[PATCH 20/41] sparc/irq: Implement new interrupt directives
Gedare Bloom
gedare at rtems.org
Wed Jul 21 19:04:21 UTC 2021
On Wed, Jul 21, 2021 at 12:31 PM Sebastian Huber
> On 21/07/2021 20:28, Gedare Bloom wrote:
> > Why not throw an error here instead? In production, you wouldn't want
> > this code...
> The main issue is the bad chip design. If we don't have this code, we
> can't test the extended interrupts. In production, you want tested code.
ok, thanks. My comments are all pretty minor, except for the
terminology issues of "cause" but that wording already exists. post
the v2 series, but I probably won't review it and you can check it in
if no one complains. It's up to you if you want to work a different
wording than "cause" -- I prefer "raise"
