read-modify-write operation.
+ LEON3_IRQCTRL_ACQUIRE(&lock_context);
+ LEON3_IrqCtrl_Regs->ipend |= bit;
+ LEON3_IRQCTRL_RELEASE(&lock_context);
@@ -93,14 +146,31 @@ rtems_status_code bsp_interrupt_cause_on(
+ bsp_interrupt_assert(cpu_index < rtems_scheduler_get_processor_maximum());
+ if ( vector > BSP_INTERRUPT_VECTOR_MAX_STD ) {
+ return RTEMS_UNSATISFIED;
+ LEON3_IrqCtrl_Regs->force[cpu_index] = 1U << vector;
#endif
rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
+ uint32_t bit;
+ LEON3_IrqCtrl_Regs->iclear = bit;
+ if (vector <= BSP_INTERRUPT_VECTOR_MAX_STD) {
+ LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] = bit << 16;
rtems_status_code bsp_interrupt_vector_is_enabled(
@@ -109,9 +179,9 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
- bsp_interrupt_assert(enabled != NULL);
- *enabled = false;
+ *enabled =
+ !BSP_Cpu_Is_interrupt_masked(vector, _LEON3_Get_current_processor());
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index aa1d412be0..d0b77bddbb 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -37,6 +37,13 @@ rtems_status_code bsp_interrupt_get_attributes(
+ attributes->is_maskable = vector != 15;
+ attributes->can_cause_on = true;
+ attributes->can_set_affinity = true;
@@ -54,7 +61,8 @@ rtems_status_code bsp_interrupt_is_pending(
+ BSP_Force_interrupt(vector);
@@ -71,7 +79,8 @@ rtems_status_code bsp_interrupt_cause_on(
+ BSP_Clear_interrupt(vector);
@@ -81,8 +90,8 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
- *enabled = false;
+ *enabled = !BSP_Cpu_Is_interrupt_masked(vector, bsp_irq_cpu(vector));
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
2.26.2
